First of all thanks for your very good job on armbian !!!
I cannot adapt screen resolution on olimex A20 micro + 10 inch LCD (connected on board).
normal resolution is 1024x600.
I tried some varions in boot.cmd, as :
setenv bootargs "console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 hdmi.audio=EDID:0 disp.screen0_output_mode=1024x600@60 panic=10 consoleblank=0 enforcing=0 loglevel=1"
many variation as
-1024x600
-1024x600 @25 @50 @60 MR-16, or other thinks found on net...
The screen never correctly configured.
Boot text is bad, graphical work, but not at right resolution visible area is cutted/bad placed...)
Did you have advice ?
Thanks !
I also tried to use pygame, and i have problem to make glx working.
glxinfo answer :
"could not find RGB GLX visual or FBconfig"
Xorg.log give :
[    20.350]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[    20.351] X Protocol Version 11, Revision 0
[    20.351] Build Operating System: Linux 3.2.0-67-highbank armv7l Ubuntu
[    20.351] Current Operating System: Linux micro 3.4.109-sun7i #4 SMP PREEMPT Sun Oct 11 14:32:15 CEST 2015 armv7l
[    20.351] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 hdmi.audio=EDID:0 disp.screen0_output_mode=1024x600@60 panic=10 consoleblank=0 enforcing=0 loglevel=1
[    20.351] Build Date: 12 February 2015  02:55:07PM
[    20.351] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support)
[    20.351] Current version of pixman: 0.30.2
[    20.351]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[    20.352] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    20.352] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Oct 25 15:10:15 2015
[    20.363] (==) Using config file: "/etc/X11/xorg.conf"
[    20.364] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    20.379] (==) No Layout section.  Using the first Screen section.
[    20.379] (==) No screen section available. Using defaults.
[    20.379] (**) |-->Screen "Default Screen Section" (0)
[    20.379] (**) |   |-->Monitor "<default monitor>"
[    20.381] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[    20.381] (**) |   |-->Device "Allwinner A10/A13 FBDEV"
[    20.381] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[    20.381] (==) Automatically adding devices
[    20.381] (==) Automatically enabling devices
[    20.381] (==) Automatically adding GPU devices
[    20.392] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    20.393]    Entry deleted from font path.
[    20.393] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    20.393] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    20.393] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[    20.393] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    20.393] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    20.393] (==) FontPath set to:
        /usr/share/fonts/X11/misc,
        built-ins
[    20.393] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    20.393] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[    20.394] (II) Loader magic: 0xb6f30f10
[    20.394] (II) Module ABI versions:
[    20.394]    X.Org ANSI C Emulation: 0.4
[    20.394]    X.Org Video Driver: 15.0
[    20.394]    X.Org XInput driver : 20.0
[    20.394]    X.Org Server Extension : 8.0
[    20.394] Initializing built-in extension Generic Event Extension
[    20.395] Initializing built-in extension SHAPE
[    20.395] Initializing built-in extension MIT-SHM
[    20.395] Initializing built-in extension XInputExtension
[    20.395] Initializing built-in extension XTEST
[    20.395] Initializing built-in extension BIG-REQUESTS
[    20.395] Initializing built-in extension SYNC
[    20.395] Initializing built-in extension XKEYBOARD
[    20.395] Initializing built-in extension XC-MISC
[    20.395] Initializing built-in extension SECURITY
[    20.395] Initializing built-in extension XINERAMA
[    20.395] Initializing built-in extension XFIXES
[    20.395] Initializing built-in extension RENDER
[    20.395] Initializing built-in extension RANDR
[    20.395] Initializing built-in extension COMPOSITE
[    20.395] Initializing built-in extension DAMAGE
[    20.395] Initializing built-in extension MIT-SCREEN-SAVER
[    20.395] Initializing built-in extension DOUBLE-BUFFER
[    20.396] Initializing built-in extension RECORD
[    20.396] Initializing built-in extension DPMS
[    20.396] Initializing built-in extension Present
[    20.396] Initializing built-in extension DRI3
[    20.396] Initializing built-in extension X-Resource
[    20.396] Initializing built-in extension XVideo
