Tido Posted March 3, 2017 Posted March 3, 2017 Hi, I have 5.25 without armbian updates - just Debian: Linux lamobo-r1 4.9.7-sunxi #1 SMP Thu Feb 2 01:52:06 CET 2017 armv7l GNU/Linux. When I boot the device, it comes up fine, gets its IP-Address on the WAN port. If I try to restart the network it will not come up, I can access via UART but no longer via Network. If I restart the network from the UART again with the same command the Network comes up. This is how it stops: root@lamobo-r1:~# service networking restart Warning: Unit file of networking.service changed on disk, 'systemctl daemon-reload' recommended. less /var/log/syslog | grep NetworkManager: Spoiler root@lamobo-r1:~# less /var/log/syslog | grep NetworkManager Mar 3 21:21:52 localhost NetworkManager[609]: <info> NetworkManager (version 0.9.10.0) is starting... Mar 3 21:21:53 localhost NetworkManager[609]: <info> Read config: /etc/NetworkManager/NetworkManager.conf Mar 3 21:21:53 localhost NetworkManager[609]: <info> WEXT support is enabled Mar 3 21:21:54 localhost NetworkManager[609]: <info> init! Mar 3 21:21:54 localhost NetworkManager[609]: <info> update_system_hostname Mar 3 21:21:54 localhost NetworkManager[609]: <info> interface-parser: parsing file /etc/network/interfaces Mar 3 21:21:54 localhost NetworkManager[609]: <info> interface-parser: finished parsing file /etc/network/interfaces Mar 3 21:21:54 localhost NetworkManager[609]: <info> guessed connection type (eth0) = 802-3-ethernet Mar 3 21:21:54 localhost NetworkManager[609]: Libgcrypt warning: missing initialization - please fix the application Mar 3 21:21:54 localhost NetworkManager[609]: <info> update_connection_setting_from_if_block: name:eth0, type:802-3-ethernet, id:Ifupdown (eth0), uuid: 681b428f-beaf-8932-dce4-687ed5bae28e Mar 3 21:21:54 localhost NetworkManager[609]: <info> adding eth0 to connections Mar 3 21:21:54 localhost NetworkManager[609]: <info> adding iface eth0 to eni_ifaces Mar 3 21:21:54 localhost NetworkManager[609]: <info> autoconnect Mar 3 21:21:54 localhost NetworkManager[609]: <info> management mode: unmanaged Mar 3 21:21:54 localhost NetworkManager[609]: <info> devices added (path: /sys/devices/platform/soc@01c00000/1c1c000.usb/usb2/2-1/2-1:1.0/net/wlan0, iface: wlan0) Mar 3 21:21:54 localhost NetworkManager[609]: <info> device added (path: /sys/devices/platform/soc@01c00000/1c1c000.usb/usb2/2-1/2-1:1.0/net/wlan0, iface: wlan0): no ifupdown configuration found. Mar 3 21:21:54 localhost NetworkManager[609]: <info> devices added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/mdio_bus/stmmac-0/stmmac-0:1e/net/lan1, iface: lan1) Mar 3 21:21:54 localhost NetworkManager[609]: <info> device added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/mdio_bus/stmmac-0/stmmac-0:1e/net/lan1, iface: lan1): no ifupdown configuration found. Mar 3 21:21:54 localhost NetworkManager[609]: <info> devices added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/mdio_bus/stmmac-0/stmmac-0:1e/net/lan2, iface: lan2) Mar 3 21:21:54 localhost NetworkManager[609]: <info> device added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/mdio_bus/stmmac-0/stmmac-0:1e/net/lan2, iface: lan2): no ifupdown configuration found. Mar 3 21:21:54 localhost NetworkManager[609]: <info> devices added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/mdio_bus/stmmac-0/stmmac-0:1e/net/lan3, iface: lan3) Mar 3 21:21:54 localhost NetworkManager[609]: <info> device added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/mdio_bus/stmmac-0/stmmac-0:1e/net/lan3, iface: