Hallo All,
I installed Armbian bpi m2p. With both server and desktop after i change, off course. i getting stuck with apt-get update not working. error showing are "could not resolve faild to fetch.
Anyone know how to solve this?
Also there seems a problem with the ethernet adapter. When i want to add new connection, after selected new connection, i cannot chose in dialog menu, nothing can be changed or edit.
with warm regards, Frank
Edited by hendricus
add some words to be more clearer
Images are set to obtain IP via DHCP from your router. You only need to boot with attached network cable and internet must work.
If you have some other case, you need to set network in /etc/network/interfaces or connect to WiFi via nmtui-connect or desktop wifi client.
Hello Igor,
Thank you for fast repleying. If i type in terminal ifconfig i have a internet connection. There is 1 thing, i live in Indonesia and my networkspeed is dropped down under 8 Mbps. Normal it above 25, can that be the issue?
Thx again,
Frank
