Hqnicolas Posted November 26, 2024 Author Posted November 26, 2024 @cmuki try to run https://forum.armbian.com/topic/40483-efforts-to-develop-firmware-for-h96-max-m9-rk3576-tv-box-8g128g/#findComment-202914 your benchmark shows the rknpu Status of performance related governors found below /sys (w/o cpufreq): * dmc: dmc_ondemand / 528 MHz (rknpu_ondemand dmc_ondemand userspace powersave performance simple_ondemand / 528 1068 1560 2112) * 27700000.npu: rknpu_ondemand / 300 MHz (rknpu_ondemand dmc_ondemand userspace powersave performance simple_ondemand / 300 400 500 600 700 800 900 1000) 0 Quote
Tusemanu Posted December 3, 2024 Posted December 3, 2024 26.11.2024 в 14:38, Hqnicolas сказал: your benchmark shows the rknpu Hello. Those. Is RKNPU working correctly? Have you tried VPU, GPU, does it work? 0 Quote
Hqnicolas Posted December 4, 2024 Author Posted December 4, 2024 On 12/3/2024 at 9:52 AM, Tusemanu said: Those. Is RKNPU working correctly? Have you tried VPU, GPU, does it work? for tv-box it's all at your own risk anything you find in this thread should always be considered non-functional or unreleased do not buy any tv-box, buy only official boards from manufacturers https://www.armbian.com/partners/ 1 Quote
kevchi Posted December 21, 2024 Posted December 21, 2024 Hi all. Any idea how to root the device? 0 Quote
tnt Posted December 22, 2024 Posted December 22, 2024 (edited) has anyone managed to save the changed u-boot environment? it seems that uboot.img is a binary u-boot file that stores the environment variables that are set during compilation. Edited December 22, 2024 by tnt add remark 0 Quote
Hqnicolas Posted January 2, 2025 Author Posted January 2, 2025 (edited) On 12/22/2024 at 9:24 AM, tnt said: has anyone managed to save the changed u-boot environment? You don't need to save the u-boot env, it's included in your armbian build. @tnt don't trust any image from factory or other forum users, just build your own images. On 9/13/2024 at 4:51 PM, hzdm said: I was able to fix the reset button in U-boot. I got the uboot.dtb file from the Android firmware. To add it to the build - you need to replace the armsom-sige5-rk3576_defconfig file in the build/patch/u-boot/legacy/u-boot-armsom-rk3576/defconfig/ directory armsom-sige5-rk3576_defconfig Edited January 2, 2025 by Hqnicolas 0 Quote
Hqnicolas Posted January 2, 2025 Author Posted January 2, 2025 On 12/21/2024 at 7:11 AM, kevchi said: Hi all. Any idea how to root the device? this is an Linux development community, Here is an tutorial for android users: https://youtu.be/1vpepaQ-VQQ 0 Quote
Freeze Posted January 4, 2025 Posted January 4, 2025 Hello. Thanks for your work, fine result. i've tested desktop image and.. 1) For begginers, before executing the command "rkdeveloptool db...", make sure that the board is in operation mode => maskrom rkdeveloptool list rkdeveloptool rd 3 #and after that h96 ready to: rkdeveloptool db RK3576_MiniLoaderAll.bin rkdeveloptool wl 0x0 Armbian-unofficial_24.8.0-trunk_H96-m9_noble_vendor_6.1.75_gnome_desktop.img ========================== 2) Disable hibernate, i catched it on SSH session (pic 1) helped me gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-ac-type nothing 3) HDMI i use virtual monitor for stable work, without real monitor #in terminal sudo nano /usr/share/X11/xorg.conf.d/10-quirks.conf add it on end of file and save. Switch off hdmi from h96 and restart. Section "Monitor" Identifier "Monitor0" HorizSync 28.0-80.0 VertRefresh 48.0-75.0 # https://arachnoid.com/modelines/ # 1920x1080 @ 60.00 Hz (GTF) hsync: 67.08 kHz; pclk: 172.80 MHz Modeline "1920x1080_60.00" 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -HSync +Vsync EndSection Section "Device" Identifier "Card0" Driver "dummy" VideoRam 256000 EndSection Section "Screen" DefaultDepth 24 Identifier "Screen0" Device "Card0" Monitor "Monitor0" SubSection "Display" Depth 24 Modes "1920x1080_60.00" EndSubSection EndSection On other PCs, only the virtual display works. In this case, both can work. It doesn't have to be that way, but it's useful in this case. ====================================== One question. I soldered sd slot on h96, but cant see disk on terminal, lsblk shows just mmcblk2. is it poorly soldered or do I need to do something else? 0 Quote
