Can't seem to get the USB redirector to work.  I suspect I have to enable but am unsure of how to do that. I've tried a variety of methods to start the daemon to no effect (I am however new to Linux and systems).   All I can bring up is this message.  I'm using Ubuntu Trusty.
******************** ERROR ***********************
Cannot connect to USB Redirector daemon.
Please make sure usbsrvd is loaded. If the module
is not loaded, please contact our support team.
Error log can be found at /var/log/usbsrvd.log
Any help would be appreciated.
Thanks.
USB redirector stops working on kernel 4.x .. I already notify the author. You need to use legacy kernel.
I have a problem with USB Redirector too...
Try to start the daemon with "sudo  usbsrvd start". Can't see the daemon to be active but have below in /var/log/usbsrvd.log
Wed Dec 31 23:59:22 1969
 Daemon startup
 Daemon can not be started!
Module 0x0003 Line 30 Error 0
 Daemon shutdown
Not sure why date is displayed as Dec 31st 1969 and why time is 23:59:22
Anything I overlooked ? Any action to be performed to enable the service (description indicates: (disabled by default /etc/init.d/rc.usbsrvd))...
Also not sure if the hint "USB redirector stops working on kernel 4.x .." is relevant to my problem. I use Kernel version: 3.14.14 as delivered in version 2.6
Thank you for support
NB: I wouldn't have a problem to re-install USB Redirector, however, I am not sure which one to download and install: armle, armbe, armv5b
