I'm trying to get a full serial console on my XU4.  I currently only get the U-boot output.  The last message says "Loading Kernel".  I never get any kernel related messages.
I understand I will need to start up a getty to actually log in via this console port, but I haven't even gotten that far.
In my (unchanged) boot.ini I have console=ttySAC2, 115200n8.  And when the system boots up, I cannot manually write anything to that port (as i believe the kernel has it opened)
Any Ideas?
Thanks!
Caleb
That is a strange port ! It is usually ttyS0 ...
I believe it's the correct one for this board
So system fully boots up and you can access it i.e. via SSH or display? Maybe dmesg log can be useful.
Yes, I can log in with a display or by ssh.
Here is dmesg:
root@odroidxu4:~# dmesg
[    0.000000] [c0] Booting Linux on physical CPU 0x100
[    0.000000] [c0] Initializing cgroup subsys cpuset
[    0.000000] [c0] Initializing cgroup subsys cpuacct
[    0.000000] [c0] Linux version 3.10.104-odroidxu4 (root@devel) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #14 SMP PREEMPT Thu Feb 2 02:48:48 CET 2017
[    0.000000] [c0] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
[    0.000000] [c0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] [c0] Machine: ODROID-XU3, model: Hardkernel odroid-xu3 board based on EXYNOS5422
[    0.000000] [c0] ION: Contiguous 0x6650000 bytes @ 0x0 defined for 0:common
[    0.000000] [c0] ION: Contiguous 0x400000 bytes @ 0x0 defined for 2:mfc_sh
[    0.000000] [c0] ION: Contiguous 0x800000 bytes @ 0x0 defined for 10:g2d_wfd
[    0.000000] [c0] ION: Contiguous 0x6000000 bytes @ 0x0 defined for 11:video
[    0.000000] [c0] ION: Contiguous 0x1000000 bytes @ 0x0 defined for 7:mfc_input
[    0.000000] [c0] ION: Contiguous 0x400000 bytes @ 0x0 defined for 9:sectbl
[    0.000000] [c0] ION: Contiguous 0x400000 bytes @ 0x0 defined for 8:mfc_fw
[    0.000000] [c0] ION: Contiguous 0x400000 bytes @ 0x0 defined for 12:mfc_nfw
[    0.000000] [c0] ION: Contiguous 0x400000 bytes @ 0x0 defined for 13:secdma
[    0.000000] [c0] cma: CMA: reserved 104 MiB at b8000000
[    0.000000] [c0] cma: CMA: reserved 4 MiB at b7c00000
[    0.000000] [c0] cma: CMA: reserved 8 MiB at b7400000
[    0.000000] [c0] cma: CMA: reserved 96 MiB at b1400000
[    0.000000] [c0] cma: CMA: reserved 16 MiB at b0400000
[    0.000000] [c0] cma: CMA: reserved 4 MiB at b0000000
[    0.000000] [c0] cma: CMA: reserved 4 MiB at afc00000
[    0.000000] [c0] cma: CMA: reserved 4 MiB at af800000
[    0.000000] [c0] cma: CMA: reserved 4 MiB at af400000
[    0.000000] [c0] cma: CMA: reserved 256 MiB at 5f800000
[    0.000000] [c0] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] [c0] create_mapping_memory: section: 40000000 ~ 6f800000
[    0.000000] [c0] CPU EXYNOS5422 (id 0xe5422001)
[    0.000000] [c0] On node 0 totalpages: 518656
[    0.000000] [c0] free_area_init_node: node 0, pgdat c09f6040, node_mem_map c0e68000
[    0.000000] [c0]   Normal zone: 1520 pages used for memmap
[    0.000000] [c0]   Normal zone: 0 pages reserved
[    0.000000] [c0]   Normal zone: 194560 pages, LIFO batch:31
[    0.000000] [c0]   HighMem zone: 2532 pages used for memmap
[    0.000000] [c0]   HighMem zone: 324096 pages, LIFO batch:31
[    0.000000] [c0] PERCPU: Embedded 9 pages/cpu @c1e76000 s14848 r8192 d13824 u36864
[    0.000000] [c0] pcpu-alloc: s14848 r8192 d13824 u36864 alloc=9*4096
[    0.000000] [c0] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] [c0] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 517136
[    0.000000] [c0] Kernel command line: console=tty1 loglevel=1 root=/dev/mmcblk0p1 rootwait ro fsck.repair=yes smsc95xx.macaddr=00:1e:06:61:7a:55 governor=performance hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi
[    0.000000] [c0] hdmi: using HDMI Mode
[    0.000000] [c0] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] [c0] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] [c0] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] [c0] allocated 4149248 bytes of page_cgroup
[    0.000000] [c0] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] [c0] Memory: 2026MB = 2026MB total
[    0.000000] [c0] Memory: 1519480k/1519480k available, 555144k reserved, 1046528K highmem
[    0.000000] [c0] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
                   vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0xc0008000 - 0xc0916fe4   (9276 kB)
                     .init : 0xc0917000 - 0xc0982a00   ( 431 kB)
                     .data : 0xc0984000 - 0xc09fdd30   ( 488 kB)
                      .bss : 0xc09fdd30 - 0xc0e67e20   (4521 kB)
[    0.000000] [c0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] [c0] Preemptible hierarchical RCU implementation.
[    0.000000] [c0] NR_IRQS:16 nr_irqs:16 16
[    0.000000] [c0] apll 800000000
[    0.000000] [c0] bpll 825000000
[    0.000000] [c0] cpll 666000000
[    0.000000] [c0] dpll 600000000
[    0.000000] [c0] epll 180633609
[    0.000000] [c0] rpll 66000000
[    0.000000] [c0] ipll 432000000
[    0.000000] [c0] spll 800000000
[    0.000000] [c0] dout_spll_ctrl_div2 400000000
[    0.000000] [c0] vpll 400000000
[    0.000000] [c0] mpll 532000000
[    0.000000] [c0] Clock enables : TOP, MIF
[    0.000000] [c0] mmc0: dout_mmc0 666000000
[    0.000000] [c0] mmc1: dout_mmc1 800000000
[    0.000000] [c0] mmc2: dout_mmc2 666000000
[    0.000000] [c0] scaler: dout_aclk_400_mscl 333000000 aclk_400_mscl 333000000
[    0.000000] [c0] [g2d_init_clock:319] aclk_333_g2d:333000000
[    0.000000] [c0] gscaler: dout_aclk_300_gscl 300000000 aclk_300_gscl 300000000
[    0.000000] [c0] [jpeg_clock_init:374]jpeg: dout_aclk_300_jpeg 300000000 aclk_300_jpeg 300000000
[    0.000000] [c0] mfc: aclk_333 400000000
[    0.000000] [c0] Exynos5422: clock setup completed
[    0.000000] [c0] Exynos: pwm: clock setup completed
[    0.000000] [c0] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] [c0] Switching to timer-based delay loop
[    0.000000] [c0] EXYNOS5422 PMU Initialize
[    0.000000] [c0] Console: colour dummy device 80x30
[    0.000000] [c0] console [tty1] enabled
[    0.000000] [c0] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[    0.000000] [c0] ... MAX_LOCKDEP_SUBCLASSES:  8
[    0.000000] [c0] ... MAX_LOCK_DEPTH:          48
[    0.000000] [c0] ... MAX_LOCKDEP_KEYS:        8191
[    0.000000] [c0] ... CLASSHASH_SIZE:          4096
[    0.000000] [c0] ... MAX_LOCKDEP_ENTRIES:     16384
[    0.000000] [c0] ... MAX_LOCKDEP_CHAINS:      32768
[    0.000000] [c0] ... CHAINHASH_SIZE:          16384
[    0.000000] [c0]  memory used by lock dependency info: 3679 kB
[    0.000000] [c0]  per task-struct memory footprint: 1152 bytes
[    0.001250] [c0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=120000)
[    0.001277] [c0] pid_max: default: 32768 minimum: 301
[    0.001733] [c0] Mount-cache hash table entries: 512
[    0.036921] [c0] Initializing cgroup subsys memory
[    0.037013] [c0] Initializing cgroup subsys devices
[    0.037044] [c0] Initializing cgroup subsys freezer
[    0.037073] [c0] Initializing cgroup subsys blkio
[    0.037093] [c0] Initializing cgroup subsys perf_event
[    0.037312] [c0] CPU: Testing write buffer coherency: ok
[    0.037374] [c0] ftrace: allocating 23472 entries in 69 pages
[    0.087042] [c0] /cpus/cpu@0 missing clock-frequency property
[    0.087075] [c0] /cpus/cpu@1 missing clock-frequency property
[    0.087096] [c0] /cpus/cpu@2 missing clock-frequency property
[    0.087117] [c0] /cpus/cpu@3 missing clock-frequency property
[    0.087136] [c0] /cpus/cpu@4 missing clock-frequency property
[    0.087155] [c0] /cpus/cpu@5 missing clock-frequency property
[    0.087175] [c0] /cpus/cpu@6 missing clock-frequency property
[    0.087194] [c0] /cpus/cpu@7 missing clock-frequency property
[    0.087266] [c0] CPU0: thread -1, cpu 0, socket 1, mpidr 80000100
[    0.087445] [c0] Running under secure firmware.
