sambento Posted April 16, 2024 Posted April 16, 2024 Hi everyone, I'm new in this forum. I'm trying to boot armbian on a Mecool KM1 tv box. It's an armlogic S905X3 with 4GB ram,, 32Gb storage. Cant find a viable uboot and dtb combination for it as the usb flashdrive or microSD card simply won't boot. I can, however, run coreelec with no issues. Does anybody had any success with this box? Thanks 0 Quote
maka Posted April 16, 2024 Posted April 16, 2024 It is known that Coreelec modifies the boot and so armbian can not boot. You'll have to restore your device. 0 Quote
sambento Posted April 16, 2024 Author Posted April 16, 2024 Hi! Thanks for replying. I didn't install coreelec actually. I booted from usb flashdrive just for curiosity and it worked. This device was shelved because It was boot looping into android recovery menu and I hadn't the time back then to reinstall stock firmware. A few days ago I decided to try armbian again when I saw a post about coreelec working with this mecool model. And, for my surprise, after i booted into coreelec, it booted into Android TV 10, the stock firmware again. Go figure.... So, the device is working with stock android again and now I'm trying to boot armbian to repurpose this old tvbox as a tiny server for light applications... 0 Quote
SteeMan Posted April 17, 2024 Posted April 17, 2024 If you have ever run coreelec on the box, you will not be able to install Armbian. The coreelec changes the boot environment on emmc in a way incompatible with Armbian. You will need to reinstall an original android firmware which will restore the boot environment if you want to install Armbian. 0 Quote
sambento Posted April 17, 2024 Author Posted April 17, 2024 Hi I didnt install coreelec. The box is still running stock android tv 10 So, I'm looking for a u-boot and dtb combination that will work with this Mecool KM1 model 0 Quote
SteeMan Posted April 17, 2024 Posted April 17, 2024 I didn't say install, I said ran. If you ever ran coreelec on. The box, which above you said you did from the SD card. That changes the boot environment on the EMMC and makes it incompatible with Armbian. 0 Quote
sambento Posted April 17, 2024 Author Posted April 17, 2024 Oh ok Now i understand. Coreelec affects armbian but still runs stock android. I'll try to reset the device to original stock firmware then. So, do you know any working armbian image for this KM1 box? I'll try armbian as soon as I restore the device. 0 Quote
SteeMan Posted April 17, 2024 Posted April 17, 2024 12 minutes ago, sambento said: So, do you know any working armbian image for this KM1 box? I'll try armbian as soon as I restore the device. No clue as I don't have that box. Search the forums for information. As far as build goes, you should be reading the FAQ posts: https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first https://forum.armbian.com/topic/33676-installation-instructions-for-tv-boxes-with-amlogic-cpus 0 Quote
