Debian Jessie Build hummingboard-i2ex
Guest sandmen
Gent's,
I try to get a image build the last days, but when the image was created, it fails booting.
On some other try's, it didn't build.
Has in the last time someone build a image ? And is it booting ? :-)
Thanks
Peter
There were some recent changes in u-boot ... but that should not affect. I'll do one test run ... Where it fails?
Guest sandmen
Do you mean the compilation, when ?
Or the boot process.
Currently, compiling on the kernel compile stage.
And booting, no splash screen and nothing !!! No print on uart.
So, it looks like, no u-boot started !?
Looks like U-boot ... I am compiling everything from clean sources ... Will report when done.
What about defective SD card?
Guest sandmen
no, flashed my old image ... :-)
Guest sandmen
Take your time ...
Thanks for your work!
Guest sandmen
Fixed. U-boot was not installing to the SD at all ... for last few days.
Thanks, will check it.
