Nikolai Asparuhov Posted February 28, 2017 Posted February 28, 2017 Hello, I'm using armbian 5.25 on OPI Lite and wifi dongle 8192cu, after instaling these drivers: https://github.com/pvaret/rtl8192cu-fixes I saw that the interface drop half of the packages.... Can someone provide better drivers or tell me how to fix that? wlan1 Link encap:Ethernet HWaddr 00:13:ef:6b:24:e2 inet addr:192.168.100.7 Bcast:192.168.100.255 Mask:255.255.255.0 inet6 addr: fe80::213:efff:fe6b:24e2/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 -------->>>>>> RX packets:22255 errors:0 dropped:20602 overruns:0 frame:0 TX packets:22 errors:0 dropped:2 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:3853233 (3.6 MiB) TX bytes:2734 (2.6 KiB) And not everytime it takes IP ?!?! Also whatever dongle i use it won't go up automatically and it's necessary to do ifconfig wlan1 down and after that ifconfig wlan1 up
tkaiser Posted February 28, 2017 Posted February 28, 2017 Don't you think providing as much information as possible would be a great idea for others to be able to diagnose your problem? What about 'wlan0'? If it's connected also to 192.168.100.0/24 maybe you already got the culprit.
Nikolai Asparuhov Posted February 28, 2017 Author Posted February 28, 2017 Sorry my bad. ifconfig: wlan1 Link encap:Ethernet HWaddr 00:e0:5d:00:01:a7 inet addr:192.168.100.10 Bcast:192.168.100.255 Mask:255.255.255.0 inet6 addr: fe80::2e0:5dff:fe00:1a7/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:50531 errors:0 dropped:26831 overruns:0 frame:0 TX packets:248 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:13014020 (12 MiB) TX bytes:31587 (30.8 KiB) tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 inet addr:10.8.0.6 P-t-P:10.8.0.5 Mask:255.255.255.255 UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:14 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:100 RX bytes:0 (0.0 TX bytes:1064 (1.0 KiB) wlan0 Link encap:Ethernet HWaddr 42:2a:ec:a5:06:f6 ------- wlan0 is AP inet addr:192.168.42.1 Bcast:192.168.42.255 Mask:255.255.255.0 inet6 addr: fe80::402a:ecff:fea5:6f6/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:17 errors:0 dropped:0 overruns:0 frame:0 TX packets:1 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 lsusb: Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 058f:3822 Alcor Micro Corp. ------- this is usb camera module Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Driver is installed with dkms and with 2 other types of chips it work fine (mt7601 and rtl8188 and they have 0 droped packages) We have like 20 of these 8192cu dongles and with every single one of them the result is fail.....
RagnerBG Posted February 28, 2017 Posted February 28, 2017 I remember i had problems with Realtek wifi module before, but it was RTL8192EU. This site help me a lot - Realtek wireless chipset: install the right driver, but it could be outdated. Isn't 8192cu used in Lamobo R1? If so, there have to be working driver in build system. Where are you from @Nikolai Asparuhov, i am just curious?