tnt Posted January 5, 2025 Posted January 5, 2025 02.01.2025 в 15:40, Hqnicolas сказал: You don't need to save the u-boot env, it's included in your armbian build. @tnt don't trust any image from factory or other forum users, just build your own images. I am considering the possibility of implementing the dual boot feature, for example emmc (android), usb/sd armbian. 0 Quote
Freeze Posted January 5, 2025 Posted January 5, 2025 After apt-get update and upgrade DTB files was damaged :(( How its recovery, dont know rkdeveloptool dont working rkdeveloptool reboot-maskrom Reset Device quit, creating comm object failed! It's log from console interface(COM port) Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x40040000 ... sha256(1d13f803de...) + OK ## Checking uboot 0x40200000 ... sha256(ad96202f45...) + OK ## Checking fdt 0x4033dd80 ... sha256(6d0c8a3eca...) + OK ## Checking atf-2 0x400f0000 ... sha256(2f297c059b...) + OK ## Checking atf-3 0x3fe70000 ... sha256(9d9e1b461e...) + OK ## Checking optee 0x48400000 ... sha256(31c3421ab3...) + OK Jumping to U-Boot(0x40200000) via ARM Trusted Firmware(0x40040000) Total: 94.153/238.645 ms INFO: Preloader serial: 0 NOTICE: BL31: v2.3():v2.3-749-g30018b771:derrick.huang, fwver: v1.04 NOTICE: BL31: Built : 09:43:01, Apr 16 2024 INFO: ext 32k is not detected INFO: ARM GICv2 driver initialized INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 1 INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 I/TC: I/TC: OP-TEE version: 3.13.0-791-g185dc3c92 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Tue Apr 16 11:05:25 CST 2024 aarch64, fwver: v1.01 I/TC: OP-TEE memory: TEEOS 0x200000 TA 0xc00000 SHM 0x200000 I/TC: Primary CPU initializing I/TC: Primary CPU switching to normal world boot INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x40200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian-2017.09-S57b8-P9d8d-H8c72-V8051-Bda0a-R448a (Sep 13 2024 - 04:56:59 +0000) Model: Rockchip RK3576 Evaluation board MPIDR: 0x0 PreSerial: 0, raw, 0x2ad40000 DRAM: 4 GiB Sysmem: init Relocation Offset: bda21000 Relocation fdt: fb9f9a70 - fb9fecf0 CR: M/C/I Using default environment DM: v2 mmc@2a310000: 1, mmc@2a330000: 0 Bootdev(atags): mmc 0 MMC0: HS400 Enhanced Strobe, 200Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition Failed to load DTB, ret=-19 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Rockchip RK3576 Evaluation board download key pressed... entering download mode... RKUSB: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x3a3e000 \usb device is high-speed \usb device is high-speed 0 Quote
Hqnicolas Posted January 5, 2025 Author Posted January 5, 2025 32 minutes ago, Freeze said: After apt-get update and upgrade DTB files was damaged @Freeze the answer is in your name.... sudo apt install armbian-config sudo armbian-config select # SYSTEM select # FREEZE 0 Quote
Hqnicolas Posted January 5, 2025 Author Posted January 5, 2025 2 hours ago, tnt said: I am considering the possibility of implementing the dual boot feature, for example emmc (android), usb/sd armbian. just solder an SD card reader. it will works: https://forum.armbian.com/topic/28895-efforts-to-develop-firmware-for-h96-max-v56-rk3566-8g64g/page/12/#findComment-196381 https://forum.armbian.com/topic/24091-efforts-to-develop-firmware-for-h96-max-v56-rk3566-4g32g/#findComment-165929 0 Quote
Freeze Posted January 5, 2025 Posted January 5, 2025 Ok, but now, how i can recovery damage DTB files? I cant start armbian, just console is working 0 Quote
Hqnicolas Posted January 5, 2025 Author Posted January 5, 2025 (edited) 22 hours ago, Freeze said: how i can recovery damage DTB files? I don't know how you guys are burning the armbian images on this model so, emmc internal memory is not accessible without rkDevTool burning system, you will need to reflash the armbian system. This brings me an old warning, don't trust a TV box to store your files, always configure a cloud like gdrive, ms onedrive, nextcloud.... On 9/8/2024 at 4:17 AM, hzdm said: Press the reset button. Turn on the power. $rkdeveloptool db RK3576_MiniLoaderAll.bin $rkdeveloptool wl 0x0 Armbian-unofficial_24.8.0-trunk_H96-m9_noble_vendor_6.1.75_gnome_desktop-test_1.img I don't have this model of TV box, my country has closed it to external products, If you manage to recover, share it with others on the forum. Edited January 6, 2025 by Hqnicolas 0 Quote