lan3): no ifupdown configuration found. Mar 3 21:21:54 localhost NetworkManager[609]: <info> devices added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/mdio_bus/stmmac-0/stmmac-0:1e/net/lan4, iface: lan4) Mar 3 21:21:54 localhost NetworkManager[609]: <info> device added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/mdio_bus/stmmac-0/stmmac-0:1e/net/lan4, iface: lan4): no ifupdown configuration found. Mar 3 21:21:54 localhost NetworkManager[609]: <info> devices added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/mdio_bus/stmmac-0/stmmac-0:1e/net/wan, iface: wan) Mar 3 21:21:54 localhost NetworkManager[609]: <info> device added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/mdio_bus/stmmac-0/stmmac-0:1e/net/wan, iface: wan): no ifupdown configuration found. Mar 3 21:21:54 localhost NetworkManager[609]: <info> devices added (path: /sys/devices/platform/soc@01c00000/1c50000.ethernet/net/eth0, iface: eth0) Mar 3 21:21:54 localhost NetworkManager[609]: <info> locking wired connection setting Mar 3 21:21:54 localhost NetworkManager[609]: <info> devices added (path: /sys/devices/virtual/net/lo, iface: lo) Mar 3 21:21:54 localhost NetworkManager[609]: <info> device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found. Mar 3 21:21:54 localhost NetworkManager[609]: <info> end _init. Mar 3 21:21:54 localhost NetworkManager[609]: <info> Loaded plugin ifupdown: (C) 2008 Canonical Ltd. To report bugs please use the NetworkManager mailing list. Mar 3 21:21:54 localhost NetworkManager[609]: <info> Loaded plugin keyfile: (c) 2007 - 2013 Red Hat, Inc. To report bugs please use the NetworkManager mailing list. Mar 3 21:21:54 localhost NetworkManager[609]: <info> (1098416) ... get_connections. Mar 3 21:21:54 localhost NetworkManager[609]: <info> (1098416) ... get_connections (managed=false): return empty list. Mar 3 21:21:54 localhost NetworkManager[609]: <info> get unmanaged devices count: 1 Mar 3 21:21:54 localhost NetworkManager[609]: <info> monitoring kernel firmware directory '/lib/firmware'. Mar 3 21:21:54 localhost NetworkManager[609]: <info> monitoring ifupdown state file '/run/network/ifstate'. Mar 3 21:21:54 localhost NetworkManager[609]: <info> rfkill0: found WiFi radio killswitch (at /sys/devices/platform/soc@01c00000/1c1c000.usb/usb2/2-1/2-1:1.0/ieee80211/phy0/rfkill0) (driver rtl8192cu) Mar 3 21:21:54 localhost NetworkManager[609]: <info> WiFi hardware radio set enabled Mar 3 21:21:54 localhost NetworkManager[609]: <info> WWAN hardware radio set enabled Mar 3 21:21:54 localhost NetworkManager[609]: <info> Loaded device plugin: /usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-wifi.so Mar 3 21:21:54 localhost NetworkManager[609]: <info> Loaded device plugin: /usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-wwan.so Mar 3 21:21:54 localhost NetworkManager[609]: <info> Loaded device plugin: /usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-adsl.so Mar 3 21:21:54 localhost NetworkManager[609]: <info> Loaded device plugin: /usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-bluetooth.so Mar 3 21:21:54 localhost NetworkManager[609]: <info> WiFi enabled by radio killswitch; enabled by state file Mar 3 21:21:54 localhost NetworkManager[609]: <info> WWAN enabled by radio killswitch; enabled by state file Mar 3 21:21:54 localhost NetworkManager[609]: <info> WiMAX enabled by radio killswitch; enabled by state file Mar 3 21:21:54 localhost NetworkManager[609]: <info> Networking is enabled by state file Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lo): link