Ben S Posted May 9, 2024 Posted May 9, 2024 (edited) Hi, In a bid to solve an issue with my NAS (which I now think was a dying HDD) I foolishly decided to upgrade from buster to bullseye and now most, if not all, of the services are failing to start - including network-manager, sshd and fancontrol so I only have access via the USB serial console. By setting a static IP I have been able to get it network access at least. When I try to start any of the dead services it hangs for a minute or so, then kicks me back to the login and the terminal is corrupted so I need to reboot before I'm able to do anything meaningful. (I am able to start fancontrol by just running `fancontrol` at which point the fans stop going at 100%, so I don't think there's a config issue there at least.) Please help! The upgrade was done with sudo sed -i 's#/debian-security bullseye/updates# bullseye-security#g' /etc/apt/sources.list sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*.list sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d.save/*.list apt full-upgrade root@helios2:~# cat /etc/apt/sources.list deb http://deb.debian.org/debian bullseye main contrib non-free # deb-src http://deb.debian.org/debian bullseye main contrib non-free deb http://deb.debian.org/debian bullseye-updates main contrib non-free # deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free deb http://deb.debian.org/debian bullseye-backports main contrib non-free # deb-src http://deb.debian.org/debian bullseye-backports main contrib non-free # deb http://security.debian.org/ bullseye/updates main contrib non-free deb http://security.debian.org/debian-security bullseye-security main contrib non-free # deb-src http://security.debian.org/ bullseye/updates main contrib non-free root@helios2:~# cat /etc/apt/sources.list.d/* deb http://apt.armbian.com bullseye main bullseye-utils bullseye-desktop deb [signed-by=/etc/apt/trusted.gpg.d/gluster.gpg] https://download.gluster.org/pub/gluster/glusterfs/LATEST/Debian/10/arm64/apt buster main deb [signed-by=/etc/apt/trusted.gpg.d/gluster.gpg] https://download.gluster.org/pub/gluster/glusterfs/LATEST/Debian/10/arm64/apt bullseye main deb http://ppa.launchpad.net/gluster/glusterfs-7/ubuntu oracular main # deb-src http://ppa.launchpad.net/gluster/glusterfs-7/ubuntu oracular main It looks like ix.io is down right now so I can't share `armbianmonitor -u` root@helios2:~# uname -a Linux helios2 5.15.93-rockchip64 #23.02.2 SMP PREEMPT Fri Feb 17 23:48:36 UTC 2023 aarch64 GNU/Linux root@helios2:~# systemctl status --all | grep dead -C 3 │ ├─1435 /sbin/sulogin │ ├─1436 bash │ ├─5144 systemctl status --all │ └─5145 grep dead -C 3 ├─dev-hugepages.mount └─system-getty.slice -- ● dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device - /dev/disk/by-uuid/406e7e7d-9517-44af-bcde-4de3adbc6b80 Loaded: loaded Active: inactive (dead) ● dev-disk-by\x2duuid-9b0108f1\x2d5a11\x2d4f24\x2dabd0\x2daebb458ebbd7.device - ST4000DM004-2CV104 1 Follow: unit currently follows state of sys-devices-platform-f8000000.pcie-pci0000:00-0000:00:00.0-0000:01:00.0-ata2-host1-target1:0:0-1:0:0:0-block-sda-sda1.device -- ● data-glusterfs-sda1.mount - /data/glusterfs/sda1 Loaded: loaded (/etc/fstab; generated) Active: inactive (dead) Where: /data/glusterfs/sda1 What: /dev/disk/by-uuid/406e7e7d-9517-44af-bcde-4de3adbc6b80 Docs: man:fstab(5) -- ● proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System Loaded: loaded (/lib/systemd/system/proc-sys-fs-binfmt_misc.mount; static; vendor preset: enabled) Active: inactive (dead) Where: /proc/sys/fs/binfmt_misc What: binfmt_misc Docs: https://www.kernel.org/doc/html/latest/admin-guide/binfmt-misc.html -- ● bootsplash-ask-password-console.path - Dispatch Password Requests to Console Directory Watch when bootsplash is active Loaded: loaded (/lib/systemd/system/bootsplash-ask-password-console.path; enabled; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:42:45 BST; 23min ago └─ ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled was not met Unit apparmor.service could not be found. ● systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch Loaded: loaded (/lib/systemd/system/systemd-ask-password-console.path; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-ask-password-console.service(8) ● systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch Loaded: loaded (/lib/systemd/system/systemd-ask-password-wall.path; static; vendor preset: enabled) Active: inactive (dead) since Thu 2024-05-09 20:44:16 BST; 22min ago Docs: man:systemd-ask-password-console.service(8) Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable. -- ● apt-daily-upgrade.service - Daily apt upgrade and clean activities Loaded: loaded (/lib/systemd/system/apt-daily-upgrade.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:apt(8) ● apt-daily.service - Daily apt download activities Loaded: loaded (/lib/systemd/system/apt-daily.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:apt(8) ● armbian-firstrun-config.service - Armbian first run optional user configuration Loaded: loaded (/lib/systemd/system/armbian-firstrun-config.service; enabled; vendor preset: enabled) Active: inactive (dead) ● armbian-hardware-monitor.service - Armbian hardware monitoring Loaded: loaded (/lib/systemd/system/armbian-hardware-monitor.service; enabled; vendor preset: enabled) Unit auditd.service could not be found. Unit connman.service could not be found. Unit console-screen.service could not be found. -- ● bootsplash-ask-password-console.service - Dispatch Password Requests to Console when bootsplash is active Loaded: loaded (/lib/systemd/system/bootsplash-ask-password-console.service; static; vendor preset: enabled) Active: inactive (dead) ● bootsplash-hide-when-booted.service - Hide bootsplash after starting the system Loaded: loaded (/lib/systemd/system/bootsplash-hide-when-booted.service; enabled; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:44:16 BST; 22min ago └─ ConditionPathExists=/sys/devices/platform/bootsplash.0/enabled was not met ● chrony.service - chrony, an NTP client/server Loaded: loaded (/lib/systemd/system/chrony.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:chronyd(8) man:chronyc(1) man:chrony.conf(5) -- ● cpufrequtils.service - LSB: set CPUFreq kernel parameters Loaded: loaded (/etc/init.d/cpufrequtils; generated) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) ● cron.service - Regular background program processing daemon Unit display-manager.service could not be found. Loaded: loaded (/lib/systemd/system/cron.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:cron(8) ● dbus.service - D-Bus System Message Bus Loaded: loaded (/lib/systemd/system/dbus.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:dbus-daemon(1) ● e2scrub_all.service - Online ext4 Metadata Check for All Filesystems Loaded: loaded (/lib/systemd/system/e2scrub_all.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:e2scrub_all(8) ● e2scrub_reap.service - Remove Stale Online ext4 Metadata Check Snapshots Loaded: loaded (/lib/systemd/system/e2scrub_reap.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:e2scrub_all(8) ● emergency.service - Emergency Shell -- ├─1435 /sbin/sulogin ├─1436 bash ├─5144 systemctl status --all └─5145 grep dead -C 3 May 09 20:44:21 helios2 systemd[579]: emergency.service: Executable /bin/plymouth missing, skipping: No such file or directory May 09 20:48:11 helios2 sudo[1764]: root : TTY=ttyS2 ; PWD=/root ; USER=root ; COMMAND=/usr/bin/apt info armbian-bsp-cli-helios64 -- ● fake-hwclock.service Loaded: masked (Reason: Unit fake-hwclock.service is masked.) Active: inactive (dead) ● fancontrol.service - fan speed regulator Loaded: loaded (/lib/systemd/system/fancontrol.service; enabled; vendor preset: enabled) Drop-In: /etc/systemd/system/fancontrol.service.d └─pid.conf Active: inactive (dead) Docs: man:fancontrol(8) man:pwmconfig(8) ● getty-static.service - getty on tty2-tty6 if dbus and logind are not available Loaded: loaded (/lib/systemd/system/getty-static.service; static; vendor preset: enabled) Active: inactive (dead) ● getty@tty1.service - Getty on tty1 Loaded: loaded (/lib/systemd/system/getty@.service; enabled; vendor preset: enabled) Drop-In: /usr/lib/systemd/system/getty@tty1.service.d └─10-noclear.conf Active: inactive (dead) Docs: man:agetty(8) man:systemd-getty-generator(8) http://0pointer.de/blog/projects/serial-console.html ● glusterd.service - GlusterFS, a clustered file-system server Loaded: loaded (/lib/systemd/system/glusterd.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:glusterd(8) ● haveged.service - Entropy Daemon based on the HAVEGE algorithm Unit kbd.service could not be found. Unit lm-sensors.service could not be found. -- ● helios64-heartbeat-led.service - Enable heartbeat & network activity led on Helios64 Loaded: loaded (/etc/systemd/system/helios64-heartbeat-led.service; enabled; vendor preset: enabled) Active: inactive (dead) ● hostapd.service - LSB: Advanced IEEE 802.11 management daemon Loaded: loaded (/etc/init.d/hostapd; generated) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) ● ifup@eth0.service - ifup for eth0 -- ● loadcpufreq.service - LSB: Load kernel modules needed to enable cpufreq scaling Loaded: loaded (/etc/init.d/loadcpufreq; generated) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) ● logrotate.service - Rotate log files Loaded: loaded (/etc/systemd/system/logrotate.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:logrotate(8) man:logrotate.conf(5) ● man-db.service - Daily man-db regeneration Loaded: loaded (/lib/systemd/system/man-db.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:mandb(8) ● mountkernfs.service Unit ntp.service could not be found. Unit ntpsec.service could not be found. Unit openntpd.service could not be found. Unit plymouth-quit-wait.service could not be found. Unit plymouth-start.service could not be found. Loaded: masked (Reason: Unit mountkernfs.service is masked.) Active: inactive (dead) ● networkd-dispatcher.service - Dispatcher daemon for systemd-networkd Loaded: loaded (/lib/systemd/system/networkd-dispatcher.service; enabled; vendor preset: enabled) Active: inactive (dead) ● networking.service - Raise network interfaces Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor preset: enabled) -- ● NetworkManager.service - Network Manager Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:NetworkManager(8) ● rc-local.service - /etc/rc.local Compatibility Loaded: loaded (/lib/systemd/system/rc-local.service; enabled-runtime; vendor preset: enabled) Drop-In: /usr/lib/systemd/system/rc-local.service.d └─debian.conf Active: inactive (dead) Docs: man:systemd-rc-local-generator(8) ● rescue.service - Rescue Shell Loaded: loaded (/lib/systemd/system/rescue.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:sulogin(8) ● resolvconf.service - Nameserver information manager -- ● rng-tools-debian.service - LSB: rng-tools (Debian variant) Loaded: loaded (/etc/init.d/rng-tools-debian; generated) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) ● rpcbind.service - RPC bind portmap service -- ● rsync.service - fast remote file copy program daemon Loaded: loaded (/lib/systemd/system/rsync.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:rsync(1) man:rsyncd.conf(5) ● rsyslog.service - System Logging Service Loaded: loaded (/lib/systemd/system/rsyslog.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:rsyslogd(8) https://www.rsyslog.com/doc/ ● selinux-autorelabel-mark.service - Mark the need to relabel after reboot Loaded: loaded (/lib/systemd/system/selinux-autorelabel-mark.service; static; vendor preset: enabled) Active: inactive (dead) ● serial-getty@ttyS2.service - Serial Getty on ttyS2 Loaded: loaded (/lib/systemd/system/serial-getty@ttyS2.service; enabled; vendor preset: enabled) Drop-In: /usr/lib/systemd/system/serial-getty@.service.d └─10-term.conf Active: inactive (dead) Docs: man:agetty(8) man:systemd-getty-generator(8) http://0pointer.de/blog/projects/serial-console.html ● ssh.service - OpenBSD Secure Shell server Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:sshd(8) man:sshd_config(5) ● sysfsutils.service - LSB: Set sysfs variables from /etc/sysfs.conf Loaded: loaded (/etc/init.d/sysfsutils; generated) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) ● systemd-ask-password-console.service - Dispatch Password Requests to Console Loaded: loaded (/lib/systemd/system/systemd-ask-password-console.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-ask-password-console.service(8) ● systemd-ask-password-wall.service - Forward Password Requests to Wall Loaded: loaded (/lib/systemd/system/systemd-ask-password-wall.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-ask-password-console.service(8) ● systemd-binfmt.service - Set Up Additional Binary Formats Loaded: loaded (/lib/systemd/system/systemd-binfmt.service; static; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:42:46 BST; 23min ago ├─ ConditionDirectoryNotEmpty=|/lib/binfmt.d was not met ├─ ConditionDirectoryNotEmpty=|/usr/lib/binfmt.d was not met -- ● systemd-fsck-root.service - File System Check on Root Device Loaded: loaded (/lib/systemd/system/systemd-fsck-root.service; enabled-runtime; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:42:46 BST; 23min ago └─ ConditionPathExists=!/run/initramfs/fsck-root was not met Docs: man:systemd-fsck-root.service(8) ● systemd-fsckd.service - File System Check Daemon to report status Loaded: loaded (/lib/systemd/system/systemd-fsckd.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-fsckd.service(8) ● systemd-hwdb-update.service - Rebuild Hardware Database Loaded: loaded (/lib/systemd/system/systemd-hwdb-update.service; static; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:42:46 BST; 23min ago ├─ ConditionPathExists=|!/lib/udev/hwdb.bin was not met ├─ ConditionPathExists=|/etc/udev/hwdb.bin was not met -- ● systemd-initctl.service - initctl Compatibility Daemon Loaded: loaded (/lib/systemd/system/systemd-initctl.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-initctl.service(8) ● systemd-journal-flush.service - Flush Journal to Persistent Storage -- ● systemd-logind.service - Login Service Loaded: loaded (/lib/systemd/system/systemd-logind.