tnt Posted January 17, 2025 Posted January 17, 2025 (edited) 05.01.2025 в 14:52, Hqnicolas сказал: just solder an SD card reader. soldering the card reader case was not successful. Perhaps the controller or some other elements need to be unsoldered. Edited January 17, 2025 by tnt Add photo 0 Quote
Hqnicolas Posted January 17, 2025 Author Posted January 17, 2025 (edited) 5 hours ago, tnt said: soldering the card reader case was not successful. Perhaps the controller or some other elements need to be unsoldered. It seems that this time they excluded the passive components from the board, look at the v56 board SD reader, you will need to add 2 ceramic capacitors to the board i think. and also check the Reader body 4 large GND pads if it's sodered. no device is needed to use the SD reader you must have a TTL connected to the board to debug, clear the EMMC with this method: using the T95 Method On android ROM flash the Wipe_part on Boot partition flash the Wipe_part on Recovery partition Connect the power cord... wait 1 second and in a fraction of second, connect the sd-Card on device..... if it doesn't boot, try again in a different timming 2 seconds after power. Based on this example Quote Edited January 17, 2025 by Hqnicolas 0 Quote
Vincenzoernst1 Posted January 18, 2025 Posted January 18, 2025 @tnt i also didnt get the the sd slot running. i soldered 3 NEW slots and none of them worked. since i ordered a 10 pack from china i didnt mind to dump them after unsoldering. i always got a dmesg error (logs somewhere above). there are 2 errors possible: bad china quality slots there is something on the board missing. also i dont think there was somthing wrong with the soldering since im an enineer and solder on daily basis. btw. i uses a hot air gun for solderding, therefor it i also should be working. if there are now 2 of us having problems i might thingk its no problem on my side..... 1 Quote
Deoptim Posted January 19, 2025 Posted January 19, 2025 18.01.2025 в 16:30, Vincenzoernst1 сказал: i also didnt get the the sd slot running. In dts RK809 node for that device needed configuration for SD card 3v3 regulator and 1v8 regulator - than theoretically SD card will work fine. 0 Quote
Hqnicolas Posted February 16, 2025 Author Posted February 16, 2025 (edited) Armbian's archives can be uncompressed with 7-Zip on Windows, Keka on OS X and 7z on Linux. Images shall only be written with imaging tools that validate burning results. This saves you from corrupted SD card contents. Approved Tools: USBImager a lightweight cross-platform imaging tool Balena Etcher an electron / node.js based cross-platform imaging tool (may contain spyware) Flashing Firmware on h96 max m9 rk3576 tv box h96 max m9 https://drive.google.com/drive/folders/1g63F8fGSLEA9iK2_Mqzd6F0xfaTRnGlm?usp=sharing https://drive.google.com/file/d/1hbM1ZCH8NU_snjVeZ-_hfRlnC_dgFcrK/view?usp=sharing https://drive.google.com/file/d/1n1Aw78G5zXKRYj5Nx19U_FrBIoU_NS6h/view?usp=sharing h96 max m9s https://drive.google.com/drive/folders/1Q360l5XbTVsWIvWkqy2xJ0sLpqHRSApM?usp=sharing https://drive.google.com/file/d/1n1Aw78G5zXKRYj5Nx19U_FrBIoU_NS6h/view?usp=sharing https://drive.google.com/file/d/1hbM1ZCH8NU_snjVeZ-_hfRlnC_dgFcrK/view?usp=sharing - Download the desired version of the stock firmware from the link from the post with the firmware. - To make it easier to install the firmware, create in the root directory of any disk (section) a folder (directory) with a memorable name, Latin characters and without spaces, for example H96MAX . - In the download folder (where the downloaded files are saved) on your computer, copy or move to the created folder H96MAX the previously downloaded archive file RK3576_firmware_tools.com and the stock firmware file that you will install. - Go to the H96MAX folder and unpack the downloaded archive RK3576_firmware_tools.com. Enter the folder RK3576_firmware_tools