Could you give some more information, run:
lsusb
dmesg | grep usb
sudo apt-get install v4l-utils, after that run v4l2-ctl --all
 ... /dev/video0 is not present ...
v4l2-ctl won't help as there is no video4linux device
IMHO: A problem in the vfe_v4l2 module.
I created a topic with a similar problem (OS Armbian5.25), the solution isn't found yet
I have downgraded (via cmd apt-get install linux-image-sun8i=5.20)to 3.4.112 as suggested by some ppl suggested
root@orangepilite:~# uname -a
Linux orangepilite 3.4.112-sun8i #14 SMP PREEMPT Wed Sep 14 20:29:31 CEST 2016
Now /dev/video0 is present however, altough camera is connected I' getting sensor error:
root@orangepilite:~# dmesg | grep GC2035
[   44.418232] [CSI_ERR][GC2035]sensor_read err at sensor_detect!
[   44.418241] [CSI_ERR][GC2035]chip found is not an target chip.
Maybe it's not a fix. but solved my problem:
1. download https://dl.armbian.com/orangepilite/archive/Armbian_5.20_Orangepilite_Debian_jessie_3.4.112.7z
2. add WiFI connection: wpa_passphrase "ssid" "wirelesskey" >/etc/wpa_supplicant.conf
3. make autconnect on start-up:
   - nano /etc/rc.local
   - add line before "exit 0": sudo wpa_supplicant -B -D nl80211 -i wlan0 -c wpa_supplicant.conf
   - add line before "exit 0": sudo dhclient wlan0
4. reboot
5. after login run: apt-get update
6. reboot
7. after login install drivers:
- sudo modprobe gc2035
- sudo modprobe vfe_v4l2
8. instal your camera program, ie: sudo apt-get install fswebcam
9. grab the pic, ie: fswebcam -r 1280x720 --no-banner image.jpg
Enjoy!
4. reboot
6. reboot
Enjoy!
The camera ceased to work from the Armbian 5.25 version. Now I will try the 5.26 version collected from source codes
In version 5.26 same problem. The camera doesn't work.
root@orangepipc:~# modprobe gc2035
root@orangepipc:~# modprobe vfe_v4l2
root@orangepipc:~# dmesg
...SKIP...
[  157.331945] [iSP] isp platform_id = 5!
[  157.408206] [CSI_ERR][GC2035]sensor_read err at sensor_detect!
[  157.408223] [CSI_ERR][GC2035]chip found is not an target chip.
root@orangepipc:~# uname -a
Linux orangepipc 3.4.113-sun8i #16 SMP PREEMPT Sat Feb 25 18:46:40 +07 2017 armv7l armv7l armv7l GNU/Linux
root@orangepipc:~# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepipc
BOARD_NAME="Orange Pi PC"
VERSION=5.26
LINUXFAMILY=sun8i
BRANCH=default
ARCH=arm
IMAGE_TYPE=stable
UPDATE:
autoconnect unfortunattely does not work as I thought it will. So either you need to type the lines everytime after boot or use a network manager:
http://forum.odroid.com/viewtopic.php?f=52&t=25472&
in terms of camera:
I found that although images/photos are taken, in fact they are blank (or actually solid black)...
Solution of the black image is the file format. the command can capture a good image:
