anthony winner Posted June 17 Share Posted June 17 The distributed images for sk-am62b do not boot, tried both the "Armbian 24.5.1 Bookworm Minimal" and the "Armbian 24.5.1 Noble CLI" , both only output a u-boot message and then hang: U-Boot SPL 2023.04-g8366064208 (May 20 2024 - 02:37:44 +0000) SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)') SPL initial stack usage: 13408 bytes Method of test: Download and write image VIA etcher to a SD card and attempt boot. Note using the same method to write the Debian or Yocto image from TI boots as normal. For reference, messages from TI Debian boot: U-Boot SPL 2023.04 (May 27 2024 - 20:11:30 +0000) SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)') SPL initial stack usage: 13392 bytes Trying to boot from MMC2 Authentication passed Authentication passed Authentication passed Authentication passed Authentication passed Starting ATF on ARM64 core... NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b8 NOTICE: BL31: Built : 20:11:18, May 27 2024 I/TC: I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 13.2.1 20231009 (Arm GNU Toolchain 13.2.rel1 (Build arm-13.7))) #1 Mon May 27 20:11:23 UTC 2024 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: GIC redistributor base address not provided I/TC: Assuming default GIC group status and modifier I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot same SD card, same hw / same switch settings on HW, .... 0 Quote Link to comment Share on other sites More sharing options...
anthony winner Posted June 18 Author Share Posted June 18 I also tried, which is the oldest image I can find, and it acts the same as the other Armbian images. i.e. fail in same way. : Armbian_24.2.1_Sk-am62b_bookworm_edge_6.6.16_minimal.img.xz 0 Quote Link to comment Share on other sites More sharing options...