[    20.396] Initializing built-in extension XVideo-MotionCompensation
[    20.396] Initializing built-in extension SELinux
[    20.396] Initializing built-in extension XFree86-VidModeExtension
[    20.396] Initializing built-in extension XFree86-DGA
[    20.396] Initializing built-in extension XFree86-DRI
[    20.396] Initializing built-in extension DRI2
[    20.396] (II) LoadModule: "glx"
[    20.407] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    20.492] (II) Module glx: vendor="X.Org Foundation"
[    20.492]    compiled for 1.15.1, module version = 1.0.0
[    20.492]    ABI class: X.Org Server Extension, version 8.0
[    20.492] (==) AIGLX enabled
[    20.493] Loading extension GLX
[    20.493] (II) LoadModule: "fbturbo"
[    20.494] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[    20.501] (II) Module fbturbo: vendor="X.Org Foundation"
[    20.502]    compiled for 1.15.1, module version = 0.5.1
[    20.502]    Module class: X.Org Video Driver
[    20.502]    ABI class: X.Org Video Driver, version 15.0
[    20.502] (II) FBTURBO: driver for framebuffer: fbturbo
[    20.502] (++) using VT number 7
[    20.509] (WW) Falling back to old probe method for fbturbo
[    20.509] (II) Loading sub module "fbdevhw"
[    20.509] (II) LoadModule: "fbdevhw"
[    20.516] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    20.519] (II) Module fbdevhw: vendor="X.Org Foundation"
[    20.519]    compiled for 1.15.1, module version = 0.0.2
[    20.519]    ABI class: X.Org Video Driver, version 15.0
[    20.519] (II) FBTURBO(0): using /dev/fb0
[    20.519] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    20.520] (II) FBTURBO(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[    20.520] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[    20.520] (==) FBTURBO(0): RGB weight 888
[    20.520] (==) FBTURBO(0): Default visual is TrueColor
[    20.520] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[    20.520] (II) FBTURBO(0): hardware:  (video memory: 3000kB)
[    20.520] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[    20.521] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[    20.521] (II) FBTURBO(0): processor: ARM Cortex-A7
[    20.521] (II) FBTURBO(0): checking modes against framebuffer device...
[    20.521] (II) FBTURBO(0): checking modes against monitor...
[    20.522] (--) FBTURBO(0): Virtual size is 800x480 (pitch 800)
[    20.522] (**) FBTURBO(0):  Built-in mode "current": 33.0 MHz, 31.3 kHz, 59.6 Hz
[    20.522] (II) FBTURBO(0): Modeline "current"x0.0   33.00  800 1009 1039 1055  480 502 503 525 -hsync -vsync -csync (31.3 kHz B)
[    20.522] (==) FBTURBO(0): DPI set to (96, 96)
[    20.522] (II) Loading sub module "fb"
[    20.522] (II) LoadModule: "fb"
[    20.523] (II) Loading /usr/lib/xorg/modules/libfb.so
[    20.532] (II) Module fb: vendor="X.Org Foundation"
[    20.532]    compiled for 1.15.1, module version = 1.0.0
[    20.532]    ABI class: X.Org ANSI C Emulation, version 0.4
[    20.532] (==) Depth 24 pixmap format is 32 bpp
[    20.540] (II) FBTURBO(0): using backing store heuristics
[    20.573] (II) FBTURBO(0): enabled G2D acceleration
[    20.573] (==) FBTURBO(0): Backing store enabled
[    20.580] (==) FBTURBO(0): DPMS enabled
[    20.580] (II) FBTURBO(0): using sunxi disp layers for X video extension
[    20.580] (II) FBTURBO(0): using hardware cursor
[    20.580] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[    20.581] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[    20.581] (==) RandR enabled
[    20.624] (II) SELinux: Disabled on system
[    20.630] (II) AIGLX: Screen 0 is not DRI2 capable
[    20.630] (EE) AIGLX: reverting to software rendering
[    20.631] (EE) AIGLX error: dlopen of /usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so failed (/usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
[    20.631] (EE) GLX: could not load software renderer
[    20.631] (II) GLX: no usable GL providers found for screen 0
[    20.712] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[    20.731] (II) config/udev: Adding input device axp20-supplyer (/dev/input/event0)
[    20.731] (**) axp20-supplyer: Applying InputClass "evdev keyboard catchall"
[    20.731] (II) LoadModule: "evdev"
[    20.732] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    20.740] (II) Module evdev: vendor="X.Org Foundation"
[    20.741]    compiled for 1.15.0, module version = 2.8.2
[    20.741]    Module class: X.Org XInput Driver
[    20.741]    ABI class: X.Org XInput driver, version 20.0
[    20.741] (II) Using input driver 'evdev' for 'axp20-supplyer'
