i'm having a problem i don't understand.
i'm using @balbes150 armbian ubuntu xenial image for s905 (sticky thread above) on nexbox a95x s905 1G/8G box.
the system runs from sdcard without problems, i've been using a previous debian image for about 6 months without any problems.
i recently had to modify the box physical setup and touching it (simply pluging an usb cable), the power connector switched off (very annoying thing about those a95x boxes).
After that the system would not boot again (no screen display) so i simply figured the sdcard got corrupted.
that's what seems to have happened as using a serial connector i get the kernel boot message which at some point hangs and breaks like this :
Give root password for maintenance
(or press Control-D to continue):
last lines :
  Reveal hidden contents
i have attached the full boot log.
so i tried fsck.ext4 and it gives me that on the live system :
root@amlogic-s905x:~
 fsck.ext4 -n -f /dev/mmcblk1p2
e2fsck 1.42.13 (17-May-2015)
Warning!  /dev/mmcblk1p2 is mounted.
Warning: skipping journal recovery because doing a read-only filesystem check.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Free blocks count wrong (3307614, counted=3307612).
Fix? no
Free inodes count wrong (868976, counted=868974).
Fix? no
ROOTFS: 57168/926144 files (0.1% non-contiguous), 479298/3786912 blocks
here's my mount output on the live system :
not sure what that one is about :
/dev/mmcblk1p2 on /var/log.hdd type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600)
touch /forcefsck, did not fix the problem.
the boot process seems to always hang at the same point, then fail to recovery login.
But when checking the sdcard i my ubuntu desktop, i don't get any fsck errors.
So i'm wondering what's going on..
thx
screenlog.0.recovery
I don't know, that's just my guess, but I've read somewhere that this model often does not properly soldered USB connector (switched contacts) and the circuit, until the burn-in USB port or the device connected. Possible after such disconnection may be corrupted office files that are physically intact, but have not the correct information.
okay it's weird, i don't think the sdcard is corrupted at all.
it looks like it fails to recovery login because of a fstab entry !?
while configuring my new sdcard, i got the same problem after a clean reboot.
As the only thing i changed was the fstab file, i just commented the USB disk line and then it booted again..
PARTUUID=9ca0ead7-01    /media/USBLinux         ext4    rw,noatime,nodiratime,data=writeback 0 0
This is a usb disc that was not plugged in..
Of course adding "noauto" solves the problem but that's not what i want.
Is this a normal ubuntu 16.04 behaviour ?
the system boots but stops at  :
systemd[1]: Mounting Configuration File System...
[   10.139505@3] systemd[1]: Started Load/Save Random Seed.
[   10.159503@3] systemd[1]: Reached target Swap.
[   10.175676@3] systemd[1]: Started Create Static Device Nodes in /dev.
[   10.177515@0] sdio: new high speed SDIO card at address 0001
[   10.177685@1] sdio: clock 50000000, 4-bit-bus-width
[   10.177685@1]
[   10.177686@1] [sdio_reinit] finish
[   10.229372@1] aml_nftl_dev: module license 'Proprietary' taints kernel.
[   10.234908@3] systemd[1]: Reached target Local File Systems (Pre).
[   10.243565@2] Disabling lock debugging due to kernel taint
[   10.259088@3] systemd[1]: Mounting /tmp...
[   10.272425@3] systemd[1]: Starting udev Kernel Device Manager...
[   10.285815@3] systemd[1]: Mounted /tmp.
[   10.297885@3] systemd[1]: Started Load Kernel Modules.
[   10.317779@3] systemd[1]: Starting Apply Kernel Variables...
[   10.330854@3] systemd[1]: Mounting Configuration File System...
this is simply because it can't mount that USBLinux partition (which s not connected to the box) as set in fstab.
it just drops to maintenance prompt ..
here's some debug info showing that nothing should be wrong on that system :
i've attached, the fstab error boot and full correct boot serial data.
looking at the end, this is the only thing different :
[   10.479897@1] systemd[1]: Mounting Configuration File System...
[   10.495994@1] systemd[1]: Starting Apply Kernel Variables...
[   10.522178@1] systemd[1]: Mounted Configuration File System.
Ubuntu 16.04.2 LTS amlogic-s905x ttyS0
amlogic-s905x login:
i don't remember that all fstab (non system) entries absolutely have to be present, in order for the system to fully boot .. ?
Am i wrong ?
[ there seem to be some differences between 14.04 and 16.04 with mountall ]
screenlog.fstaberror
screenlog.fullboot
Now I realized what it was. Add in the fstab line to mount a USB key, which disables the verification of the presence of the device (nofail)
PARTUUID=9ca0ead7-01    /media/USBLinux         ext4    rw,noatime,nodiratime,nofail,data=writeback 0 0
thx it worked
it's also recommended to use x-systemd.device-timeout=1 along with nofail, otherwise timeout is 90 sec, but here the boot won't wait for that timeout.
Also it adds a "TIME" error to the boot log..
for your info
it looks like the "nofail" option (with or without x-systemd.device-timeout) produces weird behaviors when mounting the drive.
it will often fail to actually mount it without reporting an error.
When executing the command manually after the system has booted, mount executes without error, you can see the drive flashing but the mount point is not set.
i reverted to "noauto", which prevents boot failure and mount from rc.local or manually will not fail.