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-logind.service(8) man:logind.conf(5) https://www.freedesktop.org/wiki/Software/systemd/logind -- ● systemd-machine-id-commit.service - Commit a transient machine-id on disk Loaded: loaded (/lib/systemd/system/systemd-machine-id-commit.service; static; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Thu 2024-05-09 20:44:16 BST; 22min ago └─ ConditionPathIsMountPoint=/etc/machine-id was not met Docs: man:systemd-machine-id-commit.service(8) -- ● systemd-networkd.service - Network Service Loaded: loaded (/lib/systemd/system/systemd-networkd.service; disabled; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-networkd.service(8) ● systemd-random-seed.service - Load/Save Random Seed Unit systemd-update-done.service could not be found. -- Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: enabled) Drop-In: /usr/lib/systemd/system/systemd-timesyncd.service.d └─disable-with-time-daemon.conf Active: inactive (dead) Docs: man:systemd-timesyncd.service(8) ● systemd-tmpfiles-clean.service - Cleanup of Temporary Directories Loaded: loaded (/lib/systemd/system/systemd-tmpfiles-clean.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:tmpfiles.d(5) man:systemd-tmpfiles(8) -- ● systemd-update-utmp-runlevel.service - Update UTMP about System Runlevel Changes Loaded: loaded (/lib/systemd/system/systemd-update-utmp-runlevel.service; static; vendor preset: enabled) Active: inactive (dead) since Thu 2024-05-09 20:44:19 BST; 22min ago Docs: man:systemd-update-utmp.service(8) man:utmp(5) Process: 1357 ExecStart=/lib/systemd/systemd-update-utmp runlevel (code=exited, status=0/SUCCESS) Unit systemd-vconsole-setup.service could not be found. -- ● systemd-user-sessions.service - Permit User Sessions Loaded: loaded (/lib/systemd/system/systemd-user-sessions.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd-user-sessions.service(8) ● unattended-upgrades.service - Unattended Upgrades Shutdown Loaded: loaded (/lib/systemd/system/unattended-upgrades.service; enabled; vendor preset: enabled) Active: inactive (dead) Docs: man:unattended-upgrade(8) ● wpa_supplicant.service - WPA supplicant Loaded: loaded (/lib/systemd/system/wpa_supplicant.service; enabled; vendor preset: enabled) Active: inactive (dead) ● -.slice - Root Slice Loaded: loaded -- │ ├─1435 /sbin/sulogin │ ├─1436 bash │ ├─5144 systemctl status --all │ └─5145 grep dead -C 3 ├─haveged.service │ └─1354 /usr/sbin/haveged --Foreground --verbose=1 ├─rpcbind.service -- │ ├─1435 /sbin/sulogin │ ├─1436 bash │ ├─5144 systemctl status --all │ └─5145 grep dead -C 3 ├─haveged.service │ └─1354 /usr/sbin/haveged --Foreground --verbose=1 ├─rpcbind.service -- ● dbus.socket - D-Bus System Message Bus Socket Loaded: loaded (/lib/systemd/system/dbus.socket; static; vendor preset: enabled) Active: inactive (dead) Listen: /run/dbus/system_bus_socket (Stream) ● rpcbind.socket - RPCbind Server Activation Socket -- ● syslog.socket - Syslog Socket Loaded: loaded (/lib/systemd/system/syslog.socket; static; vendor preset: disabled) Active: inactive (dead) since Thu 2024-05-09 20:44:16 BST; 22min ago Docs: man:systemd.special(7) https://www.freedesktop.org/wiki/Software/systemd/syslog Listen: /run/systemd/journal/syslog (Datagram) Unit armbian-hardware-monitor.target could not be found. Unit armbian-ramlog.target could not be found. -- ● basic.target - Basic System Loaded: loaded (/lib/systemd/system/basic.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● cryptsetup.target - Local Encrypted Volumes -- ● getty-pre.target - Login Prompts (Pre) Loaded: loaded (/lib/systemd/system/getty-pre.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) man:systemd-getty-generator(8) http://0pointer.de/blog/projects/serial-console.html -- ● graphical.target - Graphical Interface Loaded: loaded (/lib/systemd/system/graphical.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● local-fs-pre.target - Local File Systems (Pre) -- ● local-fs.target - Local File Systems Loaded: loaded (/lib/systemd/system/local-fs.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● multi-user.target - Multi-User System Loaded: loaded (/lib/systemd/system/multi-user.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● network-online.target - Network is Online -- ● nss-user-lookup.target - User and Group Name Lookups Loaded: loaded (/lib/systemd/system/nss-user-lookup.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● paths.target - Paths -- ● rescue.target - Rescue Mode Loaded: loaded (/lib/systemd/system/rescue.target; static; vendor preset: disabled) Active: inactive (dead) Docs: man:systemd.special(7) ● rpcbind.target - RPC Port Mapper -- ● shutdown.target - Shutdown Loaded: loaded (/lib/systemd/system/shutdown.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) Unit syslog.target could not be found. ● slices.target - Slices -- ● sysinit.target - System Initialization Loaded: loaded (/lib/systemd/system/sysinit.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● time-sync.target - System Time Synchronized -- ● umount.target - Unmount All Filesystems Loaded: loaded (/lib/systemd/system/umount.target; static; vendor preset: enabled) Active: inactive (dead) Docs: man:systemd.special(7) ● apt-daily-upgrade.timer - Daily apt upgrade and clean activities Loaded: loaded (/lib/systemd/system/apt-daily-upgrade.timer; enabled; vendor preset: enabled) Active: inactive (dead) Trigger: n/a ● apt-daily.timer - Daily apt download activities Loaded: loaded (/lib/systemd/system/apt-daily.timer; enabled; vendor preset: enabled) Active: inactive (dead) Trigger: n/a ● e2scrub_all.timer - Periodic ext4 Online Metadata Check for All Filesystems Loaded: loaded (/lib/systemd/system/e2scrub_all.timer; enabled; vendor preset: enabled) Active: inactive (dead) Trigger: n/a ● logrotate.timer - Daily rotation of log files Loaded: loaded (/lib/systemd/system/logrotate.timer; enabled; vendor preset: enabled) Active: inactive (dead) Trigger: n/a Docs: man:logrotate(8) man:logrotate.conf(5) ● man-db.timer - Daily man-db regeneration Loaded: loaded (/lib/systemd/system/man-db.timer; enabled; vendor preset: enabled) Active: inactive (dead) Trigger: n/a Docs: man:mandb(8) ● systemd-tmpfiles-clean.timer - Daily Cleanup of Temporary Directories Loaded: loaded (/lib/systemd/system/systemd-tmpfiles-clean.timer; static; vendor preset: enabled) Active: inactive (dead) Trigger: n/a Docs: man:tmpfiles.d(5) man:systemd-tmpfiles(8) root@helios2:~# dmesg [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.15.93-rockchip64 (root@cf2b4ed83279) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #23.02.2 SMP PREEMPT Fri Feb 17 23:48:36 UTC 2023 [ 0.000000] Machine model: Helios64 [ 0.000000] efi: UEFI not found. [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] NUMA: NODE_DATA [mem 0xf77cc100-0xf77cdfff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 128 MiB at 0x00000000e9000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 29 pages/cpu s80984 r8192 d29608 u118784 [ 0.000000] pcpu-alloc: s80984 r8192 d29608 u118784 alloc=29*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 999432 [ 0.000000] Policy zone: DMA [ 0.000000] Kernel command line: root=UUID=d82ec6f7-ac67-4a80-a092-295ebfdbbd1d rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=306d94a6-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 0.000000] Unknown kernel command line parameters "ubootpart=306d94a6-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] Memory: 3807704K/4061184K available (16000K kernel code, 2692K rwdata, 6712K rodata, 4352K init, 593K bss, 122408K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] trace event string verifier disabled [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] ITS [mem 0xfee20000-0xfee3ffff] [ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @500000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000000004d0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000004e0000 [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.002149] Console: colour dummy device 80x25 [ 0.002217] printk: console [tty1] enabled [ 0.002334] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.002357] pid_max: default: 32768 minimum: 301 [ 0.002492] LSM: Security Framework initializing [ 0.002532] Yama: becoming mindful. [ 0.002673] AppArmor: AppArmor initialized [ 0.002821] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.002859] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.006959] rcu: Hierarchical SRCU implementation. [ 0.008549] Platform MSI: interrupt-controller@fee20000 domain created [ 0.009124] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.011444] EFI services will not be available. [ 0.012340] smp: Bringing up secondary CPUs ... [ 0.013479] Detected VIPT I-cache on CPU1 [ 0.013547] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.013571] GICv3: CPU1: using allocated LPI pending table @0x00000000004f0000 [ 0.013645] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.015135] Detected VIPT I-cache on CPU2 [ 0.015203] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.015226] GICv3: CPU2: using allocated LPI pending table @0x0000000000580000 [ 0.015297] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.016845] Detected VIPT I-cache on CPU3 [ 0.016912] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.016935] GICv3: CPU3: using allocated LPI pending table @0x0000000000590000 [ 0.017005] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.018500] CPU features: detected: Spectre-v2 [ 0.018513] CPU features: detected: Spectre-v3a [ 0.018520] CPU features: detected: Spectre-v4 [ 0.018525] CPU features: detected: Spectre-BHB [ 0.018534] CPU features: detected: ARM erratum 1742098 [ 0.018540] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.018546] Detected PIPT I-cache on CPU4 [ 0.018583] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.018601] GICv3: CPU4: using allocated LPI pending table @0x00000000005a0000 [ 0.018648] CPU4: Booted secondary processor 0x0000000100 [0x410fd082] [ 0.020015] Detected PIPT I-cache on CPU5 [ 0.020061] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.020081] GICv3: CPU5: using allocated LPI pending table @0x00000000005b0000 [ 0.020127] CPU5: Booted secondary processor 0x0000000101 [0x410fd082] [ 0.020300] smp: Brought up 1 node, 6 CPUs [ 0.020338] SMP: Total of 6 processors activated. [ 0.020348] CPU features: detected: 32-bit EL0 Support [ 0.020355] CPU features: detected: 32-bit EL1 Support [ 0.020365] CPU features: detected: CRC32 instructions [ 0.047134] CPU: All CPU(s) started at EL2 [ 0.047234] alternatives: patching kernel code [ 0.050385] devtmpfs: initialized [ 0.066010] Registered cp15_barrier emulation handler [ 0.066036] Registered setend emulation handler [ 0.066050] KASLR disabled due to lack of seed [ 0.066262] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.066340] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.069355] pinctrl core: initialized pinctrl subsystem [ 0.070018] DMI not present or invalid. [ 0.070887] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.075546] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.077236] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.080044] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.080138] audit: initializing netlink subsys (disabled) [ 0.080417] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1 [ 0.081677] thermal_sys: Registered thermal governor 'fair_share' [ 0.081686] thermal_sys: Registered thermal governor 'bang_bang' [ 0.081693] thermal_sys: Registered thermal governor 'step_wise' [ 0.081699] thermal_sys: Registered thermal governor 'user_space' [ 0.082180] cpuidle: using governor menu [ 0.082456] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.082689] ASID allocator initialised with 65536 entries [ 0.084016] Serial: AMBA PL011 UART driver [ 0.114072] platform ff770000.syscon:phy@f780: Fixing up cyclic dependency with fe330000.mmc [ 0.117339] platform ff8f0000.vop: Fixing up cyclic dependency with fec00000.dp [ 0.118666] platform ff900000.vop: Fixing up cyclic dependency with fec00000.dp [ 0.131544] rockchip-gpio ff720000.gpio0: probed /pinctrl/gpio0@ff720000 [ 0.132340] rockchip-gpio ff730000.gpio1: probed /pinctrl/gpio1@ff730000 [ 0.133048] rockchip-gpio ff780000.gpio2: probed /pinctrl/gpio2@ff780000 [ 0.133824] rockchip-gpio ff788000.gpio3: probed /pinctrl/gpio3@ff788000 [ 0.134539] rockchip-gpio ff790000.gpio4: probed /pinctrl/gpio4@ff790000 [ 0.159716] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.159732] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.159741] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.159750] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.165441] cryptd: max_cpu_qlen set to 1000 [ 0.244392] raid6: neonx8 gen() 1666 MB/s [ 0.312551] raid6: neonx8 xor() 1222 MB/s [ 0.380726] raid6: neonx4 gen() 1727 MB/s [ 0.448881] raid6: neonx4 xor() 1269 MB/s [ 0.517055] raid6: neonx2 gen() 1541 MB/s [ 0.585216] raid6: neonx2 xor() 1177 MB/s [ 0.653386] raid6: neonx1 gen() 1200 MB/s [ 0.721555] raid6: neonx1 xor() 932 MB/s [ 0.789715] raid6: int64x8 gen() 1001 MB/s [ 0.857912] raid6: int64x8 xor() 577 MB/s [ 0.926047] raid6: int64x4 gen() 1001 MB/s [ 0.994213] raid6: int64x4 xor() 591 MB/s [ 1.062378] raid6: int64x2 gen() 943 MB/s [ 1.130532] raid6: int64x2 xor() 524 MB/s [ 1.198710] raid6: int64x1 gen() 724 MB/s [ 1.266853] raid6: int64x1 xor() 391 MB/s [ 1.266861] raid6: using algorithm neonx4 gen() 1727 MB/s [ 1.266867] raid6: .... xor() 1269 MB/s, rmw enabled [ 1.266874] raid6: using neon recovery algorithm [ 1.268516] vcc12v_dcin_bkup: supplied by vcc12v_dcin [ 1.268899] vcc12v_hdd: supplied by vcc12v_dcin_bkup [ 1.269401] vcc5v0_perdev: supplied by vcc12v_dcin_bkup [ 1.269764] vcc5v0_hdd: supplied by vcc12v_dcin_bkup [ 1.270104] vcc5v0_sys: supplied by vcc12v_dcin_bkup [ 1.271505] iommu: Default domain type: Translated [ 1.271515] iommu: DMA domain TLB invalidation policy: strict mode [ 1.274682] vgaarb: loaded [ 1.275149] SCSI subsystem initialized [ 1.275658] libata version 3.00 loaded. [ 1.275919] usbcore: registered new interface driver usbfs [ 1.275965] usbcore: registered new interface driver hub [ 1.276009] usbcore: registered new device driver usb [ 1.276809] pps_core: LinuxPPS API ver. 1 registered [ 1.276817] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.276845] PTP clock support registered [ 1.277168] EDAC MC: Ver: 3.0.0 [ 1.278511] NetLabel: Initializing [ 1.278519] NetLabel: domain hash size = 128 [ 1.278526] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 1.278599] NetLabel: unlabeled traffic allowed by default [ 1.279111] clocksource: Switched to clocksource arch_sys_counter [ 1.329969] VFS: Disk quotas dquot_6.6.0 [ 1.330055] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.330890] AppArmor: AppArmor Filesystem Enabled [ 1.341530] NET: Registered PF_INET protocol family [ 1.341876] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 1.344975] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 1.345230] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 1.345353] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 1.345891] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 1.346560] TCP: Hash tables configured (established 32768 bind 32768) [ 1.346754] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.346924] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.347312] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 1.347347] NET: Registered PF_XDP protocol family [ 1.347361] PCI: CLS 0 bytes, default 64 [ 1.347999] Trying to unpack rootfs image as initramfs... [ 1.348651] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 1.349157] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 1.349963] kvm [1]: IPA Size Limit: 40 bits [ 1.351307] kvm [1]: vgic-v2@fff20000 [ 1.351343] kvm [1]: GIC system register CPU interface enabled [ 1.351639] kvm [1]: vgic interrupt IRQ18 [ 1.351971] kvm [1]: Hyp mode initialized successfully [ 1.364047] Initialise system trusted keyrings [ 1.364119] Key type blacklist registered [ 1.364436] workingset: timestamp_bits=44 max_order=20 bucket_order=0 [ 1.371163] zbud: loaded [ 1.372948] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.373856] fuse: init (API version 7.34) [ 1.376680] integrity: Platform Keyring initialized [ 1.441692] xor: measuring software checksum speed [ 1.445597] 8regs : 2541 MB/sec [ 1.448978] 32regs : 2933 MB/sec [ 1.453182] arm64_neon : 2353 MB/sec [ 1.453191] xor: using function: 32regs (2933 MB/sec) [ 1.453205] Key type asymmetric registered [ 1.453212] Asymmetric key parser 'x509' registered [ 1.453344] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.453571] io scheduler mq-deadline registered [ 1.453581] io scheduler kyber registered [ 1.453796] io scheduler bfq registered [ 1.480430] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.480452] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ 1.481898] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.481911] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.487343] vdd_log: supplied by regulator-dummy [ 1.489024] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 1.492484] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 40, base_baud = 1500000) is a 16550A [ 1.493559] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 41, base_baud = 1500000) is a 16550A [ 1.493834] printk: console [ttyS2] enabled [ 1.495351] Serial: AMBA driver [ 1.497517] rockchip-vop ff8f0000.vop: Adding to iommu group 2 [ 1.498545] rockchip-vop ff900000.vop: Adding to iommu group 3 [ 1.505356] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 1.515416] loop: module loaded [ 1.524749] tun: Universal TUN/TAP device driver, 1.6 [ 1.525997] thunder_xcv, ver 1.0 [ 1.526042] thunder_bgx, ver 1.0 [ 1.526085] nicpf, ver 1.0 [ 1.527352] e1000e: Intel(R) PRO/1000 Network Driver [ 1.527359] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 1.527415] igb: Intel(R) Gigabit Ethernet Network Driver [ 1.527422] igb: Copyright (c) 2007-2014 Intel Corporation. [ 1.527464] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 1.527470] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 1.527784] sky2: driver version 1.30 [ 1.528567] VFIO - User Level meta-driver version: 0.3 [ 1.540242] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.540272] ehci-pci: EHCI PCI platform driver [ 1.540319] ehci-platform: EHCI generic platform driver [ 1.540691] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.540710] ohci-pci: OHCI PCI platform driver [ 1.540750] ohci-platform: OHCI generic platform driver [ 1.541974] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.542004] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 1.542210] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010 [ 1.542286] xhci-hcd xhci-hcd.0.auto: irq 75, io mem 0xfe900000 [ 1.542507] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.542523] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 1.542539] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 1.542758] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 1.542775] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.542786] usb usb1: Product: xHCI Host Controller [ 1.542795] usb usb1: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd [ 1.542804] usb usb1: SerialNumber: xhci-hcd.0.auto [ 1.543424] hub 1-0:1.0: USB hub found [ 1.543466] hub 1-0:1.0: 1 port detected [ 1.543910] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.544070] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 [ 1.544085] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.544096] usb usb2: Product: xHCI Host Controller [ 1.544105] usb usb2: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd [ 1.544114] usb usb2: SerialNumber: xhci-hcd.0.auto [ 1.544633] hub 2-0:1.0: USB hub found [ 1.544687] hub 2-0:1.0: 1 port detected [ 1.545171] usbcore: registered new interface driver usb-storage [ 1.548123] mousedev: PS/2 mouse device common for all mice [ 1.549661] i2c_dev: i2c /dev entries driver [ 1.556095] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 1.556601] vdd_cpu_b: supplied by vcc5v0_sys [ 1.559325] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 1.559818] vdd_gpu: supplied by vcc5v0_sys [ 1.568997] dw_wdt ff848000.watchdog: No valid TOPs array specified [ 1.571319] sdhci: Secure Digital Host Controller Interface driver [ 1.571330] sdhci: Copyright(c) Pierre Ossman [ 1.571358] Synopsys Designware Multimedia Card Interface Driver [ 1.572746] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.577292] ledtrig-cpu: registered to indicate activity on CPUs [ 1.578834] hid: raw HID events driver (C) Jiri Kosina [ 1.578965] usbcore: registered new interface driver usbhid [ 1.578974] usbhid: USB HID core driver [ 1.584210] drop_monitor: Initializing network drop monitor service [ 1.584982] NET: Registered PF_INET6 protocol family [ 1.803152] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 1.947662] Freeing initrd memory: 13060K [ 1.953250] usb 1-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04 [ 1.953270] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 1.953282] usb 1-1: Product: USB2.0 Hub [ 1.953292] usb 1-1: Manufacturer: VIA Labs, Inc. [ 1.991056] hub 1-1:1.0: USB hub found [ 1.991312] hub 1-1:1.0: 4 ports detected [ 2.005042] Segment Routing with IPv6 [ 2.005165] In-situ OAM (IOAM) with IPv6 [ 2.005310] NET: Registered PF_PACKET protocol family [ 2.005542] 8021q: 802.1Q VLAN Support v1.8 [ 2.005630] Key type dns_resolver registered [ 2.008334] registered taskstats version 1 [ 2.008361] Loading compiled-in X.509 certificates [ 2.014287] Loaded X.509 cert 'Build time autogenerated kernel key: 1fb701576c47097ebe5805564f004ecdeffa983a' [ 2.021345] zswap: loaded using pool zstd/z3fold [ 2.022740] Key type .fscrypt registered [ 2.022754] Key type fscrypt-provisioning registered [ 2.025971] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes [ 2.053304] Key type encrypted registered [ 2.053339] AppArmor: AppArmor sha1 policy hashing enabled [ 2.085691] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [ 2.117051] pcie_power: supplied by vcc5v0_perdev [ 2.128044] vcc3v3_sys_s3: supplied by vcc5v0_sys [ 2.128666] vcc3v0_sd: supplied by vcc3v3_sys_s3 [ 2.129612] vcc5v0_usb: supplied by vcc5v0_perdev [ 2.130592] vcc5v0_typec: supplied by vcc5v0_usb [ 2.131168] usblan_power: supplied by vcc5v0_usb [ 2.135297] pca953x 2-0020: using no AI [ 2.138195] rk808 0-001b: chip id: 0x0 [ 2.143667] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 2.143725] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 2.143741] rk808-regulator rk808-regulator: max buck steps per change: 4 [ 2.144508] vdd_center: supplied by vcc5v0_sys [ 2.145467] vdd_cpu_l: supplied by vcc5v0_sys [ 2.145951] vcc_ddr_s3: supplied by vcc5v0_sys [ 2.146703] vcc1v8_sys_s3: supplied by vcc5v0_sys [ 2.147763] vcc1v8_dvp: supplied by vcc5v0_sys [ 2.148360] vcc3v0_touch: supplied by vcc5v0_sys [ 2.149048] vcc1v8_s3: supplied by vcc5v0_sys [ 2.150234] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV [ 2.150676] vcc_sdio_s0: supplied by vcc5v0_sys [ 2.152048] vcca3v0_codec: supplied by vcc5v0_sys [ 2.152588] vcc1v5_s3: supplied by vcc5v0_sys [ 2.154043] vcca1v8_codec: supplied by vcc5v0_sys [ 2.154591] vcc3v0_s3: supplied by vcc5v0_sys [ 2.155600] vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER [ 2.155638] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3 [ 2.156340] vcc3v3_s0: supplied by vcc3v3_sys_s3 [ 2.160655] rk808-rtc rk808-rtc: registered as rtc0 [ 2.161254] rk808-rtc rk808-rtc: setting system clock to 2024-05-09T19:41:41 UTC (1715283701) [ 2.164638] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode. [ 2.164678] dwmmc_rockchip fe320000.mmc: Using internal DMA controller. [ 2.164695] dwmmc_rockchip fe320000.mmc: Version ID is 270a [ 2.164761] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo [ 2.165413] dwmmc_rockchip fe320000.mmc: Got CD GPIO [ 2.166716] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3 [ 2.167466] vcc0v9_s3: supplied by vcc3v3_sys_s3 [ 2.168097] avdd_0v9_s0: supplied by vcc1v8_sys_s3 [ 2.168709] avdd_1v8_s0: supplied by vcc3v3_sys_s3 [ 2.169896] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges: [ 2.169964] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000 [ 2.170000] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000 [ 2.170879] rockchip-pcie f8000000.pcie: no bus scan delay, default to 0 ms [ 2.178315] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.200296] rockchip-pcie f8000000.pcie: wait 0 ms (from device tree) before bus scan [ 2.200782] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 2.200802] pci_bus 0000:00: root bus resource [bus 00-1f] [ 2.200818] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] [ 2.200837] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) [ 2.200908] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400 [ 2.201094] pci 0000:00:00.0: supports D1 [ 2.201108] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.209023] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.209468] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601 [ 2.209554] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 2.209568] pci 0000:01:00.0: reg 0x10: [io size 0x0080] [ 2.209641] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid [ 2.209656] pci 0000:01:00.0: reg 0x14: [io size 0x0080] [ 2.209698] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid [ 2.209711] pci 0000:01:00.0: reg 0x18: [io size 0x0080] [ 2.209753] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid [ 2.209766] pci 0000:01:00.0: reg 0x1c: [io size 0x0080] [ 2.209835] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid [ 2.209839] usb 2-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04 [ 2.209850] pci 0000:01:00.0: reg 0x20: [io size 0x0080] [ 2.209859] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.209871] usb 2-1: Product: USB3.0 Hub [ 2.209881] usb 2-1: Manufacturer: VIA Labs, Inc. [ 2.209894] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff] [ 2.209939] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref] [ 2.209987] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512) [ 2.210366] pci 0000:01:00.0: PME# supported from D3hot [ 2.210638] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link) [ 2.218200] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01 [ 2.218258] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff] [ 2.218286] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref] [ 2.218306] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff] [ 2.218334] pci 0000:01:00.0: BAR 0: no space for [io size 0x0080] [ 2.218349] pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0080] [ 2.218362] pci 0000:01:00.0: BAR 1: no space for [io size 0x0080] [ 2.218376] pci 0000:01:00.0: BAR 1: failed to assign [io size 0x0080] [ 2.218390] pci 0000:01:00.0: BAR 2: no space for [io size 0x0080] [ 2.218403] pci 0000:01:00.0: BAR 2: failed to assign [io size 0x0080] [ 2.218418] pci 0000:01:00.0: BAR 3: no space for [io size 0x0080] [ 2.218431] pci 0000:01:00.0: BAR 3: failed to assign [io size 0x0080] [ 2.218445] pci 0000:01:00.0: BAR 4: no space for [io size 0x0080] [ 2.218458] pci 0000:01:00.0: BAR 4: failed to assign [io size 0x0080] [ 2.218476] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.218495] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff] [ 2.218829] pcieport 0000:00:00.0: enabling device (0000 -> 0002) [ 2.219338] pcieport 0000:00:00.0: PME: Signaling with IRQ 89 [ 2.219959] pcieport 0000:00:00.0: AER: enabled with IRQ 89 [ 2.220410] ahci 0000:01:00.0: version 3.0 [ 2.220453] ahci 0000:01:00.0: enabling device (0000 -> 0002) [ 2.221275] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled [ 2.221392] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode [ 2.221415] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh [ 2.229604] scsi host0: ahci [ 2.230577] scsi host1: ahci [ 2.230929] hub 2-1:1.0: USB hub found [ 2.231059] hub 2-1:1.0: 4 ports detected [ 2.231566] scsi host2: ahci [ 2.232443] scsi host3: ahci [ 2.233267] scsi host4: ahci [ 2.233587] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 90 [ 2.233604] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 91 [ 2.233618] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 92 [ 2.233631] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 93 [ 2.233643] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 94 [ 2.242754] mmc1: CQHCI version 5.10 [ 2.243204] WCN: marlin_init entry! [ 2.244730] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 2.245360] of_cfs_init [ 2.245407] of_cfs_init: OK [ 2.268943] mmc1: SDHCI controller on fe330000.mmc [fe330000.mmc] using ADMA [ 2.340044] mmc1: Command Queue Engine enabled [ 2.340077] mmc1: new HS200 MMC card at address 0001 [ 2.341189] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB [ 2.344236] mmcblk1: p1 [ 2.344942] mmcblk1boot0: mmc1:0001 AJTD4R 4.00 MiB [ 2.347428] mmcblk1boot1: mmc1:0001 AJTD4R 4.00 MiB [ 2.349698] mmcblk1rpmb: mmc1:0001 AJTD4R 4.00 MiB, chardev (241:0) [ 2.871217] usb 2-1.4: new SuperSpeed USB device number 3 using xhci-hcd [ 2.892193] usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00 [ 2.892210] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6 [ 2.892222] usb 2-1.4: Product: USB 10/100/1G/2.5G LAN [ 2.892232] usb 2-1.4: Manufacturer: Realtek [ 2.892240] usb 2-1.4: SerialNumber: 000000001 [ 12.231936] ata1: softreset failed (1st FIS failed) [ 22.232089] ata1: softreset failed (1st FIS failed) [ 33.759210] vcc3v0_sd: disabling [ 57.231598] ata1: softreset failed (1st FIS failed) [ 57.231616] ata1: limiting SATA link speed to 3.0 Gbps [ 62.443153] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320) [ 62.443174] ata1: link online but 1 devices misclassified, device detection might fail [ 62.919153] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 62.947839] ata2.00: ATA-10: ST4000DM004-2CV104, 0001, max UDMA/133 [ 62.956929] ata2.