Loke Posted April 29, 2017 Share Posted April 29, 2017 Hello, my orange pi pc has recently started to have reduced speeds. Where I used to get the full 100Mbit on lan, I now get around 30Mbit, be it sftp, samba, http. Speed flanctuates a bit but stays around the 30MBit so no big differences. I am able to write with consistent speeds of over 10MB/s on the microsd so that can't be the problem (using dd) and full ~30MB/s on the attached sata disk. uname -a Linux orangepipc 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l GNU/Linux Any ideas what I can check? Link to comment Share on other sites More sharing options...
tkaiser Posted April 30, 2017 Share Posted April 30, 2017 10 hours ago, Loke said: Any ideas what I can check? Check individually. Search the forum for iperf3 and iozone, then test the storage individually and use another machine on the net to test with iperf3. In 2 2nd shell watch the output of htop and in a 3rd the output of 'sudo armbianmonitor -m'. Then report back together with the output from 'sudo armbianmonitor -u'. Link to comment Share on other sites More sharing options...
Loke Posted May 6, 2018 Author Share Posted May 6, 2018 Linux orangepipc 3.4.113-sun8i #18 SMP PREEMPT Wed Jan 24 22:10:49 CET 2018 armv7l GNU/Linux iozone3 I run it with -a and it's still outputing Spoiler Auto Mode Command line used: iozone -a Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 64 4 106657 205728 355635 520419 418250 211899 346008 238862 520419 214781 250919 444572 633392 64 8 140043 280847 598110 727850 576282 300328 412466 288080 587635 271200 262193 500060 615952 64 16 121916 244297 508587 598110 499130 253048 402569 275939 528618 253766 280847 457452 581273 64 32 125507 252810 532815 620221 532815 255943 407457 280553 432398 273688 367817 515423 712397 64 64 146862 273409 679917 811459 639427 313664 460591 307907 511494 209093 263480 454354 528618 128 4 121551 241528 435134 503723 431288 228961 397739 267791 419494 232330 228571 442668 492178 128 8 124511 306992 606767 757430 688467 348661 528517 401307 731625 341345 319222 477725 535368 128 16 139890 274782 441213 601330 542400 286360 448961 328199 600657 290859 285751 462100 571257 128 32 139708 272273 515822 621518 542400 298958 393945 310006 680612 366763 367768 576780 757430 128 64 170662 324039 540217 695603 558771 320748 436904 334331 537512 350711 422464 456986 556454 128 128 120867 257022 513847 630273 493989 294368 397444 278777 431288 253983 277767 482881 582412 256 4 163884 317224 565185 629094 539079 319965 494172 372076 516022 309542 305839 534517 602276 256 8 175827 340891 602614 666586 602276 364127 543445 433169 558715 343728 277323 492134 543445 256 16 147556 295243 547044 615393 555248 336300 490560 403237 691930 319965 311789 472222 547044 256 32 178516 342195 584570 682691 606700 389064 493264 407676 707430 358534 350689 532133 549564 256 64 173441 301544 504861 620012 529770 342631 439912 372722 682691 409542 403237 514045 648079 256 128 156094 306275 516022 609801 496228 339597 418971 334623 475779 343618 441359 449112 514292 256 256 167541 335879 565185 627623 527947 363142 486779 349320 498069 356629 347398 502969 543445 512 4 157638 326722 547575 608041 523545 337029 526240 368932 528441 318202 322648 574069 588544 512 8 176069 363376 646480 654559 587096 379494 585176 469312 590486 337930 362334 625212 639930 512 16 188925 364920 589837 656360 609594 408981 591951 469312 608730 365479 367543 619799 641651 512 32 190619 371292 616065 654759 598050 410623 572691 508544 816594 375119 374008 558251 632020 512 64 189844 369376 576690 435347 557092 407352 527921 494264 773364 378157 367543 534891 605982 512 128 183580 362334 533429 584539 521385 357806 476286 436852 632765 387017 395062 506385 545211 512 256 174269 326921 495633 516122 477239 357092 483470 392320 521385 349935 494606 449941 512060 512 512 180782 355849 521891 520879 516122 371292 500951 369440 520879 374269 382672 525724 520752 1024 4 171607 344899 627478 636498 552634 333232 568583 404429 554990 331304 335628 613583 612097 1024 8 183054 381070 571458 683171 619156 393860 630518 476276 599872 370997 377022 676819 667977 1024 16 191297 382802 672369 678959 638865 424873 630240 533019 635650 360563 378718 661496 664978 1024 32 196092 392635 638011 656842 580181 424160 608455 551711 620229 370997 327789 626288 637632 1024 64 193103 383657 553489 605538 540328 415904 560495 544438 843505 347129 358427 572677 552918 1024 128 183547 370198 527844 530845 514071 400321 508653 513272 734583 342944 347354 512782 534744 1024 256 178831 351648 509679 488741 500007 373449 492553 409442 536414 364697 354697 460843 502699 1024 512 180378 332896 486913 493231 489744 368862 478931 388024 494424 316345 467769 489019 456969 1024 1024 176610 338191 455708 482808 482157 373741 474277 376493 474959 350443 383109 473859 483732 2048 4 172857 354080 674577 684958 576900 365190 603954 439297 598151 345938 327525 601291 626279 2048 8 185340 379601 678573 666671 619638 382015 655980 481881 587514 387233 377998 705955 689799 2048 16 195925 419516 714351 731942 665174 447630 684740 551740 689356 390917 382083 650171 674789 2048 32 194106 403628 628617 615377 609353 412070 641815 573051 652393 370338 386119 626508 665999 2048 64 193646 370147 569065 597111 578376 397281 569518 580526 578688 338122 350512 576900 587153 2048 128 185777 368606 532649 534738 522444 384014 504820 529889 814612 325539 322774 518502 535438 2048 256 179947 361516 508948 495988 500380 364802 501227 466291 643209 312193 332198 540934 540662 2048 512 185877 354577 496361 