I found "lib/patch/kernel/sun8i-default/30-real-time143-full-plus-rt-fixes.patch.disabled."
So, just renamed it to .patch. and build default (Vendor provided / legacy) of version 3.4.113.
But, showed ERROR.
So, I cleaned scripts and newly git clone armbian lib. but the result is the same.
Here is output log.
Displaying message: Preparing host info
Displaying message: Build host OS release trusty info
## BUILD SCRIPT ENVIRONMENT
Version: 8e605aaaf48a06d74a8e55b1636e51f6893f7b5f
## BUILD CONFIGURATION
Build target:
Board: nanopineo
Branch: default
Kernel configuration:
Repository: https://github.com/igorpecovnik/linux
Branch: branch:sun8i
Config file: linux-sun8i-default
U-boot configuration:
Repository: git://git.denx.de/u-boot.git
Branch: tag:v2017.01
Offset: 1
CPU configuration:
240000 - 912000 with interactive
Displaying message: Syncing clock host info
Displaying message: Downloading sources  info
Displaying message: Checking git sources u-boot v2017.01 info
Displaying message: Creating local copy
Displaying message: Fetching updates
Displaying message: Checking out
Displaying message: Checking git sources linux-sun8i sun8i info
Displaying message: Checking git sources sunxi-tools master info
Displaying message: Compiling sunxi-tools info
Displaying message: Cleaning output/debs for nanopineo default info
Displaying message: Cleaning u-boot/v2017.01 info
Displaying message: Compiling u-boot 2017.01 info
Displaying message: Compiler version arm-linux-gnueabihf-gcc 6.3.1 info
Displaying message: Checking out sources
Displaying message: Started patching process for u-boot sun8i-nanopineo-default info
Displaying message: Looking for user patches in userpatches/u-boot/u-boot-sunxi info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 4kfix-limit-screen-to-full-hd.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] Merrii_Hummingbird_A20.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] a10-a20-lower-dram-clk.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add-awsom-defconfig.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add-bpi-m2plus.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add-lime2-emmc.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add-nanopi-air.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add-nanopi-m1.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add-nanopi-m1plus.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add-nanopi-neo.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add-orangepi-plus2.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add-orangepi-zero.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] disable-usb-keyboards.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] enable-DT-overlays-support.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[33mb\e[0m] enable-old-kernel-compat.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] fix-cubieboard1-defconfig.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] fix-h3-spi-spl-compilation.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] h3-Fix-PLL1-setup-to-never-use-dividers.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] h3-add-disp2-video-driver-configs.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] h3-add-disp2-video-driver-jernej.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] h3-adjust-dram-frequency.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] h3-enable-power-led.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] h3-set-safe-axi_apb-clock-dividers.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] sun8i-set-machid.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] sunxi-boot-splash.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[33mb\e[0m] u-boot-fix-screen-switch.patch succeeded info
Displaying message: Building deb linux-u-boot-nanopineo_5.27_armhf.deb info
Displaying message: Cleaning linux-sun8i/sun8i info
Displaying message: Started patching process for kernel sun8i-default info
Displaying message: Looking for user patches in userpatches/kernel/sun8i-default info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0001-Fix-compilation-problems-with-more-modern-version-of.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0001-Fix-ump-build.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0001-UBUNTU-SAUCE-AppArmor-Add-profile-introspection-file.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0001-hid-Add-new-driver-for-non-compliant-Xin-Mo-devices.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0002-UBUNTU-SAUCE-AppArmor-basic-networking-rules.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0003-UBUNTU-SAUCE-apparmor-Add-the-ability-to-mediate-mou.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0006-sunxi-disp2-FBIO_WAITFORVSYNC-as-a-modifier-for-FBIO.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0010-Import-GMAC_PHY_POWER-support-from-the-loboris-sourc.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0011-gpu-drm-Add-Mali-DX910-SW-99002-r2p4-02rel1.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0012-drm-mali-fix-for-3.4.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0013-gpu-drm-mali_drv-fixed-integration-with-3.x-kernels-.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0015-Fix-paths-to-files-in-src-erroneously-searched-for-i.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0016-gcc5-fixes.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0017-linux-sunxi-add-missing-compiler-gcc5.h-from-master.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0018-orangepi_h3_gc2035_camera.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0023-WIP-remove-vsync_task-from-sunxi-fb-driver.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0024-pwm-sunxi-support-for-H3-as-appears-in-loboris-initi.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0025-h3-hdmi-table-reformatting-for-readability-from-lobo.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0026-h3-hdmi-additional-mode-800x480p-from-lobodis-initia.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0027-h3-hdmi-HDMI_EDID-from-loboris-initial-source-import.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 0028-lower-minimal-dram-clock-to-132-mhz.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.39-40.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.40-41.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.41-42.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.42-43.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.43-44.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.44-45.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.45-46.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.46-47.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.47-48.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.48-49.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.49-50.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.50-51.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.51-52.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.52-53.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.53-54.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.54-55.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.55-56.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.56-57.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.57-58.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.58-59.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.59-60.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.60-61.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.61-62.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.62-63.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.63-64.