Stephen Graf Posted April 20 Share Posted April 20 @ag123, @c0rnelius, and anyone else that has interest in sound on these devices. I have been able to put together a patch that enables audio for H161/H618 devices. So far only audio on HDMI works. Analog audio is still generating an error on startup. The patches were taken from a git repository by warpme: https://github.com/warpme/minimyth2/tree/master/script/kernel/linux-6.6/files , and probably came from the Zunlong SDK. A lot of the code was written by Allwinner. @pixdrift generated a version of the patches for Armbian and I continued to work on them. I have built a few images and have a git repository if anyone would like to test, particularly on boards other than orangpizero3, on which I have tested. zero3 desktop: https://drive.google.com/file/d/1jIMTIqKc6y_uuG7lRyXXhIWQ_fvo0XgI/view?usp=drive_link zero3 server: https://drive.google.com/file/d/1r-yn-ooeYoz1yROEJ-yx01_KhErKN_p8/view?usp=drive_link zero2 server: https://drive.google.com/file/d/1XQ9zzw_Bz-rZancDWuzGwMjHHn_4U8SE/view?usp=drive_link repository: https://github.com/stephengraf/armbian_build_sg.git There is another repository mentioned in the Armbian Forum: https://github.com/NickAlilovic/build If anyone has interest and skills to debug the analog audio, the dmesg errors are: [ 7.125509] ahub_dam-snd-soc-dummy-dai: substream ahub_dam-snd-soc-dummy-dai has no playback, no capture [ 7.125539] sunxi-snd-mach soc:ahub_dam_mach: ASoC: can't create pcm ahub_dam-snd-soc-dummy-dai :-22 [ 7.125780] sunxi-snd-mach: probe of soc:ahub_dam_mach failed with error -22 1 Quote Link to comment Share on other sites More sharing options...
ag123 Posted April 21 Share Posted April 21 thanks, I'd probably try that some time. if audio for HDMI works, I think many users will be happy, I've read some comments some are looking for that. currently, I'm using headless as wifi ap, so I did not know if it works. analog may need to go back into h616 zero 2 to see how it is done there, maybe dts etc. 0 Quote Link to comment Share on other sites More sharing options...
robertoj Posted April 26 Share Posted April 26 OrangePi has this analog audio figured out: http://www.orangepi.org/orangepiwiki/index.php/Orange_Pi_Zero_2W#Headphone_interface_audio_playback_test http://www.orangepi.org/orangepiwiki/index.php/Orange_Pi_Zero_3#Headphone_jack_playback_audio_test 0 Quote Link to comment Share on other sites More sharing options...
Stephen Graf Posted April 27 Author Share Posted April 27 7 hours ago, robertoj said: OrangePi has this analog audio figured out: Yes I have tried the Zunlong images for orangepizero3 and they work. Unfortunately those images are for a Linux 6.1 kernel and the zero3 and 2w were only officially implemented into linux with 6.6. The challenge is to get the Zunlong code into Armbian with the newer kernels. 0 Quote Link to comment Share on other sites More sharing options...
SUPA Posted May 7 Share Posted May 7 Hi @Stephen Graf, thank you so much for these images. you are correct. Having audio even on HDMI is extremely useful. Do you perhaps have the kernel headers for this image? https://drive.google.com/file/d/1jIMTIqKc6y_uuG7lRyXXhIWQ_fvo0XgI/view?usp=drive_link Also, Could you create an image for armbian jammy, or provide steps so that i can do it. Armbian_community_24.5.0-trunk.93_Orangepizero3_jammy_current_6.6.18_gnome_desktop.img 0 Quote Link to comment Share on other sites More sharing options...
Stephen Graf Posted May 7 Author Share Posted May 7 6 hours ago, SUPA said: provide steps so that i can do it @SUPA Thank you for testing the patch. I assume it worked and that you are working with an orangepisero3. If you want to build you own images follow the directions in the Armbian build manual: https://docs.armbian.com/Developer-Guide_Build-Preparation/ and clone my repository. Unfortunately I have limited space on my google drive. git clone https://github.com/stephengraf/armbian_build_sg.git 1 Quote Link to comment Share on other sites More sharing options...
