Orange Pi 5 plus.
It seems that in the 'edge' kernels, ssh is  disabled by  default.
Since HDMI doesn't  function this is a problem.
I used the debugging  UART and after setup I got the message "ssh.service is disabled"
I enabled the service and all is well.
Any reason why ssh would be disabled?
moved
ssh is enabled by default on all images. Check if there is further information in journal why it did not start.
Here is the partial boot log
Starting ssh.service - OpenBSD Secure Shell server...
sshd: no hostkeys available -- exiting.
ssh.service: Control process exited, code=exited, status=1/FAILURE
ssh.service: Failed with result 'exit-code'.
Failed to start ssh.service - OpenBSD Secure Shell server.
ssh.service: Scheduled restart job, restart counter is at 1.
Not sure what to do as keys have not been generated yet.
Thanks, Bill
have you tried to run dpkg-reconfigure openssh-server so a fresh bunch of keys is being generated?
Seems like for some reason key generation fails on first boot....
After first boot and initial setup and login, I can enable and start the openssh server with no problem.
I'm not sure how generating a set of new keys would help.
This happens with numerous images.
Armbian_24.5.0-trunk.429_Orangepi5-plus_trixie_edge_6.8.6_minimal.img
Armbian_24.5.0-trunk.429_Orangepi5-plus_trixie_vendor_6.1.43_minimal.img
Among others.
Legacy image with 5.10.160 kernel does not have this problem
Regards
Bill
Werner
Looks like it's just  trixie.
built an image with Bookworm (bookworm_edge_6.8.7_minimal) and works with no issues so far
Bill
Ah okay. Trixie is an unsupported userspace anyways. So this might be fixed at some point on the way when it reaches stable.
A while ago I debugged the ssh problem and added some comments in this thread here.
I don't remember if I used bookworm or trixie. Seems to me a timing issue or in which order things start.
For now, whenever I do some dev work, I just do either another reboot after the first setup or restart the sshd service.
