Having successfuly built and installed an Armbian image I would like to configure the WiFi connection as part of the process. Currently on first boot I have to connect a network cable to the SBC and run armbian-config to configure the WiFi manually which is a bit of a drag when I'm updating 5 boards. Is this doable ?
Edited by pkfox
add more text
I've worked out a very inelegant way of achieving what I want, once the compile.sh script has done its thing, I dd the image to an sdcard I have ready in a reader, mount the card, then copy a pre crafted NetWorkManager system connection file to the mounted card. Horrible I know but it works ( well it's worked once ).
3 hours ago, pkfox said:
 does this use NetworkManager ?
I believe so.  The other Armbian user space tools for networking do.