SUPA Posted May 8 Share Posted May 8 @Stephen Graf i see that if i use the original kernel source i want to build patched linux-image and linux-header for armbian jammy 6.6.26. It seems to include support for analog audio. I compile and install these using . **************** i have already tested all my components on jammy 6.6.26 thats why I would prefer using it ========================= Here are my cheat sheets: wget https://cdn.kernel.org/pub/linux/kernel/v6.x/linux-6.6.26.tar.xz tar -xvf linux-6.6.26.tar.xz cd ~/src/kernel-source/linux-6.6.26 copy all patches into ~/src/kernel-source/linux-6.6.26 cp /boot/config-$(uname -r) .config patch -p1 < 0606-dma-sun6i-dma-add-h616-support.patch patch -p1 < 0608-sound-soc-sunxi-add-codec-driver-for-h616.patch patch -p1 < 0609-sound-soc-add-sunxi_v2-for-h616-ahub.patch patch -p1 < 0630-arm64-dts-allwinner-h616.dtsi-add-ths-audio-hdmi.patch patch -p1 < 0631-arm64-dts-allwinner-h616-OrangePI-Zero23-enable-ths-hdmi-audio.patch patch -p1 < 0639-arm64-dts-allwinner-h616.dtsi-add-spdif.patch yes "y" | make oldconfig sudo make prepare sudo make clean cd ~/src/kernel-source/linux-6.6.26 sudo make -j$(nproc) bindeb-pkg LOCALVERSION=-custom cd ~/src/kernel-source/ sudo dpkg -i linux-image-6.6.26-custom_6.6.26-gbbc005ee4185-6_arm64.deb sudo dpkg -i linux-headers-6.6.26-custom_6.6.26-gbbc005ee4185-6_arm64.deb sudo dpkg -i linux-libc-dev_6.6.26-gbbc005ee4185-6_arm64.deb ls -l /boot/Image ls -l /boot/uInitrd ln -sf /boot/vmlinuz-6.6.26-custom /boot/Image ln -sf /boot/initrd.img-6.6.26-custom /boot/uInitrd cd ~/src/kernel-source/linux-6.6.26 make dtbs sudo mkdir /boot/dtb-6.6.26-custom/allwinner sudo cp /root/src/kernel-source/linux-6.6.26/arch/arm64/boot/dts/allwinner/*.dtb /boot/dtb-6.6.26-custom/allwinner/ sudo ln -sfn /boot/dtb-6.6.26-custom /boot/dtb sudo reboot now however my board doesnt boot. Do you have any suggestions? maybe u-boot? I have created the needed symlink which I though would be enough for u-boot. Maybe my approach is completely wrong 0 Quote Link to comment Share on other sites More sharing options...
Stephen Graf Posted May 8 Author Share Posted May 8 5 hours ago, SUPA said: i have already tested all my components on jammy 6.6.26 thats why I would prefer using it @SUPAThere is a lot more to building a system than just the kernel. That is what Armbian tries to do for you. I recommend that you use the Armbian build system. You should be able to build the system that you want. The audio patches do include analog audio, but to date there is still a problem and it does not start up. The armbian-config procedure has options to load kernel headers and also source. 1 Quote Link to comment Share on other sites More sharing options...
sasa Posted May 8 Share Posted May 8 (edited) 21.04.2024 в 02:07, Stephen Graf сказал: If anyone has interest and skills to debug the analog audio, the dmesg errors are: [ 7.125509] ahub_dam-snd-soc-dummy-dai: substream ahub_dam-snd-soc-dummy-dai has no playback, no capture [ 7.125539] sunxi-snd-mach soc:ahub_dam_mach: ASoC: can't create pcm ahub_dam-snd-soc-dummy-dai :-22 [ 7.125780] sunxi-snd-mach: probe of soc:ahub_dam_mach failed with error -22 Hi, I think these messages are not related to analog audio, at least on my custom board with t507 processor, analog audio works with this error. You can simply disable them as it was in the linux kernel 6.1 Цитата --- 6.7__sunxi64__arm64-6.7.9/sound/soc/soc-pcm.c 2024-02-21 00:16:07.645017846 +0300 +++ linux-6.7.9-sk/sound/soc/soc-pcm.c 2024-03-16 13:34:42.000000000 +0300 @@ -2867,14 +2867,14 @@ static int soc_get_playback_capture(stru if (dai_link->capture_only) has_playback = 0; - +#if 0 if (!has_playback && !has_capture) { dev_err(rtd->dev, "substream %s has no playback, no capture\n", dai_link->stream_name); return -EINVAL; } - +#endif The sound works for me if I turn it on in the mixer Цитата /usr/bin/amixer -c 0 set 'Left Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Left Output Mixer DACR' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACR' 100% unmute It’s strange, but I have another problem - the sound does not work through HDMI and there is also a problem with reading EDID through the DDC interface. I would be grateful if you could tell me whether automatic detection of monitor or TV resolution via HDMI works for you. Edited May 8 by sasa 1 Quote Link to comment Share on other sites More sharing options...