[    0.087493] [c0] Setting up static identity map for 0xc0680770 - 0xc06807c8
[    0.087520] [c0] Exynos-SnapShot: exynos_ss_init failed
[    0.107928] [c0] ftrace: Allocated trace_printk buffers
[    0.129594] [c0] cpu1: SWRESET
[    0.129848] [c1] CPU1: Booted secondary processor
[    0.129878] [c1] CPU1: thread -1, cpu 1, socket 1, mpidr 80000101
[    0.139541] [c0] cpu2: SWRESET
[    0.139800] [c2] CPU2: Booted secondary processor
[    0.139829] [c2] CPU2: thread -1, cpu 2, socket 1, mpidr 80000102
[    0.149512] [c0] cpu3: SWRESET
[    0.149771] [c3] CPU3: Booted secondary processor
[    0.149797] [c3] CPU3: thread -1, cpu 3, socket 1, mpidr 80000103
[    0.158797] [c4] CPU4: Booted secondary processor
[    0.159553] [c4] CPU4: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.168778] [c5] CPU5: Booted secondary processor
[    0.169552] [c5] CPU5: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.178789] [c6] CPU6: Booted secondary processor
[    0.179563] [c6] CPU6: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.188804] [c7] CPU7: Booted secondary processor
[    0.189560] [c7] CPU7: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.189815] [c0] Brought up 8 CPUs
[    0.189880] [c0] SMP: Total of 8 processors activated (384.00 BogoMIPS).
[    0.189895] [c0] CPU: All CPU(s) started in HYP mode.
[    0.189909] [c0] CPU: Virtualization extensions available.
[    0.192303] [c0] devtmpfs: initialized
[    0.230059] [c6] sched: registering cpufreq notifiers for scale-invariant loads
[    0.232790] [c6] pinctrl core: initialized pinctrl subsystem
[    0.233824] [c6] regulator-dummy: no parameters
[    0.243362] [c6] NET: Registered protocol family 16
[    0.243833] [c6] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.250561] [c4] gpiochip_add: registered GPIOs 0 to 7 on device: gpy7
[    0.250736] [c4] gpiochip_add: registered GPIOs 8 to 15 on device: gpx0
[    0.250901] [c4] gpiochip_add: registered GPIOs 16 to 23 on device: gpx1
[    0.251063] [c4] gpiochip_add: registered GPIOs 24 to 31 on device: gpx2
[    0.251230] [c4] gpiochip_add: registered GPIOs 32 to 39 on device: gpx3
[    0.253188] [c4] gpiochip_add: registered GPIOs 40 to 47 on device: gpc0
[    0.253362] [c4] gpiochip_add: registered GPIOs 48 to 55 on device: gpc1
[    0.253528] [c4] gpiochip_add: registered GPIOs 56 to 62 on device: gpc2
[    0.253693] [c4] gpiochip_add: registered GPIOs 63 to 66 on device: gpc3
[    0.253864] [c4] gpiochip_add: registered GPIOs 67 to 68 on device: gpc4
[    0.254029] [c4] gpiochip_add: registered GPIOs 69 to 76 on device: gpd1
[    0.254194] [c4] gpiochip_add: registered GPIOs 77 to 82 on device: gpy0
[    0.254367] [c4] gpiochip_add: registered GPIOs 83 to 86 on device: gpy1
[    0.254533] [c4] gpiochip_add: registered GPIOs 87 to 92 on device: gpy2
[    0.254740] [c4] gpiochip_add: registered GPIOs 93 to 100 on device: gpy3
[    0.254909] [c4] gpiochip_add: registered GPIOs 101 to 108 on device: gpy4
[    0.255076] [c4] gpiochip_add: registered GPIOs 109 to 116 on device: gpy5
[    0.255246] [c4] gpiochip_add: registered GPIOs 117 to 124 on device: gpy6
[    0.256873] [c4] gpiochip_add: registered GPIOs 125 to 132 on device: gpe0
[    0.257046] [c4] gpiochip_add: registered GPIOs 133 to 134 on device: gpe1
[    0.257212] [c4] gpiochip_add: registered GPIOs 135 to 140 on device: gpf0
[    0.257377] [c4] gpiochip_add: registered GPIOs 141 to 148 on device: gpf1
[    0.257546] [c4] gpiochip_add: registered GPIOs 149 to 156 on device: gpg0
[    0.257717] [c4] gpiochip_add: registered GPIOs 157 to 164 on device: gpg1
[    0.257882] [c4] gpiochip_add: registered GPIOs 165 to 166 on device: gpg2
[    0.258050] [c4] gpiochip_add: registered GPIOs 167 to 170 on device: gpj4
[    0.259439] [c4] gpiochip_add: registered GPIOs 171 to 178 on device: gpa0
[    0.259613] [c4] gpiochip_add: registered GPIOs 179 to 184 on device: gpa1
[    0.259813] [c4] gpiochip_add: registered GPIOs 185 to 192 on device: gpa2
[    0.259987] [c4] gpiochip_add: registered GPIOs 193 to 197 on device: gpb0
[    0.260156] [c4] gpiochip_add: registered GPIOs 198 to 202 on device: gpb1
[    0.260366] [c4] gpiochip_add: registered GPIOs 203 to 206 on device: gpb2
[    0.260544] [c4] gpiochip_add: registered GPIOs 207 to 214 on device: gpb3
[    0.260715] [c4] gpiochip_add: registered GPIOs 215 to 216 on device: gpb4
[    0.260905] [c4] gpiochip_add: registered GPIOs 217 to 224 on device: gph0
[    0.262816] [c4] gpiochip_add: registered GPIOs 225 to 231 on device: gpz
[    0.282000] [c4] syscon 10040000.system-controller: regmap [mem 0x10040000-0x10044fff] registered
[    0.282464] [c4] syscon 10050000.syscon: regmap [mem 0x10050000-0x10054fff] registered
[    0.289752] [c4] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.289771] [c4] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.291871] [c4] S3C Power Management, Copyright 2004 Simtec Electronics
[    0.295970] [c4] PM DOMAIN: pd-cam has a new child pd-isp.
[    0.296788] [c4] PM DOMAIN: pd-gscl has a new child pd-cam.
