jessie 5.25 legacy - reboot/shutdown hangs at "Raise network interfaces"
Installed armbian 5.25 jessie legacy from scratch. No changes to network configuration.
Cubietruck:
- eth0 (wired ethernet) - DHCP - works fine
- WLAN0 - driver is loaded during boot - but not used at all
Default /etc/networking/interfaces config:
allow-hotplug eth0
iface eth0 inet dhcp
auto lo
iface lo inet loopback
Reboot hangs forever during shutdown while executing the following stop (!!) skript:
[  *** ] A stop job is running for LSB: Raise network interfa...13s / no limit)
Tried both possible solutions to define a timeout of 15 secs from http://unix.stackexchange.com/questions/186162/how-to-change-timeout-in-systemctl
But this does not work - it keeps saying "no limit".
Question is - why does i raise network interfaces during sytem stop anyway?
TIA
Tobias
Lines grabbed from shutdown:
[  OK  ] Stopped Authenticate and Authorize Users to Run Privileged Tasks.
[  OK  ] Stopped Getty on tty1.
[  OK  ] Stopped Serial Getty on ttyS0.
[  OK  ] Stopped WPA supplicant.
[  OK  ] Stopped Bluetooth service.
[  OK  ] Stopped User Manager for UID 0.
[  OK  ] Stopped LSB: disk temperature monitoring daemon.
[  OK  ] Stopped LSB: Set sysfs variables from /etc/sysfs.conf.
[  OK  ] Stopped LSB: Starts LIRC daemon..
[  OK  ] Stopped LSB: Start NTP daemon.
[  OK  ] Stopped LSB: Armbian gathering hardware information.
[  OK  ] Stopped LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Stopped LSB: Start/stop sysstat's sadc.
[  OK  ] Started Store Sound Card State.
[  OK  ] Started Unattended Upgrades.
         Stopping LSB: set CPUFreq kernel parameters...
[  OK  ] Stopped target Network is Online.
         Stopping Login Service...
[  OK  ] Removed slice user-0.slice.
         Stopping LSB: Patch firmware for brcm40183 Bluetooth adapter...
[  OK  ] Removed slice system-serial\x2dgetty.slice.
[  OK  ] Removed slice system-getty.slice.
         Stopping /etc/rc.local Compatibility...
[  OK  ] Stopped /etc/rc.local Compatibility.
         Stopping Permit User Sessions...
[  OK  ] Stopped Login Service.
[  OK  ] Stopped LSB: set CPUFreq kernel parameters.
[  OK  ] Stopped LSB: Patch firmware for brcm40183 Bluetooth adapter.
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped target Network.
         Stopping LSB: Load kernel modules needed to enable cpufreq scaling...
[  OK  ] Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Slices.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Paths.
[  OK  ] Stopped target Timers.
[  OK  ] Stopped target Sockets.
[  OK  ] Closed Syslog Socket.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Stopped target System Initialization.
         Stopping Load/Save RF Kill Switch Status of rfkill4...
         Stopping Load/Save RF Kill Switch Status of rfkill1...
         Stopping Load/Save RF Kill Switch Status of rfkill2...
         Stopping Load/Save RF Kill Switch Status of rfkill0...
         Stopping Restore / save the current clock...
         Stopping Update UTMP about System Boot/Shutdown...
         Stopping Apply Kernel Variables...
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Stopped target Encrypted Volumes.
         Stopping Load Kernel Modules...
[  OK  ] Stopped Load Kernel Modules.
         Stopping LSB: Raise network interfaces....
[  OK  ] Stopped target Swap.
         Deactivating swap /var/swap...
[  OK  ] Stopped target Remote File Systems.
[  OK  ] Stopped target Remote File Systems (Pre).
[  OK  ] Stopped Load/Save RF Kill Switch Status of rfkill4.
[  OK  ] Stopped Load/Save RF Kill Switch Status of rfkill1.
[  OK  ] Stopped Load/Save RF Kill Switch Status of rfkill2.
[  OK  ] Stopped Load/Save RF Kill Switch Status of rfkill0.
[  OK  ] Stopped Restore / save the current clock.
[  OK  ] Stopped Update UTMP about System Boot/Shutdown.
[  OK  ] Deactivated swap /var/swap.
         Stopping Create Volatile Files and Directories...
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Removed slice system-systemd\x2drfkill.slice.
[*     ] A stop job is running for LSB: Raise network interfa...32s / no limit)
I think it's related to bug in wireless driver (ap6210) which sometimes causes crash on unload / shutdown. If you don't need wireless, disable this module and you should be fine.
Thanks - you are right. I saw the crash during unload of the wireless kernel module but wouldn't guess that it was related.
Commenting the line ap6210 in /etc/modules fixed it.
PS: And even better - disabling WLAN also fixed that 10-20 seconds delay during ssh login :)
for speedup ure ssh connect just add to /etc/ssh/sshd_config
UseDNS no
and change this option to
GSSAPIAuthentication no
after restart ssh service
systemctl restart ssh.service
Its old hax for speedup ssh
