george Posted April 13, 2017 Share Posted April 13, 2017 Hi there, I recently purchased a NanoPi NEO Air from FriendlyElec with a CAM500B module. It works alright with the mjpg-streamer and their provided Ubuntu Core. I built an Arabian 5.27 Nano Pi Air Debian Jessie image with the default kernel and the device is no longer found. I've forced the load of ov5640 and vfe_v4l2 in /etc/modules, but /dev/video0 isn't appearing. The kernel log has this in it when the module is loaded: [ 116.519650] [OV5640@lex]init_sensor - frame_rate: 0, max_win_size: 11 If I boot back to Ubuntu Core via SD, the camera is back. Link to comment Share on other sites More sharing options...
Igor Posted April 13, 2017 Share Posted April 13, 2017 This camera is working / used to work in Armbian (legacy kernel only!) - I did tests by myself ... but IIRC right modules at right order is a problem. I don't recall which, perhaps @@lex know ? Link to comment Share on other sites More sharing options...
george Posted April 13, 2017 Author Share Posted April 13, 2017 Thanks for the reply. I got the camera detected again. It helps to change the /boot/bin/nanopiair.fex instead of /boot/bin/nanopineo.fex. Nothing to see here Link to comment Share on other sites More sharing options...
