David Str Posted February 27, 2017 Share Posted February 27, 2017 Hi, I am using ARMBIAN 5.25 stable Ubuntu 16.04.2 LTS 3.4.113-sun8i on my Nanopi neo air. uname -a says Linux nanopiair 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l armv7l armv7l GNU/Linux I think, since I made the last apt-get upgrade and rebooted, my bluetooth stopped working. lsmod gives: lsmod Module Size Used by bmp085 3487 0 pcf8591 3363 0 snd_usb_audio 80352 0 snd_hwdep 5562 1 snd_usb_audio snd_usbmidi_lib 17545 1 snd_usb_audio snd_rawmidi 17134 1 snd_usbmidi_lib gspca_ov534 9254 0 gspca_main 19688 1 gspca_ov534 g_serial 27617 2 dhd 666855 0 hidp 12949 0 rfcomm 32879 0 hci_uart 20384 0 bluetooth 174097 5 hidp,hci_uart,rfcomm btrfs 712409 0 on another neo air with older system Linux nanopiair 3.4.113-sun8i #28 SMP PREEMPT Thu Feb 2 02:01:28 CET 2017 armv7l armv7l armv7l GNU/Linux lsmode it said: Module Size Used by bnep 9617 2 bmp085 3487 0 pcf8591 3363 0 g_serial 27617 2 dhd 666855 0 hidp 12949 0 rfcomm 32879 0 hci_uart 20384 1 bluetooth 174097 25 bnep,hidp,hci_uart,rfcomm btrfs 712409 0 I also tried to install a nightly build Armbian_5.26.170227_Nanopiair_Ubuntu_xenial_dev_4.10.0 but there was no bluetooth on this build as well. Any Ideas, what I can do to get my hci0 device back? Thank you very much and best regards, David Link to comment Share on other sites More sharing options...
arox Posted February 27, 2017 Share Posted February 27, 2017 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l armv7l armv7l GNU/Linux Well, is that an officially stable version or a nightly build ? With bluetooth, you always may have to correct a number of things. Check that you have the hciattach process, no power block and no interface down : # ps -ef | grep hciattach # rfkill list # hciconfig hci0 Link to comment Share on other sites More sharing options...
David Str Posted March 3, 2017 Author Share Posted March 3, 2017 Hi, maybe it was not a stable release, I am not too sure about that. But everything worked just fine until the latest apt-get upgrade.. Here are the results from your commands ps -ef | grep hciattach root 2132 2002 0 09:25 pts/0 00:00:00 grep --color=auto hciattach rfkill list 0: sunxi-bt: Bluetooth Soft blocked: no Hard blocked: no 1: phy0: Wireless LAN Soft blocked: no Hard blocked: no 2: brcmfmac-wifi: Wireless LAN Soft blocked: no Hard blocked: no hciconfig hci0 Can't get device info: No such device I have now reverted everything to the release "Armbian_5.25_Nanopiair_Ubuntu_xenial_default_3.4.113.img" which is working. Unfortunately, I now cannot update any software anymore... ;-) Thanks again and best regards, David Link to comment Share on other sites More sharing options...
Igor Posted March 3, 2017 Share Posted March 3, 2017 I don't work much with BT and my positive experiences with Bluetooth are only on modern or mainline kernel(s). I could connect keyboard, mouse and headset over Bluetooth, transfer files from and to mobile ... on desktop. On Odroid XU4 and via Exagear x86 emulator I even managed to establish a Skype call. This particular emulator is crashing on Allwinner boards but BT is operational. On NanopiAir, rather try modern / development image / kernel: https://www.armbian.com/nanopi-neo-air/#nightly You have more chances for BT there ... but this kernel is development and automated nightly build. Remember that. On kernel 3.4.x ... you might need to fix more things. Link to comment Share on other sites More sharing options...
arox Posted March 3, 2017 Share Posted March 3, 2017 Well, in previous working release, you had a "ap6212-bluetooth.service" which started your missing "hciattach" process through systemd. What is missing or bugged in you system is what is (or was in previous version) in script : /etc/init.d/ap6212-bluetooth You can see that you need to do something like : rfkill unblock all echo "0" > /sys/class/rfkill/rfkill0/state echo "1" > /sys/class/rfkill/rfkill0/state echo " " > /dev/$PORT hciattach /dev/ttyS3 bcm43xx 1500000 flow bdaddr 42:29:B1:55:01:01 hciconfig hci0 up (Here, hciattach params are a bit altered to increase serial interface speed and change MAC to enable bnep) If the script exists, try to start it (and always check hci0 is up after bluetoothd start). But it is also possible that the firmware download fails (/etc/firmware/ap6212/4343A0.hcd) or that the uboot config for ttyS3 in script.bin is bad ... Link to comment Share on other sites More sharing options...
