rmoriz Posted December 13, 2024 Posted December 13, 2024 Out of curiosity I build an image based on the official repo (default options, just selecting the board, result was Armbian-unofficial_24.11.0-trunk_Orangepipc2_bookworm_edge_6.11.9.img) and it booted fine, too. I guess the issue is already solved in git? 1 Quote
going Posted December 13, 2024 Posted December 13, 2024 9 часов назад, rmoriz сказал: Out of curiosity I build an image based on the official repo (default options, just selecting the board, result was Armbian-unofficial_24.11.0-trunk_Orangepipc2_bookworm_edge_6.11.9.img) and it booted fine I spent three days looking for a problem testing kernel variants on my bananapi-m64 (a64 core). I have no problem. Let's just test the new kernel: Orangepipc2-6.12-crust-mini + linux-image 6.12.4 0 Quote
rmoriz Posted December 15, 2024 Posted December 15, 2024 @going Installed. Works fine! in detail: [Started on:] v24.11.1 for Orange Pi PC2 running Armbian Linux 6.11.9-edge-sunxi64 Packages: Debian stable (bookworm) orangepipc2:/tmp:# uname -ar Linux orangepipc2 6.11.9-edge-sunxi64 #1 SMP Sun Nov 17 14:09:55 UTC 2024 aarch64 GNU/Linux [installed the packages:] orangepipc2:/tmp:# dpkg -l|grep linux-\* ii binutils-aarch64-linux-gnu 2.40-2 arm64 GNU binary utilities, for aarch64-linux-gnu target ii console-setup-linux 1.221 all Linux specific part of console-setup ii libselinux1:arm64 3.4-1+b6 arm64 SELinux runtime shared libraries ii linux-base 4.9 all Linux image base package ii linux-dtb-edge-sunxi64 25.02.0-trunk arm64 Armbian Linux edge DTBs in /boot/dtb-6.12.4-edge-sunxi64 ii linux-headers-edge-sunxi64 25.02.0-trunk arm64 Armbian Linux edge headers 6.12.4-edge-sunxi64 ii linux-image-edge-sunxi64 25.02.0-trunk arm64 Armbian Linux edge kernel image 6.12.4-edge-sunxi64 ii linux-libc-dev-edge-sunxi64:arm64 25.02.0-trunk arm64 Armbian Linux support headers for userspace development ii linux-u-boot-orangepipc2-edge 24.11.1 arm64 Das U-Boot for orangepipc2 ii util-linux 2.38.1-5+deb12u2 arm64 miscellaneous system utilities ii util-linux-extra 2.38.1-5+deb12u2 arm64 interactive login tools [after reboot:] ~$ uname -ar Linux orangepipc2 6.12.4-edge-sunxi64 #3 SMP Mon Dec 9 09:41:16 UTC 2024 aarch64 GNU/Linux 0 Quote
rmoriz Posted December 16, 2024 Posted December 16, 2024 (edited) Update: When I disconnect the TTL adapter, the node does not boot anymore to network, e.g. becomes unreachable after the next boot. Looks like at least UART-TTL or HDMI need to be present to successfully complete the system boot and enable networking. Edited December 16, 2024 by rmoriz 0 Quote
going Posted December 17, 2024 Posted December 17, 2024 16 часов назад, rmoriz сказал: Update: When I disconnect the TTL adapter, the node does not boot anymore to network, e.g. becomes unreachable after the next boot. Looks like at least UART-TTL or HDMI need to be present to successfully complete the system boot and enable networking. I also noticed something similar when I was testing on bananapim64. I run without HDMI, only UART and Ethernet. The Ethernet starts working immediately, but the UART does not respond to the keyboard from the minicom. After a few minutes, everything magically starts working. These two boards of ours have not been tested for a long time. Perhaps something in u-boot needs to be fixed. Try to view the kernel messages by first adding debug level 10. sudo nano /boot/armbianEnv.tx verbosity=10 # sudo reboot sudo dmesg | grep -i ether Or something like that 0 Quote
rmoriz Posted December 20, 2024 Posted December 20, 2024 When adding UART the network becomes pingable almost instantaneously, way too fast for a U-Boot issue. I still assume systemd is blocking/waiting. But as I pointed out in my first post, I couldn't find a way to debug it. The kernel commandline options seem to be ignored. 0 Quote
going Posted December 23, 2024 Posted December 23, 2024 (edited) 20.12.2024 в 15:32, rmoriz сказал: When adding UART the network becomes pingable almost instantaneously, way too fast for a U-Boot issue. I still assume systemd is blocking/waiting. But as I pointed out in my first post, I couldn't find a way to debug it. The kernel commandline options seem to be ignored. My guess: It can be a /boot/boot.cmd script. Source for sunxi64 config/bootscripts/boot-sun50i-next.cmd, for sunxi config/bootscripts/boot-sunxi.cmd The kernel command line parameters for the console and display are set in it. By default, in the settings file armbianEnv.txt It must be: console=both You can try to change console=display or any. Please keep me informed if you find an error in the script. P.S. In any case, the connection from the console service to other services seems strange to me. Maybe look in the system event log of the system in the order in which this happens during a crash? Edited December 23, 2024 by going Add P.S. 0 Quote