[    20.741] (**) axp20-supplyer: always reports core events
[    20.741] (**) evdev: axp20-supplyer: Device: "/dev/input/event0"
[    20.741] (--) evdev: axp20-supplyer: Vendor 0x1 Product 0x1
[    20.741] (--) evdev: axp20-supplyer: Found keys
[    20.741] (II) evdev: axp20-supplyer: Configuring as keyboard
[    20.741] (**) Option "config_info" "udev:/sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input0/event0"
[    20.742] (II) XINPUT: Adding extended input device "axp20-supplyer" (type: KEYBOARD, id 6)
[    20.742] (**) Option "xkb_rules" "evdev"
[    20.742] (**) Option "xkb_model" "pc105"
[    20.742] (**) Option "xkb_layout" "us"
[    20.746] (II) config/udev: Adding input device Lite-On Technology Corp. USB Mouse (/dev/input/event1)
[    20.746] (**) Lite-On Technology Corp. USB Mouse: Applying InputClass "evdev pointer catchall"
[    20.746] (II) Using input driver 'evdev' for 'Lite-On Technology Corp. USB Mouse'
[    20.746] (**) Lite-On Technology Corp. USB Mouse: always reports core events
[    20.746] (**) evdev: Lite-On Technology Corp. USB Mouse: Device: "/dev/input/event1"
[    20.747] (--) evdev: Lite-On Technology Corp. USB Mouse: Vendor 0x4ca Product 0x30
[    20.747] (--) evdev: Lite-On Technology Corp. USB Mouse: Found 3 mouse buttons
[    20.747] (--) evdev: Lite-On Technology Corp. USB Mouse: Found scroll wheel(s)
[    20.747] (--) evdev: Lite-On Technology Corp. USB Mouse: Found relative axes
[    20.747] (--) evdev: Lite-On Technology Corp. USB Mouse: Found x and y relative axes
[    20.747] (II) evdev: Lite-On Technology Corp. USB Mouse: Configuring as mouse
[    20.747] (II) evdev: Lite-On Technology Corp. USB Mouse: Adding scrollwheel support
[    20.747] (**) evdev: Lite-On Technology Corp. USB Mouse: YAxisMapping: buttons 4 and 5
[    20.747] (**) evdev: Lite-On Technology Corp. USB Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    20.747] (**) Option "config_info" "udev:/sys/devices/platform/sw-ohci.1/usb3/3-1/3-1:1.0/input/input1/event1"
[    20.747] (II) XINPUT: Adding extended input device "Lite-On Technology Corp. USB Mouse" (type: MOUSE, id 7)
[    20.748] (II) evdev: Lite-On Technology Corp. USB Mouse: initialized for relative axes.
[    20.748] (**) Lite-On Technology Corp. USB Mouse: (accel) keeping acceleration scheme 1
[    20.749] (**) Lite-On Technology Corp. USB Mouse: (accel) acceleration profile 0
[    20.749] (**) Lite-On Technology Corp. USB Mouse: (accel) acceleration factor: 2.000
[    20.749] (**) Lite-On Technology Corp. USB Mouse: (accel) acceleration threshold: 4
[    20.750] (II) config/udev: Adding input device Lite-On Technology Corp. USB Mouse (/dev/input/mouse0)
[    20.751] (II) No input driver specified, ignoring this device.
[    20.751] (II) This device may have been added with another device file.
[    20.752] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event2)
[    20.753] (**)   USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    20.753] (II) Using input driver 'evdev' for '  USB Keyboard'
[    20.753] (**)   USB Keyboard: always reports core events
[    20.753] (**) evdev:   USB Keyboard: Device: "/dev/input/event2"
[    20.753] (--) evdev:   USB Keyboard: Vendor 0x1241 Product 0x1503
[    20.753] (--) evdev:   USB Keyboard: Found keys
[    20.753] (II) evdev:   USB Keyboard: Configuring as keyboard
[    20.753] (**) Option "config_info" "udev:/sys/devices/platform/sw-ohci.2/usb5/5-1/5-1:1.0/input/input2/event2"
[    20.753] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 8)
[    20.753] (**) Option "xkb_rules" "evdev"
[    20.753] (**) Option "xkb_model" "pc105"
[    20.754] (**) Option "xkb_layout" "us"
[    20.757] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event3)
[    20.757] (**)   USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    20.757] (II) Using input driver 'evdev' for '  USB Keyboard'
[    20.757] (**)   USB Keyboard: always reports core events
[    20.757] (**) evdev:   USB Keyboard: Device: "/dev/input/event3"
[    20.757] (--) evdev:   USB Keyboard: Vendor 0x1241 Product 0x1503
[    20.757] (--) evdev:   USB Keyboard: Found keys
[    20.757] (II) evdev:   USB Keyboard: Configuring as keyboard
[    20.757] (**) Option "config_info" "udev:/sys/devices/platform/sw-ohci.2/usb5/5-1/5-1:1.1/input/input3/event3"
[    20.757] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 9)
[    20.758] (**) Option "xkb_rules" "evdev"
[    20.758] (**) Option "xkb_model" "pc105"
[    20.758] (**) Option "xkb_layout" "us"
Did you have some advice or solution ?
