I have trouble to update armbian with apt upgrade.
(ARMBIAN 5.27.170320 nightly Debian GNU/Linux 8 (jessie) 3.4.113-sun8i)
how to solve?
[ 9 updates to install: apt upgrade ]
New to Armbian? Check the documentation first: docs.armbian.com
Last login: Sun Mar 19 20:01:15 2017 from peter-laptop
root@orangepipc:~# apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  armbian-firmware armbian-tools-jessie hostapd libvdpau1 linux-headers-sun8i
  linux-image-sun8i linux-jessie-root-orangepipc
  linux-u-boot-orangepipc-default sunxi-tools
9 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 20.9 MB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Err http://beta.armbian.com/ jessie/jessie-desktop libvdpau1 armhf 1.1.1-10~armbian5.27.170321+1
  404  Not Found
Err http://beta.armbian.com/ jessie/main armbian-firmware armhf 5.27.170321
  404  Not Found
Err http://beta.armbian.com/ jessie/main armbian-tools-jessie armhf 5.27.170321
  404  Not Found
Err http://beta.armbian.com/ jessie/utils hostapd armhf 1:2.5~armbian5.27.170321+1
  404  Not Found
Err http://beta.armbian.com/ jessie/main linux-headers-sun8i armhf 5.27.170321
  404  Not Found
Err http://beta.armbian.com/ jessie/main linux-image-sun8i armhf 5.27.170321
  404  Not Found
Err http://beta.armbian.com/ jessie/main linux-jessie-root-orangepipc armhf 5.27.170321
  404  Not Found
Err http://beta.armbian.com/ jessie/main linux-u-boot-orangepipc-default armhf 5.27.170321
  404  Not Found
Err http://beta.armbian.com/ jessie/utils sunxi-tools armhf 1.4.2-1~armbian5.27.170321+1
  404  Not Found
E: Failed to fetch http://beta.armbian.com/pool/jessie-desktop/libv/libvdpau/libvdpau1_1.1.1-10~armbian5.27.170321+1_armhf.deb  404  Not Found
E: Failed to fetch http://beta.armbian.com/pool/main/a/armbian-firmware/armbian-firmware_5.27.170321_armhf.deb  404  Not Found
E: Failed to fetch http://beta.armbian.com/pool/main/a/armbian-tools-jessie/armbian-tools-jessie_5.27.170321_armhf.deb  404  Not Found
E: Failed to fetch http://beta.armbian.com/pool/utils/w/wpa/hostapd_2.5~armbian5.27.170321+1_armhf.deb  404  Not Found
E: Failed to fetch http://beta.armbian.com/pool/main/l/linux-upstream/linux-headers-sun8i_5.27.170321_armhf.deb  404  Not Found
E: Failed to fetch http://beta.armbian.com/pool/main/l/linux-upstream/linux-image-sun8i_5.27.170321_armhf.deb  404  Not Found
E: Failed to fetch http://beta.armbian.com/pool/main/l/linux-jessie-root-orangepipc/linux-jessie-root-orangepipc_5.27.170321_armhf.deb  404  Not Found
E: Failed to fetch http://beta.armbian.com/pool/main/l/linux-u-boot-orangepipc-default/linux-u-boot-orangepipc_5.27.170321_armhf.deb  404  Not Found
E: Failed to fetch http://beta.armbian.com/pool/utils/s/sunxi-tools/sunxi-tools_1.4.2-1~armbian5.27.170321+1_armhf.deb  404  Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
root@orangepipc:~#
This beta repository does not have archive. It's populated only with latest versions / rebuild every night and therefore you need to issue apt update right before upgrading. This will rebuild packages index and you will be able to issue upgrade.
Hmmmm, something similar is happening here for the main armbian repository:
Get:1 https://apt.armbian.com/ jessie/main linux-dtb-next-sunxi armhf 5.27.170427 [150 kB]
Err https://apt.armbian.com/ jessie/main linux-dtb-next-sunxi armhf 5.27.170427
  HttpError404
Get:2 https://apt.armbian.com/ jessie/main linux-image-next-sunxi armhf 5.27.170427 [15.9 MB]
Err https://apt.armbian.com/ jessie/main linux-image-next-sunxi armhf 5.27.170427
  HttpError404
E: Failed to fetch https://apt.armbian.com/pool/main/l/linux-4.10.12-sunxi/linux-dtb-next-sunxi_5.27.170427_armhf.deb  HttpError404
E: Failed to fetch https://apt.armbian.com/pool/main/l/linux-4.10.12-sunxi/linux-image-next-sunxi_5.27.170427_armhf.deb  HttpError404
However, this seems to be limited to the two packages "linux-dtb-next-sunxi" and "linux-image-next-sunxi". Not sure if this breaks anything (currently having I2C troubles, but probably they're not related to this). Edited by nkahl
added information
