[ Cubieboard] [kernel 4.9.7-sunxi & uboot 2017.01-armbian] stop opn reboot !
On cubieboard 1 with following config :
cubieboard login: root
Password:
Linux cubieboard 4.9.7-sunxi #1 SMP Thu Feb 2 01:52:06 CET 2017 armv7l
  ____      _     _      _                         _
 / ___|   _| |__ (_) ___| |__   ___   __ _ _ __ __| |
| |  | | | | '_ \| |/ _ \ '_ \ / _ \ / _` | '__/ _` |
| |__| |_| | |_) | |  __/ |_) | (_) | (_| | | | (_| |
 \____\__,_|_.__/|_|\___|_.__/ \___/ \__,_|_|  \__,_|
Welcome to ARMBIAN 5.25 stable Debian GNU/Linux 8 (jessie) 4.9.7-sunxi
System load:   0.72             Up time:       49 sec
Memory usage:  4 % of 1002Mb    IP:            192.168.15.15
CPU temp:      36°C
Usage of /:    8% of 15G
After login as root, when i launch reboot command, system hang as follow :
root@cubieboard:~# reboot
[  OK  ] Stopped target Sound Card.
[  OK  ] Removed slice system-ifup.slice.
         Stopping User Manager for UID 0...
         Stopping Authenticate and Authorize Users to Run Privileged Tasks...
[  OK  ] Stopped target Graphical Interface.
         Stopping Entropy daemon using the HAVEGE algorithm...
[  OK  ] Stopped target Multi-User System.
         Stopping Regular background program processing daemon...
         Stopping Network Manager...
         Stopping OpenBSD Secure Shell server...
         Stopping System Logging Service...
         Stopping D-Bus System Message Bus...
[  OK  ] Stopped target Login Prompts.
         Stopping Serial Getty on ttyS0...
         Stopping Getty on tty1...
         Stopping LSB: Start/stop sysstat's sadc...
         Stopping LSB: Starts LIRC daemon....
         Stopping LSB: Start NTP daemon...
         Stopping LSB: Advanced IEEE 802.11 management daemon...
         Stopping LSB: Armbian gathering hardware information...
         Stopping LSB: Set sysfs variables from /etc/sysfs.conf...
         Stopping LSB: disk temperature monitoring daemon...
         Starting Store Sound Card State...
         Starting Unattended Upgrades...
[  OK  ] Stopped Entropy daemon using the HAVEGE algorithm.
[  OK  ] Stopped Regular background program processing daemon.
[  OK  ] Stopped Network Manager.
[  OK  ] Stopped OpenBSD Secure Shell server.
[  OK  ] Stopped System Logging Service.
[  OK  ] Stopped D-Bus System Message Bus.
[  OK  ] Stopped Authenticate and Authorize Users to Run Privileged Tasks.
[  OK  ] Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Slices.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Paths.
[  OK  ] Stopped target Timers.
[  OK  ] Stopped target Sockets.
[  OK  ] Closed Syslog Socket.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Stopped target System Initialization.
         Stopping Restore / save the current clock...
[  OK  ] Stopped target Encrypted Volumes.
         Stopping Update UTMP about System Boot/Shutdown...
         Stopping LSB: Raise network interfaces....
[  OK  ] Stopped target Swap.
         Deactivating swap /var/swap...
[  OK  ] Stopped target Remote File Systems.
[  OK  ] Stopped target Remote File Systems (Pre).
[  OK  ] Stopped Restore / save the current clock.
[  OK  ] Stopped Update UTMP about System Boot/Shutdown.
[  OK  ] Deactivated swap /var/swap.
         Stopping Create Volatile Files and Directories...
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped LSB: Raise network interfaces..
         Stopping Apply Kernel Variables...
[  OK  ] Stopped Apply Kernel Variables.
         Stopping Load Kernel Modules...
[  OK  ] Stopped Load Kernel Modules.
         Stopping Load/Save Random Seed...
[  OK  ] Stopped target Local File Systems.
         Unmounting /run/user/0...
         Unmounting /var/log...
         Unmounting /var/log.hdd...
         Unmounting /tmp...
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Unmounted /run/user/0.
[  OK  ] Unmounted /var/log.
[  OK  ] Unmounted /var/log.hdd.
[  OK  ] Unmounted /tmp.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped target Local File Systems (Pre).
         Stopping Create Static Device Nodes in /dev...
[  OK  ] Stopped Create Static Device Nodes in /dev.
         Stopping Remount Root and Kernel File Systems...
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Reached target Shutdown.
[   62.764016] reboot: Restarting system
U-Boot SPL 2017.01-armbian (Feb 02 2017 - 02:20:16)
DR
[  OK  ] Stopped Serial Getty on ttyS0.
[  OK  ] Stopped Getty on tty1.
[  OK  ] Stopped User Manager for UID 0.
[  OK  ] Stopped LSB: Start/stop sysstat's sadc.
[  OK  ] Stopped LSB: Starts LIRC daemon..
[  OK  ] Stopped LSB: Start NTP daemon.
[  OK  ] Stopped LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Stopped LSB: Armbian gathering hardware information.
[  OK  ] Stopped LSB: Set sysfs variables from /etc/sysfs.conf.
[  OK  ] Stopped LSB: disk temperature monitoring daemon.
[  OK  ] Started Store Sound Card State.
[  OK  ] Started Unattended Upgrades.
         Stopping LSB: set CPUFreq kernel parameters...
[  OK  ] Stopped target Network is Online.
         Stopping Login Service...
[  OK  ] Removed slice user-0.slice.
[  OK  ] Removed slice system-getty.slice.
[  OK  ] Removed slice system-serial\x2dgetty.slice.
         Stopping /etc/rc.local Compatibility...
[  OK  ] Stopped /etc/rc.local Compatibility.
         Stopping Permit User Sessions...
[  OK  ] Stopped Login Service.
[  OK  ] Stopped LSB: set CPUFreq kernel parameters.
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped target Network.
         Stopping LSB: Load kernel modules needed to enable cpufreq scaling...
         Unmounting /tmp...
DR
And the only solution i can use is to disconnect PSU
Thank in advance for your help
Regards
Igor,
Many thanks for your patch. I confirm that this new u-boot (but more older that previous) is ok also for me.
Please note that this new u-boot is :.....
[ 1256.035752] reboot: Restarting system
U-Boot SPL 2016.09-armbian (Oct 23 2016 - 16:18:06)
DRAM: 1024 MiB
CPU: 1008000000Hz, AXI/AHB/APB: 3/2/2
Trying to boot from MMC1
U-Boot 2016.09-armbian (Oct 23 2016 - 16:18:06 +0200) Allwinner Technology
CPU:   Allwinner A10 (SUN4I)
Model: Cubietech Cubieboard
I2C:   ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0
Do you plan to integrate this old release in future cubieboard 1 ?
We tend to find a problem and move on with upstream version, perhaps this is already solved within dev version. Would need to check ...
This is just a workaround.
Wrote on mobile phone