Thanks a lot !
Fox
I found how to adapt resolution... but STILL GLXINFO problem !!! :-(
(i it can help someone else)
Adapt FEx file, like this :
Extract FEX from bin with :
bin2dex /boot/script.bin fex.txt
then edit fex.txt and replace [lcd0_para] section with this :
lcd_used = 1lcd_x = 1024lcd_y = 600lcd_dclk_freq = 45lcd_pwm_not_used = 0lcd_pwm_ch = 0lcd_pwm_freq = 10000lcd_pwm_pol = 1lcd_if = 0lcd_hbp = 160lcd_ht = 1200lcd_vbp = 23lcd_vt = 1250lcd_hv_if = 0lcd_hv_smode = 0lcd_hv_s888_if = 0lcd_hv_syuv_if = 0lcd_hv_vspw = 2lcd_hv_hspw = 10lcd_lvds_ch = 0lcd_lvds_mode = 0lcd_lvds_bitwidth = 0lcd_lvds_io_cross = 0lcd_cpu_if = 0lcd_frm = 1lcd_io_cfg0 = 268435456lcd_gamma_correction_en = 0lcd_gamma_tbl_0 = 0x0lcd_gamma_tbl_1 = 0x10101lcd_gamma_tbl_255 = 0xfffffflcd_bl_en_used = 1lcd_bl_en = port:PH07<1><0><default><1>lcd_power_used = 1lcd_power = port:PH08<1><0><default><1>lcd_pwm_used = 1lcd_pwm = port:PB02<2><0><default><default>lcdd0 = port:PD00<2><0><default><default>lcdd1 = port:PD01<2><0><default><default>lcdd2 = port:PD02<2><0><default><default>lcdd3 = port:PD03<2><0><default><default>lcdd4 = port:PD04<2><0><default><default>lcdd5 = port:PD05<2><0><default><default>lcdd6 = port:PD06<2><0><default><default>lcdd7 = port:PD07<2><0><default><default>lcdd8 = port:PD08<2><0><default><default>lcdd9 = port:PD09<2><0><default><default>lcdd10 = port:PD10<2><0><default><default>lcdd11 = port:PD11<2><0><default><default>lcdd12 = port:PD12<2><0><default><default>lcdd13 = port:PD13<2><0><default><default>lcdd14 = port:PD14<2><0><default><default>lcdd15 = port:PD15<2><0><default><default>lcdd16 = port:PD16<2><0><default><default>lcdd17 = port:PD17<2><0><default><default>lcdd18 = port:PD18<2><0><default><default>lcdd19 = port:PD19<2><0><default><default>lcdd20 = port:PD20<2><0><default><default>lcdd21 = port:PD21<2><0><default><default>lcdd22 = port:PD22<2><0><default><default>lcdd23 = port:PD23<2><0><default><default>lcdclk = port:PD24<2><0><default><default>lcdde = port:PD25<2><0><default><default>lcdhsync = port:PD26<2><0><default><default>lcdvsync = port:PD27<2><0><default><default>then recreate fex with :
fex2bin fex.txt script.txt
and replace original one :
cp script.bin /boot/bin/micro.bin
and reboot. it work.... ;-)
Can someone help me about the GLX problem ??? Thanks.
Many thanks for your answer !
I followed job description from your link, thank you.
[i removed all details about errors/retry/found solutions, ...]