[    0.296817] [c4] EXYNOS5: PM Domain Initialize
[    0.297101] [c4]    pd-gscl   - on
[    0.297267] [c4]    pd-isp    - on
[    0.297433] [c4]    pd-mfc    - on
[    0.297453] [c4]    pd-g3d    - on,  always
[    0.297472] [c4]    pd-disp1  - on,  always
[    0.297642] [c4]    pd-maudio - on
[    0.297660] [c4]    pd-g2d    - on,  always
[    0.297830] [c4]    pd-mscl   - on
[    0.297850] [c4]    pd-fsys   - on,  always
[    0.297869] [c4]    pd-psgen  - on,  always
[    0.297888] [c4]    pd-peric  - on,  always
[    0.297906] [c4]    pd-wcore  - on,  always
[    0.298076] [c4]    pd-cam    - on
[    0.298104] [c4] EXYNOS: Initializing architecture
[    0.299579] [c4] exynos-sysmmu 10a60000.sysmmu: --> 10850000.fimg2d
[    0.299601] [c4] exynos-sysmmu 10a60000.sysmmu: [OK]
[    0.299953] [c4] exynos-sysmmu 10a70000.sysmmu: --> 10850000.fimg2d
[    0.299975] [c4] exynos-sysmmu 10a70000.sysmmu: [OK]
[    0.300304] [c4] exynos-sysmmu 14650000.sysmmu: --> 14450000.mixer
[    0.300325] [c4] exynos-sysmmu 14650000.sysmmu: [OK]
[    0.300627] [c4] exynos-sysmmu 13e80000.sysmmu: --> 13e00000.gsc
[    0.300647] [c4] exynos-sysmmu 13e80000.sysmmu: [OK]
[    0.300949] [c4] exynos-sysmmu 13e90000.sysmmu: --> 13e10000.gsc
[    0.300969] [c4] exynos-sysmmu 13e90000.sysmmu: [OK]
[    0.301281] [c4] exynos-sysmmu 12880000.sysmmu: --> 12800000.scaler
[    0.301302] [c4] exynos-sysmmu 12880000.sysmmu: [OK]
[    0.301622] [c4] exynos-sysmmu 12890000.sysmmu: --> 12810000.scaler
[    0.301643] [c4] exynos-sysmmu 12890000.sysmmu: [OK]
[    0.301958] [c4] exynos-sysmmu 128a0000.sysmmu: --> 12820000.scaler
[    0.301978] [c4] exynos-sysmmu 128a0000.sysmmu: [OK]
[    0.302290] [c4] exynos-sysmmu 128c0000.sysmmu: --> 12800000.scaler
[    0.302310] [c4] exynos-sysmmu 128c0000.sysmmu: [OK]
[    0.302621] [c4] exynos-sysmmu 128d0000.sysmmu: --> 12810000.scaler
[    0.302642] [c4] exynos-sysmmu 128d0000.sysmmu: [OK]
[    0.302953] [c4] exynos-sysmmu 128e0000.sysmmu: --> 12820000.scaler
[    0.302974] [c4] exynos-sysmmu 128e0000.sysmmu: [OK]
[    0.303283] [c4] exynos-sysmmu 11f10000.sysmmu: --> 11f50000.jpeg
[    0.303303] [c4] exynos-sysmmu 11f10000.sysmmu: [OK]
[    0.303610] [c4] exynos-sysmmu 11f20000.sysmmu: --> 11f60000.jpeg
[    0.303630] [c4] exynos-sysmmu 11f20000.sysmmu: [OK]
[    0.303921] [c4] exynos-sysmmu 11200000.sysmmu: --> 11000000.mfc
[    0.303941] [c4] exynos-sysmmu 11200000.sysmmu: [OK]
[    0.304234] [c4] exynos-sysmmu 11210000.sysmmu: --> 11000000.mfc
[    0.304255] [c4] exynos-sysmmu 11210000.sysmmu: [OK]
[    0.304588] [c4] exynos-sysmmu 14640000.sysmmu: --> 14400000.fimd
[    0.304608] [c4] exynos-sysmmu 14640000.sysmmu: [OK]
[    0.304970] [c4] exynos-sysmmu 14680000.sysmmu: --> 14400000.fimd
[    0.304990] [c4] exynos-sysmmu 14680000.sysmmu: [OK]
[    0.305413] [c4] CPU Info : Samsung Exynos5422 Soc is BIN1
[    0.305428] [c4] Exynos5422 ASV : Use Fusing Speed Group 3
[    0.305441] [c4] Exynos5422 ASV : invalid IDS value
[    0.305455] [c4] EXYNOS5422 ASV :  IDS : 0 HPM : 0
[    0.305501] [c4] VDD_ARM ASV group is 3
[    0.305519] [c4] VDD_KFC ASV group is 3
[    0.305536] [c4] VDD_INT ASV group is 3
[    0.305553] [c4] VDD_MIF ASV group is 3
[    0.305569] [c4] VDD_G3D ASV group is 3
[    0.305585] [c4] VDD_ISP ASV group is 3
[    0.319347] [c4] bio: create slab <bio-0> at 0
[    0.321082] [c4] of_get_named_gpio_flags exited with status 119
[    0.321325] [c4] VUSB_BOOST_5V: 5000 mV
[    0.321670] [c4] of_get_named_gpio_flags: can't parse gpios property
[    0.321886] [c4] MAIN_DC: no parameters
[    0.322126] [c4] of_get_named_gpio_flags: can't parse gpios property
[    0.322336] [c4] hdmi-en: no parameters
[    0.323485] [c4] SCSI subsystem initialized
[    0.323885] [c4] usbcore: registered new interface driver usbfs
[    0.324004] [c4] usbcore: registered new interface driver hub
[    0.324216] [c4] usbcore: registered new device driver usb
[    0.330179] [c4] vdd_mif: 700 <--> 1300 mV at 1100 mV
[    0.331432] [c4] vdd_eagle: 800 <--> 1500 mV at 1000 mV
[    0.332677] [c4] vdd_int: 800 <--> 1400 mV at 1000 mV
[    0.333919] [c4] vdd_g3d: 700 <--> 1400 mV at 1000 mV
[    0.335269] [c4] vdd_kfc: 800 <--> 1500 mV at 1025 mV
[    0.337063] [c4] vddf_2v85: 3300 mV
[    0.338459] [c4] vdd_adc: 1800 mV
[    0.339854] [c4] vdd_pll: 1800 mV
[    0.341256] [c4] vdd_ldo6: 1000 mV
[    0.342646] [c4] vdd_ldo7: 1800 mV
[    0.344047] [c4] vdd_ldo8: 1800 mV
[    0.345496] [c4] vdd_ldo9: 3300 mV
[    0.346894] [c4] vdd_ldo10: 1800 mV
[    0.348284] [c4] vdd_ldo11: 1000 mV
[    0.349370] [c4] vdd_ldo13: 1800 <--> 3300 mV at 3300 mV
[    0.350823] [c4] vdd_ldo15: 3300 mV
[    0.352225] [c4] vdd_eth: 3300 mV
[    0.353742] [c4] vdd_ldo18: 1850 mV
[    0.354834] [c4] vdd_ldo19: 2800 <--> 3300 mV at 3300 mV
[    0.355983] [c4] vdd_mifs: 800 <--> 1100 mV at 1100 mV
[    0.357373] [c4] vdd_ldo26: 3000 mV
[    0.358461] [c4] vdd_g3ds: 800 <--> 1100 mV at 1000 mV
[    0.359860] [c4] vdd_ldo28: 3300 mV
[    0.361384] [c4] vdd_ldo30: 3300 mV
[    0.364184] [c4] of_get_named_gpio_flags exited with status 177
[    0.364214] [c4] of_get_named_gpio_flags exited with status 178
[    0.365118] [c4] i2c-gpio i2c_gpio.8: using pins 177 (SDA) and 178 (SCL)
[    0.365725] [c4] s3c-i2c 12c60000.i2c: slave address 0x00
[    0.368341] [c5] s3c-i2c 12c60000.i2c: i2c-3: S3C I2C adapter
[    0.368599] [c5] s3c-i2c 12c70000.i2c: slave address 0x00
[    0.368864] [c5] s3c-i2c 12c70000.i2c: i2c-4: S3C I2C adapter
[    0.369314] [c5] media: Linux media interface: v0.10
[    0.369406] [c5] Linux video capture interface: v2.00
[    0.371407] [c5] IOVMMU: Created debugfs entry at debugfs/iovmm
[    0.371985] [c5] Advanced Linux Sound Architecture Driver Initialized.
[    0.372603] [c5] PM DOMAIN: pd-maudio, Device : 3810000.lpass Registered
[    0.372641] [c5] Samsung Low Power Audio Subsystem driver, (c)2013 Samsung Electronics
[    0.374608] [c5] Loading modules backported from Linux version next-20150222-0-g53e418f1
[    0.374663] [c5] Backport integrated by backports.git backports-20150222-0-g2745ccd
[    0.376351] [c5] Switching to clocksource mct-frc
[    0.461141] [c5] NET: Registered protocol family 2
[    0.462931] [c5] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.463404] [c5] TCP bind hash table entries: 8192 (order: 6, 294912 bytes)
[    0.465389] [c5] TCP: Hash tables configured (established 8192 bind 8192)
[    0.465501] [c5] TCP: reno registered
[    0.465532] [c5] UDP hash table entries: 512 (order: 3, 40960 bytes)
[    0.465813] [c5] UDP-Lite hash table entries: 512 (order: 3, 40960 bytes)
[    0.466918] [c5] NET: Registered protocol family 1
[    0.467411] [c5] Unpacking initramfs...
[    0.905364] [c5] Freeing initrd memory: 6200K (c2001000 - c260f000)
[    0.918870] [c5] bounce pool size: 64 pages
[    0.927272] [c5] VFS: Disk quotas dquot_6.5.2
[    0.927635] [c5] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.930787] [c5] ROMFS MTD (C) 2007 Red Hat, Inc.
[    0.931790] [c5] msgmni has been set to 1447
[    0.936067] [c5] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.936592] [c6] io scheduler noop registered
[    0.936613] [c6] io scheduler deadline registered
[    0.936852] [c6] io scheduler cfq registered (default)
[    0.947280] [c6] dma-pl330 10800000.mdma: Loaded driver for PL330 DMAC-241330
[    0.947303] [c6] dma-pl330 10800000.mdma:    DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32
[    0.953029] [c6] dma-pl330 121a0000.pdma: Loaded driver for PL330 DMAC-241330
[    0.953051] [c6] dma-pl330 121a0000.pdma:    DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    0.958791] [c6] dma-pl330 121b0000.pdma: Loaded driver for PL330 DMAC-241330
[    0.958813] [c6] dma-pl330 121b0000.pdma:    DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    0.961890] [c6] dma-pl330 3880000.adma: Loaded driver for PL330 DMAC-241330
[    0.961911] [c6] dma-pl330 3880000.adma:     DBUFF-4x8bytes Num_Chans-6 Num_Peri-16 Num_Events-6
[    1.101352] [c6] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.104142] [c6] 12c00000.serial: ttySAC0 at MMIO 0x12c00000 (irq = 83) is a S3C6400/10
[    1.104875] [c6] 12c10000.serial: ttySAC1 at MMIO 0x12c10000 (irq = 84) is a S3C6400/10
[    1.105599] [c6] 12c20000.serial: ttySAC2 at MMIO 0x12c20000 (irq = 85) is a S3C6400/10
[    1.106295] [c6] 12c30000.serial: ttySAC3 at MMIO 0x12c30000 (irq = 86) is a S3C6400/10
[    1.109473] [c6] [drm] Initialized drm 1.1.0 20060810
[    1.112753] [c6] of_get_named_gpio_flags exited with status 39
[    1.116838] [c6] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.116857] [c6] [drm] No driver support for vblank timestamp query.
