Hello I have a little problem with the usb devices, i use usb camera and if u plug the power supply to the OPI Lite board (5.25) it recognize the camera but it doesn't work well (stream with like 8-10 fps), after a software reboot, the device go to other Bus and the camera work fine with 15-30 fps stream.
Before reboot, exact on first power of the board:
Bus 006 Device 002: ID 058f:3822 Alcor Micro Corp.
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
After reboot:
Bus 003 Device 002: ID 058f:3822 Alcor Micro Corp.
Bus 002 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
I try to remove and after that load again uvcvideo driver, but nothing happened, i tried some scripts to restart the usb ports but the result was 0, only if i unplug and plug the camera again or reboot solve the problem. Also i tried with different power supplies and nothing changed. Currently we use chargers from the Orange Pi manufacture so this is the best power supply i guess.
Any ideas how can i configure the camera to be on Bus 3 and tha wifi dongle to be on Bus 2 or some other solution to the problem?
