allatutti Posted April 2, 2024 Posted April 2, 2024 If someone is interested can easy setup OledStats for OrangePi5 and SSD1306 Hardware: Orangepi5 SSD1306 OLED display Software Armbian Jammy KDE Neon 6.1.43 Files attached in ZIP archive device.py PixelOperator.ttf setup.py stats.py How to: 1) add overlay wget https://raw.githubusercontent.com/orangepi-xunlong/linux-orangepi/orange-pi-5.10-rk3588/arch/arm64/boot/dts/rockchip/overlay/rk3588-i2c5-m3.dts sudo armbian-add-overlay rk3588-i2c5-m3.dts reboot 2) connect OLED display to I2C5 M3 Pins SDA + SCL (pins 1(VCC),2(SDA),3(SCL) and 5(GND)) check connection sudo i2cdetect -y 5 must be detected 3c value 3) install needed libs sudo apt-get install i2c-tools python3-smbus python3-pip python3-dev python3-pil 4) download main karabek project git clone https://github.com/karabek/OrangePi-OLED cd OrangePi-OLED rename old setup.py mv setup.py setup_old.py 4) create new setup.py or copy from ZIP archive nano setup.py #!/usr/bin/env python from setuptools import setup setup( name="ssd1306", version="0.1.0", author="Richard Hull", author_email="richard.hull@destructuring-bind.org", description="A small library to drive an OLED device with either SSD1306 or SH1106 chipset", license="MIT", keywords="raspberry pi rpi oled ssd1306 sh1106", url="https://github.com/rm-hull/ssd1306", packages=['oled'], ) 5) Start setup.py sudo python3 setup.py sdist 6) copy generated folders to python3 dist packages sudo cp -r OrangePi-OLED/oled/ /usr/local/lib/python3.10/dist-packages/ sudo cp -r OrangePi-OLED/ssd1306.egg-info/ /usr/local/lib/python3.10/dist-packages/ 7) replace device.py file with file in ZIP archive in dist-packages oled folder cd /usr/local/lib/python3.10/dist-packages/oled mv device.py device_old.py 9) copy stats.py and font file PixelOperator.ttf from ZIP archive start stats.py file sudo python3 stats.py result should be same as on RPI device picture Orangepi5_OLED.zip 0 Quote
compent Posted April 3, 2024 Posted April 3, 2024 Very nice and with clearly laid out installation instructions. 0 Quote
allatutti Posted April 5, 2024 Author Posted April 5, 2024 OLED stats working also in debian, you need to activate I2C5 M3 overlay in orangepi-config 0 Quote
allatutti Posted April 9, 2024 Author Posted April 9, 2024 For older Kernel Linux orangepi5 5.10.160-rockchip-rk3588 you will need to install python3-psutil sudo apt install python3-psutil 0 Quote
habro Posted May 19, 2024 Posted May 19, 2024 (edited) "OLED stats working also in debian, you need to activate I2C5 M3 overlay in orangepi-config" By doing above, do you still need to execute point #1 (add overlay) from original instructions? Edited May 19, 2024 by habro 0 Quote
allatutti Posted May 20, 2024 Author Posted May 20, 2024 (edited) nope with original orangepi debian image you dint need to do point 1. Only go to orangepi-config and enable I2C5 M3 there. Edited May 20, 2024 by allatutti 0 Quote
SHIH skshih Posted June 20, 2024 Posted June 20, 2024 Thank you for your detailed instructions! It works for me on my Orange Pi 3 LTS! (but I have to update my port to port=0) in both device.py and stats.py has anyone ever tried it with crontab too? my crontab code is: @reboot cd /home/[user]/ && /usr/bin/python3 /home/[user]/stats.py & When i run the script in crontab, it looks like that it couldn't the font file PixelOperator.ttf if it is run from crontab; my ssd1306 screen lights up, but it only shows gibberish. I even copied PixelOperator.ttf to /usr/share/fonts and /usr/local/share/fonts (and of course there is one in /home/[user]) but it still does not work... 0 Quote
SHIH skshih Posted June 20, 2024 Posted June 20, 2024 I have just managed to get my error log Traceback (most recent call last): File "/home/sqms/stats.py", line 97, in <module> main() File "/home/sqms/stats.py", line 89, in main stats(oled) File "/home/sqms/stats.py", line 79, in stats draw.text((0, 0), hostname(), font=font2, fill=255) ^^^^^^^^^^ File "/home/sqms/stats.py", line 36, in hostname ip_address = output.split()[0] ~~~~~~~~~~~~~~^^^ IndexError: list index out of range 0 Quote
SHIH skshih Posted June 21, 2024 Posted June 21, 2024 After reading a few more and getting to understand what the errors were I've realised what was the reason. from the error log of my post earlier, it seems that the problem comes from the line for getting my ip, but the code seems fine. So it gave me to feeling that my error was caused as crontab code runs before an ip was captured by the system after reboot so instead of my above crontab code, my new code is: Quote @reboot sleep 15 %% /user/bin/python3 /home/sqms/stats.py & >> /home/sqms/error.txt 2>&1 and it works with no issues. 0 Quote
AvisosMike Posted 9 hours ago Posted 9 hours ago Hello, thank you for these clear instructions. Could you tell me where could I find the zip file?, it seems the link if broken. Thank you 0 Quote