Stephen Graf Posted May 9 Author Share Posted May 9 5 hours ago, sasa said: whether automatic detection of monitor or TV resolution via HDMI works for you @sasa Many thanks for pointing out that analog sound just has to be enabled! I just tested and it works. I was dreading trying to debug kernel code when I should have been looking at the fundamental "is it turned on?" I will try the patch to remove the other sound error. As to automatic detection, yes on my orangepizero3 with H618 Allwinner SOC, HDMI detects the monitor and sets the proper resolution. 0 Quote Link to comment Share on other sites More sharing options...
sasa Posted May 9 Share Posted May 9 (edited) 6 часов назад, Stephen Graf сказал: yes on my orangepizero3 with H618 Allwinner SOC, HDMI detects the monitor and sets the proper resolution Thanks for confirming. Цитата I will try the patch to remove the other sound error. In fact, my patch does not solve the problem and can only be considered as a temporary solution. I think we need a new driver for the audio multiplexer, for example, as is implemented for NXP processors. https://elixir.bootlin.com/linux/v6.6.30/source/sound/soc/fsl/imx-audmux.c For these processors, the audio multiplexer configuration is described via DT https://elixir.bootlin.com/linux/v6.6.30/source/arch/arm/boot/dts/nxp/imx/imx6qdl-kontron-samx6i.dtsi#L176 Edited May 9 by sasa 0 Quote Link to comment Share on other sites More sharing options...
SUPA Posted May 9 Share Posted May 9 @Stephen Graf I successfully compiled using armbian build. But not sure if i successfully integrated the patches. and also don't know if I used all the correct patches. Could you review and advise please: Here are my steps: sudo apt-get -y -qq install git mkdir ~/src cd ~/src ======================= git hdmi audio patches ======================= git clone https://github.com/warpme/minimyth2.git git clone --depth=1 --branch=main https://github.com/armbian/build mkdir -p ~/src/build/userpatches/kernel/sunxi-current cp ~/src/minimyth2/script/kernel/linux-6.6/files/0600-drivers-h616-wip-add-usb-emac2-support.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0601-drivers-thermal-allwinner-add-h616-ths-support.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0602-media-cedrus-add-H616-variant.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0603-soc-sunxi-sram-Add-SRAM-C1-H616-handling.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0606-dma-sun6i-dma-add-h616-support.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0607-drivers-drm-wip-add-h616-hdmi-jernejsk-24102023.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0608-sound-soc-sunxi-add-codec-driver-for-h616.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0609-sound-soc-add-sunxi_v2-for-h616-ahub.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0615-drivers-iommu-sun50i-iommu-fix-iommu-on-h616.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0630-arm64-dts-allwinner-h616.dtsi-add-ths-audio-hdmi.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0631-arm64-dts-allwinner-h616-OrangePI-Zero23-enable-ths-hdmi-audio.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0639-arm64-dts-allwinner-h616.dtsi-add-spdif.patch ~/src/build/userpatches/kernel/sunxi-current/ cp ~/src/minimyth2/script/kernel/linux-6.6/files/0640-arm64-dts-allwinner-h618-enable-spdif-opi23-tanix-tx6s.patch ~/src/build/userpatches/kernel/sunxi-current/ ls ~/src/build/userpatches/kernel/sunxi-current ========================= armbian build =========================== cd ~/src/build ./compile.sh 0 Quote Link to comment Share on other sites More sharing options...
SUPA Posted May 9 Share Posted May 9 Okay I noted the file path should be ~/src/build/userpatches/kernel/archive/sunxi-6.6. Then it includes them... Nut now I see the patches are not setup correctly for the correct changes. They work when i build from source. But how do I add them patches from https://github.com/warpme/minimyth2/tree/master/script/kernel/linux-6.6/files so they work in Armbian build tool? Sorry if my questions are noob. 0 Quote Link to comment Share on other sites More sharing options...
Stephen Graf Posted May 9 Author Share Posted May 9 9 hours ago, SUPA said: But not sure if i successfully integrated the patches. @SUPA The warpme patches need work to implement into Armbian. That is what I have been trying to do. When and if we get it right, they should be included into the Armbian system. In the meantime clone my repository, which has the patches implemented, and build your flavour of system from there. cd ~/ git clone https://github.com/stephengraf/armbian_build_sg.git cd armbian_build_sg ./compile.sh The HDMI sound should work immediately. The analog needs to be enabled as @sasa suggested: /usr/bin/amixer -c 0 set 'Left Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Left Output Mixer DACR' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACR' 100% unmute 1 Quote Link to comment Share on other sites More sharing options...
