Tribal_ Posted February 29, 2024 Posted February 29, 2024 (edited) Hi! Is it possible to install this assembly on Ugoos AM3 S912? Edited February 29, 2024 by Tribal_ 0 Quote
SteeMan Posted February 29, 2024 Posted February 29, 2024 @Tribal_ Since TV boxes are not supported by Armbian, no one likely knows. But if you can run the community aml-s9xx-box builds on your box, these extensions should work as well. I run HA on other amlogic based TV boxes without issue. Try it out and see how it goes and report back. 0 Quote
Tribal_ Posted March 1, 2024 Author Posted March 1, 2024 @SteeMan i can run https://github.com/ophub/amlogic-s9xxx-armbian but https://github.com/armbian/community/ won't start. So I also tried to run this assembly and it doesn’t run =( 0 Quote
SteeMan Posted March 1, 2024 Posted March 1, 2024 Moved these posts to a new thread in the TV Box forums as this is getting to be off topic for the original thread since TV boxes aren't supported in any official manner by Armbian. 0 Quote
SteeMan Posted March 1, 2024 Posted March 1, 2024 So you mention the ophub builds. Just so you know those builds are not Armbian builds. They are a fork of Armbian and use the Armbian name without permission. They do not participate in Armbian development nor do they participate in these forums. So any ophub questions need to be directed to them, not here. So you say the armbian community build doesn't work, but you provide no information on what is failing. I'm not a mind reader so I can't help you if all you tell us is that it doesn't run. 0 Quote
Tribal_ Posted March 1, 2024 Author Posted March 1, 2024 (edited) On 3/1/2024 at 1:43 PM, SteeMan said: but you provide no information on what is failing Expand Nothing happens at all, u-boot not loading instead default recovery starts... i'm using "Armbian_community_24.5.0-trunk.93_Aml-s9xx-box_bookworm_current_6.6.18_minimal.img.xz" and do everything according to this guide but u-boot won't starts Edited March 1, 2024 by Tribal_ 0 Quote
SteeMan Posted March 1, 2024 Posted March 1, 2024 What dtb are you using? what uboot are you using? what menthod to invoke multiboot are you using? Have you used any other build on this box? In order to help you, you need to provide every detail of what you have done. You originally posted this in the HA thread. So I was assuming that you at least had basic armbian running and you were trying to install HA on top. 0 Quote
Tribal_ Posted March 2, 2024 Author Posted March 2, 2024 On 3/1/2024 at 3:58 PM, SteeMan said: So I was assuming that you at least had basic armbian running and you were trying to install HA on top. Expand No, your image didn't launch, so I started looking for alternative images On 3/1/2024 at 3:58 PM, SteeMan said: What dtb are you using? Expand I used different ones that in theory should match: meson-gxm-xxx On 3/1/2024 at 3:58 PM, SteeMan said: what uboot are you using? Expand u-boot-s905x-s912 - copy and rename this to u-boot.ext in same dir On 3/1/2024 at 3:58 PM, SteeMan said: what menthod to invoke multiboot are you using? Expand by holding reset button while boot On 3/1/2024 at 3:58 PM, SteeMan said: Have you used any other build on this box? Expand https://github.com/ophub/amlogic-s9xxx-armbian/releases/download/Armbian_bookworm_save_2024.02/Armbian_24.5.0_amlogic_s912_bookworm_6.1.78_server_2024.02.20.img.gz runing fine I previously used the box as a retro console and this image https://github.com/EmuELEC/EmuELEC/releases/download/v3.9/EmuELEC-Amlogic.arm-3.9-Generic.img.gz worked fine As far as I understand, Ophub use some other bootloader 0 Quote
SteeMan Posted March 2, 2024 Posted March 2, 2024 So to proceed we would need to get Armbian running on your box, first before asking about HA. Since you have run various other os's, the first note in the instructions is relevant. You need to restore the box to a factory android firmware first before proceeding. Each is will change the boot environment in potentially incompatible ways. So you need to start from a known clean environment, by reinstalling a factory android firmware. 0 Quote
SteeMan Posted March 2, 2024 Posted March 2, 2024 If you have restored the android firmware, then follow the instructions in the FAQ and report back what you have done and any issues you run into (screenshots of errors during boot if appropriate) 0 Quote
Tribal_ Posted March 2, 2024 Author Posted March 2, 2024 Wow, I understood what was the problem.... it was necessary to create a boot dir and put the u-boot.ext there, and not put it in the root dir... but now another question. What is the password for user root? 1234 does not match 0 Quote
Tribal_ Posted March 2, 2024 Author Posted March 2, 2024 Armbian_community_24.5.0-trunk.93_Aml-s9xx-box_bookworm_current_6.6.18_minimal.img 0 Quote
SteeMan Posted March 2, 2024 Posted March 2, 2024 I don't understand what you are doing. You don't need to create any /boot directory. Why do you think you needed to do that? And the default password for root is 1234 0 Quote
Tribal_ Posted March 2, 2024 Author Posted March 2, 2024 Damn I forgot about Microsd... thats output log https://www.dropbox.com/scl/fi/98i3qx0g11x8ngmwwukg9/2024-03-02-21.04.19.jpg?rlkey=kg35x3ocjuiag0ci1qldtzdug&dl=0 it's strange dtb source s905x which I definitely did not indicate 0 Quote
SteeMan Posted March 2, 2024 Posted March 2, 2024 If you look at the line trying to load you dtb file, you can see that something is wrong. Post the contents of your extlinix.conf file? 0 Quote
Tribal_ Posted March 2, 2024 Author Posted March 2, 2024 label Armbian_community kernel /Image initrd /uInitrd fdtdir /dtb/amlogic/meson-gxm-q200.dtb append root=UUID=212049b6-44a7-4741-9789-815d023561d0 rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles I talked about it, I do not indicate this dtb, he takes from somewhere himself 0 Quote
SteeMan Posted March 2, 2024 Posted March 2, 2024 Your problem is here. Look at the extlinux.conf.template for the correct contents. You need to add an FDT line not edit the FDTDIR line 0 Quote
Tribal_ Posted March 2, 2024 Author Posted March 2, 2024 (edited) Oh my God, it was obvious. Everything is working! thank you! Then let's go back to HA. If I just write image from @Igor to a USB flash drive, then boot through the reset clip, I get into the standard recovery. There is armbianEnv.txt should I also specify FDT there? Should I place u-boot there too? Just according to @Igor, you just need to write the image to usb flash, insert it into the box and it should load HA without any settings Edited March 2, 2024 by Tribal_ 0 Quote
SteeMan Posted March 2, 2024 Posted March 2, 2024 The info that Igor posted is for an extension to the build system that can be enabled to make an image with HA. You would need to build a custom image using the build framework to utilize this method. 0 Quote
