Lion Wang Posted May 9, 2024 Posted May 9, 2024 Banana Pi BPI-M5 Pro adopts the second-generation 8nm high-performance AIOT platform Rockchip RK3576, with a 6 TOPS computing power NPU and support for up to 32GB of large memory. It supports 8K video encoding and decoding, offers rich interfaces including dual gigabit Ethernet ports, WiFi 6 & BT5, and various video outputs. Compatible with multiple operating systems, it is suitable for ARM-based PCs, edge computing devices, personal mobile internet devices, and other digital multimedia applications. Key Parameter SoC: Rockchip RK3576 CPU: Integrated with four Cortex-A72 cores @ 2.2GHz and four Cortex-A53 cores @ 1.8GHz, along with a separate NEON co-processor. GPU: ARM Mali G52 MC3 GPU NPU: Up to 6 TOPs computing power (INT8), supports INT4/INT8/INT16 mixed operations. VPU/Encoding & Decoding: Hardware Decoding: Supports H.264, H.265, VP9, AV1, and AVS2 up to 8K@30fps or 4K@120fps. Hardware Encoding: Supports H.264 and H.265 up to 4K@60fps, high-quality JPEG encoder/decoder supports up to 4K@60fps. RAM: 8/16GB 32-bit LPDDR4x, default is 16GB. RK3576 supports a maximum of 16GB. Flash: 32/128GB eMMC, default is 128GB eMMC. Operating Voltage: Wide input voltage range, from 4.5V to 23V (voltage error ±5%). Operating Temperature: 0°C to 80°C Operating Systems: Official Rockchip Support: Android 14, Debian 11, Buildroot Third-party Support: Armbian PCB: 8-layer PCB board design Weight: 43g Dimensions: 92mm × 62mm 0 Quote
Lion Wang Posted May 9, 2024 Author Posted May 9, 2024 wiki page: https://docs.banana-pi.org/en/BPI-M5/BananaPi_BPI-M5_Pro 0 Quote
ArnAbbas Posted September 23, 2024 Posted September 23, 2024 Where is Armbian OS download link for this model? I can see only for regular M5, not PRO. 0 Quote
Igor Posted September 23, 2024 Posted September 23, 2024 On 9/23/2024 at 5:25 PM, ArnAbbas said: Where is Armbian OS download link for this model? I can see only for regular M5, not PRO. Expand This board is also known as armsom-sige5. Images are here: Reveal hidden contents 0 Quote