[    1.116881] [c6] exynos-mixer 14450000.mixer: probe start
[    1.117154] [c6] exynos-drm exynos-drm: bound 14450000.mixer (ops mixer_component_ops)
[    1.117472] [c6] exynos-drm exynos-drm: bound 14530000.hdmi (ops hdmi_component_ops)
[    1.117519] [c6] [drm] Initialized exynos 1.0.0 20110530 on minor 0
[    1.118103] [c6] mali 11800000.mali: Continuing without Mali clock control
[    1.121620] [c6] hrtimer: interrupt took 128167 ns
[    1.122178] [c6] mali 11800000.mali: GPU identified as 0x0620 r0p1 status 0
[    1.127888] mali 11800000.mali: Probed as mali0
[    1.136093] [c6] loop: module loaded
[    1.137288] [c6] tun: Universal TUN/TAP device driver, 1.6
[    1.137305] [c6] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.141543] [c6] of_get_named_gpio_flags exited with status 48
[    1.141570] [c6] of_get_named_gpio_flags exited with status 37
[    1.344132] [c6] of_get_named_gpio_flags exited with status 17
[    1.344159] [c6] of_get_named_gpio_flags exited with status 36
[    1.545743] [c6] dwc3 12400000.dwc3: dwc3_otg address space is not supported
[    1.546797] [c6] dwc3 12400000.dwc3: Binding gadget dwc3-gadget
[    1.547567] [c6] dwc3 12400000.dwc3: Turn on host
[    1.748644] [c6] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.748661] [c6] ehci-s5p: EHCI s5p driver
[    1.748982] [c6] of_get_named_gpio_flags exited with status 121
[    1.749256] [c6] s5p-ehci 12110000.usb: EHCI Host Controller
[    1.749404] [c6] s5p-ehci 12110000.usb: new USB bus registered, assigned bus number 1
[    1.749624] [c6] s5p-ehci 12110000.usb: irq 103, io mem 0x12110000
[    1.756585] [c6] s5p-ehci 12110000.usb: USB 2.0 started, EHCI 1.00
[    1.758031] [c6] hub 1-0:1.0: USB hub found
[    1.758074] [c6] hub 1-0:1.0: 3 ports detected
[    1.759422] [c6] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.759821] [c6] exynos-ohci 12120000.usb: EXYNOS OHCI Host Controller
[    1.759873] [c6] exynos-ohci 12120000.usb: new USB bus registered, assigned bus number 2
[    1.759952] [c6] exynos-ohci 12120000.usb: irq 103, io mem 0x12120000
[    1.816796] [c6] hub 2-0:1.0: USB hub found
[    1.816838] [c6] hub 2-0:1.0: 3 ports detected
[    1.818361] [c6] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    1.818413] [c6] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3
[    1.818679] [c6] xhci-hcd xhci-hcd.2.auto: irq 104, io mem 0x12000000
[    1.819556] [c6] xHCI xhci_add_endpoint called for root hub
[    1.819574] [c6] xHCI xhci_check_bandwidth called for root hub
[    1.819841] [c6] hub 3-0:1.0: USB hub found
[    1.819923] [c6] hub 3-0:1.0: 1 port detected
[    1.820488] [c6] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    1.820532] [c6] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 4
[    1.821442] [c6] xHCI xhci_add_endpoint called for root hub
[    1.821458] [c6] xHCI xhci_check_bandwidth called for root hub
[    1.821792] [c6] hub 4-0:1.0: USB hub found
[    1.821834] [c6] hub 4-0:1.0: 1 port detected
[    1.822507] [c6] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    1.822558] [c6] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 5
[    1.822818] [c6] xhci-hcd xhci-hcd.5.auto: irq 105, io mem 0x12400000
[    1.823693] [c6] xHCI xhci_add_endpoint called for root hub
[    1.823710] [c6] xHCI xhci_check_bandwidth called for root hub
[    1.823981] [c6] hub 5-0:1.0: USB hub found
[    1.824023] [c6] hub 5-0:1.0: 1 port detected
[    1.824581] [c6] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    1.824683] [c6] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 6
[    1.825614] [c6] xHCI xhci_add_endpoint called for root hub
[    1.825630] [c6] xHCI xhci_check_bandwidth called for root hub
[    1.825920] [c6] hub 6-0:1.0: USB hub found
[    1.825962] [c6] hub 6-0:1.0: 1 port detected
[    1.826859] [c6] usbcore: registered new interface driver usb-storage
[    1.827069] [c6] usbcore: registered new interface driver usbserial
[    1.827169] [c6] usbcore: registered new interface driver usbserial_generic
[    1.827266] [c6] usbserial: USB Serial support registered for generic
[    1.828031] [c6] of_get_named_gpio_flags: can't parse gpios property
[    1.828052] [c6] exynos-usb-switch usb-switch.10: host detect gpio is not available
[    1.828069] [c6] of_get_named_gpio_flags: can't parse gpios property
[    1.828087] [c6] exynos-usb-switch usb-switch.10: device detect gpio is not available
[    1.828103] [c6] of_get_named_gpio_flags: can't parse gpios property
[    1.828119] [c6] exynos-usb-switch usb-switch.10: vbus control gpio is not available
[    1.828160] [c6] exynos-usb-switch usb-switch.10: failed to configure pins
[    1.828370] [c6] exynos-usb-switch usb-switch.10: udc device is not available
[    1.828386] [c6] exynos-usb-switch usb-switch.10: Disable device detect IRQ
[    1.828410] [c6] usb cable = 1
[    1.829391] [c6] mousedev: PS/2 mouse device common for all mice
[    1.831060] [c6] s2m-rtc s2m-rtc: rtc init
[    1.834866] [c6] s2m-rtc s2m-rtc: s2m_rtc_enable_wtsr: enable WTSR
[    1.835181] [c6] s2m-rtc s2m-rtc: s2m_rtc_enable_smpl: enable SMPL
[    1.835651] [c6] s2m_rtc_enable_smpl: WTSR_SMPL(0xc7)
[    1.840040] [c6] s2m-rtc s2m-rtc: rtc core: registered s2m-rtc as rtc0
[    1.840910] [c6] i2c /dev entries driver
[    1.842987] [c6] IR NEC protocol handler initialized
[    1.843006] [c6] IR RC5(x) protocol handler initialized
[    1.843022] [c6] IR RC6 protocol handler initialized
[    1.843039] [c6] IR JVC protocol handler initialized
[    1.843055] [c6] IR Sony protocol handler initialized
[    1.843071] [c6] IR RC5 (streamzap) protocol handler initialized
[    1.843087] [c6] IR SANYO protocol handler initialized
[    1.843103] [c6] IR MCE Keyboard/mouse protocol handler initialized
[    1.843621] [c6] PM DOMAIN: pd-mfc, Device : 11000000.mfc Registered
[    1.843658] [c6] s5p-mfc 11000000.mfc: exynos-iommu gpd_dev_ops inserted!
[    1.843697] [c6] s5p-mfc 11000000.mfc: s5p_mfc_probe()
[    1.843724] [c6] s5p-mfc 11000000.mfc: of alias get id : mfc-0
[    1.844452] [c6] s5p-mfc 11000000.mfc: decoder registered as /dev/video6
[    1.844776] [c6] s5p-mfc 11000000.mfc: encoder registered as /dev/video7
[    1.845143] [c6] s5p-mfc 11000000.mfc: IOVMM: IOVM SIZE = 0x40000000 B, IOVMM from 0x10000000.
[    1.845179] [c6] s5p-mfc 11000000.mfc: IOVMM: IOVM SIZE = 0x20000000 B, IOVMM from 0x50000000.
[    1.845207] [c6] s5p-mfc 11000000.mfc: IOVMM: IOVM SIZE = 0x10000000 B, IOVMM from 0x70000000.
[    1.845241] [c6] s5p-mfc 11000000.mfc: IOVMM: IOVM SIZE = 0x30000000 B, IOVMM from 0x80000000.
