I want to build kernel applied with rt-patch. Latest rt-patch version is for 4.9.13. So, How can I get the result? I think I should edit configuration.sh and then, put the patch file to userpatches/kernel directory? I need a kernel for nanopi-neo.
You don't need to edit anything. Just put the patch into:
userpatches/kernel/sun8i-dev
and (try to) recompile kernel.
But we are using developing branch version 4.10.1 ... there is not much support in mainline www.kernel.org ATM.
Thank you, Igor. I got the clean previous script. and newly git clone the package (armbian lib)
Like you said, put the rt-patch in userpatches/kernel/sun8i-dev
and #./compile.sh
Compiling kernel...                                                    │
  │ ./include/linux/compiler.h:168:42: note: in definition of macro ‘unl   │
  │  # define unlikely(x) __builtin_expect(!!(x), 0)                       │
  │ ./include/linux/mutex.h:223:35: warning: comparison between pointer an │
  │   if (unlikely(__mutex_owner(lock) == current))                        │
  │ In file included from ./include/linux/cgroup-defs.h:17:0,              │
  │                  from ./include/linux/sched.h:62,                      │
  │                  from arch/arm/kernel/asm-offsets.c:13:                │
  │ ./include/linux/percpu-rwsem.h: In function ‘percpu_rwsem_release’     │
  │ ./include/linux/percpu-rwsem.h:119:14: error: ‘struct rw_semaphore     │
  │    sem->rw_sem.owner = NULL;                                           │
  │ In file included from ./include/linux/sched.h:62:0,                    │
  │ ./include/linux/cgroup-defs.h: At top level:                           │
  │ ./include/linux/cgroup-defs.h:141:21: error: field ‘destroy_swork’     │
  │   struct swork_event destroy_swork;                                    │
  │ In file included from arch/arm/kernel/asm-offsets.c:13:0:              │
  │ ./include/linux/sched.h: In function ‘mmdrop_delayed’:                 │
  │ ./include/linux/sched.h:2998:15: error: ‘struct mm_struct’ has no      │
  │    call_rcu(&mm->delayed_drop, __mmdrop_delayed);                      │
  │   HOSTCC  scripts/selinux/mdp/mdp                                      │
  │   HOSTCC  scripts/extract-cert                                         │
  │ In file included from ./include/linux/fs.h:14:0,                       │
  │                  from ./include/linux/seq_file.h:10,                   │
  │                  from ./include/linux/pinctrl/consumer.h:17,           │
  │                  from ./include/linux/pinctrl/devinfo.h:21,            │
  │                  from ./include/linux/device.h:24,                     │
  │                  from ./include/linux/dma-mapping.h:6,                 │
  │                  from arch/arm/kernel/asm-offsets.c:15:                │
  │ ./include/linux/radix-tree.h: At top level:                            │
  │ ./include/linux/radix-tree.h:347:20: error: static declaration of ‘r   │
  │  static inline void radix_tree_preload_end(void)                       │
  │ ./include/linux/radix-tree.h:326:6: note: previous declaration of ‘r   │
  │  void radix_tree_preload_end(void);                                    │
  │ cc1: some warnings being treated as errors                             │
  │ make[1]: *** [arch/arm/kernel/asm-offsets.s] Error 1                   │
  │ make: *** [prepare0] Error 2                                           │
  │ make: *** Waiting for unfinished jobs....                              │
  │   HOSTCC  scripts/asn1_compiler                                        │
[ error ] ERROR in function compile_kernel [ common.sh:249 ]
[ error ] Kernel was not built [ @host ]
[ o.k. ] Process terminated
Well, this means patch does not fit the source and you need to adjust it. It might take few minutes or a day.
This will tell you which files have troubles, next you have to manually fix the patch.
cat output/debug/patching.log
If you want to compile a generic kernel this would be a proper way, but not here since:
- decent H3 support exists only in this branch
and
- our patches are aligned only for this branch