471798 493850 367361 481773 406262 513543 305900 352917 494902 482667 2048 1024 181242 348295 472316 485202 497453 375996 482884 383808 473854 326951 511494 483918 454594 2048 2048 181902 349059 476932 471798 472342 390384 477595 393784 473984 381523 386328 476720 485531 4096 4 175056 363958 651398 673672 595699 355184 595617 440150 588577 343598 343743 665917 649969 4096 8 161553 406356 713336 711593 661940 419586 672459 522918 665478 369874 395596 710504 697665 4096 16 197989 423924 712597 734188 693665 450503 684707 554783 685390 392639 395705 695068 721243 4096 32 198813 395906 624772 646885 612979 428545 614273 580836 658615 374510 377647 648326 656426 4096 64 195466 387765 608981 625067 598835 434177 598584 615108 602616 354752 360181 599190 607624 4096 128 188477 370145 532976 536404 533274 385979 514755 580757 552393 324437 317664 549354 565205 4096 256 184660 365974 536689 536756 535969 391699 531542 501282 674227 310723 309013 542742 537462 4096 512 185440 345596 491825 500538 496961 375567 490954 413317 501897 308780 333306 497450 495885 4096 1024 182407 356363 503575 496000 496243 389276 493549 414164 488497 322749 382337 498953 496186 4096 2048 184620 362476 499693 498475 496846 390773 491488 412236 467532 340655 513601 493138 493011 4096 4096 183579 355368 478443 472275 477062 384493 462722 392908 472210 395250 393548 460218 469988 8192 4 173923 358969 653900 663381 564776 355367 591177 444493 549986 341830 342833 631417 647493 8192 8 188023 404962 701064 722787 652014 396457 668792 526007 655309 384673 380385 709460 716263 8192 16 196653 402438 699993 716397 674569 432340 683017 571911 669939 386669 387712 701837 708217 8192 32 197221 407865 674185 683003 648874 437487 657353 596908 658941 368612 369357 673340 672365 8192 64 192322 390354 604575 612486 595171 433989 598259 615238 603863 349565 351255 598708 609660 8192 128 187734 384979 553476 564071 548292 420468 553780 618862 554039 318234 314532 555840 559333 8192 256 183656 364672 534966 535943 537527 390616 527938 518905 532471 301518 301963 533537 539341 8192 512 184143 351180 517264 486779 461131 389187 520753 435165 507178 260759 324112 523418 525163 8192 1024 186435 359502 513446 515248 516060 392750 517982 420921 484166 312910 343021 513991 519273 8192 2048 187748 362896 492127 494478 495884 392845 508793 428159 509132 329577 387987 493555 494115 8192 4096 184168 359521 500398 494891 498322 393768 496006 409415 487532 336412 513185 492543 496845 8192 8192 186130 365125 499786 492988 499815 395176 495619 398619 494172 399923 399045 500886 501347 16384 4 176525 359139 656912 668030 564167 354425 596301 450753 554208 337404 344780 647589 649284 16384 8 188643 409395 719042 727561 656460 413060 677587 527767 657169 388208 387429 714363 721057 16384 16 197198 421292 708471 716150 672910 437826 681329 574352 677748 393713 392703 708128 710221 16384 32 197171 407886 672409 678116 657522 440227 659155 606747 655177 371635 371047 670677 677133 16384 64 193321 388955 601600 611917 600302 426355 590582 620464 597104 345711 349071 599182 605891 16384 128 185968 380793 547047 547060 545298 410626 544788 611025 546677 315143 313575 549097 549299 16384 256 184083 365558 541820 546351 496062 341952 537674 521052 539264 299060 299568 540048 544227 16384 512 183699 352579 519929 526207 526409 389352 523549 436322 519815 306466 313797 520804 525869 16384 1024 186355 364476 506729 509467 502964 395606 508803 433668 480909 313341 329473 503982 507088 16384 2048 186431 369076 509090 511470 507668 401697 507605 370417 507447 323264 351580 507353 509135 16384 4096 187986 365135 458023 492101 511923 404923 507841 433819 503226 331485 396610 513683 510466 16384 8192 188781 375771 519862 520819 522300 406559 521701 427557 518888 352350 531671 524220 523302 16384 16384 188625 377389 521614 521286 522149 407014 521551 412331 497056 407976 407330 516277 518270 32768 64 193250 387571 606928 600619 599772 422104 600398 621558 599343 344915 346744 606837 607253 32768 128 186839 375413 548840 552852 545306 416466 547145 459154 546488 311862 313020 548768 550130 32768 256 182651 361590 534422 537903 535161 391385 531222 524656 532000 293959 294633 536090 535005 32768 512 184422 359113 523902 524748 523617 389081 520645 438925 520316 305003 310432 519706 524448 32768 1024 186028 363615 505679 508220 493596 398264 500220 425812 471624 303303 317994 507142 506232 32768 2048 186764 371569 518504 517442 517499 362634 518966 438279 504672 321282 331911 518825 519270 32768 4096 188161 370784 517548 519649 501062 405917 516682 439467 513186 325825 353895 519088 519155 32768 8192 187303 370469 512224 516610 514000 403104 514177 419113 515407 335394 395043 513829 515245 32768 16384 188717 373628 523826 525649 526469 405942 524834 429407 527180 350160 534734 529045 528396 65536 64 190359 401199 617338 620553 610392 432090 608545 627288 581466 346280 346197 613614 614899 65536 128 178844 380128 562559 564920 561249 409909 558105 601153 556517 311561 311841 542983 550616 65536 256 174361 364188 544125 548381 544318 363620 543854 477998 536855 285075 297793 554135 554774 65536 512 171857 360925 521110 525928 522419 389134 523584 423704 480025 293962 306539 527515 527049 65536 1024 173453 367043 495573 514528 494726 379118 511612 425799 506656 311170 315249 512768 512239 65536 2048 173199 362081 513871 516186 515463 404171 511556 424200 481804 316366 325197 518444 518279 65536 4096 175475 373865 528546 529695 481552 412122 528605 436292 504270 321562 335219 526667 524066 65536 8192 168337 373243 519858 522853 520287 398245 532575 440208 510532 