Armbian-Base-Files doesn't build for bullseye
Go to solution Solved by j0ta,
Hi guys!
The armbian-base-files hasn't been generated since v23.11.1 (Beta repositories)
which is crippling new versions for bullseye users
any plan to generated it again ?
Thanks !
https://github.com/armbian/build/pull/5192
https://forum.armbian.com/events/event/33-weekly-developers-meetup/?do=findComment&comment=48
Edited by j0ta
In looking at beta.armbian.com/content.html base-files appears to be missing from the bullseye, mantic and sid repositories.  It is present in bookworm, jammy, noble and trixie.
The armbian-base-files was removed from the beta repositories
when 23.11.x-truck was moved from the beta repository to the main repository
that was the last armbian-base-files produced for bullseye
