rogus Posted April 21, 2017 Posted April 21, 2017 Hi all, I'd like to compile latest kernel 4.11-rc7, so i added KERNELTAG="v4.11-rc7" to ./compile.sh and created file /userpatches/lib.config and added KERNELBRANCH="4.11" to it i also added to /lib/configuration.sh according to documentation ARMBIAN_MAINLINE_KERNEL_VERSION='4.11' # lock in a particular kernel version but i get this error : [ o.k. ] Using user configuration override [ userpatches/lib.config ] [ o.k. ] Syncing clock [ host ] [ o.k. ] Downloading sources [ o.k. ] Checking git sources [ u-boot v2017.03 ] [ .... ] Up to date [ error ] ERROR in function fetch_from_repo [ general.sh:184 ] [ error ] Error in configuration [ o.k. ] Process terminated what is wrong?
zador.blood.stained Posted April 21, 2017 Posted April 21, 2017 1 minute ago, rogus said: what is wrong? KERNELBRANCH syntax is wrong, it should be KERNELBRANCH='branch:orange-pi-4.11' Please keep in mind that if you switch the kernel branch you may have to update the kernel configuration and you will have to update all the patches that may cause conflicts.
tkaiser Posted April 21, 2017 Posted April 21, 2017 29 minutes ago, zador.blood.stained said: Please keep in mind that if you switch the kernel branch you may have to update the kernel configuration and you will have to update all the patches that may cause conflicts Which are essentially all except packaging patch
rogus Posted April 21, 2017 Author Posted April 21, 2017 6 hours ago, zador.blood.stained said: Please keep in mind that if you switch the kernel branch you may have to update the kernel configuration and you will have to update all the patches that may cause conflicts. The syntax was wrong, and it worked with KERNELBRANCH='branch:orange-pi-4.11' , is it the same syntax for all orange pi boards ( i use Opi lite)? The u-boot package build was successful, but problems appear with kernel, so about the patches, what you mentioned above is exactly what happened, but it is not as disastrous as i expected, only few failed (if you except my userpatches) : [ .... ] Patching kernel for compiler support [ o.k. ] Started patching process for [ kernel sun8i-dev ] [ o.k. ] Looking for user patches in [ userpatches/kernel/sun8i-dev ] [ o.k. ] ... [u][c] 9700-1.patch [ succeeded ] [ o.k. ] ... [u][c] 9700-2.patch [ succeeded ] [ o.k. ] ... [u][c] 9700-3.patch [ succeeded ] [ o.k. ] ... [l][c] add-BergMicro-SPI-flashes.patch [ succeeded ] [ o.k. ] ... [l][c] add-ad9834-dt-bindings.patch [ succeeded ] [ warn ] ... [l][c] add-beelink-x2.patch [ failed ] [ o.k. ] ... [l][c] add-configfs-overlay-for-v4.10.x.patch [ succeeded ] [ o.k. ] ... [l][c] add-emac-pwr-en-orangepi-plus2e.patch [ succeeded ] [ warn ] ... [l][c] add-h3-aliases.patch [ failed ] [ o.k. ] ... [l][c] add-h3-overlays.patch [ succeeded ] [ warn ] ... [l][c] add-h3-simplefb.patch [ failed ] [ warn ] ... [l][c] add-opi-zero-dts-with-wireless.patch [ failed ] [ o.k. ] ... [l][c] add-overlay-compilation-support.patch [ succeeded ] [ o.k. ] ... [l][c] add-realtek-8189fs-driver.patch [ succeeded ] [ warn ] ... [l][c] add-thermal-otg-wireless-opi-lite.patch [ failed ] [ warn ] ... [l][c] add-uart-rts-cts-pins.patch [ failed ] [ o.k. ] ... [l][c] add-wifi-pwrseq-opi-pc-plus.patch [ succeeded ] [ o.k. ] ... [l][c] add-xradio-wireless-driver.patch [ succeeded ] [ o.k. ] ... [u][c] dm9601-bug.patch [ succeeded ] [ o.k. ] ... [l][c] enable-codec-orange-pi-2.patch [ succeeded ] [ o.k. ] ... [l][c] enable-codec-orange-pi-pc.patch [ succeeded ] [ o.k. ] ... [l][c] nanopi-neo-air-wireless-and-dvfs.patch [ succeeded ] [ o.k. ] ... [l][c] packaging-4.x-DEV-with-postinstall-scripts.patch [ succeeded ] [ warn ] ... [u][c] patch01.patch [ failed ] [ o.k. ] ... [u][c] patch02.patch [ succeeded ] [ o.k. ] ... [u][c] patch03.patch [ succeeded ] [ o.k. ] ... [u][c] patch04.patch [ succeeded ] [ o.k. ] ... [u][c] patch05.patch [ succeeded ] [ o.k. ] ... [u][c] patch06.patch [ succeeded ] [ o.k. ] ... [u][c] patch07.patch [ succeeded ] [ warn ] ... [u][c] patch1.patch [ failed ] [ warn ] ... [u][c] patch17.patch [ failed ] [ o.k. ] ... [u][c] patch18.patch [ succeeded ] [ warn ] ... [u][c] patch2.patch [ failed ] [ warn ] ... [l][c] scripts-dtc-Update-to-version-with-overlays.patch [ failed ] [ o.k. ] ... [l][c] spi-sun6i-allow-large-transfers.patch [ succeeded ] [ o.k. ] ... [l][c] spidev-remove-warnings.patch [ succeeded ] [ o.k. ] Compiling dev kernel [ 4.11.0-rc7 ] [ o.k. ] Compiler version [ arm-linux-gnueabihf-gcc 6.3.1 ] [ o.k. ] Using kernel config file [ lib/config/kernel/linux-sun8i-dev.config ] After kernel configuration, it seems that the /sources/linux-sun8i/sun8i/scripts/dtc/livetree.c file is problematic. for now, i have no idea what this file is and what to adjust in source code. *** End of the configuration. *** Execute 'make' to start the build or try 'make help'. Compiling kernel... ---------------------------------------------------------------------------------------------------------------------- scripts/dtc/livetree.c:1008:6: warning: no previous prototype for ‘generate_label_node’ [-Wmissing-prototypes] │ │ void generate_label_node(struct node *node, struct node *dt) │ │ ^ │ │ scripts/dtc/livetree.c: In function ‘generate_label_node’: │ │ scripts/dtc/livetree.c:1058:7: error: ‘symbol_fixup_support’ undeclared (first use in this function) │ │ if (symbol_fixup_support) │ │ ^ │ │ scripts/dtc/livetree.c:1058:7: note: each undeclared identifier is reported only once for each function it appears in │ │ scripts/dtc/livetree.c: At top level: │ │ scripts/dtc/livetree.c:1066:13: error: conflicting types for ‘add_fixup_entry’ │ │ static void add_fixup_entry(struct node *dt, struct node *node, │ │ ^ │ │ scripts/dtc/livetree.c:862:13: note: previous definition of ‘add_fixup_entry’ was here │ │ static void add_fixup_entry(struct dt_info *dti, struct node *fn, │ │ ^ │ │ scripts/dtc/livetree.c:1098:13: error: conflicting types for ‘add_local_fixup_entry’ │ │ static void add_local_fixup_entry(struct node *dt, struct node *node, │ │ ^ │ │ scripts/dtc/livetree.c:925:13: note: previous definition of ‘add_local_fixup_entry’ was here │ │ static void add_local_fixup_entry(struct dt_info *dti, │ │ ^ │ │ scripts/dtc/livetree.c:1159:6: warning: no previous prototype for ‘generate_fixups_node’ [-Wmissing-prototypes] │ │ void generate_fixups_node(struct node *node, struct node *dt) │ │ ^ │ │ make[2]: *** [scripts/dtc/livetree.o] Erreur 1 │ │ HOSTLD scripts/mod/modpost │ │ make[1]: *** [scripts/dtc] Erreur 2 │ │ make: *** [scripts] Erreur 2 5 hours ago, tkaiser said: Which are essentially all except packaging patch As you can see, it's not all the patches that are concerned , but may be i'm going to face other errors if this one is solved. i realize now what amount of work for each kernel change the community have to provide to make things easier for us.
martinayotte Posted April 21, 2017 Posted April 21, 2017 The errors with "scripts/dtc/livetree.c" is related to the fact that "scripts-dtc-Update-to-version-with-overlay.patch" failed.
rogus Posted April 22, 2017 Author Posted April 22, 2017 I think i have to adapt this patch to current kernel branch, which is 4.11. should i use the patch program or git ?
martinayotte Posted April 23, 2017 Posted April 23, 2017 It is not the patching tool that is broken, it is the content of the patch that doesn't match code changes in 4.11. You probably need to find out those change by comparing 4.10 and 4.11 together, and check which parts of the patch are broken.