[    1.845275] [c6] s5p-mfc 11000000.mfc: IOVMM: IOVM SIZE = 0x20000000 B, IOVMM from 0xb0000000.
[    1.845301] [c6] s5p-mfc 11000000.mfc: IOVMM: IOVM SIZE = 0x10000000 B, IOVMM from 0xd0000000.
[    1.846255] [c6] ion_cma ion_mfc_nfw: Alread isolated!
[    1.846271] [c6] s5p_mfc_probe--
[    1.846665] [c6] S5P CEC for Exynos4 Driver, (c) 2009 Samsung Electronics
[    1.848485] [c6] TRIMINFO[0] = 0x80652c
[    1.848503] [c6] TMU_CONTROL[0] = 0x10609803
[    1.848518] [c6] CURRENT_TEMP[0] = 0x0
[    1.848533] [c6] THRESHOLD_TEMP_RISE[0] = 0x817c7772
[    1.848548] [c6] THRESHOLD_TEMP_FALL[0] = 0x7f7a7570
[    1.848562] [c6] INTEN[0] = 0x11111111
[    1.848576] [c6] INTCLEAR[0] = 0x0
[    1.848622] [c6] TRIMINFO[1] = 0x80662c
[    1.848636] [c6] TMU_CONTROL[1] = 0x10609803
[    1.848650] [c6] CURRENT_TEMP[1] = 0x0
[    1.848664] [c6] THRESHOLD_TEMP_RISE[1] = 0x817c7772
[    1.848678] [c6] THRESHOLD_TEMP_FALL[1] = 0x7f7a7570
[    1.848692] [c6] INTEN[1] = 0x11111111
[    1.848706] [c6] INTCLEAR[1] = 0x0
[    1.848752] [c6] TRIMINFO[2] = 0x806e36
[    1.848766] [c6] TMU_CONTROL[2] = 0x10609803
[    1.848779] [c6] CURRENT_TEMP[2] = 0x0
[    1.848793] [c6] THRESHOLD_TEMP_RISE[2] = 0x847f7a75
[    1.848807] [c6] THRESHOLD_TEMP_FALL[2] = 0x827d7873
[    1.848820] [c6] INTEN[2] = 0x11111111
[    1.848834] [c6] INTCLEAR[2] = 0x0
[    1.848879] [c6] TRIMINFO[3] = 0x80682f
[    1.848894] [c6] TMU_CONTROL[3] = 0x10609803
[    1.848908] [c6] CURRENT_TEMP[3] = 0x0
[    1.848922] [c6] THRESHOLD_TEMP_RISE[3] = 0x7f7a7570
[    1.848936] [c6] THRESHOLD_TEMP_FALL[3] = 0x7d78736e
[    1.848949] [c6] INTEN[3] = 0x11111111
[    1.848963] [c6] INTCLEAR[3] = 0x0
[    1.849008] [c6] TRIMINFO[4] = 0x80652a
[    1.849023] [c6] TMU_CONTROL[4] = 0x10609803
[    1.849036] [c6] CURRENT_TEMP[4] = 0x0
[    1.849050] [c6] THRESHOLD_TEMP_RISE[4] = 0x8b86817c
[    1.849064] [c6] THRESHOLD_TEMP_FALL[4] = 0x89847f7a
[    1.849078] [c6] INTEN[4] = 0x11111111
[    1.849092] [c6] INTCLEAR[4] = 0x0
[    1.850331] [c6] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[    1.851229] [c6] cpuidle: using governor ladder
[    1.852943] [c6] cpuidle: using governor menu
[    1.853021] [c6] Synopsys Designware Multimedia Card Interface Driver
[    1.854084] [c6] dwmmc_exynos 12200000.dwmmc0: Clock pin control Pin:gpc0-0 Addr:13410000.pinctrl Val:3 Num:4
[    1.854196] of_get_named_gpio_flags exited with status 69
[    1.854239] [c6] dwmmc_exynos 12200000.dwmmc0: dw_mci_parse_dt : emmc h/w reset gpio[69] notifier registered.
[    1.854347] [c6] dwmmc_exynos 12200000.dwmmc0: Using internal DMA controller.
[    1.854368] [c6] dwmmc_exynos 12200000.dwmmc0: FIFOTH: 0x 300f0030
[    1.854385] dwmmc_exynos 12200000.dwmmc0: Version ID is 250a
[    1.854803] [c6] dwmmc_exynos 12200000.dwmmc0: DW MMC controller at irq 107, 64 bit host data width, 64 deep fifo
[    1.871597] [c6] mmc_host mmc0: Bus speed (slot 0) = 20812500Hz (slot req 400000Hz, actual 385416HZ div = 27)
[    1.886810] [c6] dwmmc_exynos 12200000.dwmmc0: 1 slots initialized
[    1.887416] [c6] dwmmc_exynos 12220000.dwmmc2: Clock pin control Pin:gpc2-0 Addr:13410000.pinctrl Val:3 Num:3
[    1.887504] of_get_named_gpio_flags: can't parse gpios property
[    1.887609] [c6] dwmmc_exynos 12220000.dwmmc2: Using internal DMA controller.
[    1.887630] [c6] dwmmc_exynos 12220000.dwmmc2: FIFOTH: 0x 300f0030
[    1.887646] dwmmc_exynos 12220000.dwmmc2: Version ID is 250a
[    1.888065] [c6] dwmmc_exynos 12220000.dwmmc2: DW MMC controller at irq 109, 64 bit host data width, 64 deep fifo
[    1.888429] [c6] mmc1: vmmc regulator found
[    1.888578] [c6] mmc1: vqmmc regulator found
[    1.906596] [c6] mmc_host mmc1: Bus speed (slot 0) = 20812500Hz (slot req 400000Hz, actual 385416HZ div = 27)
[    1.921846] [c7] dwmmc_exynos 12220000.dwmmc2: 1 slots initialized
[    1.923011] [c7] leds-gpio leds.15: pins are not configured from the driver
[    1.923056] [c7] of_get_named_gpio_flags exited with status 205
[    1.923083] [c7] of_get_named_gpio_flags exited with status 204
[    1.923108] [c7] of_get_named_gpio_flags exited with status 27
[    1.923146] [c7] of_get_named_gpio_flags exited with status 205
[    1.923464] [c7] of_get_named_gpio_flags exited with status 204
[    1.923708] [c7] of_get_named_gpio_flags exited with status 27
[    1.924330] [c7] ledtrig-cpu: registered to indicate activity on CPUs
[    1.924402] [c7] S5P ACE Driver(SLIMSSS), (c) 2013 Samsung Electronics
[    1.925178] [c5] ACE: ecb-aes-s5p-ace
[    1.925503] [c6] ACE: cbc-aes-s5p-ace
[    1.925811] [c6] ACE: ctr-aes-s5p-ace
[    1.926125] [c6] ACE: xts-aes-s5p-ace
[    1.926429] [c6] ACE: sha1-s5p-ace
[    1.926787] [c6] ACE: sha256-s5p-ace
[    1.926802] [c6] ACE driver is initialized
[    1.927109] [c6] hidraw: raw HID events driver (C) Jiri Kosina
[    1.927521] [c6] usbcore: registered new interface driver usbhid
[    1.927536] [c6] usbhid: USB HID core driver
[    1.928440] [c6] exynos-adc 12d10000.adc: operating without regulator vdd[-19]
[    1.929009] [c6] exynos-adc 12d10000.adc: Probed successfully driver.