326392 353722 527316 529091 65536 16384 178659 375721 527695 527384 526241 410397 526972 436871 517367 334391 372006 523141 522782 131072 64 173072 322039 632913 635652 620979 350223 608747 614484 605967 295810 291247 635229 635475 131072 128 15926 310916 564153 567723 559727 334750 563954 587203 552065 271162 265953 569378 569449 131072 256 25392 311625 554539 556061 552959 334968 551615 514227 508991 262769 257346 556582 557361 131072 512 162886 317538 552038 554919 552312 342661 552834 428286 510858 276832 271575 549920 552883 131072 1024 154336 319921 546208 547983 542184 345288 552861 428363 547216 280750 280104 550975 548558 131072 2048 168668 316793 536332 542047 541168 347628 540712 419930 537806 277890 283878 542117 543037 131072 4096 170304 322304 547299 549648 547216 352744 539182 396410 553104 291414 297999 547207 546684 131072 8192 167451 320728 537110 539939 537854 345332 533591 427047 481560 291945 302973 523086 535983 131072 16384 161610 316865 533324 543044 540024 346698 539751 423520 494775 287965 308719 529183 542498 etc I run iperf with -t 60, htop was absolutely fine (iozone was still running) TCP window size: 21.0 KByte (default) ------------------------------------------------------------ [ 3] local 192.168.10.222 port 35580 connected with 192.168.10.160 port 5001 [ ID] Interval Transfer Bandwidth [ 3] 0.0-60.0 sec 232 MBytes 32.4 Mbits/sec armbianmonitor -u failed to upload so I am gonna paste some output with -m (while iperf was active) (is it trying to use internal webserver on port 80? cause I am running a webserver doesn't seem to matter) Spoiler Time CPU load %cpu %sys %usr %nice %io %irq CPU 20:59:26: 1296MHz 2.47 8% 1% 0% 0% 5% 0% 57°C 20:59:31: 1296MHz 2.43 8% 1% 0% 0% 5% 0% 57°C 20:59:36: 1296MHz 2.39 8% 1% 0% 0% 5% 0% 57°C 20:59:41: 1296MHz 2.36 8% 1% 0% 0% 5% 0% 57°C 20:59:46: 1296MHz 2.41 8% 1% 0% 0% 5% 0% 57°C 20:59:51: 1296MHz 2.46 8% 1% 0% 0% 5% 0% 57°C 20:59:56: 1296MHz 2.50 8% 1% 0% 0% 5% 0% 57°C 21:00:01: 1296MHz 2.46 8% 1% 0% 0% 5% 0% 57°C 21:00:06: 1296MHz 2.43 8% 1% 0% 0% 5% 0% 61°C 21:00:11: 1296MHz 2.39 8% 1% 0% 0% 5% 0% 57°C 21:00:16: 1296MHz 2.36 8% 1% 0% 0% 5% 0% 57°C 21:00:21: 1296MHz 2.33 8% 1% 0% 0% 6% 0% 57°C armbianmonitor -m without iozone: Spoiler Time CPU load %cpu %sys %usr %nice %io %irq CPU 21:18:24: 1008MHz 0.41 13% 1% 0% 0% 10% 0% 52°C 21:18:29: 480MHz 0.38 13% 1% 0% 0% 10% 0% 52°C 21:18:34: 480MHz 0.35 13% 1% 0% 0% 10% 0% 52°C 21:18:40: 480MHz 0.32 13% 1% 0% 0% 10% 0% 52°C 21:18:45: 1008MHz 0.30 13% 1% 0% 0% 10% 0% 52°C 21:18:50: 480MHz 0.35 13% 1% 0% 0% 10% 0% 52°C 21:18:55: 480MHz 0.32 13% 1% 0% 0% 10% 0% 51°C 21:19:00: 480MHz 0.30 13% 1% 0% 0% 10% 0% 51°C 21:19:05: 480MHz 0.27 13% 1% 0% 0% 10% 0% 52°C 21:19:10: 480MHz 0.25 13% 1% 0% 0% 10% 0% 52°C 21:19:16: 480MHz 0.23 13% 1% 0% 0% 10% 0% 51°C 21:19:21: 480MHz 0.21 13% 1% 0% 0% 10% 0% 51°C 21:19:26: 1008MHz 0.20 13% 1% 0% 0% 10% 0% 51°C and well armhwinfo.log: Spoiler Sun May 6 20:04:54 EEST 2018 sun8i armv7l Orange Pi PC Linux version 3.4.113-sun8i (root@xeon) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #18 SMP PREEMPT Wed Jan 24 22:10:49 CET 2018 ### dmesg: [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.113-sun8i (root@xeon) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #18 SMP PREEMPT Wed Jan 24 22:10:49 CET 2018 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: sun8i [ 0.000000] cma: CMA: reserved 256 MiB at 50000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] free_area_init_node: node 0, pgdat c098f740, node_mem_map c0ac8000 [ 0.000000] Normal zone: 1710 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 192850 pages, LIFO batch:31 [ 0.000000] HighMem zone: 594 pages used for memmap [ 0.000000] HighMem zone: 66990 pages, LIFO batch:15 [ 0.000000] script_init enter! [ 0.000000] script_init exit! [ 0.000000] PERCPU: Embedded 8 pages/cpu @c13de000 s11968 r8192 d12608 u32768 [ 0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259840 [ 0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 panic=10 consoleblank=0 enforcing=0 loglevel=1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 759280k/759280k available, 289296k reserved, 270336K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc08d08c0 (8995 kB) [ 0.000000] .init : 0xc08d1000 - 0xc0923ec0 ( 332 kB) [ 0.000000] .data : 0xc0924000 - 0xc0993fb0 ( 448 kB) [ 0.000000] .bss : 0xc099476c - 0xc0ac7d40 (1230 kB) [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Additional per-CPU info printed with stalls. [ 0.000000] NR_IRQS:544 [ 0.000000] Architected local timer running at 24.00MHz. [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.000260] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000) [ 0.000283] pid_max: default: 32768 minimum: 301 [ 0.000448] Security Framework initialized [ 0.000471] AppArmor: AppArmor disabled by boot time parameter [ 0.000654] Mount-cache hash table entries: 512 [ 0.001646] Initializing cgroup subsys cpuacct [ 0.001662] Initializing cgroup subsys memory [ 0.001707] Initializing cgroup subsys devices [ 0.001719] Initializing cgroup subsys freezer [ 0.001729] Initializing cgroup subsys blkio [ 0.001752] Initializing cgroup subsys perf_event [ 0.001835] CPU: Testing write buffer coherency: ok [ 0.001876] ftrace: allocating 24835 entries in 73 pages [ 0.030296] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.030314] [sunxi_smp_prepare_cpus] enter [ 0.030351] Setting up static identity map for 0x4061eae8 - 0x4061eb40 [ 0.031293] CPU1: Booted secondary processor [ 0.031293] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.031428] CPU2: Booted secondary processor [ 0.031428] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.031428] CPU3: Booted secondary processor [ 0.031428] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.040190] Brought up 4 CPUs [ 0.040206] SMP: Total of 4 processors activated (19200.00 BogoMIPS). [ 0.040920] devtmpfs: initialized [ 0.044064] wakeup src cnt is : 2. [ 0.044076] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 [ 0.044087] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0 [ 0.044098] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 [ 0.044109] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 [ 0.044119] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8 [ 0.044129] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 [ 0.044141] sunxi pm init [ 0.044286] pinctrl core: initialized pinctrl subsystem [ 0.057496] NET: Registered protocol family 16 [ 0.058452] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.058452] script_sysfs_init success [ 0.058452] sunxi_dump_init success [ 0.058452] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl [ 0.058452] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver [ 0.058452] plat: add bmp085 device [ 0.058452] plat: add pcf8591 device [ 0.058452] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.058452] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.058452] script config pll_video to 297 Mhz [ 0.058452] script config pll_de to 864 Mhz [ 0.058452] script config pll_ve to 402 Mhz [ 0.058452] sunxi_default_clk_init [ 0.058452] try to set pll6ahb1 to 200000000 [ 0.058452] try to set ahb clk source to pll6ahb1 [ 0.058452] set ahb clk source to pll6ahb1 [ 0.058452] try to set ahb1 to 200000000 [ 0.058452] try to set apb1 to 100000000 [ 0.064715] bio: create slab <bio-0> at 0 [ 0.070102] [ARISC] :sunxi-arisc driver v1.04 [ 0.079996] [ARISC] :arisc version: [v0.1.58] [ 0.170237] [ARISC] :sunxi-arisc driver v1.04 startup succeeded [ 0.180445] SCSI subsystem initialized [ 0.180647] usbcore: registered new interface driver usbfs [ 0.180722] usbcore: registered new interface driver hub [ 0.180745] usbcore: registered new device driver usb [ 0.180745] twi_chan_cfg()340 - [twi0] has no twi_regulator. [ 0.180745] twi_chan_cfg()340 - [twi1] has no twi_regulator. [ 0.180745] twi_chan_cfg()340 - [twi2] has no twi_regulator. [ 0.180911] Linux video capture interface: v2.00 [ 0.181148] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.181902] cfg80211: Calling CRDA to update world regulatory domain [ 0.181959] NetLabel: Initializing [ 0.181959] NetLabel: domain hash size = 128 [ 0.181959] NetLabel: protocols = UNLABELED CIPSOv4 [ 0.181959] NetLabel: unlabeled traffic allowed by default [ 0.181959] Switching to clocksource arch_sys_counter [ 0.193261] FS-Cache: Loaded [ 0.193552] CacheFiles: Loaded [ 0.204855] NET: Registered protocol family 2 [ 0.216203] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.216807] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.218702] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 0.219760] TCP: Hash tables configured (established 131072 bind 65536) [ 0.219772] TCP: reno registered [ 0.219786] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.219822] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.220208] NET: Registered protocol family 1 [ 0.220627] RPC: Registered named UNIX socket transport module. [ 0.220639] RPC: Registered udp transport module. [ 0.220647] RPC: Registered tcp transport module. [ 0.220655] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.220859] Trying to unpack rootfs image as initramfs... [ 0.414086] Freeing initrd memory: 3064K [ 0.414613] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available [ 0.414741] sunxi_reg_init enter [ 0.415660] audit: initializing netlink socket (disabled) [ 0.415715] type=2000 audit(0.410:1): initialized [ 0.416963] highmem bounce pool size: 64 pages [ 0.417329] VFS: Disk quotas dquot_6.5.2 [ 0.417524] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.418085] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.418273] misc fatfs initialized [ 0.418491] NFS: Registering the id_resolver key type [ 0.418878] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.418893] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 0.419655] NTFS driver 2.1.30 [Flags: R/W]. [ 0.419952] fuse init (API version 7.18) [ 0.420411] msgmni has been set to 1472 [ 0.421877] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.421898] io scheduler noop registered [ 0.421906] io scheduler deadline registered [ 0.421970] io scheduler cfq registered (default) [ 0.422380] [DISP]disp_module_init [ 0.422683] cmdline,init_disp= [ 0.422713] cmdline,disp= [ 0.430539] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed! [ 0.446922] Console: switching to colour frame buffer device 160x45 [ 0.464284] [DISP]disp_module_init finish [ 0.464517] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator. [ 0.464828] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI [ 0.464841] sw_uart_pm()890 - uart0 clk is already enable [ 0.465388] sunxi_cmatest_init enter [ 0.465426] sunxi_cmatest_init success [ 0.469539] brd: module loaded [ 0.473568] loop: module loaded [ 0.473845] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator. [ 0.473859] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator. [ 0.474439] spi spi0: master is unqueued, this is deprecated [ 0.475507] PPP generic driver version 2.4.2 [ 0.475699] PPP BSD Compression module registered [ 0.475710] PPP Deflate Compression module