rdunkle92 Posted April 20 Share Posted April 20 Visionfive2 booting spi version starfive 5.11.3 firmware. U-boot sees the 8GB RAM. I am using Armbian_community_24.5.0-trunk.433_Visionfive2_jammy_edge_5.15.0_xfce_desktop.img. I suspect there is something broken with the dtb file. I am loading this dtb: load nvme 0:1 ${fdt_addr_r} /boot/dtb/starfive/jh7110-visionfive-v2.dtb When I use OpenBSD 7.5 the 8GB is seen, but that is a different dtb file and EFI boot process. Is there a different dtb file to use? 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted April 20 Share Posted April 20 Moved 0 Quote Link to comment Share on other sites More sharing options...
Solution rdunkle92 Posted May 2 Author Solution Share Posted May 2 Here is my solution. I created a sdcard with u-boot firmware according to the instructions on this webpage: https://docs.u-boot.org/en/latest/board/starfive/visionfive2.html I noticed these instructions will use OpenSBI v1.4. The Starfive firmware is still using OpenSBI v1.2. Flip the boot selector switch on the board ==> to select boot from sdcard. Insert the sdcard created from that u-boot website. Boot the system. It will boot without starting any operating system. U-Boot 2024.07-rc1 (Apr 26 2024 - 10:32:34 +0300) OpenSBI v1.4 Swap the sdcard with the Armbian sdcard. Enter these commands: mmc list mmc dev 1 load mmc 1:1 ${fdt_addr_r} /boot/dtb/starfive/jh7110-visionfive-v2.dtb load mmc 1:1 ${kernel_addr_r} /boot/vmlinuz-5.15.0-edge-starfive2 load mmc 1:1 ${ramdisk_addr_r} /boot/initrd.img-5.15.0-edge-starfive2 setenv bootargs 'root=/dev/mmcblk1p1 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0' setenv kernel_comp_addr_r 0x5a000000 setenv kernel_comp_size 0x04000000 booti $kernel_addr_r $ramdisk_addr_r:$filesize $fdt_addr_r This will boot Armbian and recognize the 8GB RAM. I also found there is a problem recognizing the UUID of the sdcard or nvme during operating system boot. For sdcard boot I needed to edit the /etc/fstab -- switch the UUID to the device name sdcard example: # cat /etc/fstab /dev/mmcblk1p1 / ext4 defaults,noatime,commit=600,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 These instructions also worked with Ubuntu 24.04. I saw the same memory problem as with Armbian. 0 Quote Link to comment Share on other sites More sharing options...