All seems now to be OK, But,
now, each time i run a glxinfo, glxgear pygame, or kivy (kivy is may goal), i got :
libGL error: MESA-LOADER: malformed or no PCI ID
libGL error: dlopen /usr/lib/arm-linux-gnueabihf/dri/mali_drm_dri.so failed (/usr/lib/arm-linux-gnueabihf/dri/mali_drm_dri.so: cannot open shared object file: No such file or directory)
libGL error: dlopen ${ORIGIN}/dri/mali_drm_dri.so failed (${ORIGIN}/dri/mali_drm_dri.so: cannot open shared object file: No such file or directory)
libGL error: dlopen /usr/lib/dri/mali_drm_dri.so failed (/usr/lib/dri/mali_drm_dri.so: cannot open shared object file: No such file or directory)
libGL error: unable to load driver: mali_drm_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: mali_drm
and it work, but exactly at begining speed, without any modules or drivers... :-( (ex: glxgears give 51fps)
lsmod give :
Module                  Size  Used by
disp_ump                 850  0
mali_drm                2638  2
cpufreq_userspace       3524  0
drm                   213190  3 mali_drm
mali                  112352  0
bnep                   14462  2
ump                    57103  4 mali,disp_ump
a20_tp                  3365  0
8021q                  18593  0
garp                    6072  1 8021q
stp                     2032  1 garp
llc                     5365  2 stp,garp
hidp                   17640  0
rfcomm                 58686  0
hci_uart               25000  0
bluetooth             264185  12 bnep,hidp,hci_uart,rfcomm
XLOG give :
[    20.829] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    20.830] (II) The server relies on udev to provide the list of input devices.
[    20.830] (II) Loader magic: 0xb6f38f10
[    20.830] (II) Module ABI versions:
[    20.830]    X.Org ANSI C Emulation: 0.4
[    20.830]    X.Org Video Driver: 15.0
[    20.830]    X.Org XInput driver : 20.0
[    20.830]    X.Org Server Extension : 8.0
[    20.831] Initializing built-in extension Generic Event Extension
[    20.831] Initializing built-in extension SHAPE
[    20.831] Initializing built-in extension MIT-SHM
[    20.831] Initializing built-in extension XInputExtension
[    20.831] Initializing built-in extension XTEST
[    20.831] Initializing built-in extension BIG-REQUESTS
[    20.831] Initializing built-in extension SYNC
[    20.831] Initializing built-in extension XKEYBOARD
[    20.831] Initializing built-in extension XC-MISC
[    20.831] Initializing built-in extension SECURITY
[    20.832] Initializing built-in extension XINERAMA
[    20.832] Initializing built-in extension XFIXES
[    20.832] Initializing built-in extension RENDER
[    20.832] Initializing built-in extension RANDR
[    20.832] Initializing built-in extension COMPOSITE
[    20.832] Initializing built-in extension DAMAGE
[    20.832] Initializing built-in extension MIT-SCREEN-SAVER
[    20.832] Initializing built-in extension DOUBLE-BUFFER
[    20.832] Initializing built-in extension RECORD
[    20.832] Initializing built-in extension DPMS
[    20.832] Initializing built-in extension Present
[    20.832] Initializing built-in extension DRI3
[    20.832] Initializing built-in extension X-Resource
[    20.832] Initializing built-in extension XVideo
[    20.832] Initializing built-in extension XVideo-MotionCompensation
[    20.833] Initializing built-in extension SELinux
[    20.833] Initializing built-in extension XFree86-VidModeExtension
[    20.833] Initializing built-in extension XFree86-DGA
[    20.833] Initializing built-in extension XFree86-DRI
[    20.833] Initializing built-in extension DRI2
[    20.833] (II) LoadModule: "glx"
[    20.847] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    20.948] (II) Module glx: vendor="X.Org Foundation"
[    20.948]    compiled for 1.15.1, module version = 1.0.0
[    20.948]    ABI class: X.Org Server Extension, version 8.0
[    20.948] (==) AIGLX enabled
[    20.948] Loading extension GLX
[    20.948] (II) LoadModule: "fbturbo"
[    20.949] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[    20.972] (II) Module fbturbo: vendor="X.Org Foundation"
[    20.973]    compiled for 1.15.1, module version = 0.4.0
[    20.973]    Module class: X.Org Video Driver
[    20.973]    ABI class: X.Org Video Driver, version 15.0
[    20.973] (II) FBTURBO: driver for framebuffer: fbturbo
[    20.973] (++) using VT number 7
[    20.983] (WW) Falling back to old probe method for fbturbo
[    20.983] (II) Loading sub module "fbdevhw"
[    20.983] (II) LoadModule: "fbdevhw"
[    20.984] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    20.988] (II) Module fbdevhw: vendor="X.Org Foundation"
[    20.988]    compiled for 1.15.1, module version = 0.0.2
[    20.988]    ABI class: X.Org Video Driver, version 15.0
[    20.988] (II) FBTURBO(0): using /dev/fb0
[    20.988] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    20.989] (II) FBTURBO(0): Creating default Display subsection in Screen section
[    20.989] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[    20.989] (==) FBTURBO(0): RGB weight 888
[    20.989] (==) FBTURBO(0): Default visual is TrueColor
[    20.989] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[    20.989] (II) FBTURBO(0): hardware:  (video memory: 4800kB)
[    20.989] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[    20.989] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[    20.989] (**) FBTURBO(0): Option "AccelMethod" "G2D"
[    20.990] (II) FBTURBO(0): processor: ARM Cortex-A7
[    20.990] (II) FBTURBO(0): checking modes against framebuffer device...