registered [ 0.478510] PPP MPPE Compression module registered [ 0.478528] NET: Registered protocol family 24 [ 0.478603] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.498705] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.498741] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1 [ 0.499328] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000 [ 0.510034] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00 [ 0.510138] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.510151] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.510164] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.510176] usb usb1: Manufacturer: Linux 3.4.113-sun8i ehci_hcd [ 0.510186] usb usb1: SerialNumber: sunxi-ehci [ 0.510776] hub 1-0:1.0: USB hub found [ 0.510802] hub 1-0:1.0: 1 port detected [ 0.531176] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.531206] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2 [ 0.531626] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000 [ 0.550032] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00 [ 0.550118] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.550131] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.550143] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.550154] usb usb2: Manufacturer: Linux 3.4.113-sun8i ehci_hcd [ 0.550164] usb usb2: SerialNumber: sunxi-ehci [ 0.550629] hub 2-0:1.0: USB hub found [ 0.550652] hub 2-0:1.0: 1 port detected [ 0.571034] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.571062] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3 [ 0.571450] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000 [ 0.590033] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00 [ 0.590050] ehci_irq: highspeed device connect [ 0.590099] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.590112] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.590124] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.590136] usb usb3: Manufacturer: Linux 3.4.113-sun8i ehci_hcd [ 0.590146] usb usb3: SerialNumber: sunxi-ehci [ 0.590594] hub 3-0:1.0: USB hub found [ 0.590618] hub 3-0:1.0: 1 port detected [ 0.610977] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.611006] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4 [ 0.611380] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000 [ 0.630030] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00 [ 0.630094] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.630107] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.630119] usb usb4: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.630130] usb usb4: Manufacturer: Linux 3.4.113-sun8i ehci_hcd [ 0.630140] usb usb4: SerialNumber: sunxi-ehci [ 0.630645] hub 4-0:1.0: USB hub found [ 0.630664] hub 4-0:1.0: 1 port detected [ 0.631042] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.651112] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.651141] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5 [ 0.651173] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400 [ 0.714091] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.714105] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.714116] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.714128] usb usb5: Manufacturer: Linux 3.4.113-sun8i ohci_hcd [ 0.714138] usb usb5: SerialNumber: sunxi-ohci [ 0.714610] hub 5-0:1.0: USB hub found [ 0.714629] hub 5-0:1.0: 1 port detected [ 0.734992] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.735020] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6 [ 0.735052] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400 [ 0.794097] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.794111] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.794123] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.794134] usb usb6: Manufacturer: Linux 3.4.113-sun8i ohci_hcd [ 0.794144] usb usb6: SerialNumber: sunxi-ohci [ 0.794644] hub 6-0:1.0: USB hub found [ 0.794663] hub 6-0:1.0: 1 port detected [ 0.815042] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.815071] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7 [ 0.815115] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400 [ 0.874089] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.874102] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.874115] usb usb7: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.874126] usb usb7: Manufacturer: Linux 3.4.113-sun8i ohci_hcd [ 0.874136] usb usb7: SerialNumber: sunxi-ohci [ 0.874637] hub 7-0:1.0: USB hub found [ 0.874656] hub 7-0:1.0: 1 port detected [ 0.895060] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.895088] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8 [ 0.895119] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400 [ 0.910038] usb 3-1: new high-speed USB device number 2 using sunxi-ehci [ 0.954089] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.954102] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.954114] usb usb8: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 0.954125] usb usb8: Manufacturer: Linux 3.4.113-sun8i ohci_hcd [ 0.954135] usb usb8: SerialNumber: sunxi-ohci [ 0.954575] hub 8-0:1.0: USB hub found [ 0.954594] hub 8-0:1.0: 1 port detected [ 0.954938] Initializing USB Mass Storage driver... [ 0.955168] usbcore: registered new interface driver usb-storage [ 0.955180] USB Mass Storage support registered. [ 0.955240] usbcore: registered new interface driver ums-alauda [ 0.955288] usbcore: registered new interface driver ums-cypress [ 0.955338] usbcore: registered new interface driver ums-datafab [ 