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.64-65.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.65-66.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.66-67.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.67-68.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.68-69.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.69-70.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.70-71.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.71-72.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.72-73.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.73-74.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.74-75.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.75-76.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.76-77.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.77-78.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.78-79.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.79-80.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.80-81.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.81-82.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.82-83.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.83-84.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.84-85.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.85-86.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.86-87.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.87-88.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.88-89.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.89-90.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.90-91.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.91-92.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.92-93.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.93-94.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.94-95.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.95-96.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.96-97.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.97-98.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.98-99.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0001-patch-3.4.99-100.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0002-patch-3.4.100-101.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0002-patch-3.4.101-102.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0002-patch-3.4.102-103.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0002-patch-3.4.103-104.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0002-patch-3.4.104-105.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0002-patch-3.4.105-106.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0002-patch-3.4.106-107.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0002-patch-3.4.107-108.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0003-linux-sunxi-3.4.108-overlayfs.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0004-patch-3.4.108-109.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0004-patch-3.4.109-110.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0004-patch-3.4.110-111.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0004-patch-3.4.111-112.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0004-patch-3.4.112-113.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0005-backport-firmware-loader.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0007-fbdev-fixes.patch.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0008-backport-lirc-sunxi-driver.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0009-unify-ethernet-settings.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0010-export_read_current_timer.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0011-fbtft_for_older.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0013-w1_h3.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0014-no_dev_console.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-0015-openelec-audio-and-video-fixes.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 02-rtl2832.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] 30-real-time143-full-plus-rt-fixes.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add-mali-r3p0-fixed.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add_8189es_v4.3.18.1_15373.20151005.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] add_8189fs_v4.3.24_15589.20151023.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] bash_to_afterinstall.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] cedar-remove-insecure-code.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] cpufreq-add-more-frequencies.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] disp2-fb-force-soft-cursor.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] enable_g_ether.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] fix-kswapd.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] friendlyarm_audio_able_to_handle_situation_without_audio_pa_ctrl_.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] friendlyarm_crypto_add_CMAC_support_to_CryptoAPI.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] friendlyarm_fix_nanopi-air_sdcard_detect_mode.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] friendlyarm_m1_gigabit.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] friendlyarm_not_print_debug_info_when_camera_is_detached.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] friendlyarm_watchdog_not_print_err_info_when_timeout_is_invalid.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] linux-200-wifi-mac-fix.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] linux-202-bcmdhd-add-wow-selection.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] linux-203-rf_pm-auto-power-on.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] linux-509-support-for-dvbsky-usb-receiver.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] linux-82-fix-build-on-non-amd64-hosts.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] linux-88-enable-tv.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] m2-plus-ap6212-wireless.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] m2-update-bcmdhd-driver.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] make-irq-set-affinity-hint-work-properly.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] matrix-support-Matrix-starter-kit.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] ov5640-enhanced-driver-with-vfe-drc-table-fix.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] packaging-3.4.x-DEFAULT-with-postinstall-scripts.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] packaging-text-fix.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] remove-sunxi-debug.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] sun8i-add-scaling_available_freqs-sysfs-node.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] sun8i-led-behaviour-through-fex.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] sun8i-simple-cpu-corekeeper.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] tbs5520.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] wdt_reduce_logging.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] wireless-opi-zero.patch succeeded info
Displaying message: ... [\e[32ml\e[0m][\e[32mc\e[0m] z-0003-add-additional-video-modes.patch succeeded info
Displaying message: Compiling default kernel 3.4.113 info
Displaying message: Compiler version arm-linux-gnueabihf-gcc 4.8 info
Displaying message: Using kernel config file lib/config/kernel/linux-sun8i-default.config info
Displaying message: ERROR in function compile_kernel common.sh:249 err
Displaying message: Kernel was not built @host err
Displaying message: Process terminated  info
Edited by Igor
Add logs under spoiler
