nemonein Posted February 26, 2017 Posted February 26, 2017 I'm using CT with Armbian 5.25(mainline) server version. The system hangs on every Sundays, and this is the 3rd time, since it hanged two weeks ago for the first time. When I connected a monitor with it, it says.. mmcblk0 : error -5 sending status command, retrying blk_update_request : I/O error, dev mmcblk0, sector 1503312 .... similar messages are repeated.. I have no idea what causes this. I do not use CRON. I installed these packages. Mpd, nginx, nfs server, samba server, deluge-daemon, pure-ftpd, Resilio Sync. Can anyone help me?
Toast Posted February 26, 2017 Posted February 26, 2017 dumb question perhaps but have you tried another sd card ?
tkaiser Posted February 26, 2017 Posted February 26, 2017 https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-provide-boot-logs-for-inspection
nemonein Posted February 27, 2017 Author Posted February 27, 2017 @tkaiser Thanks. Here's the log. http://sprunge.us/eaYE @Toast If it happens randomly, I would try it.
nemonein Posted February 27, 2017 Author Posted February 27, 2017 The results of armbianmonitor -c $HOME. ........ Starting iozone tests. Be patient, this can take a very long time to complete: Iozone: Performance Test of File I/O Version $Revision: 3.429 $ Compiled for 32 bit mode. Build: linux Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins Al Slater, Scott Rhine, Mike Wisner, Ken Goss Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR, Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner, Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone, Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root, Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer, Vangel Bojaxhi, Ben England, Vikentsi Lapa. Run began: Mon Feb 27 14:57:12 2017 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 512 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 512k -r 16M -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 1151 2766 7293 7306 6765 2958 102400 512 17175 19856 21668 21732 21719 20625 102400 16384 15232 16455 22040 22038 22037 17607 iozone test complete. touch: cannot touch './cardtest.m2rKKL/.starttime': No such file or directory Test stopped, read-only filesystem Please be careful using this media since it seems it's already broken. Exiting test. I don't know why it says read only file system, while it is not. My sd disk is Samsung MICROSDXC 64GB EVO PLUS. Is there something wrong with my sd disk?
tkaiser Posted February 27, 2017 Posted February 27, 2017 I don't know why it says read only file system, while it is not. There's something strange going on. Unfortunately you ran the disk test after providing the output from 'armbianmonitor -u' (we've designed it that '-u' is able to pick up detailed results from '-c' and now this piece of information is missing). In case you've not rebooted in between please provide the output from '-u' again. (-c provides a logfile '/tmp/armbianmonitor_checks_nnn' which contains useful information. But /tmp will be cleared on every reboot)
nemonein Posted February 27, 2017 Author Posted February 27, 2017 @tkaiser Thank you for your concern. Here's another one. Which is the log after I tested armbianmonitor -c. http://sprunge.us/WIRS
tkaiser Posted February 27, 2017 Posted February 27, 2017 @tkaiser Thank you for your concern. Here's another one. Which is the log after I tested armbianmonitor -c. http://sprunge.us/WIRS Thank you. There's a bug in armbianmonitor (but vey low priority to fix it since testing through this was very time consuming). The checks were successfully completed (see the end of the log output) but since your 64GB SD card is mostly filled only ~20GB were tested so maybe there's something wrong with other pages/blocks on the card. The error messages in your 1st post suggest that there's a problem with the card (or card slot, maybe check the seating?)
nemonein Posted February 27, 2017 Author Posted February 27, 2017 I've been using Armbian 5.2x since last December, but I've got this error 3 weeks ago. I'll wait and see if there's an error this Sunday. If so, then try to change the card.. BTW, I don't understand what you meant, "check the seating".
nemonein Posted March 5, 2017 Author Posted March 5, 2017 For anyone who might be interested in.. Yes, another Sunday has come. It did not frozen, and I could connect to CubieTruck with ssh. However most of commands are not woking. ls works, but ps, lsof, reboot, shutdown... now work. I powered down and remove the SD card, and check it on my desktop PC. Here is the result of fsck. $ sudo fsck.ext4 -v -C 0 /dev/sdc1 e2fsck 1.42.13 (17-May-2015) ArmBuntu: 저널 복구중 (Journal recovering, maybe.) Clearing orphaned inode 6490 (uid=0, gid=0, mode=0100644, size=304832) Clearing orphaned inode 9584 (uid=0, gid=0, mode=0100644, size=345164) Clearing orphaned inode 1766981 (uid=999, gid=999, mode=0100600, size=11308) Clearing orphaned inode 1766927 (uid=999, gid=999, mode=0100600, size=2056) Setting free inodes count to 3691751 (was 3691763) Setting free blocks count to 8304046 (was 5050204) ArmBuntu: clean, 70825/3762576 files, 7326034/15630080 blocks There must be something wrong with my SD card. I can change this card to a new one, but I have to visit the Customer center, or send it to them by mail.. Anyway it takes time. I've just reinstall Armbian again, and wait for another Sunday.
nemonein Posted March 13, 2017 Author Posted March 13, 2017 For anyone who might concern. I reinstalled Armbian, and everything works fine so far. If anything happens, I'll post it here. I have no idea what causes this, but I resized(extend the partition to maximum size) the SD card, that could be the reason. This thread might help.
nemonein Posted March 19, 2017 Author Posted March 19, 2017 Another bloody and gloomy sunday. It hangs again. Same error. (I/O error, dev mmcblk0, sector xxxxxxx) Here the log, but nothing special I think. I'll change the SD card with the same one. And have to wait for another Sundays.. Wish me luck! ;-)
