Jean-Marc Posted March 3, 2017 Posted March 3, 2017 Hi, With current cubieboard2 image on SD class 10, local@solo:~$ time sudo dd if=/tmp/Armbian_5.25_Cubieboard2_Debian_jessie_next_4.9.7.img of=/dev/sdb bs=4k 326656+0 enregistrements lus 326656+0 enregistrements écrits 1337982976 octets (1,3 GB) copiés, 317,544 s, 4,2 MB/s not possible to boot on cubieboard2. Please find following log => => U-Boot SPL 2017.01-armbian (Feb 02 2017 - 02:16:44) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2017.01-armbian (Feb 02 2017 - 02:16:44 +0100) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Cubietech Cubieboard2 I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@01c50000 Hit any key to stop autoboot: 0 6944 bytes read in 170 ms (39.1 KiB/s) scanning bus for devices... Found 0 device(s). Device 0: not available starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 2 USB Device(s) found USB device 0: unknown device ethernet@01c50000 Waiting for PHY auto negotiation to complete.. done Speed: 100, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.15.2 (4 ms) *** Warning: no boot file name; using 'C0A80F02.img' Using ethernet@01c50000 device TFTP from server 0.0.0.0; our IP address is 192.168.15.2 Filename 'C0A80F02.img'. Load address: 0x42000000 Loading: T T T T T T T T T T Retry count exceeded; starting again missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/01-02-c5-06-42-04-4b Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/C0A80F02 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/C0A80F0 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/C0A80F Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/C0A80 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/C0A8 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/C0A Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/C0 Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/C Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm Speed: 100, full duplex *** ERROR: `serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default Speed: 100, full duplex *** ERROR: `serverip' not set Config file not found Speed: 100, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.15.2 (3 ms) Using ethernet@01c50000 device TFTP from server 0.0.0.0; our IP address is 192.168.15.2 Filename 'boot.scr.uimg'. Load address: 0x43100000 Loading: * CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7 | VT102 | Déconnecté | Thanks in advance for your help
Igor Posted March 10, 2017 Posted March 10, 2017 4 hours ago, Honor said: Same problem, any fix? I have a banana pro! How much of this document have you read and took into consideration? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card If you can't boot anything, than other rear HW issues are also possible - broken SD card slot for example.