and further to the folder DriverAssitant_v5.12. Highlight the file name DriverInstall.exe with the mouse cursor and right-click on this line (PCM), open the context menu and click on the line - Run as administrator. Confirm (Yes / OK) in the system window - "Allow ...". In the driver installer window that appears, click on the virtual driver removal button "Uninstall driver", wait for the successful driver removal window. Confirm OK. Close the driver installer window. To remove possible leftovers and traces of the previous driver in the registry and in the Windows system, restart your computer. This will only benefit your computer's operating system. Pre-installing the driver is done in order to exclude possible failures during driver installation, because you do not know exactly whether a particular version of the processor driver was installed and which version of Rockchip. - After restarting your computer, go back to the folder \ H96MAX \ RK3576_firmware_tools \ DriverAssitant_v5.12. Highlight the file name DriverInstall.exe with the mouse cursor and right-click on this line (PCM), open the context menu and click on the line - Run as administrator. Confirm (Yes / OK) in the system window - "Allow ...". In the driver installer window that appears, now click on the virtual driver installation button "Install driver", wait for the successful driver installation window. Confirm OK. Close the driver installer window. The entire driver is installed. - Go to the H96MAX folder. Make sure that it contains the previously downloaded archive of the desired firmware. Typically, firmware downloaded from publicly available links is packed with archivers - zip, 7z, etc., in order to reduce its size and minimize the risk of data damage. For the firmware program, it is not an archive file that is needed, but the firmware image packed with an archiver. Therefore, the downloaded archive must be unpacked to get the firmware image itself (a file with a unique name and an .img extension). Unpack the firmware file. Go to the new unpacked archive folder and check if there is a file with the unique name of the installed firmware image and the .img extension. If your computer is running Windows 7, then to unpack the firmware file you will need a third-party archiver - WinRAR, 7z, etc. After making sure that there is a firmware image, go back to the H96MAX folder, then to the RK3576_firmware_tools folder, then to the FactoryTool_v1.89 folder. Make sure that there is a FactoryTool.exe file. This is the executable file of the firmware program. Do not close the explorer window with the FactoryTool.exe program folder open. - Go to the console with the TV connected. If the prefix is on, with a long press on the Power button on the panel, call the system menu and select and confirm Disable in it. The prefix should turn off and not go into service. You can check this if you press any button on the remote control (except the Power button) and the prefix does not turn on. If the console is turned off, follow the following steps in the sequence as indicated. Confidently pull the BP cable plug out of the console's power socket. Turn off the TV. Disconnect the TV from the mains. Disconnect the HDMI cable from the console. Disconnected from all cables, transfer to the computer. - On your computer, open an Explorer window with the FactoryTool.exe program folder. Double-click on the FactoryTool.exe file name and run the firmware program. In the opened window of the running program, click on the "Firmware" button (top left corner of the window) and in the window that appears, go to the directory where the unpacked firmware image that needs to be installed is located. Highlight the image file name with the mouse cursor and click "Open". The file selection window will close automatically and the firmware window will become active. Make sure that the program displays the path and file name of the firmware image in the "Firmware" section under the button of the same name, and in the Bootloader and Chip lines, the bootloader version number and the RK3576 chip name are indicated respectively. Until the Factory Tool program window is active, click on the "Restore" tab. After