Hey,
I was wondering if anyone came across the board layout files.  If eagle cad files were available that would be great!  I'm assuming that they dont exist.. Or has someone designed a hat or shield for the OPi0?  I want to design one and was hoping someone else beat me to it.  If not i'll just have to measure it out and make it.  I dont want to reinvent the wheel so that would be cool
Thanks
I have made a footprint with just the 2x13 pin header.. Of course the library can be changed to add the 1x13 pin header.
The footprint has not been tested, and it comes with about 0.00% warranty! Use at your own risk! :)
OrangePi0.lbr.zip
Thanks man.  I was going to do the same and just slap the standard 2x13 and try to guestimate the rest, but I really want the shield to go over the 2x13 and the 1x13 as well as those 3 pins next to the RJ45 jack.  I wish I had a printer, i could just test design, print, fix, repeat until i was confident they all lined up.  Thanks for the follow up.
The footprint is the whole PCB, but not with the 1x13 pin header. So you have the outline and the mounting holes...
I have updated the library (see post #3) to include a footprint with the 1x13 pin header, and an outline of a hat. The same still applies... Use at your own risk. Not tested!!