0.955386] usbcore: registered new interface driver ums_eneub6250 [ 0.955433] usbcore: registered new interface driver ums-freecom [ 0.955491] usbcore: registered new interface driver ums-isd200 [ 0.955541] usbcore: registered new interface driver ums-jumpshot [ 0.955590] usbcore: registered new interface driver ums-karma [ 0.955636] usbcore: registered new interface driver ums-onetouch [ 0.955697] usbcore: registered new interface driver ums-realtek [ 0.955746] usbcore: registered new interface driver ums-sddr09 [ 0.955795] usbcore: registered new interface driver ums-sddr55 [ 0.955842] usbcore: registered new interface driver ums-usbat [ 0.956050] uinput result 0 , vmouse_init [ 0.956669] mousedev: PS/2 mouse device common for all mice [ 0.956886] sunxikbd_init failed. [ 0.957647] ls_fetch_sysconfig_para: type err device_used = -1073057372. [ 0.957658] =========script_get_err============ [ 0.957666] ltr_init: ls_fetch_sysconfig_para err. [ 0.958227] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0 [ 0.958276] i2c /dev entries driver [ 0.958668] sunxi cedar version 0.1 [ 0.958711] [cedar]: install start!!! [ 0.958905] [cedar]: install end!!! [ 0.959146] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18) [ 0.959318] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19) [ 0.959487] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a) [ 0.959656] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29) [ 0.959826] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a) [ 0.959994] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b) [ 0.960183] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c) [ 0.960348] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d) [ 0.960513] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e) [ 0.960708] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18) [ 0.960900] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19) [ 0.961091] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a) [ 0.961283] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29) [ 0.961475] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a) [ 0.961666] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b) [ 0.961857] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c) [ 0.962048] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d) [ 0.962239] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e) [ 0.962254] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0 [ 0.962414] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf [ 0.962560] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0) [ 0.962574] wdt_enable, write reg 0xf1c20cb8 val 0x00000000 [ 0.962587] timeout_to_interv, line 167 [ 0.962596] interv_to_timeout, line 189 [ 0.962607] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec [ 0.963031] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 0.963241] calibrat: max_cpufreq 1200Mhz Type 0! [ 0.963561] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Jan 24 2018 at 22:09:36 [ 0.963594] [mmc]: get mmc0's sdc_power is null! [ 0.963622] [mmc]: get mmc1's sdc_power is null! [ 0.963631] [mmc]: get mmc1's 2xmode ok, val = 1 [ 0.963640] [mmc]: get mmc1's ddrmode ok, val = 1 [ 0.963656] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2 [ 0.967229] [mmc]: sdc0 power_supply is null [ 0.969074] no blue_led, ignore it! [ 0.969308] Registered led device: red_led [ 0.969423] Registered led device: green_led [ 0.969438] no led_0, ignore it! [ 0.969446] no led_1, ignore it! [ 0.969453] no led_2, ignore it! [ 0.969459] no led_3, ignore it! [ 0.969466] no led_4, ignore it! [ 0.969473] no led_5, ignore it! [ 0.969480] no led_6, ignore it! [ 0.969487] no led_7, ignore it! [ 0.970405] usbcore: registered new interface driver usbhid [ 0.970417] usbhid: USB HID core driver [ 0.974826] asoc: sndcodec <-> sunxi-codec mapping ok [ 0.975911] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly! [ 0.976109] [I2S]snddaudio cannot find any using configuration for controllers, return directly! [ 0.976122] [DAUDIO0] driver not init,just return. [ 0.979518] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok [ 0.980931] oprofile: using arm/armv7-ca7 [ 0.981125] u32 classifier [ 0.981135] Performance counters on [ 0.981143] input device check on [ 0.981150] Actions configured [ 0.981469] TCP: bic registered [ 0.981479] TCP: cubic registered [ 0.981488] TCP: westwood registered [ 0.981495] TCP: highspeed registered [ 0.981503] TCP: hybla registered [ 0.981510] TCP: htcp registered [ 0.981517] TCP: vegas registered [ 0.981524] TCP: veno registered [ 0.981531] TCP: scalable registered [ 0.981539] TCP: lp registered [ 0.981546] TCP: yeah registered [ 0.981553] TCP: illinois registered [ 0.981560] Initializing XFRM netlink socket [ 0.981776] NET: Registered protocol family 10 [ 0.982872] NET: Registered protocol family 17 [ 0.982904] NET: Registered protocol family 15 [ 0.982950] Registering the dns_resolver key type [ 0.983418] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.983440] ThumbEE CPU extension supported. [ 0.983461] Registering SWP/SWPB emulation handler [ 0.984017] registered taskstats version 1 [ 0.984470] cmdline,disp= [ 0.984771] [HDMI] power vcc-hdmi-18 [ 1.015685] cmdline,disp= [ 1.016003] [DISP] disp_init_tv,line:539:screen 0 do not support TV TYPE! [ 1.016020] [DISP] bsp_disp_tv_register,line:998:'ptv is null [ 1.016031] tv registered!! [ 1.033887] mmc0: new high speed SDHC card at address 59b4 [ 1.034346] mmcblk0: mmc0:59b4 00000 14.9 GiB [ 1.035598] mmcblk0: p1 [ 1.036175] mmcblk mmc0:59b4: Card claimed for testing. [ 