[    1.929896] [c6] odroid-fan odroid_fan.14: unable to request PWM, trying legacy API
[    1.930050] [c6] pwm-samsung: tin parent at 66600000
[    1.932190] [c6] of_get_named_gpio_flags exited with status 34
[    1.934072] [c6] lpass_register_subip: i2s(de384810) registered
[    2.126438] [c7] mmc0: BKOPS_EN bit is not set
[    2.126639] [c5] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    2.143954] [c7] mmc_host mmc0: Bus speed (slot 0) = 166500000Hz (slot req 400000Hz, actual 398325HZ div = 209)
[    2.144016] [c7] mmc_host mmc0: Bus speed (slot 0) = 166500000Hz (slot req 166500000Hz, actual 166500000HZ div = 0)
[    2.144128] [c7] mmc_host mmc0: Bus speed (slot 0) = 333000000Hz (slot req 166500000Hz, actual 166500000HZ div = 1)
[    2.144179] [c7] mmc_host mmc0: Bus speed (slot 0) = 333000000Hz (slot req 200000000Hz, actual 166500000HZ div = 1)
[    2.144983] [c0] dwmmc_exynos 12200000.dwmmc0: End bit error
[    2.145166] [c7] mmc_host mmc0: Tuning error: cmd.error:0, data.error:-5
[    2.145299] [c0] dwmmc_exynos 12200000.dwmmc0: End bit error
[    2.145430] [c7] mmc_host mmc0: Tuning error: cmd.error:0, data.error:-5
[    2.146030] [c7] dwmmc_exynos 12200000.dwmmc0: sample_good: 0x cf best_sample: 0x 00
[    2.146903] [c7] mmc_host mmc0: Bus speed (slot 0) = 41625000Hz (slot req 200000000Hz, actual 41625000HZ div = 0)
[    2.146965] [c7] mmc_host mmc0: Bus speed (slot 0) = 41625000Hz (slot req 41625000Hz, actual 41625000HZ div = 0)
[    2.148139] [c7] mmc_host mmc0: Bus speed (slot 0) = 333000000Hz (slot req 41625000Hz, actual 41625000HZ div = 4)
[    2.148199] [c7] mmc_host mmc0: Bus speed (slot 0) = 333000000Hz (slot req 200000000Hz, actual 166500000HZ div = 1)
[    2.149123] [c7] mmc0: new HS200-DDR MMC card at address 0001
[    2.150350] [c7] mmcblk0: mmc0:0001 SDW16G 14.6 GiB
[    2.150898] [c7] mmcblk0boot0: mmc0:0001 SDW16G partition 1 4.00 MiB
[    2.151446] [c7] mmcblk0boot1: mmc0:0001 SDW16G partition 2 4.00 MiB
[    2.153612] [c7]  mmcblk0: p1
[    2.156350] [c7]  mmcblk0boot1: unknown partition table
[    2.158528] [c7]  mmcblk0boot0: unknown partition table
[    2.173417] [c5] hub 3-1:1.0: USB hub found
[    2.173891] [c5] hub 3-1:1.0: 2 ports detected
[    2.371913] [c5] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[    2.388051] [c5] usb 4-1: Parent hub missing LPM exit latency info.  Power management will be impacted.
[    2.397592] [c5] hub 4-1:1.0: USB hub found
[    2.398036] [c5] hub 4-1:1.0: 2 ports detected
[    2.506873] [c5] usb 6-1: new SuperSpeed USB device number 2 using xhci-hcd
[    2.522123] [c5] usb 6-1: Parent hub missing LPM exit latency info.  Power management will be impacted.
[    2.931569] [c6] exynos5-hsi2c 12cb0000.hsi2c: Register dump(suspended : 0)
               : CTL          0x00000089
               : FIFO_CTL     0x00200203
               : TRAILING_CTL 0x0000000f
               : CLK_CTL      0x00000000
               : CLK_SLOT     0x00000000
               : INT_EN       0x00000000
               : INT_STAT     0x00000000
               : ERR_STAT     0x00000000
               : FIFO_STAT    0x01000002
               : TXDATA       0xdeadbeaf
               : RXDATA       0x00000000
               : CONF         0xb00300ff
               : AUTO_CONF    0x00020002
               : TIMEOUT      0x000000ff
               : MANUAL_CMD   0x00000000
               : TRANS_STAT   0x00000000
               : TIMING_HS1   0x4b4b4b00
               : TIMING_HS2   0x25004b4b
               : TIMING_HS3   0x00000096
               : TIMING_FS1   0x4b4b4b00
               : TIMING_FS2   0x25004b4b
               : TIMING_FS3   0x00000096
               : TIMING_SLA   0x00000025
               : ADDR         0x00004000
[    2.931649] [c6] exynos5-hsi2c 12cb0000.hsi2c: tx timeout
[    3.931566] [c6] exynos5-hsi2c 12cb0000.hsi2c: Register dump(suspended : 0)
               : CTL          0x00000089
               : INT_EN       0x00000000
               : TXDATA       0xdeadbeaf
               : RXDATA       0x00000000
               : CONF         0xb00300ff
               : ADDR         0x00004000
[    3.931641] [c6] exynos5-hsi2c 12cb0000.hsi2c: tx timeout
[    3.931759] [c6] exynos5-hsi2c 12cb0000.hsi2c: xfer message failed
[    3.931798] [c6] max98090 1-0010: Failed to reset codec: -5
[    3.931815] [c6] max98090 1-0010: Failed to device reset : -5
[    3.931831] [c6] max98090 1-0010: ASoC: failed to probe CODEC -5
[    3.932063] [c6] odroid-audio sound.13: ASoC: failed to instantiate card -5
[    3.932398] [c6] odroid-audio sound.13: snd_soc_register_card() failed(max98090): -5
[    3.933284] [c6] dummy-codec dummy-codec.11: ASoC: Failed to create Capture debugfs file
[    3.933320] [c6] dummy-codec dummy-codec.11: ASoC: Failed to create Playback debugfs file
[    3.933355] [c6] dummy-codec dummy-codec.11: ASoC: Failed to create Capture debugfs file
[    3.933388] [c6] dummy-codec dummy-codec.11: ASoC: Failed to create Playback debugfs file
[    3.933422] [c6] dummy-codec dummy-codec.11: ASoC: Failed to create Capture debugfs file
[    3.933455] [c6] dummy-codec dummy-codec.11: ASoC: Failed to create Playback debugfs file
[    3.934395] [c6] odroid-audio sound.13:  dummy-aif1 <-> samsung-i2s-sec mapping ok
[    3.935391] [c7] odroid-audio sound.13:  dummy-aif2 <-> 3830000.i2s mapping ok
[    3.938490] [c7] Netfilter messages via NETLINK v0.30.
[    3.939226] [c7] arp_tables: (C) 2002 David S. Miller
[    3.939426] [c7] TCP: cubic registered
[    3.939450] [c7] Initializing XFRM netlink socket
[    3.940252] [c7] NET: Registered protocol family 10
[    3.942016] [c7] mip6: Mobile IPv6
[    3.942038] [c7] sit: IPv6 over IPv4 tunneling driver
[    3.943840] [c7] NET: Registered protocol family 17
[    3.943913] [c7] NET: Registered protocol family 15
[    3.943982] [c7] NET: Registered protocol family 35
[    3.944429] [c7] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    3.944515] [c7] Registering SWP/SWPB emulation handler
[    3.944537] [c7] SRAM ASV group [3] : MIF(950000), G3D(975000)
[    3.950830] [c7] registered taskstats version 1
[    3.951020] [c7] hdmi-en: disabling
[    3.951038] [c7] MAIN_DC: disabling
[    3.951058] [c7] regulator-dummy: disabling
[    3.952074] [c7] of_get_named_gpio_flags exited with status 11
[    3.952203] [c7] gpiod_set_debounce: gpio-11 status -22
[    3.952727] [c7] input: gpio_keys.7 as /devices/gpio_keys.7/input/input0
[    3.953449] [c7] CPUFREQ of CA7  L0 : 1300000 uV
[    3.953466] [c7] CPUFREQ of CA7  L0 : ABB 8
[    3.953480] [c7] CPUFREQ of CA7  L1 : 1287500 uV
[    3.953494] [c7] CPUFREQ of CA7  L1 : ABB 4
[    3.953508] [c7] CPUFREQ of CA7  L2 : 1237500 uV
[    3.953522] [c7] CPUFREQ of CA7  L2 : ABB 4
[    3.953535] [c7] CPUFREQ of CA7  L3 : 1187500 uV
[    3.953548] [c7] CPUFREQ of CA7  L3 : ABB 4
[    3.953562] [c7] CPUFREQ of CA7  L4 : 1137500 uV
[    3.953575] [c7] CPUFREQ of CA7  L4 : ABB 4
[    3.953587] [c7] CPUFREQ of CA7  L5 : 1100000 uV
[    3.953600] [c7] CPUFREQ of CA7  L5 : ABB 4
[    3.953613] [c7] CPUFREQ of CA7  L6 : 1062500 uV
