SpityuHun Posted March 26, 2017 Posted March 26, 2017 Hy all! I have ona big problem. I use armbian 5.24(ubuntu 16.04.2 lts) on pi pc, install transmission torrent from terminal line( sudo apt-get install transmission*), install success, run transmission, set up(download dir,port etc), working fine. Restart app, and "oh-oh" transmission not saved modified settings and lose downloaded torrent file, download list is empty, all settings back to default... I read many guide fix this problem. Not working permission change, not work group change, not work reinstall, not work daemon manual settings, apps not read/save config file... Idea?
Igor Posted March 26, 2017 Posted March 26, 2017 It looks like one of the most common problems. Bad SD card. https://docs.armbian.com/User-Guide_Getting-Started/
SpityuHun Posted March 26, 2017 Author Posted March 26, 2017 54 minutes ago, Igor said: It looks like one of the most common problems. Bad SD card. https://docs.armbian.com/User-Guide_Getting-Started/ Sd card is not bad. Qbittorrent work fine,saving settings and dont delete download list after restart...99% transmission is bad build...
Igor Posted March 26, 2017 Posted March 26, 2017 You said settings are not saved ... one thing is with transmission - you have to disable daemon when you edit config file otherwise changes are not saved. If low level things are working fine, than this is a general issue.
SpityuHun Posted March 26, 2017 Author Posted March 26, 2017 48 minutes ago, Igor said: You said settings are not saved ... one thing is with transmission - you have to disable daemon when you edit config file otherwise changes are not saved. If low level things are working fine, than this is a general issue. No no no... I edit settings.json and save, nano saving modified settings, transmission app not read and/or write this settings, only using default value...the app can't access and read settings files...
Igor Posted March 26, 2017 Posted March 26, 2017 If you were editing settings while transmission was running it's normal, than it doesn't work.
