Erica Posted June 8, 2024 Posted June 8, 2024 The default /. bashrc over rides any title or name setting set on the command line for all xterm and urxvt terms. This is very ugly and irresponsible behavior. I'm not sure where the source is kept but those lines of code need to be removed. Setting the prompt is one thing, smashing the title and name is something else. 0 Quote
Igor Posted June 13, 2024 Posted June 13, 2024 On 6/8/2024 at 7:45 PM, Erica said: This is very ugly and irresponsible behavior. Armbian framework nor those packages we make are not / should not be touching this, but we could perhaps patch this behaviour if you provide more context, do additional research. How this can be reproduced, where (Jammy, Noble, hardware X, desktop Y) this happens, etc. Without supplying logs, developers needs to use black magic Personally I don't practice that and BTW, I use ZSH. 0 Quote