[    20.990] (II) FBTURBO(0): checking modes against monitor...
[    20.990] (--) FBTURBO(0): Virtual size is 1024x600 (pitch 1024)
[    20.990] (**) FBTURBO(0):  Built-in mode "current": 45.0 MHz, 37.5 kHz, 60.0 Hz
[    20.991] (II) FBTURBO(0): Modeline "current"x0.0   45.00  1024 1040 1050 1200  600 602 604 625 -hsync -vsync -csync (37.5 kHz B)
[    20.991] (==) FBTURBO(0): DPI set to (96, 96)
[    20.991] (II) Loading sub module "fb"
[    20.991] (II) LoadModule: "fb"
[    20.992] (II) Loading /usr/lib/xorg/modules/libfb.so
[    21.000] (II) Module fb: vendor="X.Org Foundation"
[    21.001]    compiled for 1.15.1, module version = 1.0.0
[    21.001]    ABI class: X.Org ANSI C Emulation, version 0.4
[    21.001] (==) Depth 24 pixmap format is 32 bpp
[    21.009] (II) FBTURBO(0): using backing store heuristics
[    21.041] (II) FBTURBO(0): enabled G2D acceleration
[    21.041] (==) FBTURBO(0): Backing store enabled
[    21.048] (==) FBTURBO(0): DPMS enabled
[    21.048] (II) FBTURBO(0): using sunxi disp layers for X video extension
[    21.048] (II) FBTURBO(0): using hardware cursor
[    21.119] (II) Loading sub module "dri2"
[    21.119] (II) LoadModule: "dri2"
[    21.124] (II) Module "dri2" already built-in
[    21.148] (II) FBTURBO(0): tear-free zero-copy double buffering needs more video memory
[    21.148] (II) FBTURBO(0): please set fb0_framebuffer_num >= 3 in the fex file
[    21.148] (II) FBTURBO(0): and sunxi_fb_mem_reserve >= 8 in the kernel cmdline
[    21.148] (II) FBTURBO(0): enabled display controller hardware overlays for DRI2
[    21.148] (II) FBTURBO(0): Wait on SwapBuffers? enabled
[    21.149] (II) FBTURBO(0): [DRI2] Setup complete
[    21.149] (II) FBTURBO(0): [DRI2]   DRI driver: lima
[    21.149] (II) FBTURBO(0): using DRI2 integration for Mali GPU (UMP buffers)
[    21.149] (II) FBTURBO(0): Mali binary drivers can only accelerate EGL/GLES
[    21.149] (II) FBTURBO(0): so AIGLX/GLX is expected to fail or fallback to software
[    21.149] (==) RandR enabled
[    21.185] (II) SELinux: Disabled on system
[    21.200] (EE) AIGLX error: dlopen of /usr/lib/arm-linux-gnueabihf/dri/lima_dri.so failed (/usr/lib/arm-linux-gnueabihf/dri/lima_dri.so: cannot open shared object file: No such file or directory)
[    21.201] (EE) AIGLX: reverting to software rendering
[    21.357] (II) AIGLX: Loaded and initialized swrast
[    21.357] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    21.464] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[    21.483] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/platform/mali_drm.0/drm/card0
[    21.483] (II) xfree86: Adding drm device (/dev/dri/card0)
[    21.483] (II) LoadModule: "modesetting"
[    21.484] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    21.489] (II) Module modesetting: vendor="X.Org Foundation"
[    21.489]    compiled for 1.15.0, module version = 0.8.1
[    21.489]    Module class: X.Org Video Driver
[    21.489]    ABI class: X.Org Video Driver, version 15.0
[    21.490] xf86: found device 0
[    21.491] (II) config/udev: Adding drm device (/dev/dri/card1) card1 /sys/devices/platform/mali_drm.1/drm/card1
[    21.491] (II) xfree86: Adding drm device (/dev/dri/card1)
[    21.491] (II) LoadModule: "modesetting"
[    21.492] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    21.492] (II) Module modesetting: vendor="X.Org Foundation"
[    21.492]    compiled for 1.15.0, module version = 0.8.1
[    21.492]    Module class: X.Org Video Driver
[    21.492]    ABI class: X.Org Video Driver, version 15.0
[    21.492] (II) UnloadModule: "modesetting"
