jimg Posted June 3, 2024 Posted June 3, 2024 The "create access point" utility in `armbian-config` has several bugs that prevent it from working, due to changes in the default installation since it was written: - hostapd does not install a default configuration file at `/etc/hostapd.conf` - hostapd is installed masked by default - dnsmasq fails to start because systemd-resolvd launches first as the default DNS resolver I can write patches to fix this utility, but I'm wondering if it will ultimately be worth it. I noticed this access point utility doesn't exist in the `armbian-configng` repository. Is that because Armbian is dropping this utility, or no one has gotten around to it yet? (There's not even a placeholder for it.) What's the status of `armbian-configng` anyhow? Will it eventually replace `armbian-config`? 0 Quote
Solution Igor Posted June 5, 2024 Solution Posted June 5, 2024 On 6/3/2024 at 12:53 PM, jimg said: or no one has gotten around to it yet? This. I think the shell / concept is done and adding this should already be possible, but from scratch. We try to get rid of that old spaghetti code that is in old armbian-config. On 6/3/2024 at 12:53 PM, jimg said: What's the status of `armbian-configng` anyhow? I am not very up 2 date on what is going on there. @Tearran and @schwar3kat are trying hard to push it further and perhaps they can give you some hints how to add this section. On 6/3/2024 at 12:53 PM, jimg said: Will it eventually replace `armbian-config`? Yes. That the idea. 0 Quote
Tearran Posted June 23, 2024 Posted June 23, 2024 sorry for the delay this stumped me. Quote or no one has gotten around to it yet? Simply put, Hotspot does not show on all devices. Well mine at least .Thanks for bringing this to light. Quote This. I think the shell / concept is done and adding this should already be possible, but from scratch. We try to get rid of that old spaghetti code that is in old armbian-config. Started something to act at the least a placeholder helper function. https://github.com/armbian/configng/blob/hotspot/lib/armbian-configng/config.ng.network.sh#L122 corasponding job https://github.com/armbian/configng/blob/hotspot/lib/armbian-configng/config.ng.jobs.json#L195 the default condition is hidden. As mentioned hotspot is not available to all devices. Runtime condition checks would be needed to show on compatible devices. Quote I can write patches to fix this utility, but I'm wondering if it will ultimately be worth it. can not say, I can only say @jimg any further insights you provided will be welcomed. 0 Quote
Igor Posted February 7, 2025 Posted February 7, 2025 On 6/3/2024 at 12:53 PM, jimg said: The "create access point" utility in `armbian-config` has several bugs that prevent it from working Have you got chance to try new variant? This part was completely rewritten (works for me), but bugs are possible. And room for improvements too. 0 Quote
jimg Posted February 9, 2025 Author Posted February 9, 2025 No, I haven't yet. Thanks for letting me know. I'll try it out soon and report what I find. 1 Quote
laibsch Posted March 25, 2025 Posted March 25, 2025 as a step in the right direction, there is some work being done to get dnsmasq to install and work properly. 0 Quote
izzo Posted March 27 Posted March 27 HC4 kernel and headers version dont match. Does not install ZFS. 0 Quote
Igor Posted March 27 Posted March 27 13 minutes ago, izzo said: HC4 kernel and headers version dont match Did you ran apt update + upgrade + reboot before ? Edit: we might add warning if installed and running kernel version differs. I ran into this problem myself. 0 Quote