1.036191] mmc0:59b4: 00000 14.9 GiB [ 1.061249] usb 3-1: New USB device found, idVendor=152d, idProduct=2329 [ 1.061264] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5 [ 1.061276] usb 3-1: Product: USB to ATA/ATAPI bridge [ 1.061286] usb 3-1: Manufacturer: JMicron [ 1.061295] usb 3-1: SerialNumber: 317740039630 [ 1.062608] usb-storage 3-1:1.0: Quirks match for vid 152d pid 2329: 8020 [ 1.062706] scsi0 : usb-storage 3-1:1.0 [ 1.620047] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5 [ 1.620606] ths_fetch_sysconfig_para: type err device_used = 1. [ 1.622155] CPU Budget:Register notifier [ 1.622169] CPU Budget:register Success [ 1.622180] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0 [ 1.625473] [rf_pm]: module power0 name vcc-wifi-33 [ 1.625490] [rf_pm]: Did not config module_power1 in sys_config [ 1.625501] [rf_pm]: Did not config module_power2 in sys_config [ 1.625510] [rf_pm]: Did not config module_power3 in sys_config [ 1.625520] [rf_pm]: mod has no chip_en gpio [ 1.625528] [rf_pm]: failed to fetch lpo_use_apclk [ 1.625536] [rf_pm]: regulator on. [ 1.625546] [wifi_pm]: no wifi used in configuration [ 1.625556] [rfkill]: init no bt used in configuration [ 1.625564] ALSA device list: [ 1.625571] #0: audiocodec [ 1.625578] #1: sndhdmi [ 1.626369] Freeing init memory: 328K [ 1.672435] systemd-udevd[100]: starting version 215 [ 2.082351] scsi 0:0:0:0: Direct-Access SAMSUNG HM160HI HH10 PQ: 0 ANSI: 2 CCS [ 2.083808] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB) [ 2.084703] sd 0:0:0:0: [sda] Write Protect is off [ 2.084719] sd 0:0:0:0: [sda] Mode Sense: 28 00 00 00 [ 2.085550] sd 0:0:0:0: [sda] No Caching mode page found [ 2.085563] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 2.088523] sd 0:0:0:0: [sda] No Caching mode page found [ 2.088538] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 2.213370] sda: sda1 [ 2.216680] sd 0:0:0:0: [sda] No Caching mode page found [ 2.216704] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 2.216725] sd 0:0:0:0: [sda] Attached SCSI disk [ 4.692516] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 5.940328] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 5.940644] systemd[1]: Detected architecture 'arm'. [ 5.967160] systemd[1]: Set hostname to <orangepipc>. [ 6.554050] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. [ 6.556976] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 6.557359] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 6.557440] systemd[1]: Expecting device dev-ttySAC2.device... [ 6.558058] systemd[1]: Starting Remote File Systems (Pre). [ 6.558502] systemd[1]: Reached target Remote File Systems (Pre). [ 6.558672] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point. [ 6.559680] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 6.559787] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. [ 6.559999] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 6.560109] systemd[1]: Starting Paths. [ 6.560514] systemd[1]: Reached target Paths. [ 6.560573] systemd[1]: Starting Encrypted Volumes. [ 6.560974] systemd[1]: Reached target Encrypted Volumes. [ 6.561048] systemd[1]: Expecting device dev-sda1.device... [ 6.561412] systemd[1]: Starting Root Slice. [ 6.561889] systemd[1]: Created slice Root Slice. [ 6.561951] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 6.562579] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 6.562643] systemd[1]: Starting Delayed Shutdown Socket. [ 6.563175] systemd[1]: Listening on Delayed Shutdown Socket. [ 6.563239] systemd[1]: Starting Journal Socket (/dev/log). [ 6.563771] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.563838] systemd[1]: Starting User and Session Slice. [ 6.564387] systemd[1]: Created slice User and Session Slice. [ 6.564468] systemd[1]: Starting udev Control Socket. [ 6.564953] systemd[1]: Listening on udev Control Socket. [ 6.565026] systemd[1]: Starting udev Kernel Socket. [ 6.565469] systemd[1]: Listening on udev Kernel Socket. [ 6.565556] systemd[1]: Starting Journal Socket. [ 6.566054] systemd[1]: Listening on Journal Socket. [ 6.566176] systemd[1]: Starting System Slice. [ 6.566702] systemd[1]: Created slice System Slice. [ 6.566846] systemd[1]: Starting Increase datagram queue length... [ 6.700741] systemd[1]: Starting Restore / save the current clock... [ 6.790806] systemd[1]: Mounting POSIX Message Queue File System... [ 6.840859] systemd[1]: Mounting Debug File System... [ 6.902886] systemd[1]: Started Set Up Additional Binary Formats. [ 6.903040] systemd[1]: Starting udev Coldplug all Devices... [ 6.931140] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 7.000839] systemd[1]: Mounted Huge Pages File System. [ 7.001010] systemd[1]: Starting LSB: Set keymap... [ 7.060663] systemd[1]: Starting system-serial\x2dgetty.slice. [ 7.061617] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 7.061736] systemd[1]: Starting system-getty.slice. [ 7.062542] systemd[1]: Created slice system-getty.slice. [ 7.066295] systemd[1]: Starting Load Kernel Modules... [ 7.110846] systemd[1]: Started File System Check on Root Device. [ 7.111036] systemd[1]: Starting Slices. [ 7.111590] systemd[1]: Reached target Slices. [ 7.114279] systemd[1]: Mounted Debug File System. [ 7.114937] systemd[1]: Mounted POSIX Message Queue File System. [ 7.200833] systemd[1]: Started Increase datagram queue length. [ 7.240067] [mmc]: sdc1 power_supply is null [ 7.295231] [mmc]: sdc1 power_supply is null [ 7.295376] systemd[1]: Started Restore / save the current clock. [ 7.299429] [mmc]: sdc1 power_supply is null [ 