I lost whole day yesterday to try boot with new images from Armbian download page - kernel 6.1 / kernel 6.8 bookworm/trixi and none boots...
If I take Ubuntu or Debian image I have no problem to boot from.
Do you have the same?
I tried a few images and I wasn't able to use only the 6.8.10/11 because of video issues. All the others with kernel 6.1 worked fine. Maybe you're using the non-plus version of the images?
8 hours ago, ricardo_brz said:
doesn't look like it's Armbian.
Because it isn't. That is some other people's work.
OP most likely used wrong image.
how exactly are you writing to the SD card? I just did it today with Gnome Image Writer and it worked without any issue. The image I used was https://mirror-us-stl1.armbian.airframes.io/dl/orangepi5-plus/archive/Armbian_24.5.1_Orangepi5-plus_noble_vendor_6.1.43_gnome-oibaf_desktop.img.xz
There is no need to unpack. Right click -> open with Image Writer -> select destination (SD card) -> wait until the process finishes -> boot with SD card -> setup Armbian -> start using.
For me all Armbian images stop after that:
DDR Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
Manufacturer ID:0x6
CH0 RX Vref:30.7%, TX Vref:21.8%,20.8%
CH1 RX Vref:31.7%, TX Vref:23.8%,22.8%
CH2 RX Vref:30.7%, TX Vref:21.8%,20.8%
CH3 RX Vref:31.7%, TX Vref:21.8%,21.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-orangepi (Jun 01 2023 - 11:41:40)
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(806278dba1...) + OK
## Checking uboot 0x00200000 ... sha256(cc23d8931f...) + OK
## Checking fdt 0x00311f08 ... sha256(d2dda3ef7c...) + OK
## Checking atf-2 0x000f0000 ... sha256(c00c7fd75b...) + OK
## Checking atf-3 0xff100000 ... sha256(71c3a5841b...) + OK
## Checking atf-4 0xff001000 ... sha256(2301cf73be...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 920.859 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-405-gb52c2eadd:derrick.huang
NOTICE:  BL31: Built : 11:23:47, Aug 15 2022
INFO:    spec: 0x1
INFO:    ext 32k is valid
I gave up with that  now... I installed Ubuntu and it works :)
Maybe I would come back to Armbian later...
So OP confirms there is no issue since they refuse to provide necessary information.
Case closed.
  • Werner locked this topic