connected Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lo): carrier is ON Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lo): new Generic device (driver: 'unknown' ifindex: 1) Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lo): exported as /org/freedesktop/NetworkManager/Devices/0 Mar 3 21:21:54 localhost NetworkManager[609]: <info> (eth0): link connected Mar 3 21:21:54 localhost NetworkManager[609]: <info> (eth0): carrier is ON Mar 3 21:21:54 localhost NetworkManager[609]: <info> (eth0): new Ethernet device (driver: 'sun7i-dwmac' ifindex: 2) Mar 3 21:21:54 localhost NetworkManager[609]: <info> (eth0): exported as /org/freedesktop/NetworkManager/Devices/1 Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan2): carrier is OFF Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan2): new Ethernet device (driver: 'bcm53xx' ifindex: 3) Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan2): exported as /org/freedesktop/NetworkManager/Devices/2 Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan3): carrier is OFF Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan3): new Ethernet device (driver: 'bcm53xx' ifindex: 4) Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan3): exported as /org/freedesktop/NetworkManager/Devices/3 Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan4): carrier is OFF Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan4): new Ethernet device (driver: 'bcm53xx' ifindex: 5) Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan4): exported as /org/freedesktop/NetworkManager/Devices/4 Mar 3 21:21:54 localhost NetworkManager[609]: <info> (wan): carrier is OFF Mar 3 21:21:54 localhost NetworkManager[609]: <info> (wan): new Ethernet device (driver: 'bcm53xx' ifindex: 6) Mar 3 21:21:54 localhost NetworkManager[609]: <info> (wan): exported as /org/freedesktop/NetworkManager/Devices/5 Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan1): carrier is OFF Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan1): new Ethernet device (driver: 'bcm53xx' ifindex: 7) Mar 3 21:21:54 localhost NetworkManager[609]: <info> (lan1): exported as /org/freedesktop/NetworkManager/Devices/6 Mar 3 21:21:54 localhost NetworkManager[609]: <info> (wlan0): using nl80211 for WiFi device control Mar 3 21:21:54 localhost NetworkManager[609]: <info> (wlan0): driver supports Access Point (AP) mode Mar 3 21:21:54 localhost NetworkManager[609]: <info> (wlan0): new 802.11 WiFi device (driver: 'rtl8192cu' ifindex: 8) Mar 3 21:21:54 localhost NetworkManager[609]: <info> (wlan0): exported as /org/freedesktop/NetworkManager/Devices/7 Mar 3 21:21:54 localhost NetworkManager[609]: <info> (wlan0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2] Mar 3 21:21:55 localhost NetworkManager[609]: <info> (wlan0): preparing device Mar 3 21:21:55 localhost NetworkManager[609]: <info> NetworkManager state is now CONNECTED_GLOBAL Mar 3 21:21:55 localhost NetworkManager[609]: <info> wpa_supplicant started Mar 3 21:21:55 localhost NetworkManager[609]: <info> (wlan0) supports 4 scan SSIDs Mar 3 21:21:55 localhost NetworkManager[609]: <info> (wlan0): supplicant interface state: starting -> ready Mar 3 21:21:55 localhost NetworkManager[609]: <info> (wlan0): device state change: unavailable -> disconnected (reason 'supplicant-available') [20 30 42] Mar 3 21:21:55 localhost NetworkManager[609]: <info> (wlan0): supplicant interface state: ready -> disconnected Mar 3 21:21:55 localhost NetworkManager[609]: <info> (wlan0) supports 4 scan SSIDs Mar 3 