that, the "Restore" radio button should become active (light up). Remove your hands from the mouse and keyboard, the FactoryTool window should remain active and in the foreground. That's it, you can proceed to the final part of the firmware process itself. - Securely insert the plug of a previously prepared USB cable into the working USB port of the computer. Insert the previously prepared (sharpened) match into the hole in the headrest on the rear panel of the console. Dip it into the hole until the characteristic click and with one hand, lock the match in this position. With the other hand, take an elongated cable plug and confidently insert it into the USB 3.0 port (blue) of the prefix. After 1-2 seconds, a line will appear in the FactoryTool firmware window with information about the system number of the hub to which the prefix was connected, the type of the Loader device. Release and remove the match. In the program window, click on the virtual button "Run" and the direct firmware process will begin. Wait until the process is complete. After 2-3 minutes, if the firmware is successful, the line with information will be highlighted in green, an inscription will appear Success (Success) and the time spent on the firmware. Press the virtual button "Stop" at the top of the program window, close the program window. Disconnect the USB cable plug from the console. Re-interrogation for the new version is done. Move the console to the TV. - Make sure the TV is completely disconnected from the mains. Reliably connect the cable from the TV HDMI input to the console's HDMI output. Turn on the TV from the mains. Turn on the TV from the remote control. Wait until the TV is completely loaded. Confidently insert the plug of the console's pin cable into the console's power socket, if the console's power supply was disconnected from the mains, connect it. When you turn it on for the first time after the overload, the firmware in the console's memory should start, this will take longer than the usual download after turning it off. When the console boots up, make the necessary device settings. Edited February 16, 2025 by Hqnicolas 0 Quote
Pavel S Posted February 17, 2025 Posted February 17, 2025 Hi, after the Armbian test, I returned to Android 14, I have problems with AI VisionPQ and the serial number has changed. Do you have any thoughts on how to restore the serial number? 0 Quote
DeadOfGamers Posted March 31, 2025 Posted March 31, 2025 Hi everyone, how can the stock firmware be reloaded onto the box? 0 Quote
Keko Posted April 2, 2025 Posted April 2, 2025 (edited) Hello, Just compiled and installed Armbian 24.11 (6.1.75 vendor kernel for rk35xx) on this H96 MAx TV Box (m9S version) following instructions in this post. Thanks to @Hqnicolas, @cmuki, @hzdm et al. Everything running smoothly (except BT, as usual with the tv boxes). I had to recompile the vendor kernel with this patch applied to solve an issue reported here (applications crashing, system not responding) related to the maximum number of threads allowed by the kernel. Will try to run some RKNN stuff, to check the NPU and see it in action. My use case requires running some computer vision and style transfer models with a reasonable frame rate. Edited April 2, 2025 by Keko 3 Quote
cmuki Posted April 4, 2025 Posted April 4, 2025 (edited) Hello, Yesterday I decided to revisit this project, found out that the VPU actually WORKS with Jellyfin for HW Transcoding (I did use nyanmisaka's docker image here), but mainly to get Immich ML working on the NPU. Tried to compile a new image using the defconfig and csc given in this thread, but the boot process didn't resume after this error in u-boot: optee check api revision fail: -1.0 optee api revision is too low ### ERROR ### Please RESET the board ### Then I checked and saw that there are some differences in the defconfig and csc for sige 5 - some new and also some deleted stuff. It seems that Armsom no longer add OP-TEE to their defconfig. Also the Panfrost GPU driver is no longer blacklisted - https://github.com/armbian/build/pull/7307/files. The only way to restore the board to a working state was through rkdevtool and MASKROM mode. @hzdm, would you be able to compile new images with the latest version (6.1.99) of the kernel? I also did try compiling with the mesa-vpu extension. @Pavel S - in the 4PDA forum I saw some mentions of a serial number, but haven't checked them myself - https://4pda.to/forum/index.php?showtopic=1095643 @DeadOfGamers - check Hqnicolas' post above yours - https://forum.armbian.com/topic/40483-efforts-to-develop-firmware-for-h96-max-m9-rk3576-tv-box-8g128g/page/3/#findComment-212665 Edited April 4, 2025 by cmuki 0 Quote