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 63.017151] ata2.00: configured for UDMA/133 [ 63.017799] scsi 1:0:0:0: Direct-Access ATA ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5 [ 63.019201] sd 1:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [ 63.019223] sd 1:0:0:0: [sda] 4096-byte physical blocks [ 63.019318] sd 1:0:0:0: [sda] Write Protect is off [ 63.019339] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 63.019507] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 63.110763] sda: sda1 [ 63.127476] sd 1:0:0:0: [sda] Attached SCSI disk [ 63.495157] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 63.497569] ata3.00: ATA-10: ST4000DM004-2CV104, 0001, max UDMA/133 [ 63.497814] ata3.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 63.500666] ata3.00: configured for UDMA/133 [ 63.501214] scsi 2:0:0:0: Direct-Access ATA ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5 [ 63.502517] sd 2:0:0:0: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [ 63.502533] sd 2:0:0:0: [sdb] 4096-byte physical blocks [ 63.502585] sd 2:0:0:0: [sdb] Write Protect is off [ 63.502597] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [ 63.502682] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 63.588633] sdb: sdb1 [ 63.603350] sd 2:0:0:0: [sdb] Attached SCSI disk [ 63.817781] ata4: SATA link down (SStatus 0 SControl 300) [ 64.129791] ata5: SATA link down (SStatus 0 SControl 300) [ 64.132579] Freeing unused kernel memory: 4352K [ 64.132703] Run /init as init process [ 64.132711] with arguments: [ 64.132719] /init [ 64.132726] with environment: [ 64.132732] HOME=/ [ 64.132739] TERM=linux [ 64.132745] ubootpart=306d94a6-01 [ 64.132751] cgroup_enable=memory [ 64.132757] cgroup_memory=1 [ 64.786426] input: adc-keys as /devices/platform/adc-keys/input/input1 [ 65.003675] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found [ 65.003698] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found [ 65.003856] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock [ 65.004323] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 65.004340] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 65.004353] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20). [ 65.004371] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). [ 65.004456] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed [ 65.004465] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 65.011874] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 65.015423] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35 [ 65.015447] rk_gmac-dwmac fe300000.ethernet: DWMAC1000 [ 65.015458] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported [ 65.015467] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported [ 65.015475] rk_gmac-dwmac fe300000.ethernet: COE Type 2 [ 65.015484] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported [ 65.015492] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported [ 65.015602] rk_gmac-dwmac fe300000.ethernet: Normal descriptors [ 65.015612] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled [ 65.015619] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 65.146278] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL) [ 65.146305] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL) [ 65.350024] async_tx: api initialized (async) [ 65.668181] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [ 66.088777] systemd[1]: Inserted module 'autofs4' [ 66.142611] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 66.143545] systemd[1]: Detected architecture arm64. [ 66.204214] systemd[1]: Set hostname to <helios2>. [ 66.310253] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console [ 66.625803] random: systemd: uninitialized urandom read (16 bytes read) [ 66.629970] systemd[1]: /lib/systemd/system/haveged.service:19: Unknown lvalue 'ProtectHostname' in section 'Service', ignoring [ 66.630017] systemd[1]: /lib/systemd/system/haveged.service:20: Unknown lvalue 'ProtectKernelLogs' in section 'Service', ignoring [ 66.636333] random: systemd: uninitialized urandom read (16 bytes read) [ 66.637122] systemd[1]: Listening on udev Control Socket. [ 66.637656] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 66.637714] random: systemd: uninitialized urandom read (16 bytes read) [ 66.638215] systemd[1]: Listening on fsck to fsckd communication Socket. [ 66.638739] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 66.639021] systemd[1]: Reached target Swap. [ 66.753097] lm75 2-004c: supply vs not found, using dummy regulator [ 66.753894] hwmon hwmon2: temp1_input not attached to any thermal zone [ 66.753913] lm75 2-004c: hwmon2: sensor 'lm75' [ 66.759941] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. [ 67.683595] mc: Linux media interface: v0.10 [ 67.720321] random: systemd: uninitialized urandom read (16 bytes read) [ 67.720429] random: systemd: uninitialized urandom read (16 bytes read) [ 67.720469] random: systemd: uninitialized urandom read (16 bytes read) [ 67.732347] videodev: Linux video capture interface: v2.00 [ 67.750408] input: beeper as /devices/platform/beeper/input/input2 [ 67.804206] sd 1:0:0:0: Attached scsi generic sg0 type 0 [ 67.818956] sd 2:0:0:0: Attached scsi generic sg1 type 0 [ 67.914746] rockchip-iep ff670000.iep: Device rockchip-iep registered as /dev/video0 [ 67.928725] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned. [ 67.935676] rockchip-rga ff680000.rga: HW Version: 0x03.02 [ 67.950103] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned. [ 67.981471] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video1 [ 67.984266] rkvdec ff660000.video-codec: Adding to iommu group 1 [ 68.010586] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22 [ 68.019663] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [ 68.021040] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video3 [ 68.032817] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video4 [ 68.131515] panfrost ff9a0000.gpu: clock rate = 500000000 [ 68.194795] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops) [ 68.194969] [drm] unsupported AFBC format[3231564e] [ 68.196796] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops) [ 68.197418] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops) [ 68.201673] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 68.203396] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 68.215852] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1 [ 68.271185] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 68.272400] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3 [ 68.272531] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010 [ 68.272552] xhci-hcd xhci-hcd.3.auto: irq 74, io mem 0xfe800000 [ 68.272656] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 68.272664] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4 [ 68.272670] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed [ 68.272770] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 68.272775] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 68.272779] usb usb3: Product: xHCI Host Controller [ 68.272783] usb usb3: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd [ 68.272786] usb usb3: SerialNumber: xhci-hcd.3.auto [ 68.273197] ehci-platform fe380000.usb: EHCI Host Controller [ 68.281431] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [ 68.281458] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400 [ 68.281467] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [ 68.281478] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [ 68.291991] hub 3-0:1.0: USB hub found [ 68.292019] hub 3-0:1.0: 1 port detected [ 68.292299] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 68.292369] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 [ 68.292374] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 68.292379] usb usb4: Product: xHCI Host Controller [ 68.292382] usb usb4: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd [ 68.292385] usb usb4: SerialNumber: xhci-hcd.3.auto [ 68.303795] hub 4-0:1.0: USB hub found [ 68.303849] hub 4-0:1.0: 1 port detected [ 68.306660] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 68.312297] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 0 [ 68.357318] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5 [ 68.357688] ehci-platform fe380000.usb: irq 34, io mem 0xfe380000 [ 68.371190] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ 68.373813] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 68.373839] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 68.373846] usb usb5: Product: EHCI Host Controller [ 68.373852] usb usb5: Manufacturer: Linux 5.15.93-rockchip64 ehci_hcd [ 68.373857] usb usb5: SerialNumber: fe380000.usb [ 68.455792] hub 5-0:1.0: USB hub found [ 68.455834] hub 5-0:1.0: 1 port detected [ 68.562994] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ 68.564446] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6 [ 68.564739] ohci-platform fe3a0000.usb: irq 35, io mem 0xfe3a0000 [ 68.621598] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 68.627303] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 [ 68.627315] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 68.627320] usb usb6: Product: Generic Platform OHCI controller [ 68.627324] usb usb6: Manufacturer: Linux 5.15.93-rockchip64 ohci_hcd [ 68.627327] usb usb6: SerialNumber: fe3a0000.usb [ 68.627873] hub 6-0:1.0: USB hub found [ 68.627900] hub 6-0:1.0: 1 port detected [ 68.680671] EXT4-fs (sdb1): recovery complete [ 68.680697] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [ 68.807792] usb 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 68.829899] EXT4-fs (sda1): recovery complete [ 68.829913] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [ 68.846117] r8152 2-1.4:1.0: Direct firmware load for rtl_nic/rtl8156a-2.fw failed with error -2 [ 68.846155] r8152 2-1.4:1.0: unable to load firmware patch rtl_nic/rtl8156a-2.fw (-2) [ 68.887755] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256 [ 68.903489] r8152 2-1.4:1.0 eth1: v1.12.13 [ 68.903688] usbcore: registered new interface driver r8152 [ 69.000196] random: systemd: uninitialized urandom read (16 bytes read) [ 69.000248] random: systemd: uninitialized urandom read (16 bytes read) [ 69.588914] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 72.831526] random: crng init done [ 72.831543] random: 99 urandom warning(s) missed due to ratelimiting [ 156.715598] systemd[1]: dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device: Job dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device/start timed out. [ 156.715646] systemd[1]: Timed out waiting for device /dev/disk/by-uuid/406e7e7d-9517-44af-bcde-4de3adbc6b80. [ 156.716005] systemd[1]: Dependency failed for /data/glusterfs/sda1. [ 156.716313] systemd[1]: Dependency failed for Local File Systems. [ 156.716609] systemd[1]: Dependency failed for Mark the need to relabel after reboot. [ 156.716924] systemd[1]: selinux-autorelabel-mark.service: Job selinux-autorelabel-mark.service/start failed with result 'dependency'. [ 156.716977] systemd[1]: local-fs.target: Job local-fs.target/start failed with result 'dependency'. [ 156.717002] systemd[1]: local-fs.target: Triggering OnFailure= dependencies. [ 156.718933] systemd[1]: data-glusterfs-sda1.mount: Job data-glusterfs-sda1.mount/start failed with result 'dependency'. [ 156.718982] systemd[1]: dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device: Job dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device/start failed with result 'timeout'. [ 156.900586] zram: Added device: zram0 [ 156.901201] zram: Added device: zram1 [ 156.901843] zram: Added device: zram2 [ 156.915238] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL) [ 156.918923] rk_gmac-dwmac fe300000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 156.927175] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found [ 156.927210] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW [ 156.927768] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode [ 156.956618] zram0: detected capacity change from 0 to 3956192 [ 157.006138] Adding 1978092k swap on /dev/zram0. Priority:5 extents:1 across:1978092k SSFS [ 157.170458] zram1: detected capacity change from 0 to 102400 [ 157.268107] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none. [ 157.268158] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) [ 159.706322] systemd-journald[1325]: Received request to flush runtime journal from PID 1 [ 161.056445] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 161.056494] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready root@helios2:~# journalctl | cat -- Logs begin at Thu 2024-05-09 20:44:18 BST, end at Thu 2024-05-09 20:50:27 BST. -- May 09 