Giunti Posted April 28, 2017 Posted April 28, 2017 I'm currently running ARMBIAN 5.25 Debian GNU/Linux 8 (jessie) 4.10.12-sunxi on my Cubietruck, which otherwise works fine as a headless data and media server. However, as I don't need any Bluetooth service whatsoever in the given environment, I have been trying to get rid of it - in vain. Is there a safe and lasting method of preventing the Bluetooth module from loading on reboot? Can it be stripped from the system at all completely? Many thanx in advance
martinayotte Posted April 28, 2017 Posted April 28, 2017 systemctl disable bluetooth ... or whatever the service is named ... And then reboot, or do "systemctl stop bluetooth". 1
pfeerick Posted April 29, 2017 Posted April 29, 2017 On the Xenial Ubuntu image, the following worked (thanks martinayotte, I just fleshed out your suggestion): sudo systemctl disable bluetooth.service sudo systemctl stop bluetooth.service You'll see if you run systemctl status bluetooth.service afterwards that it is no longer active. Might I ask exactly why you were wanting to disable it? I have a CT running as a media/data/intranet web server also, and can't say I ever bothered doing anything with the bluetooth, so just left it how it was as it didn't seem to be hurting anything (other some unnecessary RF and power drain, I'm sure!)
Giunti Posted April 29, 2017 Author Posted April 29, 2017 Thank you, martinayotte and pfeerick ! I followed your hints and got this in return. Quote root@CT:~# systemctl disable bluetooth Synchronizing state for bluetooth.service with sysvinit using update-rc.d... Executing /usr/sbin/update-rc.d bluetooth defaults Executing /usr/sbin/update-rc.d bluetooth disable insserv: warning: current start runlevel(s) (empty) of script `bluetooth' overrides LSB defaults (2 3 4 5). insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script `bluetooth' overrides LSB defaults (0 1 6). Removed symlink /etc/systemd/system/dbus-org.bluez.service. So currently bluetooth isn't active any more. However, I haven't had the chance to reboot the system, as a weekly backup is running at the moment. So I'll have to postpone that. Then I'll see if the current status prevails. @pfeerick: The sole reason for my wanting to get rid of bluetooth was that I wanted to keep the headless system as slim as possible, save resources for purposes I do need and keep power consumption as low as posible. That's all.
Giunti Posted April 29, 2017 Author Posted April 29, 2017 Well now, after rebooting the system, "dmesg" still lists Bluetooth in the startup log: Quote Sat Apr 29 15:54:36 CEST 2017 sun7i armv7l 4.10.12-sunxi Cubietruck 5.25 ### dmesg: . . . [ 19.096299] EXT4-fs (mmcblk0p1): re-mounted. Opts: data=writeback,commit=600,errors=remount-ro [ 21.809943] Bluetooth: Core ver 2.22 [ 21.810151] NET: Registered protocol family 31 [ 21.810163] Bluetooth: HCI device and connection manager initialized [ 21.810203] Bluetooth: HCI socket layer initialized [ 21.810231] Bluetooth: L2CAP socket layer initialized [ 21.810308] Bluetooth: SCO socket layer initialized [ 21.824968] Bluetooth: RFCOMM TTY layer initialized [ 21.825025] Bluetooth: RFCOMM socket layer initialized [ 21.825080] Bluetooth: RFCOMM ver 1.11 [ 21.905001] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 21.905046] Bluetooth: HIDP socket layer initialized [ 21.997144] Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) [ 22.158662] fuse init (API version 7.26) . . . However, when checking service status, it tells me that there is no such service running. >root@CT:~# service bluetooth status >[FAIL] bluetooth is not running ... failed! I don't quite get that.
jhpadjustable Posted May 2, 2017 Posted May 2, 2017 The low-level hardware driver has loaded, but no application level drivers are plugged into it. Maybe you want to blacklist the rfcomm module? Try this answer from way back (covers both Wi-Fi and BT)
EtlARM Posted May 6, 2017 Posted May 6, 2017 As I asked the same question some time ago, this thread may help . . .
