Today I did update my 3 NanoPi Neo2 via apt update/upgrade, but only one is accessable via ssh after the update.
(without SSH/SSL-conect also no conection via SFTP/WinSCP because if the timeout)
The one which is accessable has after the update
Welcome to Armbian 23.02.2 Bullseye with bleeding edge Linux 6.7.12-edge-sunxi64
( Machine model: FriendlyARM NanoPi NEO 2)
The two other do show prompts for user/password but doesnt login via ssh - and after some time they time out and I can reenter user/password
After connecting via TTL-serial I can also enter user/password and then the Neo2 shows me:
 _   _ ____  _   _   _              ____
| \ | |  _ \(_) | \ | | ___  ___   |___ \
|  \| | |_) | | |  \| |/ _ \/ _ \    __) |
| |\  |  __/| | | |\  |  __/ (_) |  / __/
|_| \_|_|   |_| |_| \_|\___|\___/  |_____|
Welcome to Armbian 23.8.1 Bullseye with bleeding edge Linux 6.7.12-edge-sunxi64
No end-user support: community creations
System load:   266%             Up time:       2 min
Memory usage:  22% of 982M      IP:            192.168.6.24
CPU temp:      73°C             Usage of /:    54% of 15G
storage/:      56% of 458G      storage temp:  41°C
RX today:      4.2 GiB
[ General system configuration (beta): armbian-config ]
Last login: Tue Dec 27 14:13:30 +03 2022 from 192.168.6.17 on pts/0
After prssing Ctrl-C:
^C
Armbian 23.8.1 bullseye ttyS0
npi-neo2-24 login:
For non-existing users I do get a timeout at the serial-TTL-Port:
npi-neo2-24 login: maxandmoritz
Password:
Login timed out after
npi-neo2-24 login:
but nothing more - and this time the login doenst time out.
But the armbian seems to boot up correctly, because the SAMBA-server on the Neo2 is available/useable.
So the only way to change something in the system will be to make modifikations to the SDCard - but which change have I to do?
Maybe its something between the Neo2 Revisions 1&2 (not/no Black Revision).
Does anyone got a glue/idea for me?
Thanks in advance
Guido
Edited by guidol
  • guidol changed the title to NanoPi Neo2 login stuck past entering user/password after Update
I dont know was it was - with updated armbian (with Kernel 6.7.12-edge-sunxi64 or 6.6.31-current-sunci64) I do get a high cpu load and couldnt login anymore.
Because of the CPU load the temperature gets high as 73-89 degree celsius :(
Because I could login or find a error (maybe the installation is too old or too mich times updated) I didi go the way of fresh install, but had to avoid to much kernel/firmware to kernel 6.6.31-current-sunxi64....
So I ended in reinstalling all my 3 Neo2 as base-system with
Armbian_23.11.1_Nanopineo2_bookworm_current_6.1.63
(latest full cli-image for bookworm for download)
After initial setup (user/passwd/timezone) I did freeze kernel/firmware in armbian-config.
Then updated via apt update/upgrade to
Welcome to Armbian 24.5.1 Bookworm with Linux 6.1.63-current-sunxi64
With that my 3 Neo2 do work stable at 43 degree Celsius (when my room is at around 29 degree celsius) - like it was before the critical update.
because they are mostly samba-servers (in theit siler aluminum-case) it should'nt be a problem to use only this kernel.
When it works - it works - never change a running system ;)
login as: root
root@192.168.6.22's password:
 _   _ ____  _   _   _              ____
System load:   6%               Up time:       1 min
Memory usage:  22% of 482M      IP:            192.168.6.22
CPU temp:      43°C             Usage of /:    14% of 15G
storage/:      2% of 229G       storage temp:  40°C
RX today:      158.1 MiB
[ Kernel and firmware upgrades disabled: armbian-config ]
Last check: 2024-06-05 22:23
Last login: Wed Jun  5 22:06:23 2024 from 192.168.6.17
root@npineo2-22:~#
