Nico21311 Posted May 6 Share Posted May 6 Hello all I have broken my installation when I tried to install the kernel 6.1 my current kernel 5.10.160-legacy-rk35xx. My nanopc t6 do not start. My installation is on EMMC and start on it. Could you please help me to recover it ? I have a backup file from OMV but I don't know how to push the backup to the EMMC? other possibility I guess copy the boot folder backup to EMMC boot folder but I do not know if it is enough. I really appreciate an help furthermore a clear turial could help evryone to recover an installation on EMMC memory. Thanks in advance for your support. 0 Quote Link to comment Share on other sites More sharing options...
fever_wits Posted May 11 Share Posted May 11 Hello. I also had such a problem some time ago. I don't know how much experience you have with linux. Probably missing the /boot stuff. You can try the following, but it's a bit risky. You make an mmc card with arbian and kernel 6.1.XX. and you start nanopc from it. After it loads. You put in a USB to SD card adapter. In the new memory card, after loading the OS, create an OMV folder, in it /OMV/boot and /OMV/os/ in it you create /OMV/boot and /OMV/os/ rsync -va /boot/ /OMV/boot/ mv /OMV/os/lib/modules/6.1.43-vendor-rk35xx /OMV/os/lib/modules/6.1.43-vendor-rk35xx_old rsync -va /lib/modules/6.1.43-vendor-rk35xx /OMV/os/lib/modules/ After that, umount /OMV/boot and /OMV/os/, put the OMV card in the nanopc and if you're lucky, it might start. I hope I was helpful and good luck 0 Quote Link to comment Share on other sites More sharing options...
Nico21311 Posted May 15 Author Share Posted May 15 Hello Fever_wits Thanks you for your answer. I tried to reinstall an Armbian image with SD but the device never boot. when I use an official image all working well. Could you help me to recover the the possibility to install armbian image ? Thanks in advance for your support. 0 Quote Link to comment Share on other sites More sharing options...
Nico21311 Posted May 19 Author Share Posted May 19 I have reinstall the device and the docker. However, I need to install the firmware 5.10.160. Indeed the nanopc-t6 don ot star with any image with firmware 6.1.43 or 6.8.9. I do not understand why ?. Apprently I understand that you are able to install the version 6.1.43 without issue. Could you please explain me the procedure you have used ? Thanks in advance for your support. 0 Quote Link to comment Share on other sites More sharing options...
