dgm78 Posted February 21, 2017 Posted February 21, 2017 Hi! I think all fine in my configuration, but not connect on boot, I need to killall -q wpa_supplicant and run /etc/init.d/networking restart to connect. # /etc/network/interfacesiface wlan0 inet staticaddress 192.168.1.200netmask 255.255.255.0network 192.168.1.0broadcast 192.168.1.255gateway 192.168.1.1pre-up wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf -wB -D <forgot the name>post-down killall -q wpa_supplicant
jkajolin Posted February 22, 2017 Posted February 22, 2017 If you have network manager running it will mess up and you should not use wpa_supplicant direcrly but use nmcli commands / profiles I just use thins simple line on /etc/network/interfaces wpa-conf /etc/wpa_supplicant/example.conf
tkaiser Posted February 22, 2017 Posted February 22, 2017 I need to killall -q wpa_supplicant and run /etc/init.d/networking restart to connect Why? Just ignore wpa_supplicant and other anachronistic methods you find in gazillions of tutorials, configure Wi-Fi with nmtui ('Edit connection' as second step if you missed to assign a static IP address config before) and you're done.