20:44:18 helios2 kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd034] May 09 20:44:18 helios2 kernel: Linux version 5.15.93-rockchip64 (root@cf2b4ed83279) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #23.02.2 SMP PREEMPT Fri Feb 17 23:48:36 UTC 2023 May 09 20:44:18 helios2 kernel: Machine model: Helios64 May 09 20:44:18 helios2 kernel: efi: UEFI not found. May 09 20:44:18 helios2 kernel: NUMA: No NUMA configuration found May 09 20:44:18 helios2 kernel: NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff] May 09 20:44:18 helios2 kernel: NUMA: NODE_DATA [mem 0xf77cc100-0xf77cdfff] May 09 20:44:18 helios2 kernel: Zone ranges: May 09 20:44:18 helios2 kernel: DMA [mem 0x0000000000200000-0x00000000f7ffffff] May 09 20:44:18 helios2 kernel: DMA32 empty May 09 20:44:18 helios2 kernel: Normal empty May 09 20:44:18 helios2 kernel: Movable zone start for each node May 09 20:44:18 helios2 kernel: Early memory node ranges May 09 20:44:18 helios2 kernel: node 0: [mem 0x0000000000200000-0x00000000f7ffffff] May 09 20:44:18 helios2 kernel: Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff] May 09 20:44:18 helios2 kernel: On node 0, zone DMA: 512 pages in unavailable ranges May 09 20:44:18 helios2 kernel: cma: Reserved 128 MiB at 0x00000000e9000000 May 09 20:44:18 helios2 kernel: psci: probing for conduit method from DT. May 09 20:44:18 helios2 kernel: psci: PSCIv1.0 detected in firmware. May 09 20:44:18 helios2 kernel: psci: Using standard PSCI v0.2 function IDs May 09 20:44:18 helios2 kernel: psci: MIGRATE_INFO_TYPE not supported. May 09 20:44:18 helios2 kernel: psci: SMC Calling Convention v1.0 May 09 20:44:18 helios2 kernel: percpu: Embedded 29 pages/cpu s80984 r8192 d29608 u118784 May 09 20:44:18 helios2 kernel: pcpu-alloc: s80984 r8192 d29608 u118784 alloc=29*4096 May 09 20:44:18 helios2 kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 May 09 20:44:18 helios2 kernel: Detected VIPT I-cache on CPU0 May 09 20:44:18 helios2 kernel: CPU features: detected: GIC system register CPU interface May 09 20:44:18 helios2 kernel: CPU features: detected: ARM erratum 845719 May 09 20:44:18 helios2 kernel: Built 1 zonelists, mobility grouping on. Total pages: 999432 May 09 20:44:18 helios2 kernel: Policy zone: DMA May 09 20:44:18 helios2 kernel: Kernel command line: root=UUID=d82ec6f7-ac67-4a80-a092-295ebfdbbd1d rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=306d94a6-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 May 09 20:44:18 helios2 kernel: Unknown kernel command line parameters "ubootpart=306d94a6-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space. May 09 20:44:18 helios2 kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) May 09 20:44:18 helios2 kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) May 09 20:44:18 helios2 kernel: mem auto-init: stack:off, heap alloc:on, heap free:off May 09 20:44:18 helios2 kernel: Memory: 3807704K/4061184K available (16000K kernel code, 2692K rwdata, 6712K rodata, 4352K init, 593K bss, 122408K reserved, 131072K cma-reserved) May 09 20:44:18 helios2 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 May 09 20:44:18 helios2 kernel: trace event string verifier disabled May 09 20:44:18 helios2 kernel: rcu: Preemptible hierarchical RCU implementation. May 09 20:44:18 helios2 kernel: rcu: RCU event tracing is enabled. May 09 20:44:18 helios2 kernel: rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. May 09 20:44:18 helios2 kernel: Trampoline variant of Tasks RCU enabled. May 09 20:44:18 helios2 kernel: Rude variant of Tasks RCU enabled. May 09 20:44:18 helios2 kernel: Tracing variant of Tasks RCU enabled. May 09 20:44:18 helios2 kernel: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. May 09 20:44:18 helios2 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 May 09 20:44:18 helios2 kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 May 09 20:44:18 helios2 kernel: GICv3: GIC: Using split EOI/Deactivate mode May 09 20:44:18 helios2 kernel: GICv3: 256 SPIs implemented May 09 20:44:18 helios2 kernel: GICv3: 0 Extended SPIs implemented May 09 20:44:18 helios2 kernel: GICv3: Distributor has no Range Selector support May 09 20:44:18 helios2 kernel: Root IRQ handler: gic_handle_irq May 09 20:44:18 helios2 kernel: GICv3: 16 PPIs implemented May 09 20:44:18 helios2 kernel: GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000 May 09 20:44:18 helios2 kernel: ITS [mem 0xfee20000-0xfee3ffff] May 09 20:44:18 helios2 kernel: ITS@0x00000000fee20000: allocated 65536 Devices @500000 (flat, esz 8, psz 64K, shr 0) May 09 20:44:18 helios2 kernel: ITS: using cache flushing for cmd queue May 09 20:44:18 helios2 kernel: GICv3: using LPI property table @0x00000000004d0000 May 09 20:44:18 helios2 kernel: GIC: using cache flushing for LPI property table May 09 20:44:18 helios2 kernel: GICv3: CPU0: using allocated LPI pending table @0x00000000004e0000 May 09 20:44:18 helios2 kernel: GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } May 09 20:44:18 helios2 kernel: GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } May 09 20:44:18 helios2 kernel: arch_timer: cp15 timer(s) running at 24.00MHz (phys). May 09 20:44:18 helios2 kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns May 09 20:44:18 helios2 kernel: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns May 09 20:44:18 helios2 kernel: Console: colour dummy device 80x25 May 09 20:44:18 helios2 kernel: printk: console [tty1] enabled May 09 20:44:18 helios2 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) May 09 20:44:18 helios2 kernel: pid_max: default: 32768 minimum: 301 May 09 20:44:18 helios2 kernel: LSM: Security Framework initializing May 09 20:44:18 helios2 kernel: Yama: becoming mindful. May 09 20:44:18 helios2 kernel: AppArmor: AppArmor initialized May 09 20:44:18 helios2 kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) May 09 20:44:18 helios2 kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) May 09 20:44:18 helios2 kernel: rcu: Hierarchical SRCU implementation. May 09 20:44:18 helios2 kernel: Platform MSI: interrupt-controller@fee20000 domain created May 09 20:44:18 helios2 kernel: PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created May 09 20:44:18 helios2 kernel: EFI services will not be available. May 09 20:44:18 helios2 kernel: smp: Bringing up secondary CPUs ... May 09 20:44:18 helios2 kernel: Detected VIPT I-cache on CPU1 May 09 20:44:18 helios2 kernel: GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000 May 09 20:44:18 helios2 kernel: GICv3: CPU1: using allocated LPI pending table @0x00000000004f0000 May 09 20:44:18 helios2 kernel: CPU1: Booted secondary processor 0x0000000001 [0x410fd034] May 09 20:44:18 helios2 kernel: Detected VIPT I-cache on CPU2 May 09 20:44:18 helios2 kernel: GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000 May 09 20:44:18 helios2 kernel: GICv3: CPU2: using allocated LPI pending table @0x0000000000580000 May 09 20:44:18 helios2 kernel: CPU2: Booted secondary processor 0x0000000002 [0x410fd034] May 09 20:44:18 helios2 kernel: Detected VIPT I-cache on CPU3 May 09 20:44:18 helios2 kernel: GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000 May 09 20:44:18 helios2 kernel: GICv3: CPU3: using allocated LPI pending table @0x0000000000590000 May 09 20:44:18 helios2 kernel: CPU3: Booted secondary processor 0x0000000003 [0x410fd034] May 09 20:44:18 helios2 kernel: CPU features: detected: Spectre-v2 May 09 20:44:18 helios2 kernel: CPU features: detected: Spectre-v3a May 09 20:44:18 helios2 kernel: CPU features: detected: Spectre-v4 May 09 20:44:18 helios2 kernel: CPU features: detected: Spectre-BHB May 09 20:44:18 helios2 kernel: CPU features: detected: ARM erratum 1742098 May 09 20:44:18 helios2 kernel: CPU features: detected: ARM errata 1165522, 1319367, or 1530923 May 09 20:44:18 helios2 kernel: Detected PIPT I-cache on CPU4 May 09 20:44:18 helios2 kernel: GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000 May 09 20:44:18 helios2 kernel: GICv3: CPU4: using allocated LPI pending table @0x00000000005a0000 May 09 20:44:18 helios2 kernel: CPU4: Booted secondary processor 0x0000000100 [0x410fd082] May 09 20:44:18 helios2 kernel: Detected PIPT I-cache on CPU5 May 09 20:44:18 helios2 kernel: GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000 May 09 20:44:18 helios2 kernel: GICv3: CPU5: using allocated LPI pending table @0x00000000005b0000 May 09 20:44:18 helios2 kernel: CPU5: Booted secondary processor 0x0000000101 [0x410fd082] May 09 20:44:18 helios2 kernel: smp: Brought up 1 node, 6 CPUs May 09 20:44:18 helios2 kernel: SMP: Total of 6 processors activated. May 09 20:44:18 helios2 kernel: CPU features: detected: 32-bit EL0 Support May 09 20:44:18 helios2 kernel: CPU features: detected: 32-bit EL1 Support May 09 20:44:18 helios2 kernel: CPU features: detected: CRC32 instructions May 09 20:44:18 helios2 kernel: CPU: All CPU(s) started at EL2 May 09 20:44:18 helios2 kernel: alternatives: patching kernel code May 09 20:44:18 helios2 kernel: devtmpfs: initialized May 09 20:44:18 helios2 kernel: Registered cp15_barrier emulation handler May 09 20:44:18 helios2 kernel: Registered setend emulation handler May 09 20:44:18 helios2 kernel: KASLR disabled due to lack of seed May 09 20:44:18 helios2 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns May 09 20:44:18 helios2 kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear) May 09 20:44:18 helios2 kernel: pinctrl core: initialized pinctrl subsystem May 09 20:44:18 helios2 kernel: DMI not present or invalid. May 09 20:44:18 helios2 kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family May 09 20:44:18 helios2 kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations May 09 20:44:18 helios2 kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations May 09 20:44:18 helios2 kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations May 09 20:44:18 helios2 kernel: audit: initializing netlink subsys (disabled) May 09 20:44:18 helios2 kernel: audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1 May 09 20:44:18 helios2 kernel: thermal_sys: Registered thermal governor 'fair_share' May 09 20:44:18 helios2 kernel: thermal_sys: Registered thermal governor 'bang_bang' May 09 20:44:18 helios2 kernel: thermal_sys: Registered thermal governor 'step_wise' May 09 20:44:18 helios2 kernel: thermal_sys: Registered thermal governor 'user_space' May 09 20:44:18 helios2 kernel: cpuidle: using governor menu May 09 20:44:18 helios2 kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. May 09 20:44:18 helios2 kernel: ASID allocator initialised with 65536 entries May 09 20:44:18 helios2 kernel: Serial: AMBA PL011 UART driver May 09 20:44:18 helios2 kernel: platform ff770000.syscon:phy@f780: Fixing up cyclic dependency with fe330000.mmc May 09 20:44:18 helios2 kernel: platform ff8f0000.vop: Fixing up cyclic dependency with fec00000.dp May 09 20:44:18 helios2 kernel: platform ff900000.vop: Fixing up cyclic dependency with fec00000.dp May 09 20:44:18 helios2 kernel: rockchip-gpio ff720000.gpio0: probed /pinctrl/gpio0@ff720000 May 09 20:44:18 helios2 kernel: rockchip-gpio ff730000.gpio1: probed /pinctrl/gpio1@ff730000 May 09 20:44:18 helios2 kernel: rockchip-gpio ff780000.gpio2: probed /pinctrl/gpio2@ff780000 May 09 20:44:18 helios2 kernel: rockchip-gpio ff788000.gpio3: probed /pinctrl/gpio3@ff788000 May 09 20:44:18 helios2 kernel: rockchip-gpio ff790000.gpio4: probed /pinctrl/gpio4@ff790000 May 09 20:44:18 helios2 kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages May 09 20:44:18 helios2 kernel: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages May 09 20:44:18 helios2 kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages May 09 20:44:18 helios2 kernel: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages May 09 20:44:18 helios2 kernel: cryptd: max_cpu_qlen set to 1000 May 09 20:44:18 helios2 kernel: raid6: neonx8 gen() 1666 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx8 xor() 1222 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx4 gen() 1727 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx4 xor() 1269 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx2 gen() 1541 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx2 xor() 1177 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx1 gen() 1200 MB/s May 09 20:44:18 helios2 kernel: raid6: neonx1 xor() 932 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x8 gen() 1001 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x8 xor() 577 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x4 gen() 1001 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x4 xor() 591 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x2 gen() 943 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x2 xor() 524 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x1 gen() 724 MB/s May 09 20:44:18 helios2 kernel: raid6: int64x1 xor() 391 MB/s May 09 20:44:18 helios2 kernel: raid6: using algorithm neonx4 gen() 1727 MB/s May 09 20:44:18 helios2 kernel: raid6: .... xor() 1269 MB/s, rmw enabled May 09 20:44:18 helios2 kernel: raid6: using neon recovery algorithm May 09 20:44:18 helios2 kernel: vcc12v_dcin_bkup: supplied by vcc12v_dcin May 09 20:44:18 helios2 kernel: vcc12v_hdd: supplied by vcc12v_dcin_bkup May 09 20:44:18 helios2 kernel: vcc5v0_perdev: supplied by vcc12v_dcin_bkup May 09 20:44:18 helios2 kernel: vcc5v0_hdd: supplied by vcc12v_dcin_bkup May 09 20:44:18 helios2 kernel: vcc5v0_sys: supplied by vcc12v_dcin_bkup May 09 20:44:18 helios2 kernel: iommu: Default domain type: Translated May 09 20:44:18 helios2 kernel: iommu: DMA domain TLB invalidation policy: strict mode May 09 20:44:18 helios2 kernel: vgaarb: loaded May 09 20:44:18 helios2 kernel: SCSI subsystem initialized May 09 20:44:18 helios2 kernel: libata version 3.00 loaded. May 09 20:44:18 helios2 kernel: usbcore: registered new interface driver usbfs May 09 20:44:18 helios2 kernel: usbcore: registered new interface driver hub May 09 20:44:18 helios2 kernel: usbcore: registered new device driver usb May 09 20:44:18 helios2 kernel: pps_core: LinuxPPS API ver. 1 registered May 09 20:44:18 helios2 kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> May 09 20:44:18 helios2 kernel: PTP clock support registered May 09 20:44:18 