21:21:55 localhost NetworkManager[609]: <info> startup complete Mar 3 21:21:57 localhost NetworkManager[609]: <info> (wlan0): supplicant interface state: disconnected -> inactive Mar 3 21:29:34 localhost NetworkManager[609]: <info> NetworkManager state is now DISCONNECTED Mar 3 21:29:34 localhost NetworkManager[609]: <info> (eth0): link disconnected Mar 3 21:29:36 localhost NetworkManager[609]: <info> (eth0): link connected Mar 3 21:35:33 localhost NetworkManager[609]: <info> NetworkManager state is now CONNECTED_GLOBAL less /var/log/syslog | grep dhclient: Spoiler root@lamobo-r1:~# less /var/log/syslog | grep dhclient Mar 3 21:21:51 localhost dhclient: Internet Systems Consortium DHCP Client 4.3.1 Mar 3 21:21:51 localhost dhclient: Copyright 2004-2014 Internet Systems Consortium. Mar 3 21:21:51 localhost dhclient: All rights reserved. Mar 3 21:21:51 localhost dhclient: For info, please visit https://www.isc.org/software/dhcp/ Mar 3 21:21:51 localhost dhclient: Mar 3 21:21:51 localhost dhclient: Listening on LPF/eth0/02:cc:07:02:66:93 Mar 3 21:21:51 localhost dhclient: Sending on LPF/eth0/02:cc:07:02:66:93 Mar 3 21:21:51 localhost dhclient: Sending on Socket/fallback Mar 3 21:21:51 localhost dhclient: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6 Mar 3 21:21:57 localhost dhclient: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 9 Mar 3 21:21:57 localhost dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67 Mar 3 21:21:57 localhost dhclient: DHCPOFFER from 192.168.11.1 Mar 3 21:21:57 localhost dhclient: DHCPACK from 192.168.11.1 Mar 3 21:21:57 localhost dhclient: bound to 192.168.11.3 -- renewal in 39019 seconds. Mar 3 21:29:33 localhost dhclient: Killed old client process Mar 3 21:29:34 localhost dhclient: Internet Systems Consortium DHCP Client 4.3.1 Mar 3 21:29:34 localhost dhclient: Copyright 2004-2014 Internet Systems Consortium. Mar 3 21:29:34 localhost dhclient: All rights reserved. Mar 3 21:29:34 localhost dhclient: For info, please visit https://www.isc.org/software/dhcp/ Mar 3 21:29:34 localhost dhclient: Mar 3 21:29:34 localhost dhclient: Listening on LPF/eth0/02:cc:07:02:66:93 Mar 3 21:29:34 localhost dhclient: Sending on LPF/eth0/02:cc:07:02:66:93 Mar 3 21:29:34 localhost dhclient: Sending on Socket/fallback Mar 3 21:29:34 localhost dhclient: DHCPRELEASE on eth0 to 192.168.11.1 port 67 Mar 3 21:35:33 localhost dhclient: Internet Systems Consortium DHCP Client 4.3.1 Mar 3 21:35:33 localhost dhclient: Copyright 2004-2014 Internet Systems Consortium. Mar 3 21:35:33 localhost dhclient: All rights reserved. Mar 3 21:35:33 localhost dhclient: For info, please visit https://www.isc.org/software/dhcp/ Mar 3 21:35:33 localhost dhclient: Mar 3 21:35:33 localhost dhclient: Listening on LPF/eth0/02:cc:07:02:66:93 Mar 3 21:35:33 localhost dhclient: Sending on LPF/eth0/02:cc:07:02:66:93 Mar 3 21:35:33 localhost dhclient: Sending on Socket/fallback Mar 3 21:35:33 localhost dhclient: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4 Mar 3 21:35:33 localhost dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67 Mar 3 21:35:33 localhost dhclient: DHCPOFFER from 192.168.11.1 Mar 3 21:35:33 localhost dhclient: DHCPACK from 192.168.11.1 Mar 3 21:35:33 localhost dhclient: bound to 192.168.11.3 -- renewal in 33964 seconds. /var/log/armhwinfo.log has been uploaded to http://sprunge.us/gcTT Looking at the logfiles above I cannot see a major problem - do you have an idea what I shall look for ? Is it the wrong restart command because it has systemd and networkmanager?