David Str Posted April 15, 2017 Author Share Posted April 15, 2017 Hi, thanks very much for your help! I tried the latest nightly today. When I execute root@nanopiair:~# /etc/init.d/ap6212-bluetooth start I get this answer [....] Starting ap6212-bluetooth (via systemctl): ap6212-bluetooth.serviceJob for ap6212-bluetooth.service failed because the control process exited with error code. See "systemctl status ap6212-bluetooth.service" and "journalctl -xe" for details. failed! When I check the given sources: > systemctl status ap6212-bluetooth.service ap6212-bluetooth.service - LSB: Patch firmware for ap6212 adapter Loaded: loaded (/etc/init.d/ap6212-bluetooth; bad; vendor preset: enabled) Active: failed (Result: exit-code) since Fri 2017-04-14 04:57:00 UTC; 23s ago Docs: man:systemd-sysv-generator(8) Process: 1522 ExecStart=/etc/init.d/ap6212-bluetooth start (code=exited, statu Apr 14 04:56:49 nanopiair systemd[1]: Starting LSB: Patch firmware for ap6212 ad Apr 14 04:57:00 nanopiair ap6212-bluetooth[1522]: Initialization timed out. Apr 14 04:57:00 nanopiair ap6212-bluetooth[1522]: bcm43xx_init Apr 14 04:57:00 nanopiair ap6212-bluetooth[1522]: Can't get device info: No such Apr 14 04:57:00 nanopiair systemd[1]: ap6212-bluetooth.service: Control process Apr 14 04:57:00 nanopiair systemd[1]: Failed to start LSB: Patch firmware for ap Apr 14 04:57:00 nanopiair systemd[1]: ap6212-bluetooth.service: Unit entered fai Apr 14 04:57:00 nanopiair systemd[1]: ap6212-bluetooth.service: Failed with resu and root@nanopiair:~# journalctl -xe Apr 14 04:57:57 nanopiair sh[475]: DHCPDISCOVER on eth0 to 255.255.255.255 port Apr 14 04:57:57 nanopiair ntpd[854]: error resolving pool ntp.ubuntu.com: Name o Apr 14 04:58:04 nanopiair dhclient[506]: No DHCPOFFERS received. Apr 14 04:58:04 nanopiair dhclient[506]: No working leases in persistent databas Apr 14 04:58:04 nanopiair sh[475]: No DHCPOFFERS received. Apr 14 04:58:04 nanopiair sh[475]: No working leases in persistent database - sl Apr 14 04:58:04 nanopiair systemd[1]: Reloading OpenBSD Secure Shell server. -- Subject: Unit ssh.service has begun reloading its configuration -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit ssh.service has begun reloading its configuration Apr 14 04:58:04 nanopiair sshd[1236]: Received SIGHUP; restarting. Apr 14 04:58:04 nanopiair systemd[1]: Reloaded OpenBSD Secure Shell server. -- Subject: Unit ssh.service has finished reloading its configuration -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit ssh.service has finished reloading its configuration -- -- The result is done. Apr 14 04:58:04 nanopiair sshd[1236]: Server listening on 0.0.0.0 port 22. Apr 14 04:58:04 nanopiair sshd[1236]: Server listening on :: port 22. Do you have any Idea what is going on? When I try your commands, the first ones will just return, but > echo " " > /dev/$PORT -bash: /dev/: Is a directory Also, if $PORT might be ttys3 then >echo " " > /dev/ttys3 -bash: /dev/ttys3: Input/output error and finally > hciattach /dev/ttyS3 bcm43xx 1500000 flow bdaddr 42:29:B1:55 bcm43xx_init Initialization timed out. root@nanopiair:~# hciconfig hci0 up Can't get device i So, I still cannot get bluethooth running. I do not understand why it was no problem with hte older build? It still works, when I use the SD-Card with that build, but that is apparently no solution for the future. Also, is it only me experiencing this? I would have thought that many buy the AIR for its wireless capabilities?! Anyways, any help greatly appreciated, I am sorry, that I do not understand the UNIX boot procedure enough to make something from your hints... Best, David Link to comment Share on other sites More sharing options...
David Str Posted April 15, 2017 Author Share Posted April 15, 2017 Hi, BTW: When I inspect the bootprocess via serial console I also see the error messages: [FAILED] Failed to start LSB: Patch firmware for ap6212 adapter. See 'systemctl status ap6212-bluetooth.service' for details. So, I have to patch the kernel? How in the world could I do this and why is this necessary (the adapter is the standnard on this machine...) Thanks again & best, David Link to comment Share on other sites More sharing options...
David Str Posted April 15, 2017 Author Share Posted April 15, 2017 Hi guys, latest breakthrough: I just run the script with "status" on th working nanopi, it said -with plenty of other informations- something like hciattach /dev/ttyS3 bcm43xx 115200 flow bdaddr 43:29:B1:55:01:01 When execute this line on the not working system... everything is all right... So it seemed to have something to do with the MAC ADRESS.. but why... and still how do I fix this permanentely? Thanks and best regards, David Link to comment Share on other sites More sharing options...