helios2 kernel: EDAC MC: Ver: 3.0.0 May 09 20:44:18 helios2 kernel: NetLabel: Initializing May 09 20:44:18 helios2 kernel: NetLabel: domain hash size = 128 May 09 20:44:18 helios2 kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO May 09 20:44:18 helios2 kernel: NetLabel: unlabeled traffic allowed by default May 09 20:44:18 helios2 kernel: clocksource: Switched to clocksource arch_sys_counter May 09 20:44:18 helios2 kernel: VFS: Disk quotas dquot_6.6.0 May 09 20:44:18 helios2 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) May 09 20:44:18 helios2 kernel: AppArmor: AppArmor Filesystem Enabled May 09 20:44:18 helios2 kernel: NET: Registered PF_INET protocol family May 09 20:44:18 helios2 kernel: IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) May 09 20:44:18 helios2 kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) May 09 20:44:18 helios2 kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) May 09 20:44:18 helios2 kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) May 09 20:44:18 helios2 kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) May 09 20:44:18 helios2 kernel: TCP: Hash tables configured (established 32768 bind 32768) May 09 20:44:18 helios2 kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) May 09 20:44:18 helios2 kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) May 09 20:44:18 helios2 kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family May 09 20:44:18 helios2 kernel: NET: Registered PF_XDP protocol family May 09 20:44:18 helios2 kernel: PCI: CLS 0 bytes, default 64 May 09 20:44:18 helios2 kernel: Trying to unpack rootfs image as initramfs... May 09 20:44:18 helios2 kernel: hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available May 09 20:44:18 helios2 kernel: hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available May 09 20:44:18 helios2 kernel: kvm [1]: IPA Size Limit: 40 bits May 09 20:44:18 helios2 kernel: kvm [1]: vgic-v2@fff20000 May 09 20:44:18 helios2 kernel: kvm [1]: GIC system register CPU interface enabled May 09 20:44:18 helios2 kernel: kvm [1]: vgic interrupt IRQ18 May 09 20:44:18 helios2 kernel: kvm [1]: Hyp mode initialized successfully May 09 20:44:18 helios2 kernel: Initialise system trusted keyrings May 09 20:44:18 helios2 kernel: Key type blacklist registered May 09 20:44:18 helios2 kernel: workingset: timestamp_bits=44 max_order=20 bucket_order=0 May 09 20:44:18 helios2 kernel: zbud: loaded May 09 20:44:18 helios2 kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher May 09 20:44:18 helios2 kernel: fuse: init (API version 7.34) May 09 20:44:18 helios2 kernel: integrity: Platform Keyring initialized May 09 20:44:18 helios2 kernel: xor: measuring software checksum speed May 09 20:44:18 helios2 kernel: 8regs : 2541 MB/sec May 09 20:44:18 helios2 kernel: 32regs : 2933 MB/sec May 09 20:44:18 helios2 kernel: arm64_neon : 2353 MB/sec May 09 20:44:18 helios2 kernel: xor: using function: 32regs (2933 MB/sec) May 09 20:44:18 helios2 kernel: Key type asymmetric registered May 09 20:44:18 helios2 kernel: Asymmetric key parser 'x509' registered May 09 20:44:18 helios2 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) May 09 20:44:18 helios2 kernel: io scheduler mq-deadline registered May 09 20:44:18 helios2 kernel: io scheduler kyber registered May 09 20:44:18 helios2 kernel: io scheduler bfq registered May 09 20:44:18 helios2 kernel: dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 May 09 20:44:18 helios2 kernel: dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 May 09 20:44:18 helios2 kernel: dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 May 09 20:44:18 helios2 kernel: dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 May 09 20:44:18 helios2 kernel: vdd_log: supplied by regulator-dummy May 09 20:44:18 helios2 kernel: Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled May 09 20:44:18 helios2 kernel: ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 40, base_baud = 1500000) is a 16550A May 09 20:44:18 helios2 kernel: ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 41, base_baud = 1500000) is a 16550A May 09 20:44:18 helios2 kernel: printk: console [ttyS2] enabled May 09 20:44:18 helios2 kernel: Serial: AMBA driver May 09 20:44:18 helios2 kernel: rockchip-vop ff8f0000.vop: Adding to iommu group 2 May 09 20:44:18 helios2 kernel: rockchip-vop ff900000.vop: Adding to iommu group 3 May 09 20:44:18 helios2 kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0 May 09 20:44:18 helios2 kernel: loop: module loaded May 09 20:44:18 helios2 kernel: tun: Universal TUN/TAP device driver, 1.6 May 09 20:44:18 helios2 kernel: thunder_xcv, ver 1.0 May 09 20:44:18 helios2 kernel: thunder_bgx, ver 1.0 May 09 20:44:18 helios2 kernel: nicpf, ver 1.0 May 09 20:44:18 helios2 kernel: e1000e: Intel(R) PRO/1000 Network Driver May 09 20:44:18 helios2 kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation. May 09 20:44:18 helios2 kernel: igb: Intel(R) Gigabit Ethernet Network Driver May 09 20:44:18 helios2 kernel: igb: Copyright (c) 2007-2014 Intel Corporation. May 09 20:44:18 helios2 kernel: igbvf: Intel(R) Gigabit Virtual Function Network Driver May 09 20:44:18 helios2 kernel: igbvf: Copyright (c) 2009 - 2012 Intel Corporation. May 09 20:44:18 helios2 kernel: sky2: driver version 1.30 May 09 20:44:18 helios2 kernel: VFIO - User Level meta-driver version: 0.3 May 09 20:44:18 helios2 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver May 09 20:44:18 helios2 kernel: ehci-pci: EHCI PCI platform driver May 09 20:44:18 helios2 kernel: ehci-platform: EHCI generic platform driver May 09 20:44:18 helios2 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver May 09 20:44:18 helios2 kernel: ohci-pci: OHCI PCI platform driver May 09 20:44:18 helios2 kernel: ohci-platform: OHCI generic platform driver May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: irq 75, io mem 0xfe900000 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed May 09 20:44:18 helios2 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 May 09 20:44:18 helios2 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:18 helios2 kernel: usb usb1: Product: xHCI Host Controller May 09 20:44:18 helios2 kernel: usb usb1: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd May 09 20:44:18 helios2 kernel: usb usb1: SerialNumber: xhci-hcd.0.auto May 09 20:44:18 helios2 kernel: hub 1-0:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 1-0:1.0: 1 port detected May 09 20:44:18 helios2 kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. May 09 20:44:18 helios2 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 May 09 20:44:18 helios2 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:18 helios2 kernel: usb usb2: Product: xHCI Host Controller May 09 20:44:18 helios2 kernel: usb usb2: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd May 09 20:44:18 helios2 kernel: usb usb2: SerialNumber: xhci-hcd.0.auto May 09 20:44:18 helios2 kernel: hub 2-0:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 2-0:1.0: 1 port detected May 09 20:44:18 helios2 kernel: usbcore: registered new interface driver usb-storage May 09 20:44:18 helios2 kernel: mousedev: PS/2 mouse device common for all mice May 09 20:44:18 helios2 kernel: i2c_dev: i2c /dev entries driver May 09 20:44:18 helios2 kernel: fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! May 09 20:44:18 helios2 kernel: vdd_cpu_b: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! May 09 20:44:18 helios2 kernel: vdd_gpu: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: dw_wdt ff848000.watchdog: No valid TOPs array specified May 09 20:44:18 helios2 kernel: sdhci: Secure Digital Host Controller Interface driver May 09 20:44:18 helios2 kernel: sdhci: Copyright(c) Pierre Ossman May 09 20:44:18 helios2 kernel: Synopsys Designware Multimedia Card Interface Driver May 09 20:44:18 helios2 kernel: sdhci-pltfm: SDHCI platform and OF driver helper May 09 20:44:18 helios2 kernel: ledtrig-cpu: registered to indicate activity on CPUs May 09 20:44:18 helios2 kernel: hid: raw HID events driver (C) Jiri Kosina May 09 20:44:18 helios2 kernel: usbcore: registered new interface driver usbhid May 09 20:44:18 helios2 kernel: usbhid: USB HID core driver May 09 20:44:18 helios2 kernel: drop_monitor: Initializing network drop monitor service May 09 20:44:18 helios2 kernel: NET: Registered PF_INET6 protocol family May 09 20:44:18 helios2 kernel: usb 1-1: new high-speed USB device number 2 using xhci-hcd May 09 20:44:18 helios2 kernel: Freeing initrd memory: 13060K May 09 20:44:18 helios2 kernel: usb 1-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04 May 09 20:44:18 helios2 kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 May 09 20:44:18 helios2 kernel: usb 1-1: Product: USB2.0 Hub May 09 20:44:18 helios2 kernel: usb 1-1: Manufacturer: VIA Labs, Inc. May 09 20:44:18 helios2 kernel: hub 1-1:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 1-1:1.0: 4 ports detected May 09 20:44:18 helios2 kernel: Segment Routing with IPv6 May 09 20:44:18 helios2 kernel: In-situ OAM (IOAM) with IPv6 May 09 20:44:18 helios2 kernel: NET: Registered PF_PACKET protocol family May 09 20:44:18 helios2 kernel: 8021q: 802.1Q VLAN Support v1.8 May 09 20:44:18 helios2 kernel: Key type dns_resolver registered May 09 20:44:18 helios2 kernel: registered taskstats version 1 May 09 20:44:18 helios2 kernel: Loading compiled-in X.509 certificates May 09 20:44:18 helios2 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 1fb701576c47097ebe5805564f004ecdeffa983a' May 09 20:44:18 helios2 kernel: zswap: loaded using pool zstd/z3fold May 09 20:44:18 helios2 kernel: Key type .fscrypt registered May 09 20:44:18 helios2 kernel: Key type fscrypt-provisioning registered May 09 20:44:18 helios2 kernel: Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes May 09 20:44:18 helios2 kernel: Key type encrypted registered May 09 20:44:18 helios2 kernel: AppArmor: AppArmor sha1 policy hashing enabled May 09 20:44:18 helios2 kernel: usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd May 09 20:44:18 helios2 kernel: pcie_power: supplied by vcc5v0_perdev May 09 20:44:18 helios2 kernel: vcc3v3_sys_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc3v0_sd: supplied by vcc3v3_sys_s3 May 09 20:44:18 helios2 kernel: vcc5v0_usb: supplied by vcc5v0_perdev May 09 20:44:18 helios2 kernel: vcc5v0_typec: supplied by vcc5v0_usb May 09 20:44:18 helios2 kernel: usblan_power: supplied by vcc5v0_usb May 09 20:44:18 helios2 kernel: pca953x 2-0020: using no AI May 09 20:44:18 helios2 kernel: rk808 0-001b: chip id: 0x0 May 09 20:44:18 helios2 kernel: rk808-regulator rk808-regulator: there is no dvs0 gpio May 09 20:44:18 helios2 kernel: rk808-regulator rk808-regulator: there is no dvs1 gpio May 09 20:44:18 helios2 kernel: rk808-regulator rk808-regulator: max buck steps per change: 4 May 09 20:44:18 helios2 kernel: vdd_center: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vdd_cpu_l: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc_ddr_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc1v8_sys_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc1v8_dvp: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc3v0_touch: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc1v8_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV May 09 20:44:18 helios2 kernel: vcc_sdio_s0: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcca3v0_codec: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc1v5_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcca1v8_codec: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc3v0_s3: supplied by vcc5v0_sys May 09 20:44:18 helios2 kernel: vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER May 09 20:44:18 helios2 kernel: vcc3v3_sys_s0: supplied by vcc3v3_sys_s3 May 09 20:44:18 helios2 kernel: vcc3v3_s0: supplied by vcc3v3_sys_s3 May 09 20:44:18 helios2 kernel: rk808-rtc rk808-rtc: registered as rtc0 May 09 20:44:18 helios2 kernel: rk808-rtc rk808-rtc: setting system clock to 2024-05-09T19:41:41 UTC (1715283701) May 09 20:44:18 helios2 kernel: dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode. May 09 20:44:18 helios2 kernel: dwmmc_rockchip fe320000.mmc: Using internal DMA controller. May 09 20:44:18 helios2 kernel: dwmmc_rockchip fe320000.mmc: Version ID is 270a May 09 20:44:18 helios2 kernel: dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo May 09 20:44:18 helios2 kernel: dwmmc_rockchip fe320000.mmc: Got CD GPIO May 09 20:44:18 helios2 kernel: vcc1v8_sys_s0: supplied by vcc1v8_sys_s3 May 09 20:44:18 helios2 kernel: vcc0v9_s3: supplied by vcc3v3_sys_s3 May 09 20:44:18 helios2 kernel: avdd_0v9_s0: supplied by vcc1v8_sys_s3 May 09 20:44:18 helios2 kernel: avdd_1v8_s0: supplied by vcc3v3_sys_s3 May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges: May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000 May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000 May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: no bus scan delay, default to 0 ms May 09 20:44:18 helios2 kernel: mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: wait 0 ms (from device tree) before bus scan May 09 20:44:18 helios2 kernel: rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 May 09 20:44:18 helios2 kernel: pci_bus 0000:00: root bus resource [bus 00-1f] May 09 20:44:18 helios2 kernel: pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] May 09 20:44:18 helios2 kernel: pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400 May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: supports D1 May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: PME# supported from D0 D1 D3hot May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: [197b:0585] type 00 class 0x010601 May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x10: [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x14: [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x18: [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x1c: [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid May 09 20:44:18 helios2 kernel: usb 2-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04 May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x20: [io size 0x0080] May 09 20:44:18 helios2 kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 May 09 20:44:18 helios2 kernel: usb 2-1: Product: USB3.0 Hub May 09 20:44:18 helios2 kernel: usb 2-1: Manufacturer: VIA Labs, Inc. May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512) May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: PME# supported from D3hot May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link) May 09 20:44:18 helios2 kernel: pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01 May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 0: no space for [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 1: no space for [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 1: failed to assign [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 2: no space for [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 2: failed to assign [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 3: no space for [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 3: failed to assign [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 4: no space for [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:01:00.0: BAR 4: failed to assign [io size 0x0080] May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: PCI bridge to [bus 01] May 09 20:44:18 helios2 kernel: pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff] May 09 20:44:18 helios2 kernel: pcieport 0000:00:00.0: enabling device (0000 -> 0002) May 09 20:44:18 helios2 kernel: pcieport 0000:00:00.0: PME: Signaling with IRQ 89 May 09 20:44:18 helios2 kernel: pcieport 0000:00:00.0: AER: enabled with IRQ 89 May 09 20:44:18 helios2 kernel: ahci 0000:01:00.0: version 3.0 May 09 20:44:18 helios2 kernel: ahci 0000:01:00.0: enabling device (0000 -> 0002) May 09 20:44:18 helios2 kernel: ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled May 09 20:44:18 helios2 kernel: ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode May 09 20:44:18 helios2 kernel: ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh May 09 20:44:18 helios2 kernel: scsi host0: ahci May 09 20:44:18 helios2 kernel: scsi host1: ahci May 09 20:44:18 helios2 kernel: hub 2-1:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 2-1:1.0: 4 ports detected May 09 20:44:18 helios2 kernel: scsi host2: ahci May 09 20:44:18 helios2 kernel: scsi host3: ahci May 09 20:44:18 helios2 kernel: scsi host4: ahci May 09 20:44:18 helios2 kernel: ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 90 May 09 20:44:18 helios2 kernel: ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 91 May 09 20:44:18 helios2 kernel: ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 92 May 09 20:44:18 helios2 kernel: ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 93 May 09 20:44:18 helios2 kernel: ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 94 May 09 20:44:18 helios2 kernel: mmc1: CQHCI version 5.10 May 09 20:44:18 helios2 kernel: WCN: marlin_init entry! May 09 20:44:18 helios2 kernel: input: gpio-keys as /devices/platform/gpio-keys/input/input0 May 09 20:44:18 helios2 kernel: of_cfs_init May 09 20:44:18 helios2 kernel: of_cfs_init: OK May 09 20:44:18 helios2 kernel: mmc1: SDHCI controller on fe330000.mmc [fe330000.mmc] using ADMA May 09 20:44:18 helios2 kernel: mmc1: Command Queue Engine enabled May 09 20:44:18 helios2 kernel: mmc1: new HS200 MMC card at address 0001 May 09 20:44:18 helios2 kernel: mmcblk1: mmc1:0001 AJTD4R 14.6 GiB May 09 20:44:18 helios2 kernel: mmcblk1: p1 May 09 20:44:18 helios2 kernel: mmcblk1boot0: mmc1:0001 AJTD4R 4.00 MiB May 09 20:44:18 helios2 kernel: mmcblk1boot1: mmc1:0001 AJTD4R 4.00 MiB May 09 20:44:18 helios2 kernel: mmcblk1rpmb: mmc1:0001 AJTD4R 4.00 MiB, chardev (241:0) May 09 20:44:18 helios2 kernel: usb 2-1.4: new SuperSpeed USB device number 3 using xhci-hcd May 09 20:44:18 helios2 kernel: usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00 May 09 20:44:18 helios2 kernel: usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6 May 09 20:44:18 helios2 kernel: usb 2-1.4: Product: USB 10/100/1G/2.5G LAN May 09 20:44:18 helios2 kernel: usb 2-1.4: Manufacturer: Realtek May 09 20:44:18 helios2 kernel: usb 2-1.4: SerialNumber: 000000001 May 09 20:44:18 helios2 kernel: ata1: softreset failed (1st FIS failed) May 09 20:44:18 helios2 kernel: ata1: softreset failed (1st FIS failed) May 09 20:44:18 helios2 kernel: vcc3v0_sd: disabling May 09 20:44:18 helios2 kernel: ata1: softreset failed (1st FIS failed) May 09 20:44:18 helios2 kernel: ata1: limiting SATA link speed to 3.0 Gbps May 09 20:44:18 helios2 kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320) May 09 20:44:18 helios2 kernel: ata1: link online but 1 devices misclassified, device detection might fail May 09 20:44:18 helios2 kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) May 09 20:44:18 helios2 kernel: ata2.00: ATA-10: ST4000DM004-2CV104, 0001, max UDMA/133 May 09 20:44:18 helios2 kernel: ata2.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA May 09 20:44:18 helios2 kernel: ata2.00: configured for UDMA/133 May 09 20:44:18 helios2 kernel: scsi 1:0:0:0: Direct-Access ATA ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5 May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] 4096-byte physical blocks May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] Write Protect is off May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00 May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA May 09 20:44:18 helios2 kernel: sda: sda1 May 09 20:44:18 helios2 kernel: sd 1:0:0:0: [sda] Attached SCSI disk May 09 20:44:18 helios2 kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) May 09 20:44:18 helios2 kernel: ata3.00: ATA-10: ST4000DM004-2CV104, 0001, max UDMA/133 May 09 20:44:18 helios2 kernel: ata3.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA May 09 20:44:18 helios2 kernel: ata3.00: configured for UDMA/133 May 09 20:44:18 helios2 kernel: scsi 2:0:0:0: Direct-Access ATA ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5 May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] 4096-byte physical blocks May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] Write Protect is off May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00 May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA May 09 20:44:18 helios2 kernel: sdb: sdb1 May 09 20:44:18 helios2 kernel: sd 2:0:0:0: [sdb] Attached SCSI disk May 09 20:44:18 helios2 kernel: ata4: SATA link down (SStatus 0 SControl 300) May 09 20:44:18 helios2 kernel: ata5: SATA link down (SStatus 0 SControl 300) May 09 20:44:18 helios2 kernel: Freeing unused kernel memory: 4352K May 09 20:44:18 helios2 kernel: Run /init as init process May 09 20:44:18 helios2 kernel: with arguments: May 09 20:44:18 helios2 kernel: /init May 09 20:44:18 helios2 kernel: with environment: May 09 20:44:18 helios2 kernel: HOME=/ May 09 20:44:18 helios2 kernel: TERM=linux May 09 20:44:18 helios2 kernel: ubootpart=306d94a6-01 May 09 20:44:18 helios2 kernel: cgroup_enable=memory May 09 20:44:18 helios2 kernel: cgroup_memory=1 May 09 20:44:18 helios2 kernel: input: adc-keys as /devices/platform/adc-keys/input/input1 May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: PTP uses main clock May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: RX delay(0x20). May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: clock input from PHY May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: init for RGMII May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35 May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: DWMAC1000 May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: COE Type 2 May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: Normal descriptors May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: Ring mode enabled May 09 20:44:18 helios2 kernel: rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer May 09 20:44:18 helios2 kernel: RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL) May 09 20:44:18 helios2 kernel: RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL) May 09 20:44:18 helios2 kernel: async_tx: api initialized (async) May 09 20:44:18 helios2 kernel: EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. May 09 20:44:18 helios2 systemd[1]: Inserted module 'autofs4' May 09 20:44:18 helios2 systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) May 09 20:44:18 helios2 systemd[1]: Detected architecture arm64. May 09 20:44:18 helios2 systemd[1]: Set hostname to <helios2>. May 09 20:44:18 helios2 kernel: dw-apb-uart ff1a0000.serial: forbid DMA for kernel console May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 systemd[1]: /lib/systemd/system/haveged.service:19: Unknown lvalue 'ProtectHostname' in section 'Service', ignoring May 09 20:44:18 helios2 systemd[1]: /lib/systemd/system/haveged.service:20: Unknown lvalue 'ProtectKernelLogs' in section 'Service', ignoring May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 systemd[1]: Listening on udev Control Socket. May 09 20:44:18 helios2 systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 systemd[1]: Listening on fsck to fsckd communication Socket. May 09 20:44:18 helios2 systemd[1]: Listening on initctl Compatibility Named Pipe. May 09 20:44:18 helios2 systemd[1]: Reached target Swap. May 09 20:44:18 helios2 kernel: lm75 2-004c: supply vs not found, using dummy regulator May 09 20:44:18 helios2 kernel: hwmon hwmon2: temp1_input not attached to any thermal zone May 09 20:44:18 helios2 kernel: lm75 2-004c: hwmon2: sensor 'lm75' May 09 20:44:18 helios2 kernel: EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. May 09 20:44:18 helios2 kernel: mc: Linux media interface: v0.10 May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:18 helios2 kernel: videodev: Linux video capture interface: v2.00 May 09 20:44:18 helios2 kernel: input: beeper as /devices/platform/beeper/input/input2 May 09 20:44:18 helios2 kernel: sd 1:0:0:0: Attached scsi generic sg0 type 0 May 09 20:44:18 helios2 kernel: sd 2:0:0:0: Attached scsi generic sg1 type 0 May 09 20:44:18 helios2 kernel: rockchip-iep ff670000.iep: Device rockchip-iep registered as /dev/video0 May 09 20:44:18 helios2 kernel: rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned. May 09 20:44:18 helios2 kernel: rockchip-rga ff680000.rga: HW Version: 0x03.02 May 09 20:44:18 helios2 kernel: hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned. May 09 20:44:18 helios2 kernel: rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video1 May 09 20:44:18 helios2 kernel: rkvdec ff660000.video-codec: Adding to iommu group 1 May 09 20:44:18 helios2 kernel: OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22 May 09 20:44:18 helios2 kernel: hantro-vpu ff650000.video-codec: Adding to iommu group 0 May 09 20:44:18 helios2 kernel: hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video3 May 09 20:44:18 helios2 kernel: hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video4 May 09 20:44:18 helios2 kernel: panfrost ff9a0000.gpu: clock rate = 500000000 May 09 20:44:18 helios2 kernel: rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops) May 09 20:44:18 helios2 kernel: [drm] unsupported AFBC format[3231564e] May 09 20:44:18 helios2 kernel: rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops) May 09 20:44:18 helios2 kernel: rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops) May 09 20:44:18 helios2 kernel: cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn May 09 20:44:18 helios2 kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes May 09 20:44:18 helios2 kernel: [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: xHCI Host Controller May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: irq 74, io mem 0xfe800000 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: xHCI Host Controller May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4 May 09 20:44:18 helios2 kernel: xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed May 09 20:44:18 helios2 kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 May 09 20:44:18 helios2 kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:18 helios2 kernel: usb usb3: Product: xHCI Host Controller May 09 20:44:18 helios2 kernel: usb usb3: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd May 09 20:44:18 helios2 kernel: usb usb3: SerialNumber: xhci-hcd.3.auto May 09 20:44:18 helios2 kernel: ehci-platform fe380000.usb: EHCI Host Controller May 09 20:44:18 helios2 kernel: panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 May 09 20:44:18 helios2 kernel: panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400 May 09 20:44:18 helios2 kernel: panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 May 09 20:44:18 helios2 kernel: panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 May 09 20:44:18 helios2 kernel: hub 3-0:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 3-0:1.0: 1 port detected May 09 20:44:18 helios2 kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. May 09 20:44:18 helios2 kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 May 09 20:44:18 helios2 kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:18 helios2 kernel: usb usb4: Product: xHCI Host Controller May 09 20:44:18 helios2 kernel: usb usb4: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd May 09 20:44:18 helios2 kernel: usb usb4: SerialNumber: xhci-hcd.3.auto May 09 20:44:18 helios2 kernel: hub 4-0:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 4-0:1.0: 1 port detected May 09 20:44:18 helios2 kernel: cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn May 09 20:44:18 helios2 kernel: [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 0 May 09 20:44:18 helios2 kernel: ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5 May 09 20:44:18 helios2 kernel: ehci-platform fe380000.usb: irq 34, io mem 0xfe380000 May 09 20:44:18 helios2 kernel: ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 May 09 20:44:18 helios2 kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 May 09 20:44:18 helios2 kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:18 helios2 kernel: usb usb5: Product: EHCI Host Controller May 09 20:44:18 helios2 kernel: usb usb5: Manufacturer: Linux 5.15.93-rockchip64 ehci_hcd May 09 20:44:18 helios2 kernel: usb usb5: SerialNumber: fe380000.usb May 09 20:44:18 helios2 kernel: hub 