[    21.492] (II) Unloading modesetting
[    21.492] (II) Failed to load module "modesetting" (already loaded, 0)
[    21.493] xf86: found device 0
[    21.496] (II) config/udev: Adding input device axp20-supplyer (/dev/input/event0)
[    21.496] (**) axp20-supplyer: Applying InputClass "evdev keyboard catchall"
[    21.496] (II) LoadModule: "evdev"
[    21.497] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    21.506] (II) Module evdev: vendor="X.Org Foundation"
[    21.506]    compiled for 1.15.0, module version = 2.8.2
[    21.506]    Module class: X.Org XInput Driver
[    21.506]    ABI class: X.Org XInput driver, version 20.0
[    21.506] (II) Using input driver 'evdev' for 'axp20-supplyer'
[    21.506] (**) axp20-supplyer: always reports core events
[    21.506] (**) evdev: axp20-supplyer: Device: "/dev/input/event0"
[    21.506] (--) evdev: axp20-supplyer: Vendor 0x1 Product 0x1
[    21.507] (--) evdev: axp20-supplyer: Found keys
[    21.507] (II) evdev: axp20-supplyer: Configuring as keyboard
[    21.507] (**) Option "config_info" "udev:/sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input0/event0"
[    21.507] (II) XINPUT: Adding extended input device "axp20-supplyer" (type: KEYBOARD, id 6)
[    21.507] (**) Option "xkb_rules" "evdev"
[    21.507] (**) Option "xkb_model" "pc105"
[    21.507] (**) Option "xkb_layout" "be"
[    21.523] (II) XKB: reuse xkmfile /var/lib/xkb/server-BCDBD3DBC93B3E588F97965C4D87FE91FAEC6B41.xkm
[    21.533] (II) config/udev: Adding input device Lite-On Technology Corp. USB Mouse (/dev/input/event1)
[    21.533] (**) Lite-On Technology Corp. USB Mouse: Applying InputClass "evdev pointer catchall"
[    21.533] (II) Using input driver 'evdev' for 'Lite-On Technology Corp. USB Mouse'
[    21.533] (**) Lite-On Technology Corp. USB Mouse: always reports core events
[    21.533] (**) evdev: Lite-On Technology Corp. USB Mouse: Device: "/dev/input/event1"
[    21.533] (--) evdev: Lite-On Technology Corp. USB Mouse: Vendor 0x4ca Product 0x30
[    21.534] (--) evdev: Lite-On Technology Corp. USB Mouse: Found 3 mouse buttons
[    21.534] (--) evdev: Lite-On Technology Corp. USB Mouse: Found scroll wheel(s)
[    21.534] (--) evdev: Lite-On Technology Corp. USB Mouse: Found relative axes
[    21.534] (--) evdev: Lite-On Technology Corp. USB Mouse: Found x and y relative axes
[    21.534] (II) evdev: Lite-On Technology Corp. USB Mouse: Configuring as mouse
[    21.534] (II) evdev: Lite-On Technology Corp. USB Mouse: Adding scrollwheel support
[    21.534] (**) evdev: Lite-On Technology Corp. USB Mouse: YAxisMapping: buttons 4 and 5
[    21.534] (**) evdev: Lite-On Technology Corp. USB Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    21.534] (**) Option "config_info" "udev:/sys/devices/platform/sw-ohci.1/usb3/3-1/3-1:1.0/input/input1/event1"
[    21.534] (II) XINPUT: Adding extended input device "Lite-On Technology Corp. USB Mouse" (type: MOUSE, id 7)
[    21.535] (II) evdev: Lite-On Technology Corp. USB Mouse: initialized for relative axes.
[    21.535] (**) Lite-On Technology Corp. USB Mouse: (accel) keeping acceleration scheme 1
[    21.536] (**) Lite-On Technology Corp. USB Mouse: (accel) acceleration profile 0
[    21.536] (**) Lite-On Technology Corp. USB Mouse: (accel) acceleration factor: 2.000
[    21.536] (**) Lite-On Technology Corp. USB Mouse: (accel) acceleration threshold: 4
[    21.538] (II) config/udev: Adding input device Lite-On Technology Corp. USB Mouse (/dev/input/mouse0)
[    21.538] (II) No input driver specified, ignoring this device.
