zetalex Posted June 21, 2024 Posted June 21, 2024 Hello: I am tyring to build the latest version of moonlight-qt (6.0.0). Up until now, I succeded by removing the disable-libdrm and disable-wayland to enable hardware acceleration and use H264, H265 and AV1 all of them through hardware acceleration. However, I get huge decoding times and they are even variable, ranging from 40ms to 300ms depending on what is going on in the streaming. The 4.3.1 version provided by @amazingfate works very good at 4ms decoding time but I would like to test the new AV1 encoder and features from the latest version. What steps should I follow to get it working correctly? Thank you in advance 0 Quote
amazingfate Posted June 22, 2024 Posted June 22, 2024 Decoding time is ok if there is no frame drop. 0 Quote
zetalex Posted June 23, 2024 Author Posted June 23, 2024 Hello again @amazingfate: I did some more tests to check what you said. First, there are no frame drops, video is smooth using any decoder. Regarding decoding time, the behaviour is a little bit strange: the higher the framerate that moonlight renders, the lower the decoding time. When I am running 120fps, the decoding time is 35 ms which is as low as I managed to get it to. In your 4.3.1 moonlight that you have in your ppa at launchpad I get 4ms decoding time. Sorry for the dumb question, I am just trying to understand: did you apply any patch or did anything in the source code to make the decoding time lower? Thanks in advance 0 Quote
Solution amazingfate Posted June 23, 2024 Solution Posted June 23, 2024 4.3.1 moonlight is linked to ffmpeg 4.4, while new moonlight is linked to ffmpeg 6 because libavcode-dev in my ppa is updated to 6.0. Decoding time caculation is ffmpeg releated. I think moonlight can't distinguish decoding time and rendering time with new ffmpeg. 0 Quote
zetalex Posted June 23, 2024 Author Posted June 23, 2024 Thanks for answering so quickly. I didnt know that the decoding time measurement was performed this way. So, there shouldnt be any difference between both versions performance then. I didnt try to play much and latency didnt seem as noticeable. Thanks for sharing your knowledge again! PS: I put another post about linux kernel 6.1 not booting after updating some libraries from your ppa, could you take a look or tell me how can I debug it? 0 Quote
q-bert Posted June 24, 2024 Posted June 24, 2024 @zetalex Were you able to use 4k120? If so, how did you enable 4k120 in Linux? I am not able to set the display (my TV) to 4k120, only 4k60... My TV's HDMI port is definitely a 4k120 port (verified with my PC and Nvidia GPU). Have you seen this tutorial? I lists all required steps if you want to use hardware acceleration on RK3588 with 6.1 kernel. https://jellyfin.org/docs/general/administration/hardware-acceleration/rockchip 0 Quote
zhonghuihong Posted June 30, 2024 Posted June 30, 2024 @amazingfate @zetalex I tried to compile version 6.0 of Moonlight with libavcodec-dev 6.0.1 from amazingfate's ppa. However, I got significant decoding times too and noticeable lag when moving the mouse. After reading amazingfate's post, I recompiled it using libavcodec-dev 4.4.2. Now, the decoding time is below 10 ms and noticeable lag is gone. 0 Quote
q-bert Posted June 30, 2024 Posted June 30, 2024 @zhonghuihong could you please list all required steps? I build moonlight-qt following their instructions, but I get a segmentation fault when I run the app. 0 Quote
zhonghuihong Posted July 1, 2024 Posted July 1, 2024 (edited) @q-bert It seems like you might have missed some dependencies while building, such as egl. Without the start log, it's difficult to point out why. I've uploaded a compiled moonlight-qt 6.0 binary file. Just make it executable with chmod +x then enjoy it. https://drive.google.com/drive/folders/17hK8OjAUbbXZNHlfMHf7VH-iqcUmBz7Q?usp=drive_link Edited July 1, 2024 by zhonghuihong typo 0 Quote
q-bert Posted July 1, 2024 Posted July 1, 2024 @zhonghuihong I get this error: ./moonlight6: error while loading shared libraries: libavcodec.so.58: cannot open shared object file: No such file or directory How did you configure your build and where do you have ffmpeg? Here is how I build it (I did not change any directories): https://github.com/nyanmisaka/ffmpeg-rockchip/wiki/Compilation 0 Quote
q-bert Posted July 1, 2024 Posted July 1, 2024 @zhonghuihong please ignore my previous post. All good now. 0 Quote
luizkun Posted September 11, 2024 Posted September 11, 2024 Hi @q-bert , would you like to guide my how to fix missing libavcodec.so.58 and libavutil.so56 issue ? I tried to make symplink from libavcodec.so.60 and libavutil.so58 , but it showed missing version 'LIBAVCODEC_58' not found 0 Quote
luizkun Posted September 12, 2024 Posted September 12, 2024 Hi @amazingfate , would you mind help us upload your moonlight 6 package to your ppa ? 0 Quote
q-bert Posted October 4, 2024 Posted October 4, 2024 @luizkun Sorry for my late reply, I totally missed your message. As far as I remember I updated packages (apt update etc.) and followed the steps on moonlight's GitHub page: https://github.com/moonlight-stream/moonlight-qt 0 Quote
StonedEdgeMods Posted August 16 Posted August 16 (edited) Sorry to bump an old thread. Quote Hi @q-bert , would you like to guide my how to fix missing libavcodec.so.58 and libavutil.so56 issue ? I tried to make symplink from libavcodec.so.60 and libavutil.so58 , but it showed missing version 'LIBAVCODEC_58' not found I am having the exact same issue here with that predefined build. I tried building moonlight-qt from source after installing ffmpeg-rockchip, I still cant get hardware decoding working... I am on a pure Wayland setup. Anyone have any tips to get this to work? What needs to be changed in the qt.pro files? Edited August 16 by StonedEdgeMods 0 Quote