5-0:1.0: USB hub found May 09 20:44:18 helios2 kernel: hub 5-0:1.0: 1 port detected May 09 20:44:18 helios2 kernel: ohci-platform fe3a0000.usb: Generic Platform OHCI controller May 09 20:44:18 helios2 kernel: ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6 May 09 20:44:18 helios2 kernel: ohci-platform fe3a0000.usb: irq 35, io mem 0xfe3a0000 May 09 20:44:18 helios2 kernel: cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn May 09 20:44:18 helios2 kernel: usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 May 09 20:44:19 helios2 kernel: usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 May 09 20:44:19 helios2 kernel: usb usb6: Product: Generic Platform OHCI controller May 09 20:44:19 helios2 kernel: usb usb6: Manufacturer: Linux 5.15.93-rockchip64 ohci_hcd May 09 20:44:19 helios2 kernel: usb usb6: SerialNumber: fe3a0000.usb May 09 20:44:19 helios2 kernel: hub 6-0:1.0: USB hub found May 09 20:44:19 helios2 kernel: hub 6-0:1.0: 1 port detected May 09 20:44:19 helios2 kernel: EXT4-fs (sdb1): recovery complete May 09 20:44:19 helios2 kernel: EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. May 09 20:44:19 helios2 kernel: usb 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd May 09 20:44:19 helios2 kernel: EXT4-fs (sda1): recovery complete May 09 20:44:19 helios2 kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. May 09 20:44:19 helios2 kernel: r8152 2-1.4:1.0: Direct firmware load for rtl_nic/rtl8156a-2.fw failed with error -2 May 09 20:44:19 helios2 kernel: r8152 2-1.4:1.0: unable to load firmware patch rtl_nic/rtl8156a-2.fw (-2) May 09 20:44:19 helios2 kernel: r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256 May 09 20:44:19 helios2 kernel: r8152 2-1.4:1.0 eth1: v1.12.13 May 09 20:44:19 helios2 kernel: usbcore: registered new interface driver r8152 May 09 20:44:19 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:19 helios2 kernel: random: systemd: uninitialized urandom read (16 bytes read) May 09 20:44:19 helios2 kernel: cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn May 09 20:44:19 helios2 kernel: random: crng init done May 09 20:44:19 helios2 kernel: random: 99 urandom warning(s) missed due to ratelimiting May 09 20:44:19 helios2 systemd[1]: dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device: Job dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device/start timed out. May 09 20:44:19 helios2 systemd[1]: Timed out waiting for device /dev/disk/by-uuid/406e7e7d-9517-44af-bcde-4de3adbc6b80. May 09 20:44:19 helios2 systemd[1]: Dependency failed for /data/glusterfs/sda1. May 09 20:44:19 helios2 systemd[1]: Dependency failed for Local File Systems. May 09 20:44:19 helios2 systemd[1]: Dependency failed for Mark the need to relabel after reboot. May 09 20:44:19 helios2 systemd[1]: selinux-autorelabel-mark.service: Job selinux-autorelabel-mark.service/start failed with result 'dependency'. May 09 20:44:19 helios2 systemd[1]: local-fs.target: Job local-fs.target/start failed with result 'dependency'. May 09 20:44:19 helios2 systemd[1]: local-fs.target: Triggering OnFailure= dependencies. May 09 20:44:19 helios2 systemd[1]: data-glusterfs-sda1.mount: Job data-glusterfs-sda1.mount/start failed with result 'dependency'. May 09 20:44:19 helios2 systemd[1]: dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device: Job dev-disk-by\x2duuid-406e7e7d\x2d9517\x2d44af\x2dbcde\x2d4de3adbc6b80.device/start failed with result 'timeout'. May 09 20:44:19 helios2 kernel: zram: Added device: zram0 May 09 20:44:19 helios2 kernel: zram: Added device: zram1 May 09 20:44:19 helios2 kernel: zram: Added device: zram2 May 09 20:44:19 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL) May 09 20:44:19 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 May 09 20:44:19 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found May 09 20:44:19 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW May 09 20:44:19 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode May 09 20:44:19 helios2 kernel: zram0: detected capacity change from 0 to 3956192 May 09 20:44:19 helios2 kernel: Adding 1978092k swap on /dev/zram0. Priority:5 extents:1 across:1978092k SSFS May 09 20:44:19 helios2 kernel: zram1: detected capacity change from 0 to 102400 May 09 20:44:19 helios2 kernel: EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none. May 09 20:44:19 helios2 kernel: ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) May 09 20:44:19 helios2 systemd-journald[1325]: Journal started May 09 20:44:19 helios2 systemd-journald[1325]: Runtime journal (/run/log/journal/25f3942c18884f46bd8ed710d6b0edb4) is 4.8M, max 38.6M, 33.8M free. May 09 20:44:19 helios2 systemd-modules-load[410]: Inserted module 'lm75' May 09 20:44:19 helios2 systemd-modules-load[410]: Inserted module 'ledtrig_netdev' May 09 20:44:19 helios2 systemd-udevd[469]: Using default interface naming scheme 'v240'. May 09 20:44:19 helios2 systemd-udevd[448]: Process '/bin/ln -sf /sys/devices/platform/ff120000.i2c/i2c-2/2-004c/hwmon/hwmon2 /dev/thermal-board' failed with exit code 1. May 09 20:44:19 helios2 systemd-udevd[469]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable. May 09 20:44:19 helios2 systemd-udevd[469]: link_config: could not get ethtool features for eth0 May 09 20:44:19 helios2 systemd-udevd[469]: Could not set offload features of eth0: Device or resource busy May 09 20:44:19 helios2 systemd-udevd[452]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable. May 09 20:44:19 helios2 systemd-udevd[443]: Process '/bin/ln -sf /sys/devices/virtual/thermal/thermal_zone0/hwmon0 /dev/thermal-cpu' failed with exit code 1. May 09 20:44:19 helios2 systemd-udevd[441]: Using default interface naming scheme 'v240'. May 09 20:44:19 helios2 systemd-udevd[441]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable. May 09 20:44:19 helios2 ifup[558]: ifup: waiting for lock on /run/network/ifstate.eth0 May 09 20:44:19 helios2 sh[560]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /run/resolvconf/resolv.conf May 09 20:44:19 helios2 sh[560]: eth0=eth0 May 09 20:44:19 helios2 armbian-zram-config[562]: Setting up swapspace version 1, size = 1.9 GiB (2025566208 bytes) May 09 20:44:19 helios2 armbian-zram-config[562]: no label, UUID=ed7bfb56-a4cb-453e-9cbd-5fe82531227e May 09 20:44:19 helios2 armbian-zram-config[562]: mke2fs 1.46.2 (28-Feb-2021) May 09 20:44:19 helios2 armbian-zram-config[562]: [74B blob data] May 09 20:44:19 helios2 armbian-zram-config[562]: Creating filesystem with 12800 4k blocks and 12800 inodes May 09 20:44:19 helios2 armbian-zram-config[562]: [41B blob data] May 09 20:44:19 helios2 armbian-zram-config[562]: [38B blob data] May 09 20:44:19 helios2 armbian-zram-config[562]: [75B blob data] May 09 20:44:19 helios2 armbian-hardware-optimization[585]: aplay: device_list:272: no soundcards found... May 09 20:44:19 helios2 armbian-ramlog[975]: e2label: Bad magic number in super-block while trying to open /dev/zram0 May 09 20:44:19 helios2 armbian-hardware-optimization[585]: [ ok ] Setting bfq I/O scheduler for sda May 09 20:44:19 helios2 armbian-hardware-optimization[585]: [ ok ] Setting bfq I/O scheduler for sdb May 09 20:44:19 helios2 armbian-hardware-optimization[585]: [ ok ] Setting none I/O scheduler for mmcblk1 May 09 20:44:19 helios2 armbian-hardware-optimization[585]: [ ok ] Setting none I/O scheduler for mmcblk1boot0 May 09 20:44:19 helios2 armbian-hardware-optimization[585]: [ ok ] Setting none I/O scheduler for mmcblk1boot1 May 09 20:44:19 helios2 armbian-ramlog[975]: Mounting /dev/zram1 as /var/log/ May 09 20:44:19 helios2 armbian-ramlog[975]: Thu 09 May 2024 08:44:16 PM BST: Loading logs from storage May 09 20:44:19 helios2 armbian-ramlog[975]: sending incremental file list May 09 20:44:19 helios2 armbian-ramlog[975]: ./ May 09 20:44:19 helios2 armbian-ramlog[975]: alternatives.log May 09 20:44:19 helios2 armbian-ramlog[975]: armbian-hardware-monitor.log May 09 20:44:19 helios2 armbian-ramlog[975]: auth.log May 09 20:44:19 helios2 armbian-ramlog[975]: bootstrap.log May 09 20:44:19 helios2 armbian-ramlog[975]: btmp May 09 20:44:19 helios2 armbian-ramlog[975]: daemon.log May 09 20:44:19 helios2 armbian-ramlog[975]: debug May 09 20:44:19 helios2 armbian-ramlog[975]: dpkg.log May 09 20:44:19 helios2 armbian-ramlog[975]: faillog May 09 20:44:19 helios2 armbian-ramlog[975]: kern.log May 09 20:44:19 helios2 armbian-ramlog[975]: lastlog May 09 20:44:19 helios2 armbian-ramlog[975]: messages May 09 20:44:19 helios2 armbian-ramlog[975]: nand-sata-install.log May 09 20:44:19 helios2 armbian-ramlog[975]: syslog May 09 20:44:19 helios2 armbian-ramlog[975]: user.log May 09 20:44:19 helios2 armbian-ramlog[975]: wtmp May 09 20:44:19 helios2 armbian-ramlog[975]: apt/ May 09 20:44:19 helios2 armbian-ramlog[975]: apt/history.log May 09 20:44:19 helios2 armbian-ramlog[975]: apt/term.log May 09 20:44:19 helios2 armbian-ramlog[975]: chrony/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/bitd.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/cli.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/cmd_history.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/data-media.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/glusterd.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/media-rebalance.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/scrub.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/bricks/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/bricks/data-glusterfs-sda1-brick1.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/bricks/data-glusterfs-sdb1-brick1.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/bricks/data-glusterfs-sdc1-brick1.log May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/geo-replication-slaves/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/geo-replication-slaves/mbr/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/geo-replication/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/gfproxy/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/gfproxy/media/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/snaps/ May 09 20:44:19 helios2 armbian-ramlog[975]: glusterfs/snaps/media/ May 09 20:44:19 helios2 armbian-ramlog[975]: private/ May 09 20:44:19 helios2 armbian-ramlog[975]: runit/ May 09 20:44:19 helios2 armbian-ramlog[975]: runit/ssh/ May 09 20:44:19 helios2 armbian-ramlog[975]: sysstat/ May 09 20:44:19 helios2 armbian-ramlog[975]: unattended-upgrades/ May 09 20:44:19 helios2 armbian-ramlog[975]: unattended-upgrades/unattended-upgrades-shutdown.log May 09 20:44:19 helios2 armbian-ramlog[975]: sent 9,084,219 bytes received 650 bytes 6,056,579.33 bytes/sec May 09 20:44:19 helios2 armbian-ramlog[975]: total size is 9,079,468 speedup is 1.00 May 09 20:44:19 helios2 systemd[1]: Starting Flush Journal to Persistent Storage... May 09 20:44:19 helios2 systemd-journald[1325]: Runtime journal (/run/log/journal/25f3942c18884f46bd8ed710d6b0edb4) is 4.8M, max 38.6M, 33.8M free. May 09 20:44:19 helios2 systemd[1]: Started Flush Journal to Persistent Storage. May 09 20:44:19 helios2 systemd[1]: Starting Create Volatile Files and Directories... May 09 20:44:19 helios2 systemd[1]: Started Create Volatile Files and Directories. May 09 20:44:19 helios2 systemd[1]: Starting RPC bind portmap service... May 09 20:44:19 helios2 systemd[1]: Starting Update UTMP about System Boot/Shutdown... May 09 20:44:19 helios2 systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm. May 09 20:44:19 helios2 systemd[1]: Started RPC bind portmap service. May 09 20:44:19 helios2 systemd[1]: Reached target RPC Port Mapper. May 09 20:44:19 helios2 systemd[1]: Reached target Remote File Systems (Pre). May 09 20:44:19 helios2 haveged[1354]: haveged: command socket is listening at fd 3 May 09 20:44:19 helios2 systemd[1]: Mounting /data/media... May 09 20:44:19 helios2 systemd[1]: Started Update UTMP about System Boot/Shutdown. May 09 20:44:19 helios2 systemd[1]: Starting Update UTMP about System Runlevel Changes... May 09 20:44:19 helios2 systemd[1]: systemd-update-utmp-runlevel.service: Succeeded. May 09 20:44:19 helios2 systemd[1]: Started Update UTMP about System Runlevel Changes. May 09 20:44:19 helios2 haveged[1354]: haveged: ver: 1.9.14; arch: generic; vend: ; build: (gcc 10.2.1 CTV); collect: 128K May 09 20:44:19 helios2 haveged[1354]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 15456/64452 May 09 20:44:19 helios2 haveged[1354]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B): last entropy estimate 7.99723 May 09 20:44:19 helios2 haveged[1354]: haveged: fills: 0, generated: 0 May 09 20:44:20 helios2 kernel: rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off May 09 20:44:20 helios2 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready May 09 20:44:21 helios2 systemd[579]: emergency.service: Executable /bin/plymouth missing, skipping: No such file or directory May 09 20:44:22 helios2 mount[1355]: Mounting glusterfs on /data/media failed. May 09 20:44:22 helios2 systemd[1]: data-media.mount: Mount process exited, code=exited, status=1/FAILURE May 09 20:44:22 helios2 systemd[1]: Mounted /data/media. May 09 20:44:22 helios2 systemd[1]: Reached target Remote File Systems. May 09 20:44:22 helios2 systemd[1]: Startup finished in 1min 6.014s (kernel) + 1min 37.173s (userspace) = 2min 43.188s. May 09 20:48:11 helios2 sudo[1764]: root : TTY=ttyS2 ; PWD=/root ; USER=root ; COMMAND=/usr/bin/apt info armbian-bsp-cli-helios64 May 09 20:48:11 helios2 sudo[1764]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0) May 09 20:48:12 helios2 sudo[1764]: pam_unix(sudo:session): session closed for user root May 09 20:49:01 helios2 sudo[2123]: root : TTY=ttyS2 ; PWD=/root ; USER=root ; COMMAND=/usr/bin/apt info armbian-bsp-cli-helios64 May 09 20:49:01 helios2 sudo[2123]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0) May 09 20:49:02 helios2 sudo[2123]: pam_unix(sudo:session): session closed for user root May 09 20:50:27 helios2 sudo[2130]: root : TTY=ttyS2 ; PWD=/root ; USER=root ; COMMAND=/usr/sbin/service status --all May 09 20:50:27 helios2 sudo[2130]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0) May 09 20:50:27 helios2 sudo[2130]: pam_unix(sudo:session): session closed for user root``` Edited May 9, 2024 by Ben S 0 Quote
