today I want to connect the OpiPcPlus to a Flexscan S1921 Monitor.
I select h3disp -m 33 -d to use my *tested* hdmi-to-dvi cable and reboot.
Now the monitor complains:
fV:  59.9 Hz
fH:  63.9 kHz
fD:  161.7 MHz  ****red***
this seems too high because VESA mode should use a pixel frequency of 108MHz which is also the spec of the monitor.
1280x1024 @ 60Hz (VESA) hsync: 64.0kHz 	1280x1024	108.0 1280 1328 1440 1688 1024 1025 1028 1066 	+hsync 	+vsync
The pixel frequency seems too high for the 60 Hz image refresh, it corresponds to 85 Hz.
I am using legacy kernel:
Linux JagOpi 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l GNU/Linux
Any ideas?
Thanks,
gnasch
bump - where could I find the relevant kernel sources? Did the armbian project patch this legacy kernel?
Thanks
gnasch
@tkaiser: thank you very much for your help. I was able to track down the bug. Contrary to first belief, the kernel is not concerned, but in h3disp on line 196 the pll_video is initialized to 646 MHz. With kernels divisor of 4 this results in pixel frequency of 161.5 MHz, which is too high for Vesa 1280*1024.
So I  replaced this initialization with 432 MHz, which results in correct fD of 108 MHz. Now the monitor synchronizes.
Unfortunately I found a bugfix by @igor on 24.Oct.2016 which inserted the 646 MHz value. I could not read the reasoning behind this (facebook srsly?), so I would kindly ask to revert this change if no important reasons for it exist.
best wishes and thanks to armbian team for your great work!
gnasch
I changed the value in h3disp manually to 432MHz (-m 33 -d). Now my Display DELL108FP (1280x1024 @60Hz) works well too.
ludwich
