Hello, I'm trying to upgrade Armbian on my little OrangePi Lite, and it's been 3 days at it already. It is stuck at "Compiling headers", and it is not hung, I can use it.
It does happen from time to time to all my SoCs, sometimes I prefer to re-dd and reconfigure.
So I was thinking, if compilation cannot be avoided, can it be done on another computer? Cross-compile?
If you don't need headers, you can kill that process that upgrade can continue and repeat headers compilation manually later.
It worked, thank you.
But I think I made a valid point, somebody would need the headers and SoCs usually are too underpowered to fast compiling. Maybe it can be done on a faster machine and later just installed on the destination SoC?
It is usually a storage problem rather than CPU utilization. Adding a timeout for the headers compilation is on the TODO list, but it will be implemented slowly and probably not soon.
Can you explain how to recompile headers? thank you