[    3.953626] [c7] CPUFREQ of CA7  L6 : ABB 4
[    3.953639] [c7] CPUFREQ of CA7  L7 : 1025000 uV
[    3.953652] [c7] CPUFREQ of CA7  L7 : ABB 4
[    3.953665] [c7] CPUFREQ of CA7  L8 : 987500 uV
[    3.953678] [c7] CPUFREQ of CA7  L8 : ABB 255
[    3.953692] [c7] CPUFREQ of CA7  L9 : 950000 uV
[    3.953705] [c7] CPUFREQ of CA7  L9 : ABB 255
[    3.953718] [c7] CPUFREQ of CA7  L10 : 912500 uV
[    3.953732] [c7] CPUFREQ of CA7  L10 : ABB 255
[    3.953745] [c7] CPUFREQ of CA7  L11 : 900000 uV
[    3.953758] [c7] CPUFREQ of CA7  L11 : ABB 255
[    3.953772] [c7] CPUFREQ of CA7  L12 : 900000 uV
[    3.953785] [c7] CPUFREQ of CA7  L12 : ABB 255
[    3.953798] [c7] CPUFREQ of CA7  L13 : 900000 uV
[    3.953811] [c7] CPUFREQ of CA7  L13 : ABB 255
[    3.953824] [c7] CPUFREQ of CA7  L14 : 900000 uV
[    3.953837] [c7] CPUFREQ of CA7  L14 : ABB 255
[    3.954154] [c7] kfc clock[800000], mx_mspll clock[666000]
[    3.954179] [c7] [SET_EMA_TEST] volt : 887500  value : 0x44
[    3.954194] [c7] [SET_EMA_TEST] volt : 937500  value : 0x44
[    3.954208] [c7] [SET_EMA_TEST] volt : 1032500  value : 0x33
[    3.954222] [c7] [SET_EMA_TEST] volt : 1142500  value : 0x11
[    3.954236] [c7] [SET_EMA_TEST] volt : 1167500  value : 0x11
[    3.954251] [c7] CPUFREQ of CA15 L0 : 1362500 uV
[    3.954265] [c7] CPUFREQ of CA15  L0 : ABB 8
[    3.954279] [c7] CPUFREQ of CA15 L1 : 1362500 uV
[    3.954292] [c7] CPUFREQ of CA15  L1 : ABB 8
[    3.954305] [c7] CPUFREQ of CA15 L2 : 1362500 uV
[    3.954319] [c7] CPUFREQ of CA15  L2 : ABB 8
[    3.954332] [c7] CPUFREQ of CA15 L3 : 1337500 uV
[    3.954344] [c7] CPUFREQ of CA15  L3 : ABB 255
[    3.954357] [c7] CPUFREQ of CA15 L4 : 1287500 uV
[    3.954370] [c7] CPUFREQ of CA15  L4 : ABB 255
[    3.954384] [c7] CPUFREQ of CA15 L5 : 1212500 uV
[    3.954397] [c7] CPUFREQ of CA15  L5 : ABB 255
[    3.954410] [c7] CPUFREQ of CA15 L6 : 1162500 uV
[    3.954423] [c7] CPUFREQ of CA15  L6 : ABB 255
[    3.954436] [c7] CPUFREQ of CA15 L7 : 1125000 uV
[    3.954449] [c7] CPUFREQ of CA15  L7 : ABB 255
[    3.954462] [c7] CPUFREQ of CA15 L8 : 1087500 uV
[    3.954475] [c7] CPUFREQ of CA15  L8 : ABB 255
[    3.954487] [c7] CPUFREQ of CA15 L9 : 1050000 uV
[    3.954500] [c7] CPUFREQ of CA15  L9 : ABB 255
[    3.954513] [c7] CPUFREQ of CA15 L10 : 1025000 uV
[    3.954527] [c7] CPUFREQ of CA15  L10 : ABB 255
[    3.954540] [c7] CPUFREQ of CA15 L11 : 1012500 uV
[    3.954553] [c7] CPUFREQ of CA15  L11 : ABB 255
[    3.954567] [c7] CPUFREQ of CA15 L12 : 987500 uV
[    3.954580] [c7] CPUFREQ of CA15  L12 : ABB 255
[    3.954593] [c7] CPUFREQ of CA15 L13 : 962500 uV
[    3.954606] [c7] CPUFREQ of CA15  L13 : ABB 255
[    3.954619] [c7] CPUFREQ of CA15 L14 : 937500 uV
[    3.954632] [c7] CPUFREQ of CA15  L14 : ABB 255
[    3.954644] [c7] CPUFREQ of CA15 L15 : 912500 uV
[    3.954658] [c7] CPUFREQ of CA15  L15 : ABB 255
[    3.954670] [c7] CPUFREQ of CA15 L16 : 900000 uV
[    3.954683] [c7] CPUFREQ of CA15  L16 : ABB 255
[    3.954697] [c7] CPUFREQ of CA15 L17 : 900000 uV
[    3.954710] [c7] CPUFREQ of CA15  L17 : ABB 255
[    3.954723] [c7] CPUFREQ of CA15 L18 : 900000 uV
[    3.954736] [c7] CPUFREQ of CA15  L18 : ABB 255
[    3.954749] [c7] CPUFREQ of CA15 L19 : 900000 uV
[    3.954763] [c7] CPUFREQ of CA15  L19 : ABB 255
[    3.954776] [c7] CPUFREQ of CA15 L20 : 900000 uV
[    3.954789] [c7] CPUFREQ of CA15  L20 : ABB 255
[    3.954802] [c7] CPUFREQ of CA15 L21 : 900000 uV
[    3.954815] [c7] CPUFREQ of CA15  L21 : ABB 255
[    3.954828] [c7] CPUFREQ of CA15 L22 : 900000 uV
[    3.954841] [c7] CPUFREQ of CA15  L22 : ABB 255
[    3.955194] [c7] eagle clock[800000], mpll clock[800000]
[    3.959545] [c7] Exynos: Kernel Thermal management registered
[    3.959987] [c7] ### dt-test ### No testcase data in device tree; not running tests
[    3.995529] [c7] MIF 825000Khz ASV is 962500uV
[    3.995592] [c7] DEVFREQ(MIF) : 825000Khz, ABB 14
[    3.995599] [c7] MIF 728000Khz ASV is 925000uV
[    3.995609] [c7] DEVFREQ(MIF) : 728000Khz, ABB 14
[    3.995616] [c7] MIF 633000Khz ASV is 887500uV
[    3.995625] [c7] DEVFREQ(MIF) : 633000Khz, ABB 14
[    3.995632] [c7] MIF 543000Khz ASV is 862500uV
[    3.995641] [c7] DEVFREQ(MIF) : 543000Khz, ABB 14
[    3.995647] [c7] MIF 413000Khz ASV is 800000uV
[    3.995656] [c7] DEVFREQ(MIF) : 413000Khz, ABB 14
[    3.995663] [c7] MIF 275000Khz ASV is 775000uV
[    3.995672] [c7] DEVFREQ(MIF) : 275000Khz, ABB 14
[    3.995678] [c7] MIF 206000Khz ASV is 775000uV
[    3.995687] [c7] DEVFREQ(MIF) : 206000Khz, ABB 14
[    3.995694] [c7] MIF 165000Khz ASV is 775000uV
[    3.995703] [c7] DEVFREQ(MIF) : 165000Khz, ABB 14
[    3.995710] [c7] MIF 138000Khz ASV is 775000uV
[    3.995718] [c7] DEVFREQ(MIF) : 138000Khz, ABB 14
[    3.997023] [c7] MIF: set ASV freq 825000, voltage 962500
[    3.997590] [c7] INT 600000Khz ASV is 950000uV
[    3.997607] [c7] DEVFREQ(INT) : 600000Khz, ABB 255
[    4.996519] [c7] PM DOMAIN: Power off unused power domains.
[    4.996954] [c7] ALSA device list:
[    4.997052] [c7]   #0: odroid-audio
[    4.997510] [c7] Freeing unused kernel memory: 428K (c0917000 - c0982000)
[    5.961720] [c6] raid6: int32x1    507 MB/s
[    6.046519] [c6] raid6: int32x2    668 MB/s
[    6.131541] [c6] raid6: int32x4    778 MB/s
[    6.216568] [c6] raid6: int32x8    917 MB/s
[    6.216576] [c6] raid6: using algorithm int32x8 (917 MB/s)
[    6.216583] [c6] raid6: using intx1 recovery algorithm
[    6.217046] [c6] xor: measuring software checksum speed
[    6.266524] [c6]    arm4regs  :  3225.600 MB/sec
[    6.316517] [c6]    8regs     :  2699.200 MB/sec
[    6.366518] [c6]    32regs    :  2474.400 MB/sec
[    6.366526] [c6] xor: using function: arm4regs (3225.600 MB/sec)
[    6.376163] [c6] bio: create slab <bio-1> at 1
[    6.377384] [c7] Btrfs loaded
[    6.575845] [c4] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.739974] [c6] systemd[1]: System time before build time, advancing clock.
[    6.756587] [c6] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    6.757214] [c6] systemd[1]: Detected architecture arm.
[    6.761420] [c6] systemd[1]: Set hostname to <odroidxu4>.
[    6.948340] [c6] systemd[1]: Listening on fsck to fsckd communication Socket.
[    6.948985] [c6] systemd[1]: Listening on Syslog Socket.
[    6.949886] [c6] systemd[1]: Created slice User and Session Slice.
[    6.950444] [c6] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    6.950981] [c6] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.951309] [c6] systemd[1]: Reached target User and Group Name Lookups.
[    6.951673] [c6] systemd[1]: Reached target Swap.
[    6.952109] [c6] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    6.952531] [c6] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.953536] [c6] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.954343] [c6] systemd[1]: Created slice System Slice.
[    6.955099] [c6] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    6.955419] [c6] systemd[1]: Reached target Slices.
[    6.955721] [c6] systemd[1]: Reached target Remote File Systems (Pre).