[    21.538] (II) This device may have been added with another device file.
[    21.541] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event2)
[    21.541] (**)   USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    21.541] (II) Using input driver 'evdev' for '  USB Keyboard'
[    21.541] (**)   USB Keyboard: always reports core events
[    21.541] (**) evdev:   USB Keyboard: Device: "/dev/input/event2"
[    21.542] (--) evdev:   USB Keyboard: Vendor 0x1241 Product 0x1503
[    21.542] (--) evdev:   USB Keyboard: Found keys
[    21.542] (II) evdev:   USB Keyboard: Configuring as keyboard
[    21.542] (**) Option "config_info" "udev:/sys/devices/platform/sw-ohci.2/usb5/5-1/5-1:1.0/input/input2/event2"
[    21.542] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 8)
[    21.542] (**) Option "xkb_rules" "evdev"
[    21.542] (**) Option "xkb_model" "pc105"
[    21.542] (**) Option "xkb_layout" "be"
[    21.546] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event3)
[    21.546] (**)   USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    21.546] (II) Using input driver 'evdev' for '  USB Keyboard'
[    21.546] (**)   USB Keyboard: always reports core events
[    21.546] (**) evdev:   USB Keyboard: Device: "/dev/input/event3"
[    21.546] (--) evdev:   USB Keyboard: Vendor 0x1241 Product 0x1503
[    21.546] (--) evdev:   USB Keyboard: Found keys
[    21.546] (II) evdev:   USB Keyboard: Configuring as keyboard
[    21.546] (**) Option "config_info" "udev:/sys/devices/platform/sw-ohci.2/usb5/5-1/5-1:1.1/input/input3/event3"
[    21.547] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 9)
[    21.547] (**) Option "xkb_rules" "evdev"
[    21.547] (**) Option "xkb_model" "pc105"
[    21.547] (**) Option "xkb_layout" "be"
[    21.567] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/platform/mali_drm.0/drm/card0
[    21.567] (II) xfree86: Adding drm device (/dev/dri/card0)
[    21.567] (II) LoadModule: "modesetting"
[    21.568] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    21.569] (II) Module modesetting: vendor="X.Org Foundation"
[    21.569]    compiled for 1.15.0, module version = 0.8.1
[    21.569]    Module class: X.Org Video Driver
[    21.569]    ABI class: X.Org Video Driver, version 15.0
[    21.569] (II) UnloadModule: "modesetting"
[    21.569] (II) Unloading modesetting
[    21.569] (II) Failed to load module "modesetting" (already loaded, 0)
[    21.569] xf86: found device 0
[    21.570] (II) config/udev: Adding drm device (/dev/dri/card1) card1 /sys/devices/platform/mali_drm.1/drm/card1
[    21.570] (II) xfree86: Adding drm device (/dev/dri/card1)
[    21.570] (II) LoadModule: "modesetting"
[    21.571] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    21.571] (II) Module modesetting: vendor="X.Org Foundation"
[    21.571]    compiled for 1.15.0, module version = 0.8.1
[    21.571]    Module class: X.Org Video Driver
[    21.571]    ABI class: X.Org Video Driver, version 15.0
[    21.571] (II) UnloadModule: "modesetting"
[    21.571] (II) Unloading modesetting
[    21.571] (II) Failed to load module "modesetting" (already loaded, 0)
[    21.571] xf86: found device 0
Any Suggestion ? Thanks.....
I found many poeple talking about LIMA driver... see that glxgear can run up to 150 FPS with this driver on linux A20....
but the link is dead...
Anyone has tried ? Anyone has source file to share ?
Thanks !!!
I was not playing around those features since I don't even use a desktop. The core mission from start is to provide a stable server images. What I read / hear around:
http://limadriver.org/opensource driver but no updates since ... Than we had a problem to compile MALI with kernel sunxi (3.4x) which was on Armibian up to 4.4, with latest 4.5 (kernel named sun7i v3.4.109) it should work but I never try to.
I hope someone else can give you more information regarding this.
the gitourious link to download source redirect to "archive.org" and i cannot found the file to download on this :-(
is LIMA the complement, or a part of MALI ?
not really clear for me.
MALI is for OPEN GL ES2 and LIMA for openGL "normal" ..... ???