rmoriz Posted December 23, 2024 Posted December 23, 2024 Sorry for my late response. It's hard to reproduce. *current* incomplete observation using your kernels as mentioned in Successful path: When powered on: - at 0+17 seconds the green LED on the board starts turning on solid - at 0+28 seconds the yellow link LED of the ethernet port turns on solid for 3 seconds - at 0+37-40 seconds ICMP responses to PING start The rare unsuccessful boot: - at 0+17 seconds the green LED on the board starts turning on solid - at 0+28 seconds the yellow link LED of the ethernet port turns on solid AND STAYS ON nothing happens from this point on Variant: all LEDs turn off after a while Contrary to my prior observations, it does not have anything to do with UART or HDMI. Even when one or both plugged in, the unsuccessful path stays frozen. At this point I speculate about the power source, maybe the second case is kind of a brown-out. I will try other power sources and report back. 0 Quote
going Posted December 24, 2024 Posted December 24, 2024 17 часов назад, rmoriz сказал: Variant: all LEDs turn off after a while I've watched it. It looks like the OS has fallen asleep when the user is not doing anything. 17 часов назад, rmoriz сказал: At this point I speculate about the power source, maybe the second case is kind of a brown-out. What kind of power supply is it now? And what is connected to the board besides the mouse and keyboard? 0 Quote
rmoriz Posted December 25, 2024 Posted December 25, 2024 @going I'm using an USB-A to barrel adapter. It works fine when directly attached to my old 2017 5k iMac but fails when using a rather sophisticated 45W GAN wall adapter that claims to provide up to 3A at 5V. I run the device headless, nothing attached besides power and Ethernet, except when debugging. 0 Quote
tutralex Posted January 11 Posted January 11 (edited) Maybe it will be useful for someone. Working file "sun50i-h5-orangepi-pc2.dtb" with processor overclocking to 1.44 GHz. For everything to work, you also need to correct the parameter MAX_SPEED=1440000 in the file "/etc/default/cpufrequtils". As for the boot issue, it's still not solved. I just wrote a script that after the next update replaces the non-working "/boot/dtb/allwinner/sun50i-h5-orangepi-pc2.dtb" with the one attached in this post (this needs to be done before rebooting). cpufrequtils sun50i-h5-orangepi-pc2.dtb Edited January 11 by tutralex A small clarification. 2 Quote
rmoriz Posted January 22 Posted January 22 (edited) @tutralex What boot issue in your case? I just wiped my SD, built out of the current main branch 'Armbian-unofficial_25.02.0-trunk_Orangepipc2_bookworm_edge_6.12.9_minimal.img' and it booted fine but I've currently attached a NanoKVM via HDMI. cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepipc2 BOARD_NAME="Orange Pi PC2" BOARDFAMILY=sun50iw2 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=d4b5c30 LINUXFAMILY=sunxi64 ARCH=arm64 BOOT_SOC= IMAGE_TYPE=user-built BOARD_TYPE=csc INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image KERNEL_TARGET=legacy,current,edge KERNEL_TEST_TARGET=current FORCE_BOOTSCRIPT_UPDATE= FORCE_UBOOT_UPDATE= OVERLAY_DIR="/boot/dtb/allwinner/overlay" VENDOR="Armbian-unofficial" VENDORDOCS="https://docs.armbian.com/" VENDORURL="https://duckduckgo.com/" VENDORSUPPORT="https://community.armbian.com/" VENDORBUGS="https://armbian.atlassian.net/" BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" VERSION=25.02.0-trunk REVISION=25.02.0-trunk BRANCH=edge Edited January 22 by rmoriz 0 Quote
going Posted January 23 Posted January 23 12.01.2025 в 01:22, tutralex сказал: Working file "sun50i-h5-orangepi-pc2.dtb" with processor overclocking to 1.44 GHz. Warning: H5 processors from the first batches cannot be overclocked to these frequencies. On my device, I was unable to get stable operation at a frequency higher than 1.2Ghz. 0 Quote
going Posted January 23 Posted January 23 12.01.2025 в 01:22, tutralex сказал: I just wrote a script that after the next update replaces the non-working "/boot/dtb/allwinner/sun50i-h5-orangepi-pc2.dtb" with the one attached in this post (this needs to be done before rebooting). Can you post your changes here as "git diff" or "git format-patch -1" 0 Quote
tutralex Posted January 24 Posted January 24 (edited) @rmoriz The problem exists in the official "current" image. @going Oh, forgot to say that this is the latest revision of the board with a 1.368 GHz processor. These settings will not break older devices and can be easily rolled back. Edited January 24 by tutralex 1.368 freq 0 Quote
tutralex Posted January 24 Posted January 24 Цитата Can you post your changes here as "git diff" or "git format-patch -1" I'm afraid I don't have enough experience for this. 0 Quote