7.338610] [wifi_pm]: set wl_reg_on 1 ! [ 7.358607] [mmc]: sdc1 power_supply is null [ 7.362720] [mmc]: sdc1 power_supply is null [ 7.425574] [mmc]: sdc1 power_supply is null [ 7.429741] [mmc]: sdc1 power_supply is null [ 7.455560] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 7.501978] [mmc]: sdc1 power_supply is null [ 7.575269] systemd[1]: Started LSB: Set keymap. [ 7.625225] systemd[1]: Started Load Kernel Modules. [ 7.704980] systemd[1]: Started udev Coldplug all Devices. [ 7.707067] systemd[1]: Time has been changed [ 7.707420] systemd[1]: Starting Apply Kernel Variables... [ 7.790815] systemd[1]: Mounting FUSE Control File System... [ 7.880833] systemd[1]: Mounted Configuration File System. [ 7.881328] systemd[1]: Starting Create Static Device Nodes in /dev... [ 8.040924] systemd[1]: Starting Syslog Socket. [ 8.045992] systemd[1]: Listening on Syslog Socket. [ 8.046142] systemd[1]: Starting Journal Service... [ 8.145829] systemd[1]: Started Journal Service. [ 8.475646] systemd-udevd[179]: starting version 215 [ 8.795698] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x77) [ 8.795738] bmp085: probe of 0-0077 failed with error -70 [ 8.817579] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x48) [ 8.817771] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x48) [ 9.333564] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 9.594347] Adding 131068k swap on /var/swap. Priority:-1 extents:3 across:1168556k SS [ 9.674518] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 10.907993] systemd-journald[178]: Received request to flush runtime journal from PID 1 [ 11.150746] gmac0: probed [ 11.151074] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00) [ 16.150223] PHY: gmac0-0:00 - Link is Up - 100/Full [ 21.320023] eth0: no IPv6 routers present ### lsusb: Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 152d:2329 JMicron Technology Corp. / JMicron USA Technology Corp. JM20329 SATA Bridge Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: armv7l Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0-3 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 CPU max MHz: 1296.0000 CPU min MHz: 480.0000 ### cpuinfo: Processor : ARMv7 Processor rev 5 (v7l) processor : 0 BogoMIPS : 6171.42 processor : 1 BogoMIPS : 6171.42 processor : 2 BogoMIPS : 6171.42 processor : 3 BogoMIPS : 6171.42 Features : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 Hardware : sun8i Revision : 0000 Serial : 9434501e07ce50000000 ### meminfo: MemTotal: 1024816 kB MemFree: 871932 kB Buffers: 12848 kB Cached: 53576 kB SwapCached: 0 kB Active: 64228 kB Inactive: 50640 kB Active(anon): 48940 kB Inactive(anon): 4392 kB Active(file): 15288 kB Inactive(file): 46248 kB Unevictable: 0 kB Mlocked: 0 kB HighTotal: 270336 kB HighFree: 185760 kB LowTotal: 754480 kB LowFree: 686172 kB SwapTotal: 131068 kB SwapFree: 131068 kB Dirty: 44 kB Writeback: 0 kB AnonPages: 48812 kB Mapped: 15532 kB Shmem: 4604 kB Slab: 14616 kB SReclaimable: 5692 kB SUnreclaim: 8924 kB KernelStack: 984 kB PageTables: 1172 kB NFS_Unstable: 0 kB Bounce: 116 kB WritebackTmp: 0 kB CommitLimit: 643476 kB Committed_AS: 120304 kB VmallocTotal: 245760 kB VmallocUsed: 16764 kB VmallocChunk: 212864 kB ### interrupts: CPU0 CPU1 CPU2 CPU3 3: 1 0 0 0 sunxi_gpio_irq_chip gk_EINT 29: 1359 1314 1621 1254 GIC arch_timer 30: 0 0 0 0 GIC arch_timer 38: 24 0 0 0 GIC twi0 39: 18 0 0 0 GIC twi1 43: 0 0 0 0 GIC PA 49: 0 0 0 0 GIC PG 50: 0 0 0 0 GIC sunxi_timer0 63: 0 0 0 0 GIC Thermal 72: 0 0 0 0 GIC sunxi-rtc alarm 77: 1 0 0 0 GIC PL 81: 0 0 0 0 GIC arisc_hwmsgbox_irq 82: 0 0 0 0 GIC sunxi_dmac 90: 0 0 0 0 GIC cedar_dev 92: 12298 0 0 0 GIC sunxi-mmc 93: 52 0 0 0 GIC sunxi-mmc 97: 0 0 0 0 GIC spi0 104: 0 0 0 0 GIC ehci_hcd:usb1 105: 0 0 0 0 GIC ohci_hcd:usb5 106: 0 0 0 0 GIC ehci_hcd:usb2 107: 0 0 0 0 GIC ohci_hcd:usb6 108: 1020 0 0 0 GIC ehci_hcd:usb3 109: 0 0 0 0 GIC ohci_hcd:usb7 110: 0 0 0 0 GIC ehci_hcd:usb4 111: 0 0 0 0 GIC ohci_hcd:usb8 114: 166 0 0 0 GIC gmac0 118: 1860 0 0 0 GIC dispaly IPI0: 0 0 0 0 CPU wakeup interrupts IPI1: 0 0 0 0 Timer broadcast interrupts IPI2: 1766 2826 2411 2098 Rescheduling interrupts IPI3: 120 148 37 145 Function call interrupts IPI4: 1 4 3 0 Single function call interrupts IPI5: 0 0 0 0 CPU stop interrupts IPI6: 0 0 0 0 CPU backtrace IPI7: 0 0 0 0 completion interrupts Err: 0 ### ifconfig: eth0 Link encap:Ethernet HWaddr ID inet addr:192.168.10.222 Bcast:192.168.10.255 Mask:255.255.255.0 inet6 addr: fe80::3821:d2ff:feb4:1237/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:115 errors:0 dropped:0 overruns:0 frame:0 TX packets:82 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:21327 (20.8 KiB) TX bytes:15720 (15.3 KiB) Interrupt:114 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 TX bytes:0 (0.0 ### df: Filesystem Size Used Avail Use% Mounted on /dev/mmcblk0p1 15G 6.6G 8.0G 46% / udev 10M 0 10M 0% /dev tmpfs 201M 4.5M 196M 3% /run tmpfs 501M 0 501M 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 501M 0 501M 0% /sys/fs/cgroup tmpfs 501M 32K 501M 1% /tmp /dev/sda1 147G 113G 27G 81% /srv/media ### mmc0:59b4 info: cid: 1b534d303030303010cb4653be00f9d9 csd: 400e00325b590000775d7f800a4000a3 scr: 0235800300000000 date: 09/2015 name: 00000 type: SD preferred_erase_size: 4194304 fwrev: 0x0 hwrev: 0x1 oemid: 0x534d manfid: 0x00001b serial: 0xcb4653be uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=00000 MODALIAS=mmc:block erase_size: 512 I also tried to switch network cables in case I was using one from who knows when. Link to comment Share on other sites More sharing options...
