Skip Login Automatically
Go to solution Solved by nygrule56,
Hello I have an Orange pi Prime and I need help getting it to boot directly to the desktop bypassing the login prompt.  I have been searching for a solution but the threads I've found are pretty outdated.  Is there a way to accomplish this?
No LSB modules are available.
Distributor ID:    Debian
Description:    Armbian 24.2.1 bookworm
Release:    12
Codename:    bookworm
6.6.16-current-sunxi64
Not working so far.  I used this code:
sudo nano /etc/lightdm/lightdm.conf
I found the line #autologin-user=
I uncommented the line using ctrl+shift+d
added my username directly after the =
commented with ctrl+d
saved the file and rebooted.
No change so far.
  • Solution
OK YES!  Got it to work.  The first thing I did was learn what comment and uncommented lines actually mean.  Then I did these steps because there were some differences between the arch linux solutions and debian.
sudo dpkg-reconfigure lightdm
sudo groupadd -r autologin
sudo gpasswd -a YOURUSERNAME autologin
In the lightdm.conf file there is a section called [Seat:*].  I uncommented (activated) these lines:
[Seat:*]
pam-service=lightdm
pam-autologin-service=lightdm-autologin
autologin-user=username
autologin-user-timeout=0
autologin-session=
What I did to retrieve the session type was
echo $DESKTOP_SESSION
Overall, not as easy as flipping a switch but it was a good learning experience.  I'm not sure if there are any unnecessary steps here but it is working as it should.
Thank you, Werner for pointing me in the right direction!
