giga Posted May 5, 2024 Posted May 5, 2024 Hello! I have got the LEMFO RBOX HK1RBOX with rk3528 (https://de.aliexpress.com/item/1005006654505780.html?spm=a2g0o.order_list.order_list_main.32.7cbf5c5fIj4Quv&gatewayAdapt=glo2deu) I have tried the following image recommended in one thread https://github.com/armbian/community/releases/download/24.5.0-trunk.367/Armbian_community_24.5.0-trunk.367_Hinlink-ht2_bookworm_legacy_5.10.160_minimal.img.xz I copied the rockchip folder to the boot folder and as well the a armbianEnv.txt adding dtfile=rockchip/rk3528-hlink-ht2.dtb. The original armbianEnv.txt was modified the same way. that did not work. Did you miss any other steps? Later on I tried I tried Armbian_24.5.0_rockchip_h28k_jammy_5.10.160_server_2024.04.25.img.gz from ophub with rk3528-hlink-ht2.dtb, unfortunately the LAN did not work, even I have tried all other rk3528 dtb's. [LAN error: ....... eth0: stmmac_hw_setup: DMA engine initialisation failed , eth0: stmmac_open Hw setup failed] Is there any img and dtb that works with this TV Box? I would appreciate any hint? 0 Quote
fedes_gl Posted May 8, 2024 Posted May 8, 2024 I have this Rupa X88 13 TV BOX with also uses RK3528, I dumped many parts of firmware using a tool called rkdumper and managed to extract .dtb files using a tool called dtb-extract Maybe this can help you. I don't know how to use those files yet, but reading your post I think I have a hint now 0 Quote
giga Posted May 9, 2024 Author Posted May 9, 2024 Thanks for your reply! I am going to give a try! 0 Quote
fedes_gl Posted May 10, 2024 Posted May 10, 2024 On 5/5/2024 at 6:38 AM, giga said: Later on I tried I tried Armbian_24.5.0_rockchip_h28k_jammy_5.10.160_server_2024.04.25.img.gz from ophub with rk3528-hlink-ht2.dtb, Did you try to play a video through HDMI? was sound present? You can use a USB flash (pendrive) to try it. As, I understand, the RK3528 is not working with HDMI audio (in my case neither GPU acceleration for videoplayback, it plays but it's choppy). 0 Quote
giga Posted May 19, 2024 Author Posted May 19, 2024 Hi Fedes_gl! HDMI is working, but I could not play any video or audio due to missing applications and any internet connection. 0 Quote
337043613 Posted June 5, 2024 Posted June 5, 2024 No matter which DTB I use, HDMI doesn't respond. What's going on? 0 Quote
Panda Posted July 26, 2024 Posted July 26, 2024 I have the same box, but with 4/64 and I havent sucess to boot the image, maybe I'm missing someting, I put the SD card on the box and turn on, but after 10 minutes no HDMI screen, I havent yet connected by TTL. Can someone share an image of SD Card so, I can try? Or maybe write a step by step how to create the SD Card, I follow the guide of the forum, without success. Even multiboot does not boot. Regards Panda 0 Quote
