Kemal Posted June 25 Share Posted June 25 Dear Armbian Community, I hope this message finds you well. I am encountering an issue with PWM on my Orange PI 5 Plus running Armbian. Despite my attempts, I am unable to utilize PWM via GPIO pins. Upon navigating to /sys/class/pwm, I can only see the pin designated for controlling the fan. The PWM pins on the GPIO are not visible. I have successfully controlled GPIO pins using WiringPi and Go Lang Periph libraries; however, when attempting to use PWM via GPIO, I encounter the following error: Quote pwm is not supported via sysfs I have also checked the “hardware setup” screen in armbian-config, where I can see two hardware components listed, but PWMs are not among them. For your reference, here is the output of armbianmonitor -U: https://paste.armbian.com/uvejirijen.yaml I would greatly appreciate any guidance or assistance on how to resolve this issue and enable PWM functionality on my Orange PI 5 Plus. Thank you very much in advance for your help. 0 Quote Link to comment Share on other sites More sharing options...
Solution royk Posted June 26 Solution Share Posted June 26 @Kemal You need to activate them by enabling the correct pwm. See /boot/dtb/rockchip/overlay/ Add the one(s) you need to /boot/armbianEnv.txt at overlays= For example: overlay_prefix=rk3588 overlays=pwm1-m1 pwm2-m1 You can find the right pwm numbers in the manual 0 Quote Link to comment Share on other sites More sharing options...
Kemal Posted Thursday at 11:23 AM Author Share Posted Thursday at 11:23 AM Dear @royk, Thank you very much for your prompt response and assistance! Your suggestion indeed helped me resolve the issue with PWM on my Orange PI 5 Plus. I also wanted to mention that I am using the Go Lang Periph library, and the error message “pwm is not supported via sysfs” originates from the library itself, indicating that PWM functionality has not been implemented. A clearer error message such as “not implemented” would have been more helpful. Once again, I truly appreciate your help in resolving this matter. 0 Quote Link to comment Share on other sites More sharing options...
