hi-ko Posted April 25, 2024 Posted April 25, 2024 Im running Armbian 24.2.1 jammy on odroidm1 with additional zfs volumes. On update, sometimes I had to reinstall the zfs kernel module, but now I have the problem, that the system does not recognize the kernel headers: sudo apt-get --reinstall install zfs-dkms Reading package lists... Done Building dependency tree... Done Reading state information... Done 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded. Need to get 2,397 kB of archives. After this operation, 0 B of additional disk space will be used. Get:1 http://mirrors.dotsrc.org/armbian-apt jammy/jammy-utils arm64 zfs-dkms all 2.2.3-1 [2,397 kB] Fetched 2,397 kB in 1s (3,567 kB/s) Preconfiguring packages ... (Reading database ... 72929 files and directories currently installed.) Preparing to unpack .../zfs-dkms_2.2.3-1_all.deb ... Deleting module zfs-2.2.3 completely from the DKMS tree. Unpacking zfs-dkms (2.2.3-1) over (2.2.3-1) ... Setting up zfs-dkms (2.2.3-1) ... Loading new zfs-2.2.3 DKMS files... Building for 6.1.12-rk3568-odroid Module build for kernel 6.1.12-rk3568-odroid was skipped since the kernel headers for this kernel does not seem to be installed. Processing triggers for initramfs-tools (0.140ubuntu13.4) ... update-initramfs: Generating /boot/initrd.img-6.1.12-rk3568-odroid W: Possible missing firmware /lib/firmware/nvidia/tegra194/xusb.bin for built-in driver xhci_tegra W: Possible missing firmware /lib/firmware/nvidia/tegra186/xusb.bin for built-in driver xhci_tegra W: Possible missing firmware /lib/firmware/nvidia/tegra210/xusb.bin for built-in driver xhci_tegra W: Possible missing firmware /lib/firmware/nvidia/tegra124/xusb.bin for built-in driver xhci_tegra update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.1.12-rk3568-odroid Image Name: uInitrd Created: Thu Apr 25 11:27:48 2024 Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 27753116 Bytes = 27102.65 KiB = 26.47 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.1.12-rk3568-odroid to /boot/uInitrd '/boot/uInitrd' -> 'uInitrd-6.1.12-rk3568-odroid' update-initramfs: Armbian: done. I already removed and reinstalled the headers via armbian-config > Headers_remove, Headers_install but without change. apt-get list --installed |grep header linux-headers-edge-rockchip64/jammy,now 24.2.1 arm64 [installed] do I need to create some magic symlinks or parameters for apt-get to get the headers resolved since the kernel version is missing in the package? 0 Quote
hi-ko Posted April 25, 2024 Author Posted April 25, 2024 additional info: in armbian-config I see, that the kernel is frozen (I can't remembere to have that configured) When I select "Defreeze", the dialog just returns and still offers "Defreeze". On a odroidc2 I have similar issue with headers not regognized: In armbian-config of the odroidc2 device the kernel was not frozen so I could update to the latest (6.7.4-edge-meson64) installed headers: linux-headers-current-meson64/jammy,now 24.2.1 arm64 [installed] but `apt-get --reinstall install zfs-dkms` also returns Loading new zfs-2.2.3 DKMS files... Building for 6.7.4-edge-meson64 Module build for kernel 6.7.4-edge-meson64 was skipped since the kernel headers for this kernel does not seem to be installed. 0 Quote
Igor Posted April 25, 2024 Posted April 25, 2024 1 hour ago, hi-ko said: but `apt-get --reinstall install zfs-dkms` also returns Did you reboot after installing headers? I tried on beta software https://paste.armbian.com/ayilamofor and kernel 6.8.7 ... it works https://paste.armbian.com/aqumeheguf.yaml 1 hour ago, hi-ko said: 6.1.12-rk3568-odroid I think this is a problem .... Odroid M1 was merged into rockchip64 kernel ... remove linux-*-edge-rk3568-odroid and install linux-*-edge-rockchip64 and try again. It must work. Tested also on stable branch https://paste.armbian.com/efilumozaq.yaml 0 Quote
Solution hi-ko Posted April 25, 2024 Author Solution Posted April 25, 2024 Thanks @Igor for your help, Zitat Did you reboot after installing headers? yes, I did, but now found out, that installed headers are: /usr/src/linux-headers-6.6.16-current-rockchip64 while kernel still was Linux odroidm1 6.1.12-rk3568-odroid #23.02.2 SMP PREEMPT Sat Feb 18 00:05:38 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux I got my Frozen kernel in armbian-config somehow solved by updating firmware and rebooting several times. Now kernel and headers are in sync again and zfs-module gets loaded! I will need to reanimate my odroidc2, which I use as a standby for the odroidm1, since that device doesn't boot any more after reinstall latest kernel, but that's another story ... Thanks! 1 Quote