DeadOfGamers Posted April 4, 2025 Posted April 4, 2025 (edited) @cmuki Thank you very much for your response! However, I want to install the stock firmware that was fully backed up from the original factory software. Unfortunately, what I see is that it was not saved as an .img file but as an .iso, which I extracted. I thought I could flash it using RKDevTool, but even the files don’t seem to match It looks like the files and the RKDevTool are not properly linked, meaning the configuration is not set up correctly in the RKDevTool. Could you send me the correct configuration for it? (I have also tried the Factory Firmware, which installed successfully, but unfortunately, it has issues. In Kodi, hardware decoding doesn't work, and every video I try to watch is completely blue. That’s why I prefer the Stock Firmware i would like instead.) Edited April 4, 2025 by DeadOfGamers 0 Quote
cmuki Posted April 4, 2025 Posted April 4, 2025 Hey, @DeadOfGamers! Unfortunately I haven't tried going back to Android - if you want, you can check the link to the forum that I gave to Pavel S, there should be more instructions on Android (albeit in Russian). 0 Quote
DeadOfGamers Posted April 4, 2025 Posted April 4, 2025 managed to fix the blue screen in kodi I had to disable AI in the system settings in Display thank you very much for your help! 0 Quote
cmuki Posted April 6, 2025 Posted April 6, 2025 Yesterday I did some changes to the defconfig and to the csc, hoping that it would help and it certainly seems so, BUT I get no further console logs after Starting kernel and, when the box is hooked to a display, the loading icon freezes after a few seconds after the kernel message. I removed parts of the csc and also combined the latest Sige 5 defconfig ant the one from earlier in the thread. Quote U-Boot SPL 2017.09-armbian-2017.09-Sb9a0-P0dc3-H3d34-V3758-Bb703-R448a (Apr 04 2 025 - 18:40:06) SPL Hotkey: ctrl+q sfc cmd=00H(6BH-x4) unknown raw ID 0 0 0 unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 MMC: no card present mmc_init: -123, time 0 spl: mmc init failed with error: -123 Trying to boot from MMC1 No misc partition spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x40040000 ... sha256(1d13f803de...) + OK ## Checking uboot 0x40200000 ... sha256(1420808eae...) + OK ## Checking fdt 0x4033a0d0 ... sha256(a0788c8219...) + OK ## Checking atf-2 0x400f0000 ... sha256(2f297c059b...) + OK ## Checking atf-3 0x3fe70000 ... sha256(9d9e1b461e...) + OK Jumping to U-Boot(0x40200000) via ARM Trusted Firmware(0x40040000) Total: 97.19/264.968 ms INFO: Preloader serial: 0 NOTICE: BL31: v2.3():v2.3-749-g30018b771:derrick.huang, fwver: v1.04 NOTICE: BL31: Built : 09:43:01, Apr 16 2024 INFO: ext 32k is not detected INFO: ARM GICv2 driver initialized INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 1 INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE init ialization. SMCs destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x40200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian-2017.09-Sb9a0-P0dc3-H3d34-V3758-Bb703-R448a (Apr 04 2025 - 18:40:06 +0000) Model: ArmSoM Sige5 MPIDR: 0x0 PreSerial: 0, raw, 0x2ad40000 DRAM: 8 GiB Sysmem: init Relocation Offset: bda25000 Relocation fdt: fb9f9db0 - fb9fece0 CR: M/C/I Using default environment DM: v2 mmc@2a310000: 1, mmc@2a330000: 0 Bootdev(atags): mmc 0 MMC0: HS400 Enhanced Strobe, 200Mhz PartType: EFI 262377 bytes read in 97 ms (2.6 MiB/s) DTB(Distro): /boot/dtb/rockchip/h96-m9_original.dtb No misc partition boot mode: None I2c1 speed: 100000Hz PMIC: RK8060 (on=0x40, off=0x00) vdd_cpu_big_s0 init 850000 uV vdd_npu_s0 750000 uV vdd_cpu_lit_s0 init 850000 uV vdd_gpu_s0 init 750000 uV vdd_logic_s0 init 750000 uV vdd_ddr_s0 850000 uV Could not find baseparameter partition Model: Rockchip RK3576 EVB1 V10 Board ## Error: Can't overwrite "ethaddr" ## Error inserting "ethaddr" variable, errno=1 ## Error: Can't overwrite "eth1addr" ## Error inserting "eth1addr" variable, errno=1 starting USB... Bus usb@23000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@23400000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@23000000 for devices... 