Stephen Graf Posted May 9 Author Share Posted May 9 15 hours ago, sasa said: In fact, my patch does not solve the problem and can only be considered as a temporary solution. @sasa I tested with your patch and it gets rid of the error but also creates a new sound device. ahubdam, that has no input or output. I then just took the device creation out of the dtb and then there is no error even without the patch. Analog and HDMI audio still work. This is the piece removed from the dtb. ahub_dam_mach { compatible = "allwinner,sunxi-snd-mach"; soundcard-mach,name = "ahubdam"; status = "okay"; phandle = <0x3f>; soundcard-mach,cpu { sound-dai = <0x0e>; }; soundcard-mach,codec { }; }; 0 Quote Link to comment Share on other sites More sharing options...
SUPA Posted May 10 Share Posted May 10 11 hours ago, Stephen Graf said: @SUPA The warpme patches need work to implement into Armbian. That is what I have been trying to do. When and if we get it right, they should be included into the Armbian system. In the meantime clone my repository, which has the patches implemented, and build your flavour of system from there. cd ~/ git clone https://github.com/stephengraf/armbian_build_sg.git cd armbian_build_sg ./compile.sh The HDMI sound should work immediately. The analog needs to be enabled as @sasa suggested: /usr/bin/amixer -c 0 set 'Left Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Left Output Mixer DACR' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACR' 100% unmute Thank you soooo much Stephan. I realized my error. I had to add the patches with the expected root path. Which was linux6.6. So I had to add my patches here: ~/src/build/userpatches/kernel/sunxi-6.6/linux-6.6/ @sasa Thank you for showing us how to enable audio through the mixer. 0 Quote Link to comment Share on other sites More sharing options...
sasa Posted May 10 Share Posted May 10 8 часов назад, Stephen Graf сказал: ahubdam, that has no input or output This device is used to control the Audio HUB сrossbar switch, for example it makes possible to use external i2s interfaces. https://github.com/elkoni/Opi_Zero_3_I2S3_5.4/blob/main/OpiZero3_I2S_3_mixer.JPG 0 Quote Link to comment Share on other sites More sharing options...
sakesm Posted May 11 Share Posted May 11 Hello, everyone I used your patch @Stephen Graf https://github.com/stephengraf/armbian_build_sg/blob/main/patch/kernel/archive/sunxi-6.6/patches.armbian/sound-soc-h616.patch I found a bug when using it. If I turned on Volume Control in the middle of playing video or audio, the video or audio would suddenly speed up playing, even if I just turned on Volume Control without doing anything,very crazy😂 0 Quote Link to comment Share on other sites More sharing options...
Stephen Graf Posted May 11 Author Share Posted May 11 29 minutes ago, sakesm said: I found a bug @sakesm Yes i came across that also. Can you confirm that it only happens on analog audio and not on HDMI and when using pulseaudio. I also tested with mpg123 and did not have problems using the mpg123 built in volume controls. 0 Quote Link to comment Share on other sites More sharing options...
sakesm Posted May 11 Share Posted May 11 2 hours ago, Stephen Graf said: Can you confirm that it only happens on analog audio and not on HDMI and when using pulseaudio. Sorry, I don't have a device that supports hdmi audio 2 hours ago, Stephen Graf said: I also tested with mpg123 and did not have problems using the mpg123 built in volume controls. I tried to use mpg123 to play audio, but as long as the Volume Control is turned on, the bug also appeared I'm still new to audio and video, so I don't know how to solve it 0 Quote Link to comment Share on other sites More sharing options...
sakesm Posted May 11 Share Posted May 11 In pavucontrol, which is the Configuration in Volume Control, set the second Audio to off and exit. After playing the audio and opening the Volume Control at the same time, this problem will not occur and can be adjusted normally My understanding is that two Audio may have output conflict? 0 Quote Link to comment Share on other sites More sharing options...
Stephen Graf Posted May 11 Author Share Posted May 11 @sakesm Thank you for the update. I don't have a lot of experience with audio either. Usually it just works. With mpg123 you can adjust volume with the + and - keys, which I think do not cause any problems. 0 Quote Link to comment Share on other sites More sharing options...
sasa Posted Wednesday at 04:32 PM Share Posted Wednesday at 04:32 PM 09.05.2024 в 01:40, sasa сказал: the sound does not work through HDMI and there is also a problem with reading EDID through the DDC interface Perhaps it will be interesting to someone - audio on hdmi and edid reading work on the t507 too, there was a problem in our DDC connection scheme. 0 Quote Link to comment Share on other sites More sharing options...