[    6.956035] [c6] systemd[1]: Reached target Remote File Systems.
[    6.956522] [c6] systemd[1]: Listening on Journal Socket.
[    6.963313] [c6] systemd[1]: Starting Load Kernel Modules...
[    6.966264] [c6] systemd[1]: Starting Nameserver information manager...
[    6.970074] [c6] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    6.974816] [c6] systemd[1]: Starting Restore / save the current clock...
[    6.978535] [c6] systemd[1]: Mounting POSIX Message Queue File System...
[    6.982225] [c6] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.986369] [c5] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[    6.990875] [c5] systemd[1]: Mounting Debug File System...
[    6.994878] [c5] systemd[1]: Starting Set console keymap...
[    6.995515] [c5] systemd[1]: Listening on udev Kernel Socket.
[    6.996326] [c5] systemd[1]: Reached target Encrypted Volumes.
[    6.997316] [c5] systemd[1]: Listening on udev Control Socket.
[    7.008659] [c6] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    7.009876] [c7] systemd[1]: Mounted POSIX Message Queue File System.
[    7.010566] [c7] systemd[1]: Mounted Debug File System.
[    7.014589] [c7] systemd[1]: Started Load Kernel Modules.
[    7.027091] [c4] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    7.030113] [c4] systemd[1]: Started Remount Root and Kernel File Systems.
[    7.034605] [c4] systemd[1]: Started Restore / save the current clock.
[    7.043344] [c4] systemd[1]: Started Nameserver information manager.
[    7.049729] [c4] systemd[1]: Time has been changed
[    7.091946] [c7] systemd[1]: Started Set console keymap.
[    7.127254] [c7] systemd[1]: Starting udev Coldplug all Devices...
[    7.130730] [c7] systemd[1]: Starting Load/Save Random Seed...
[    7.134546] [c7] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.138437] [c7] systemd[1]: Mounting Configuration File System...
[    7.142483] [c7] systemd[1]: Starting Apply Kernel Variables...
[    7.147876] [c7] systemd[1]: Started Load/Save Random Seed.
[    7.157247] [c4] systemd[1]: Mounted Configuration File System.
[    7.179762] [c4] systemd[1]: Started Create Static Device Nodes in /dev.
[    7.184987] [c4] systemd[1]: Starting udev Kernel Device Manager...
[    7.185339] [c4] systemd[1]: Reached target Local File Systems (Pre).
[    7.189763] [c5] systemd[1]: Mounting /tmp...
[    7.201279] [c6] systemd[1]: Started Apply Kernel Variables.
[    7.211328] [c6] systemd[1]: Mounted /tmp.
[    7.260045] [c6] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[    7.264474] [c6] systemd[1]: Starting Journal Service...
[    7.264860] [c6] systemd[1]: Reached target Local File Systems.
[    7.269667] [c6] systemd[1]: Starting Set console font and keymap...
[    7.282910] [c7] systemd[1]: Starting Armbian enhanced Log2Ram...
[    7.289401] [c5] systemd[1]: Starting Raise network interfaces...
[    7.292581] [c5] systemd[1]: Started udev Kernel Device Manager.
[    7.499194] [c5] systemd[1]: Started Armbian enhanced Log2Ram.
[    7.817237] [c0] systemd[1]: Started Journal Service.
[    7.864816] [c4] systemd-journald[309]: Received request to flush runtime journal from PID 1
[    8.212845] [c6] [d:0, c:0] s5p_mfc_open:1629: NORMAL instance is opened [0:1]
[    8.214570] [c6] [d:0] s5p_mfc_alloc_firmware:122: Port for DRM F/W : 0xafc00000
[    8.218663] [c6] pd-mfc: Power-on latency exceeded, new value 3329125 ns
[    8.222354] [c6] [d:0] s5p_mfc_init_memctrl:304: [1] Base Address : 10000000
[    8.223620] [c6] [d:0] mfc_init_hw:426: MFC v8.0, F/W: 14yy, 01mm, 13dd (D)
[    8.223784] [c6] [d:0, c:0] s5p_mfc_open:1725: MFC open completed [0:1] dev = dd971810, ctx = dcf2d800
[    8.224112] [c6] [d:0, c:0] s5p_mfc_release:1883: MFC driver release is called [0:1], is_drm(0)
[    8.224254] [c6] s5p_mfc_dev_release:1801: power off
[    8.225076] [c6] [d:0] s5p_mfc_release:2037: mfc driver release finished [0:0], dev = dd971810
[    8.227323] [c5] [d:0, c:0] s5p_mfc_open:1629: NORMAL instance is opened [0:1]
[    8.228470] [c5] [d:0] s5p_mfc_alloc_firmware:122: Port for DRM F/W : 0xafc00000
[    8.230694] [c5] [d:0] s5p_mfc_init_memctrl:304: [1] Base Address : 10000000
[    8.232758] [c4] [d:0] mfc_init_hw:426: MFC v8.0, F/W: 14yy, 01mm, 13dd (D)
[    8.233058] [c4] [d:0, c:0] s5p_mfc_open:1725: MFC open completed [0:1] dev = dd971810, ctx = ddcec800
[    8.233361] [c4] [d:0, c:0] s5p_mfc_release:1883: MFC driver release is called [0:1], is_drm(0)
[    8.233393] [c4] s5p_mfc_dev_release:1801: power off
[    8.233930] [c6] [d:0] s5p_mfc_release:2037: mfc driver release finished [0:0], dev = dd971810
[    8.284089] [c1] of_get_named_gpio_flags exited with status 190
[    8.284123] [c1] of_get_named_gpio_flags exited with status 25
[    8.324973] [c7] of_get_named_gpio_flags exited with status 190
[    8.336077] [c0] of_get_named_gpio_flags exited with status 25
[    8.337221] [c0] PM DOMAIN: pd-isp, Device : 131a0000.spi Registered
[    8.337296] [c0] s3c64xx-spi 131a0000.spi: spi bus clock parent not specified, using clock at index 0 as parent
[    8.337312] [c0] s3c64xx-spi 131a0000.spi: number of chip select lines not specified, assuming 1 chip select line
[    8.337660] [c0] PM DOMAIN: pd-isp, Device : 131b0000.spi Registered
[    8.337703] [c0] s3c64xx-spi 131b0000.spi: spi bus clock parent not specified, using clock at index 0 as parent
[    8.337718] [c0] s3c64xx-spi 131b0000.spi: number of chip select lines not specified, assuming 1 chip select line
[    9.068192] [c7] usbcore: registered new interface driver r8152
[    9.100849] [c7] usbcore: registered new interface driver cdc_ether
[    9.254723] [c0] usb 6-1: reset SuperSpeed USB device number 2 using xhci-hcd
[    9.266934] [c0] usb 6-1: Parent hub missing LPM exit latency info.  Power management will be impacted.
[    9.267182] [c0] xhci-hcd xhci-hcd.5.auto: xHCI xhci_drop_endpoint called with disabled ep ddd0db40
[    9.267196] [c0] xhci-hcd xhci-hcd.5.auto: xHCI xhci_drop_endpoint called with disabled ep ddd0db6c
[    9.267248] [c0] xhci-hcd xhci-hcd.5.auto: xHCI xhci_drop_endpoint called with disabled ep ddd0db98
[    9.304328] [c0] r8152 6-1:1.0 eth0: v2.07.0 (2016/06/14)
[    9.304352] [c0] r8152 6-1:1.0 eth0: This product is covered by one or more of the following patents:
                        US6,570,884, US6,115,776, and US6,327,625.
[   10.379522] [c6] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   12.930603] [c3] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   13.189976] [c4] fuse init (API version 7.22)
[   41.480385] [c0] cgroup: systemd (1) created nested cgroup for controller "blkio" which has incomplete hierarchy support. Nested cgroups may change behavior in the future.
root@odroidxu4:~#
Caleb
Edited by zador.blood.stained
Added spoiler tags
Ahhh so i just fixed it....
change the boot.ini from
  GNU nano 2.5.3                                                       File: /boot/boot.ini
ODROIDXU-UBOOT-CONFIG
setenv rootdev "/dev/mmcblk0p1"
# U-Boot Parameters
setenv initrd_high "0xffffffff"
setenv fdt_high "0xffffffff"
# Mac address configuration
setenv macaddr "00:1e:06:61:7a:55
# Basic Ubuntu Setup. Don't touch unless you know what you are doing.
setenv bootrootfs "console=tty1 loglevel=1 root=${rootdev} rootwait ro fsck.repair=yes"
# boot parameter for serial console
console=ttySAC2,115200n8
to this
# U-Boot Parameters
setenv bootrootfs "console=tty1 console=ttySAC2,115200n8 loglevel=1 root=${rootdev} rootwait ro fsck.repair=yes"
All is well!
Thanks.
Caleb