1 USB Device(s) found scanning bus usb@23400000 for devices... Device not responding to set address. USB device not accepting new address (error=80000000) ERROR: Invalid USB EP length (9) 3 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found No usb mass storage found Error: Invalid boot sector signature for partition. Partition with label 'CONFIG' not found. FIT: No boot partition No resource file: logo.bmp failed to display uboot logo CLK: (uboot. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) bpll 816000 KHz lpll 816000 KHz vpll 594000 KHz aupll 786431 KHz cpll 1000000 KHz gpll 1188000 KHz ppll 1300000 KHz aclk_bus_root 396000 KHz pclk_bus_root 100000 KHz hclk_bus_root 198000 KHz aclk_top 786431 KHz aclk_top_mid 396000 KHz pclk_top 100000 KHz hclk_top 200000 KHz Net: Net Initialization Skipped No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 Device 0: unknown device MMC: no card present mmc_init: -123, time 0 scanning bus for devices... Device 0: unknown device switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4150 bytes read in 9 ms (450.2 KiB/s) ## Executing script at 40500000 Boot script loaded from mmc 0:1 185 bytes read in 9 ms (19.5 KiB/s) 16959365 bytes read in 73 ms (221.6 MiB/s) 47870464 bytes read in 183 ms (249.5 MiB/s) 262377 bytes read in 97 ms (2.6 MiB/s) ** File not found /boot/dtb/rockchip/overlay/rk35xx-panthor-gpu.dtbo ** ** File not found /boot/dtb/rockchip/overlay/panthor-gpu.dtbo ** Trying kaslrseed command... Info: Unknown command can be safely ignored since ka slrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 4a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 16959301 Bytes = 16.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x48300000 Booting using the fdt blob at 0x48300000 the always on regulator (vcc5v0-host) should never be disabled! rockchip_usb2phy_power_off: Failed to set VBus supply PHY: Failed to power off otg-port: -13. reserving fdt memory region: addr=48300000 size=a6000 Using Device Tree in place at 0000000048300000, end 00000000483a8fff Error: Invalid boot sector signature for partition. Partition with label 'CONFIG' not found. FIT: No boot partition No resource file: VP0 fail to load kernel logo ## reserved-memory: ramoops@40110000: addr=40110000 size=e0000 Adding bank: 0x40200000 - 0x100000000 (size: 0xbfe00000) Adding bank: 0x100000000 - 0x240000000 (size: 0x140000000) Total: 5170.280/5178.916 ms Starting kernel ... As you can see, I did remove the blacklist for the GPU drive (which is one of the errors at the end of the bootlog) and also the boot process is different this time. UFS support is removed from the defconfig since we don't need it and the OP-TEE client (the errors that I got previously) is also no longer needed as well as the BL32 blob that was present in csc. At least now I won't need to force MASKROM mode to install newer images. Will try to follow the errors and hope to update this post soon. armsom-sige5-rk3576_defconfig h96-m9.csc 0 Quote
枕畔雨 Posted April 11, 2025 Posted April 11, 2025 @Keko Hello,Is there any successful running of rknn? 0 Quote
Keko Posted April 11, 2025 Posted April 11, 2025 (edited) Yes I've checked some examples from RKNN Toolkit 2 and they are working as expected. Its a two steps process: 1. Use RKNN Toolkit2 to convert models (onnx, tensorflow, tflite, caffe, others) to RK3576 NPU 2. Use RNKK Toolkit Lite 2 to perform the inference on the board. I can provide some instructions on how to do it, if anyone is interested. Everything is covered here. At this moment I'm trying to find a fast style transfer model able to do inference (ideally something around 10fps, for 1920x1080 frames) on the H96 max M9s. Edited April 11, 2025 by Keko 0 Quote
